Re: [U-Boot] [PATCH] ARM: imx: dh-imx6: Enable DM GPIO
Marek Vasut marex@denx.de Thursday 20th June 2019 22:56:
Enable DM support for regulators and fixed regulator driver and convert USB Vbus control over to the regulators defined in DT.
Signed-off-by: Marek Vasut marex@denx.de Cc: Ludwig Zenz lzenz@dh-electronics.com Cc: Stefano Babic sbabic@denx.de
board/dhelectronics/dh_imx6/dh_imx6.c | 17 ----------------- configs/dh_imx6_defconfig | 2 ++ 2 files changed, 2 insertions(+), 17 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index 50e3cb50a3..e5ff91248a 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -196,7 +196,6 @@ int board_eth_init(bd_t *bis) #ifdef CONFIG_USB_EHCI_MX6 static void setup_usb(void) {
- gpio_request(IMX_GPIO_NR(3, 31), "USB-VBUS"); /*
- Set daisy chain for otg_pin_id on MX6Q.
- For MX6DL, this bit is reserved.
@@ -211,22 +210,6 @@ int board_usb_phy_mode(int port) else return USB_INIT_DEVICE; }
-int board_ehci_power(int port, int on) -{
- switch (port) {
- case 0:
break;
- case 1:
gpio_direction_output(IMX_GPIO_NR(3, 31), !!on);
break;
- default:
printf("MXC USB port %d not yet supported\n", port);
return -EINVAL;
-} #endif
static int setup_dhcom_mac_from_fuse(void) diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 70f0277040..3f615b4634 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -64,6 +64,8 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_SCSI=y CONFIG_SPI=y CONFIG_DM_SPI=y -- 2.20.1
Tested-by: Ludwig Zenz lzenz@dh-electronics.com
Thanks, Regards Ludwig Zenz
- switch (port) {
- case 0:
break;
- case 1:
break;
- default:
return -EINVAL;
-} #endif
Thanks. There's a V2 patch with corrected $Subject.
Ludwig Zenz
