[U-Boot-Users] [RFC 0/2] Make board config available to build system
This series extracts the u-boot configuration from the config header files and makes it usable by the build system. The obvious application for this is to allow conditional compiliation of files without wrapping every file with a large #if defined() block (which results in shorter build times).
This is another step towards using a kconfig style build system. This step just enables make and gcc to have the same configuration data. Next step I think is to allow boards to supply a Kconfig style config file instead of a header file (and in this case, do the opposite of this patch; generate the header file based on the .config file). Until all boards are ported over, both methods can be supported based on what kind of config file (either .h or .config) is present.
Word of warning: I've most certainly broken stuff in this version. If there is suppport for this direction, then I'll make sure I get it sorted out for real.
Cheers, g.
-- Grant Likely, B.Sc. P.Eng. Secret Lab Technologies Ltd.
Use cpp and sed to postprocess config.h and import the defined values into include/config.mk. This is to support conditional compile of modules
Signed-off-by: Grant Likely grant.likely@secretlab.ca ---
Makefile | 4 ++++ mkconfig | 7 +++++++ tools/scripts/define2mk.sed | 24 ++++++++++++++++++++++++ 3 files changed, 35 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index 0477cd3..75fc4d7 100644 --- a/Makefile +++ b/Makefile @@ -362,6 +362,10 @@ unconfig: @rm -f $(obj)include/config.h $(obj)include/config.mk \ $(obj)board/*/config.tmp $(obj)board/*/*/config.tmp
+# Helper target for populating include/config.mk +.populate.config.mk: + @${CPP} ${CFLAGS} -dM include/common.h | sed -n -f tools/scripts/define2mk.sed >> $(obj)include/config.mk + #======================================================================== # PowerPC #======================================================================== diff --git a/mkconfig b/mkconfig index c3e4cea..eff7d2a 100755 --- a/mkconfig +++ b/mkconfig @@ -84,4 +84,11 @@ fi echo "/* Automatically generated - do not edit */" >>config.h echo "#include <configs/$1.h>" >>config.h
+# +# Import the board config into config.mk +# + +cd .. +make .populate.config.mk + exit 0 diff --git a/tools/scripts/define2mk.sed b/tools/scripts/define2mk.sed new file mode 100644 index 0000000..0a74e2e --- /dev/null +++ b/tools/scripts/define2mk.sed @@ -0,0 +1,24 @@ +# +# Sed script to parse CPP macros and generate output usable by make +# + +# Only process values prefixed with #define CONFIG_ or CFG_ +/^#define (CONFIG_|CFG_)[A-Za-z0-9_]+/ { + # Strip the #define prefix + s/#define *//; + # Change to form CONFIG_*=VALUE + s/ +/=/; + # Drop trailing spaces + s/ *$//; + # drop quoted string values + s/="(.*)"$/=\1/; + # Concatenate string values + s/" *"//g; + # Wrap unknown with quotes + s/=(.*?[^0-9].*)$/="\1"/; + # Change empty properties and '1' properties to "y" + s/=$/=y/; + s/=1$/=y/; + # print the line + p +}
In message 20070905140015.29345.70726.stgit@trillian.cg.shawcable.net you wrote:
Just a few comments....
This will NOT work!
Optional white space between ^ and # and between # and define. White space after define may be any sequence of space and TAB chars.
- # Strip the #define prefix
- s/#define *//;
Ditto.
- # Change to form CONFIG_*=VALUE
- s/ +/=/;
One or more spaces or tabs...
- # Drop trailing spaces
- s/ *$//;
or tabs...
- # drop quoted string values
- s/="(.*)"$/=\1/;
What about embedded escaped " chars?
- # Concatenate string values
- s/" *"//g;
- # Wrap unknown with quotes
Ditto.
- s/=(.*?[^0-9].*)$/="\1"/;
- # Change empty properties and '1' properties to "y"
- s/=$/=y/;
- s/=1$/=y/;
- # print the line
What about #defines between #if 0 / #endif pairs? Or
/* #define CONFIG_FOO */
etc.
Parsing C preprocessor code is not that simple, I guess...
This will NOT work!
Please ignore me.
This will NOT work!
Please ignore me.
I could never ignore you Wolfgang. :-)
g.
This will NOT work!
