[U-Boot] [PATCH v2 1/1] dm: MIGRATION: Add migration plan for CONFIG_DM
For many sub-systems we already require the driver model to be used. Yet there is still a handful of boards that do not have CONFIG_DM enabled.
We should make CONFIG_DM compulsory with release v2020.01
Conversion dates for CONFIG_DM_SPL and CONFIG_DM_TPL are yet to be defined.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 CONFIG_DM_SPL and CONFIG_DM_TPL are not concerned. --- Makefile | 8 ++++++++ doc/driver-model/migration.rst | 10 ++++++++++ 2 files changed, 18 insertions(+)
diff --git a/Makefile b/Makefile index 57d0700227..ffc2c4b3e4 100644 --- a/Makefile +++ b/Makefile @@ -940,6 +940,14 @@ ifneq ($(CONFIG_DM_SPI)$(CONFIG_OF_CONTROL),yy) endif endif endif +ifneq ($(CONFIG_DM),y) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM. CONFIG_DM will be" + @echo >&2 "compulsory starting with the v2020.01 release." + @echo >&2 "Failure to update may result in board removal." + @echo >&2 "See doc/driver-model/migration.rst for more info." + @echo >&2 "====================================================" +endif ifeq ($(CONFIG_MMC),y) ifneq ($(CONFIG_DM_MMC)$(CONFIG_OF_CONTROL)$(CONFIG_BLK),yyy) @echo >&2 "===================== WARNING ======================" diff --git a/doc/driver-model/migration.rst b/doc/driver-model/migration.rst index 75b85235ef..0b0ee44ca2 100644 --- a/doc/driver-model/migration.rst +++ b/doc/driver-model/migration.rst @@ -7,6 +7,16 @@ U-Boot has been migrating to a new driver model since its introduction in 2014. This file describes the schedule for deprecation of pre-driver-model features.
+CONFIG_DM +--------- + +* Status: In progress +* Deadline: 2020.01 + +Starting with the 2010.01 release CONFIG_DM will be enabled for all boards. +This does not concern CONFIG_DM_SPL and CONFIG_DM_TPL. The conversion date for +these configuration items still needs to be defined. + CONFIG_DM_MMC -------------
-- 2.20.1
I think we should move SPL to of-platdata and thus require DM there also. But that requires a bit more discussion!
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org
