[U-Boot] [PULL] u-boot-atmel-2019.07-a
Hello Tom,
Please pull tag u-boot-atmel-2019.07-a , the first set of new features and fixes for u-boot-atmel for 2019.07 release.
The features include the pincontrol drive strength/slew rate for Microchip at91 9x60 SoC, new Gardena board, pm9g45 migration to DM, SPL and watchdog fixes for at91 9x5 boards.
Travis CI: https://travis-ci.org/ehristev/u-boot/builds/517655546
Thanks, Eugen
The following changes since commit 3c99166441bf3ea325af2da83cfe65430b49c066:
Prepare v2019.04 (2019-04-08 21:40:40 -0400)
git://git.denx.de/u-boot-atmel.git tags/u-boot-atmel-2019.07-a
for you to fetch changes up to 7bf9bca7c0a9fe5c63e8fd5c2aa63884d76dace0:
net: macb: Add small delay after link establishment (2019-04-09 09:28:50 +0300)
---------------------------------------------------------------- First set of u-boot-atmel features and fixes for 2019.07 cycle
---------------------------------------------------------------- Alexander Dahl (1): ARM: at91: sama5d2: Wrap cpu detection to fix macb driver
Claudiu Beznea (4): pinctrl: at91: add option to use drive strength bits pinctrl: at91: add drive strength support for SAM9X60 pinctrl: at91: add compatibles for SAM9X60 pin controller pinctrl: at91: add slewrate support for SAM9X60
Ilko Iliev (1): board: pm9g45: Migrate to CONFIG_DM
Stefan Roese (14): arm: at91: Makefile: Compile lowlevel_init only when really necessary arm: at91: spl_at91.c: Call spl_early_init() if OF_CONTROL is enabled serial: atmel_usart: Use fixed clock value in SPL version with DM_SERIAL watchdog: Handle SPL build with watchdog disabled watchdog: at91sam9_wdt: Fix WDT setup in at91_wdt_start() arm: at91: Remove CONFIG_AT91_HW_WDT_TIMEOUT arm: at91: Enable watchdog support arm: at91: arm926ejs/u-boot-spl.lds: Add _image_binary_end to SPL lds Makefile.spl: Move generated AT91SAM NAND image boot.bin to spl directory Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binary arm: at91: siemens: Add support to generate combined SPL+U-Boot image arm: at91: at91sam9x5.dtsi: Add watchdog handle arm: at91: Add gardena-gateway-at91sam support net: macb: Add small delay after link establishment
Kconfig | 11 ++ Makefile | 4 +- README | 3 - arch/arm/dts/Makefile | 5 + .../at91sam9g25-gardena-smart-gateway-u-boot.dtsi | 5 + arch/arm/dts/at91sam9g25-gardena-smart-gateway.dts | 120 ++++++++++++++ arch/arm/dts/at91sam9x5.dtsi | 2 +- arch/arm/mach-at91/Kconfig | 8 + arch/arm/mach-at91/arm926ejs/Makefile | 2 + arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 2 + arch/arm/mach-at91/armv7/sama5d2_devices.c | 2 +- arch/arm/mach-at91/clock.c | 48 ++++++ arch/arm/mach-at91/include/mach/at91_wdt.h | 10 ++ arch/arm/mach-at91/include/mach/sama5d2.h | 5 +- arch/arm/mach-at91/spl_at91.c | 10 ++ board/gardena/smart-gateway-at91sam/Kconfig | 12 ++ board/gardena/smart-gateway-at91sam/MAINTAINERS | 7 + board/gardena/smart-gateway-at91sam/Makefile | 7 + board/gardena/smart-gateway-at91sam/board.c | 59 +++++++ board/gardena/smart-gateway-at91sam/spl.c | 135 ++++++++++++++++ board/ronetix/pm9g45/pm9g45.c | 10 +- configs/gardena-smart-gateway-at91sam_defconfig | 83 ++++++++++ configs/pm9g45_defconfig | 44 +++++- configs/smartweb_defconfig | 1 - configs/taurus_defconfig | 1 - drivers/net/macb.c | 8 +- drivers/pinctrl/pinctrl-at91.c | 84 +++++++++- drivers/serial/Kconfig | 9 ++ drivers/serial/atmel_usart.c | 12 ++ drivers/watchdog/Kconfig | 4 - drivers/watchdog/at91sam9_wdt.c | 32 ++-- include/configs/corvus.h | 3 + include/configs/gardena-smart-gateway-at91sam.h | 88 +++++++++++ include/configs/pm9g45.h | 173 +++++++++++---------- include/configs/smartweb.h | 4 + include/configs/taurus.h | 3 + include/dt-bindings/pinctrl/at91.h | 4 + include/watchdog.h | 10 +- scripts/Makefile.spl | 6 +- 39 files changed, 899 insertions(+), 137 deletions(-) create mode 100644 arch/arm/dts/at91sam9g25-gardena-smart-gateway-u-boot.dtsi create mode 100644 arch/arm/dts/at91sam9g25-gardena-smart-gateway.dts create mode 100644 board/gardena/smart-gateway-at91sam/Kconfig create mode 100644 board/gardena/smart-gateway-at91sam/MAINTAINERS create mode 100644 board/gardena/smart-gateway-at91sam/Makefile create mode 100644 board/gardena/smart-gateway-at91sam/board.c create mode 100644 board/gardena/smart-gateway-at91sam/spl.c create mode 100644 configs/gardena-smart-gateway-at91sam_defconfig create mode 100644 include/configs/gardena-smart-gateway-at91sam.h
On Tue, Apr 09, 2019 at 12:14:58PM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks, Eugen
