[U-Boot] [PATCH 5/7] configs: ls208xa: enable sata configs for all ls208xa defconfigs
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls208xardb and ls208xaqds defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls208xa defconfigs
Signed-off-by: Peng Ma peng.ma@nxp.com --- configs/ls2080aqds_SECURE_BOOT_defconfig | 3 +++ configs/ls2080aqds_nand_defconfig | 3 +++ configs/ls2080aqds_qspi_defconfig | 3 +++ configs/ls2080aqds_sdcard_defconfig | 3 +++ configs/ls2080ardb_SECURE_BOOT_defconfig | 3 +++ configs/ls2080ardb_nand_defconfig | 3 +++ configs/ls2081ardb_defconfig | 4 ++++ configs/ls2088aqds_tfa_defconfig | 9 +++++---- configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls2088ardb_qspi_defconfig | 3 +++ configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 18 +++++++----------- configs/ls2088ardb_tfa_defconfig | 14 ++++++-------- 12 files changed, 46 insertions(+), 23 deletions(-)
diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index d7c0db6343..5b85a94ed1 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -46,6 +48,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 30b506fafc..6340c19b08 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -41,6 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -53,6 +55,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 44a718e855..5c509f60be 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -32,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index d6ca28979f..9c85b8e9c0 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -40,6 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -51,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 150693b387..647edeaed7 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y @@ -46,6 +48,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index e12c3d5a7e..9f9297c5fb 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -39,6 +40,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -54,6 +56,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index 39d431aec1..d7c8a5613c 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2081ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -30,7 +31,9 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_PHYLIB=y @@ -42,6 +45,7 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index b04796cbb7..85e6a01f5d 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -31,11 +32,13 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -50,6 +53,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y @@ -58,7 +62,4 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index d230e64307..3fedbc2038 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -26,6 +27,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y @@ -40,6 +42,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 1c9a39d4b0..ff1f95f081 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -29,6 +30,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y @@ -44,6 +46,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index cb9490a867..058b3dd938 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -1,11 +1,12 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_TFABOOT=y CONFIG_SECURE_BOOT=y -CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_QSPI_AHB_INIT=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -32,10 +33,10 @@ CONFIG_CMD_DATE=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" -CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_FSL_CAAM=y +CONFIG_SATA_CEVA=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -44,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y - CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y @@ -53,22 +53,18 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y - CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 016d8bcdb6..e15156be3e 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -1,10 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y -CONFIG_QSPI_AHB_INIT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y CONFIG_NR_DRAM_BANKS=3 # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -32,11 +33,13 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -46,7 +49,6 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set - CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y @@ -55,19 +57,15 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y -CONFIG_FSL_SPI_ALIGNED_TXFIFO=y - CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_BLK=y -CONFIG_DM_MMC=y
Peng Ma
