[U-Boot] How to restore NVRAM on MTD partition from backup
U-Boot 2009.03 on custom board. How to restore NVRAM on MTD partition from backup use U-boot memory commands, by uploading backup over serial line? (kermit mode or ymodem mode) NAND flash type.
Regards, Alex
On Wed, 20 Dec 2017 13:19:58 +0000 (UTC) "A.W.C." bluestream@ymail.com wrote:
Nice :-)
I assume that it is not possible to move to newer one?
It depends on what commands do you have?
Yes, it would be best to use load command to get the data via serial line, store it in RAM and then flash it on persistent memory.
How do you access NVRAM? (Is it really this memory - not some Parallel NAND, SPI-NOR, OneNAND)?
If it has a custom driver ,then you may want to look for 'cp' or other command.
Regards, Alex
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
A.W.C.
Lukasz Majewski