It WILL (but perhaps I should change the comment)! :-) See below.
cpp scrubs this for me (see below)
s/#define *//;
Ditto.
cpp again (and again, see below)
s/ \+/=/;
cpp... (are you detecting a pattern yet?) :-)
s/ *$//;
or tabs...
cpp...
s/="\(.*\)"$/=\1/;
Okay, I do need to comment on this one. The only (sane) possibility for embedded " chars is within a string. All embedded double quotes inside a string will *already* be escaped. (if not, the compile will break anyway)
s/" *"//g;
Ditto.
This should be safe also.
s/=\(.*\?[^0-9].*\)$/=\"\1\"/;
s/=$/=y/;
s/=1$/=y/;
# print the line
cpp...
etc.
cpp...
Indeed! I'm not even attempting this. Instead, I run common.h through '$(CROSS_COMPILE}cpp -dM' and parse the output of that. By letting cpp do the heavy lifting, all I need to parse is what 'cpp -dM' produces with is scrubbed for formatting.
common/Makefile | 139 ++++++++++++++++++++++++++++++++++++++-------- common/bedbug.c | 5 -- common/cmd_autoscript.c | 7 -- common/cmd_bdinfo.c | 2 - common/cmd_bedbug.c | 3 - common/cmd_bmp.c | 4 - common/cmd_cache.c | 4 - common/cmd_console.c | 4 - common/cmd_date.c | 4 - common/cmd_dcr.c | 4 - common/cmd_display.c | 4 - common/cmd_doc.c | 5 -- common/cmd_dtt.c | 4 - common/cmd_eeprom.c | 6 -- common/cmd_elf.c | 4 - common/cmd_ext2.c | 4 - common/cmd_fat.c | 8 --- common/cmd_fdc.c | 4 - common/cmd_fdos.c | 4 - common/cmd_fdt.c | 4 - common/cmd_flash.c | 4 - common/cmd_i2c.c | 5 -- common/cmd_ide.c | 4 - common/cmd_immap.c | 7 -- common/cmd_itest.c | 3 - common/cmd_jffs2.c | 7 -- common/cmd_log.c | 4 - common/cmd_mac.c | 3 - common/cmd_mfsl.c | 4 - common/cmd_mii.c | 4 - common/cmd_misc.c | 4 - common/cmd_mmc.c | 5 -- common/cmd_nand.c | 10 --- common/cmd_net.c | 4 - common/cmd_pci.c | 9 --- common/cmd_portio.c | 4 - common/cmd_reginfo.c | 10 --- common/cmd_reiser.c | 4 - common/cmd_sata.c | 3 - common/cmd_scsi.c | 4 - common/cmd_spi.c | 4 - common/cmd_universe.c | 4 - common/cmd_usb.c | 10 --- common/cmd_vfd.c | 4 - common/docecc.c | 4 - common/env_dataflash.c | 3 - common/env_eeprom.c | 5 -- common/env_flash.c | 5 -- common/env_nand.c | 4 - common/env_nowhere.c | 5 -- common/env_nvram.c | 4 - common/fdt_support.c | 5 -- common/hush.c | 2 - common/lcd.c | 4 - common/lynxkdi.c | 4 - common/miiphybb.c | 5 -- common/miiphyutil.c | 4 - common/serial.c | 4 - common/soft_i2c.c | 5 -- common/soft_spi.c | 4 - common/usb.c | 7 -- common/usb_kbd.c | 5 -- common/usb_storage.c | 8 --- config.mk | 1 include/configs/pf5200.h | 2 - 65 files changed, 118 insertions(+), 319 deletions(-)
diff --git a/common/Makefile b/common/Makefile index ef7d097..d8c4713 100644 --- a/common/Makefile +++ b/common/Makefile @@ -27,31 +27,122 @@ LIB = $(obj)libcommon.a
AOBJS =
