[U-Boot-Users] [MIPS] Introduce machine_restart
Handles machine specific functions by using function pointers.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
board/incaip/incaip.c | 8 ++++++++ board/purple/purple.c | 10 ++++++++++ board/tb0229/tb0229.c | 11 ++++++++++- cpu/mips/cpu.c | 17 ++++++++++------- include/asm-mips/reboot.h | 15 +++++++++++++++ 5 files changed, 53 insertions(+), 8 deletions(-) create mode 100644 include/asm-mips/reboot.h
diff --git a/board/incaip/incaip.c b/board/incaip/incaip.c index dbf0ecc..c2324bc 100644 --- a/board/incaip/incaip.c +++ b/board/incaip/incaip.c @@ -26,9 +26,15 @@ #include <asm/addrspace.h> #include <asm/inca-ip.h> #include <asm/io.h> +#include <asm/reboot.h>
extern uint incaip_get_cpuclk(void);
+static void incaip_machine_restart(char *command) +{ + *INCA_IP_WDT_RST_REQ = 0x3f; +} + static ulong max_sdram_size(void) { /* The only supported SDRAM data width is 16bit. @@ -108,5 +114,7 @@ int checkboard (void)
set_io_port_base(0);
+ _machine_restart = incaip_machine_restart; + return 0; } diff --git a/board/purple/purple.c b/board/purple/purple.c index 74718af..2fa2e19 100644 --- a/board/purple/purple.c +++ b/board/purple/purple.c @@ -29,6 +29,7 @@ #include <asm/io.h> #include <asm/addrspace.h> #include <asm/cacheops.h> +#include <asm/reboot.h>
#include "sconsole.h"
@@ -52,6 +53,13 @@ extern int asc_serial_getc (void); extern int asc_serial_tstc (void); extern void asc_serial_setbrg (void);
+static void purple_machine_restart(char *command) +{ + void (*f)(void) = (void *) 0xbfc00000; + + f(); +} + static void sdram_timing_init (ulong size) { register uint pass; @@ -148,6 +156,8 @@ int checkboard (void)
+ _machine_restart = purple_machine_restart; + return 0; }
diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index 61c2e9b..c775069 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -12,9 +12,16 @@ #include <common.h> #include <command.h> #include <asm/addrspace.h> -#include <asm/inca-ip.h> #include <asm/io.h> #include <pci.h> +#include <asm/reboot.h> + +static void tb0229_machine_restart(char *command) +{ + void (*f)(void) = (void *) 0xbfc00000; + + f(); +}
#if defined(CONFIG_PCI) static struct pci_controller hose; @@ -37,5 +44,7 @@ int checkboard (void)
+ _machine_restart = tb0229_machine_restart; + return 0; } diff --git a/cpu/mips/cpu.c b/cpu/mips/cpu.c index 71e5028..4c50829 100644 --- a/cpu/mips/cpu.c +++ b/cpu/mips/cpu.c @@ -23,9 +23,9 @@
#include <common.h> #include <command.h> -#include <asm/inca-ip.h> #include <asm/mipsregs.h> #include <asm/cacheops.h> +#include <asm/reboot.h>
#define cache_op(op,addr) \ __asm__ __volatile__( \ @@ -37,15 +37,18 @@ : \ : "i" (op), "R" (*(unsigned char *)(addr)))
+/* + * Urgs ... Too many MIPS machines to handle this in a generic way. + * So handle all using function pointers to machine specific + * functions. + */ +void (*_machine_restart)(char *command); + int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { -#if defined(CONFIG_INCA_IP) - *INCA_IP_WDT_RST_REQ = 0x3f; -#elif defined(CONFIG_PURPLE) || defined(CONFIG_TB0229) - void (*f)(void) = (void *) 0xbfc00000; + if (_machine_restart) + _machine_restart(NULL);
- f(); -#endif fprintf(stderr, "*** reset failed ***\n"); return 0; } diff --git a/include/asm-mips/reboot.h b/include/asm-mips/reboot.h new file mode 100644 index 0000000..e48c0bf --- /dev/null +++ b/include/asm-mips/reboot.h @@ -0,0 +1,15 @@ +/* + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file "COPYING" in the main directory of this archive + * for more details. + * + * Copyright (C) 1997, 1999, 2001, 06 by Ralf Baechle + * Copyright (C) 2001 MIPS Technologies, Inc. + */ +#ifndef _ASM_REBOOT_H +#define _ASM_REBOOT_H + +extern void (*_machine_restart)(char *command); +extern void (*_machine_halt)(void); + +#endif /* _ASM_REBOOT_H */
If possible I will prefer a weak function
Best Regards, J.
In message <004701c88928$4f457bb0$edd07310$@Tjernlund@transmode.se> Joakim Tjernlund wrote:
I don't think it is good to use global fun ptrs. These are not available until relocated to RAM.
