[U-Boot] [PATCH] kconfig: doc: Update comment regarding CONFIG_IS_ENABLED(FOO) for TPL
This patch adds some commit info for CONFIG_IS_ENABLED(FOO) when used in TPL context.
Signed-off-by: Lukasz Majewski lukma@denx.de
include/linux/kconfig.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index fbfc7188b8..3a2da738c4 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -75,6 +75,7 @@ * CONFIG_VAL(FOO) evaluates to the value of * CONFIG_FOO if CONFIG_SPL_BUILD is undefined, * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. + * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. */ #define CONFIG_VAL(option) config_val(option)
@@ -82,6 +83,7 @@ * CONFIG_IS_ENABLED(FOO) evaluates to * 1 if CONFIG_SPL_BUILD is undefined and CONFIG_FOO is set to 'y' or 'm', * 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_FOO is set to 'y' or 'm', + * 1 if CONFIG_TPL_BUILD is defined and CONFIG_TPL_FOO is set to 'y' or 'm', * 0 otherwise. */ #define CONFIG_IS_ENABLED(option) \
Lukasz Majewski