-COBJS = main.o ACEX1K.o altera.o bedbug.o circbuf.o cmd_autoscript.o \ - cmd_bdinfo.o cmd_bedbug.o cmd_bmp.o cmd_boot.o cmd_bootm.o \ - cmd_cache.o cmd_console.o \ - cmd_date.o cmd_dcr.o cmd_diag.o cmd_display.o cmd_doc.o cmd_dtt.o \ - cmd_eeprom.o cmd_elf.o cmd_ext2.o \ - cmd_fat.o cmd_fdc.o cmd_fdt.o cmd_fdos.o cmd_flash.o cmd_fpga.o \ - cmd_i2c.o cmd_ide.o cmd_immap.o cmd_itest.o cmd_jffs2.o \ - cmd_load.o cmd_log.o \ - cmd_mem.o cmd_mii.o cmd_misc.o cmd_mmc.o \ - cmd_nand.o cmd_net.o cmd_nvedit.o \ - cmd_pci.o cmd_pcmcia.o cmd_portio.o \ - cmd_reginfo.o cmd_reiser.o cmd_sata.o cmd_scsi.o cmd_spi.o \ - cmd_universe.o cmd_usb.o cmd_vfd.o \ - command.o console.o cyclon2.o devices.o dlmalloc.o docecc.o \ - environment.o env_common.o \ - env_nand.o env_dataflash.o env_flash.o env_eeprom.o \ - env_nvram.o env_nowhere.o \ - exports.o \ - fdt_support.o flash.o fpga.o ft_build.o \ - hush.o kgdb.o lcd.o lists.o lynxkdi.o \ - memsize.o miiphybb.o miiphyutil.o \ - s_record.o serial.o soft_i2c.o soft_spi.o spartan2.o spartan3.o \ - usb.o usb_kbd.o usb_storage.o \ - virtex2.o xilinx.o crc16.o xyzModem.o cmd_mac.o cmd_mfsl.o +COBJS-y += main.o ACEX1K.o circbuf.o cmd_boot.o cmd_bootm.o +COBJS-y += cmd_load.o cmd_mem.o +COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o +COBJS-$(CONFIG_AUTOSCRIPT) += cmd_autoscript.o +COBJS-$(CONFIG_CMD_AUTOSCRIPT) += cmd_autoscript.o +COBJS-$(CONFIG_CMD_BDI) += cmd_bdinfo.o +COBJS-$(CONFIG_CMD_BEDBUG) += cmd_bedbug.o +COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o +COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o +COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o +COBJS-$(CONFIG_CMD_DATE) += cmd_date.o +COBJS-$(CONFIG_4xx) += cmd_dcr.o +COBJS-$(CONFIG_CMD_GETSETDCR) += cmd_diag.o +COBJS-$(CONFIG_CMD_DISPLAY) += cmd_display.o +COBJS-$(CONFIG_CMD_DOC) += cmd_doc.o docecc.o +COBJS-$(CONFIG_CMD_DTT) += cmd_dtt.o
+ifeq ($(CONFIG_CMD_EEPROM),y) +COBJS-y += cmd_eeprom.o +else +COBJS-$(CONFIG_ENV_IN_EEPROM) += cmd_eeprom.o +endif + +COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o +COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o +COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o + +ifeq ($(CONFIG_CMD_FDC),y) +COBJS-$(CONFIG_CMD_FDC) += cmd_fdc.o +else +COBJS-$(CONFIG_CMD_FDOS) += cmd_fdc.o +endif + +COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o +COBJS-$(CONFIG_OF_FLAT_TREE) += ft_build.o +COBJS-$(CONFIG_CMD_FDOS) += cmd_fdos.o +COBJS-$(CONFIG_CMD_FLASH) += cmd_flash.o +COBJS-$(CONFIG_CMD_I2C) += cmd_i2c.o +COBJS-$(CONFIG_CMD_IDE) += cmd_ide.o + +ifeq ($(CONFIG_CMD_IMMAP),y) +COBJS-$(CONFIG_8xx) += cmd_immap.o +COBJS-$(CONFIG_8260) += cmd_immap.o +endif + +COBJS-$(CONFIG_CMD_ITEST) += cmd_itest.o +COBJS-$(CONFIG_CMD_JFFS2) += cmd_jffs2.o +COBJS-$(CONFIG_LOGBUFFER) += cmd_log.o +COBJS-$(CONFIG_CMD_MISC) += cmd_misc.o +COBJS-$(CONFIG_CMD_MMC) += cmd_mmc.o + +ifneq ($(CFG_NAND_LEGACY),y) +COBJS-$(CONFIG_CMD_NAND) += cmd_nand.o +endif + +COBJS-$(CONFIG_CMD_NET) += cmd_net.o +COBJS-y += cmd_nvedit.o +ifeq ($(CONFIG_PCI),y) +COBJS-$(CONFIG_CMD_PCI) += cmd_pci.o +endif +COBJS-y += cmd_pcmcia.o +COBJS-$(CONFIG_CMD_PORTIO) += cmd_portio.o +COBJS-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o +COBJS-$(CONFIG_CMD_REISER) += cmd_reiser.o +COBJS-$(CFG_SATA_SUPPORTED) += cmd_sata.o +COBJS-$(CONFIG_CMD_SCSI) += cmd_scsi.o +COBJS-$(CONFIG_CMD_SPI) += cmd_spi.o +COBJS-$(CONFIG_CMD_UNIVERSE) += cmd_universe.o +COBJS-$(CONFIG_CMD_USB) += cmd_usb.o usb.o +COBJS-$(CONFIG_CMD_VFD) += cmd_vfd.o +COBJS-y += command.o +COBJS-y += console.o +COBJS-y += cyclon2.o +COBJS-y += devices.o +COBJS-y += dlmalloc.o +COBJS-y += environment.o +COBJS-y += env_common.o +COBJS-$(CFG_ENV_IS_IN_NAND) += env_nand.o +COBJS-$(CFG_ENV_IS_IN_DATAFLASH)+= env_dataflash.o +COBJS-$(CFG_ENV_IS_IN_FLASH) += env_flash.o +COBJS-$(CFG_ENV_IS_IN_EEPROM) += env_eeprom.o +COBJS-$(CFG_ENV_IS_IN_NVRAM) += env_nvram.o +COBJS-$(CFG_ENV_IS_NOWHERE) += env_nowhere.o +COBJS-y += exports.o +COBJS-y += flash.o +COBJS-$(CFG_HUSH_PARSER) += hush.o +COBJS-y += kgdb.o +COBJS-$(CONFIG_LCD) += lcd.o +COBJS-y += lists.o +COBJS-$(CONFIG_LYNXKDI) += lynxkdi.o +COBJS-y += memsize.o +COBJS-$(CONFIG_BITBANGMII) += miiphybb.o + +ifeq ($(CONFIG_MII),y) +COBJS-y += miiphyutil.o +else +COBJS-$(CONFIG_CMD_MII) += miiphyutil.o cmd_mii.o +endif + +COBJS-y += s_record.o +COBJS-$(CONFIG_SERIAL_MULTI) += serial.o +COBJS-$(CONFIG_SOFT_I2C) += soft_i2c.o +COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o +COBJS-$(CONFIG_USB_KEYBOARD) += usb_kbd.o +COBJS-$(CONFIG_USB_STORAGE) += usb_storage.o +COBJS-y += crc16.o +COBJS-y += xyzModem.o +COBJS-$(CFG_ID_EEPROM) += cmd_mac.o +COBJS-$(CONFIG_CMD_MFSL) += cmd_mfsl.o + +# FPGA support +COBJS-y += fpga.o cmd_fpga.o +COBJS-y += altera.o +COBJS-y += xilinx.o spartan2.o spartan3.o virtex2.o + +COBJS := $(COBJS-y) SRCS := $(AOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS))
diff --git a/common/bedbug.c b/common/bedbug.c index 3bf1fc3..3e76c62 100644 --- a/common/bedbug.c +++ b/common/bedbug.c @@ -1,9 +1,6 @@ /* $Id$ */
#include <common.h> - -#if defined(CONFIG_CMD_BEDBUG) - #include <linux/ctype.h> #include <bedbug/bedbug.h> #include <bedbug/ppc.h> @@ -1252,5 +1249,3 @@ int find_next_address (unsigned char *nextaddr, int step_over, * warranties of merchantability and fitness for a particular * purpose. */ - -#endif diff --git a/common/cmd_autoscript.c b/common/cmd_autoscript.c index a6038a6..7929d6f 100644 --- a/common/cmd_autoscript.c +++ b/common/cmd_autoscript.c @@ -47,8 +47,6 @@ #include <hush.h> #endif
-#if defined(CONFIG_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) - extern image_header_t header; /* from cmd_bootm.c */ int autoscript (ulong addr) @@ -149,8 +147,6 @@ autoscript (ulong addr) return rcode; }
-#endif - /**************************************************/ #if defined(CONFIG_CMD_AUTOSCRIPT) int @@ -170,7 +166,6 @@ do_autoscript (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return rcode; }
-#if defined(CONFIG_CMD_AUTOSCRIPT) U_BOOT_CMD( autoscr, 2, 0, do_autoscript, "autoscr - run script from memory\n", @@ -178,5 +173,3 @@ U_BOOT_CMD( " - A valid autoscr header must be present\n" ); #endif - -#endif diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index ef15a00..d059983 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -30,7 +30,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_CMD_BDI) static void print_num(const char *, ulong);
#ifndef CONFIG_ARM /* PowerPC and other */ @@ -350,4 +349,3 @@ U_BOOT_CMD( "bdinfo - print Board Info structure\n", NULL ); -#endif diff --git a/common/cmd_bedbug.c b/common/cmd_bedbug.c index 1c3547a..94f7e08 100644 --- a/common/cmd_bedbug.c +++ b/common/cmd_bedbug.c @@ -13,8 +13,6 @@