Agreed!
In message 20080318184338.GA8728@game.jcrosoft.org Jean-Christophe Plagniol-Villar wrote:
...which raises the interesting question if, and how, weak function pointers work before relocation.
Has anyone ever tested / analyzed this?
Agreed!
I got it. Thanks for your comments.
I think I could, in a few days...
Shinya
Agreed!
Revised patch is attached. This builds and works fine with me.
[MIPS] Introduce _machine_restart
Handles machine specific functions by using weak functions.
board/incaip/incaip.c | 6 ++++++ board/purple/purple.c | 8 ++++++++ board/tb0229/tb0229.c | 9 ++++++++- cpu/mips/cpu.c | 13 ++++++------- include/asm-mips/reboot.h | 14 ++++++++++++++ 5 files changed, 42 insertions(+), 8 deletions(-) create mode 100644 include/asm-mips/reboot.h
diff --git a/board/incaip/incaip.c b/board/incaip/incaip.c index dbf0ecc..c624b3d 100644 --- a/board/incaip/incaip.c +++ b/board/incaip/incaip.c @@ -26,9 +26,15 @@ #include <asm/addrspace.h> #include <asm/inca-ip.h> #include <asm/io.h> +#include <asm/reboot.h>
+void _machine_restart(void) +{ + *INCA_IP_WDT_RST_REQ = 0x3f; +} + static ulong max_sdram_size(void) { /* The only supported SDRAM data width is 16bit. diff --git a/board/purple/purple.c b/board/purple/purple.c index 74718af..13a1455 100644 --- a/board/purple/purple.c +++ b/board/purple/purple.c @@ -29,6 +29,7 @@ #include <asm/io.h> #include <asm/addrspace.h> #include <asm/cacheops.h> +#include <asm/reboot.h>
+void _machine_restart(void) +{ + void (*f)(void) = (void *) 0xbfc00000; + + f(); +} + static void sdram_timing_init (ulong size) { register uint pass; diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index 61c2e9b..d08b422 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -12,10 +12,17 @@ #include <common.h> #include <command.h> #include <asm/addrspace.h> -#include <asm/inca-ip.h> #include <asm/io.h> +#include <asm/reboot.h> #include <pci.h>
+void _machine_restart(void) +{ + void (*f)(void) = (void *) 0xbfc00000; + + f(); +} + #if defined(CONFIG_PCI) static struct pci_controller hose;
diff --git a/cpu/mips/cpu.c b/cpu/mips/cpu.c index de70c4d..8b43d8e 100644 --- a/cpu/mips/cpu.c +++ b/cpu/mips/cpu.c @@ -23,9 +23,9 @@
#define cache_op(op,addr) \ __asm__ __volatile__( \ @@ -37,15 +37,14 @@ : \ : "i" (op), "R" (*(unsigned char *)(addr)))
+void __attribute__((weak)) _machine_restart(void) +{ +} + int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { -#if defined(CONFIG_INCA_IP) - *INCA_IP_WDT_RST_REQ = 0x3f; -#elif defined(CONFIG_PURPLE) || defined(CONFIG_TB0229) - void (*f)(void) = (void *) 0xbfc00000; + _machine_restart();
- f(); -#endif fprintf(stderr, "*** reset failed ***\n"); return 0; } diff --git a/include/asm-mips/reboot.h b/include/asm-mips/reboot.h new file mode 100644 index 0000000..978d206 --- /dev/null +++ b/include/asm-mips/reboot.h @@ -0,0 +1,14 @@ +/* + * This file is subject to the terms and conditions of the GNU General Public + * License. See the file "COPYING" in the main directory of this archive + * for more details. + * + * Copyright (C) 1997, 1999, 2001, 06 by Ralf Baechle + * Copyright (C) 2001 MIPS Technologies, Inc. + */ +#ifndef _ASM_REBOOT_H +#define _ASM_REBOOT_H + +extern void _machine_restart(void); + +#endif /* _ASM_REBOOT_H */
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: den 18 mars 2008 20:25 To: Jean-Christophe PLAGNIOL-VILLARD Cc: Shinya Kuribayashi; Joakim Tjernlund; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] [MIPS] Introduce machine_restart
Agreed!
From memory during my work on uClibc ld.so:
It is no difference, the weak function makes it possible to have several versions and select one at link time. I THINK the linker will use the first it finds, weak or not. That implies that the weak functions must be presented last on the linker cmd line.
Jocke
Agreed!
Weak symbols are a compile-time thing, not a run-time thing. The linker discards weak symbols if a "regular" symbol with the same name is found, that's all. So it's actually link-time, rather than compile-time :-).
Vlad
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Shinya Kuribayashi Sent: den 18 mars 2008 18:56 To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] [MIPS] Introduce machine_restart
Jocke
participants (5)
Joakim Tjernlund
Shinya Kuribayashi
Vlad Lungu