-#if defined(CONFIG_CMD_BEDBUG) - #ifndef MAX #define MAX(a,b) ((a) > (b) ? (a) : (b)) #endif @@ -413,7 +411,6 @@ int do_bedbug_rdump (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) U_BOOT_CMD (rdump, 1, 1, do_bedbug_rdump, "rdump - Show registers.\n", " - Show registers.\n"); /* ====================================================================== */ -#endif
/* diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index 241aa83..907f9a2 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -31,8 +31,6 @@ #include <asm/byteorder.h> #include <malloc.h>
-#if defined(CONFIG_CMD_BMP) - static int bmp_info (ulong addr); static int bmp_display (ulong addr, int x, int y);
@@ -187,5 +185,3 @@ static int bmp_display(ulong addr, int x, int y) # error bmp_display() requires CONFIG_LCD or CONFIG_VIDEO #endif } - -#endif /* defined(CONFIG_CMD_BMP) */ diff --git a/common/cmd_cache.c b/common/cmd_cache.c index 675d43f..99b92bd 100644 --- a/common/cmd_cache.c +++ b/common/cmd_cache.c @@ -27,8 +27,6 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_CMD_CACHE) - static int on_off (const char *);
int do_icache ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -108,5 +106,3 @@ U_BOOT_CMD( "[on, off]\n" " - enable or disable data (writethrough) cache\n" ); - -#endif diff --git a/common/cmd_console.c b/common/cmd_console.c index 5e0f990..50ddb01 100644 --- a/common/cmd_console.c +++ b/common/cmd_console.c @@ -28,8 +28,6 @@ #include <command.h> #include <devices.h>
-#if defined(CONFIG_CMD_CONSOLE) - extern void _do_coninfo (void); int do_coninfo (cmd_tbl_t * cmd, int flag, int argc, char *argv[]) { @@ -67,5 +65,3 @@ U_BOOT_CMD( "coninfo - print console devices and information\n", "" ); - -#endif diff --git a/common/cmd_date.c b/common/cmd_date.c index 4a42534..7511598 100644 --- a/common/cmd_date.c +++ b/common/cmd_date.c @@ -31,8 +31,6 @@
-#if defined(CONFIG_CMD_DATE) - const char *weekdays[] = { "Sun", "Mon", "Tues", "Wednes", "Thurs", "Fri", "Satur", }; @@ -210,5 +208,3 @@ U_BOOT_CMD( " - with numeric argument: set the system date & time\n" " - with 'reset' argument: reset the RTC\n" ); - -#endif diff --git a/common/cmd_dcr.c b/common/cmd_dcr.c index 12fa9db..a053343 100644 --- a/common/cmd_dcr.c +++ b/common/cmd_dcr.c @@ -29,8 +29,6 @@ #include <config.h> #include <command.h>
-#if defined(CONFIG_4xx) && defined(CONFIG_CMD_SETGETDCR) - unsigned long get_dcr (unsigned short); unsigned long set_dcr (unsigned short, unsigned long);
@@ -245,5 +243,3 @@ U_BOOT_CMD( "setidcr - Set a register value via indirect DCR addressing\n", "adr_dcrn[.dat_dcrn] offset value - write offset to adr_dcrn, write value to dat_dcrn.\n" ); - -#endif diff --git a/common/cmd_display.c b/common/cmd_display.c index d19f412..a29345c 100644 --- a/common/cmd_display.c +++ b/common/cmd_display.c @@ -24,8 +24,6 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_CMD_DISPLAY) - #undef DEBUG_DISP
#define DISP_SIZE 8 @@ -78,5 +76,3 @@ U_BOOT_CMD( " - with <string> argument: display <string> on dot matrix display\n" " - without arguments: clear dot matrix display\n" ); - -#endif diff --git a/common/cmd_doc.c b/common/cmd_doc.c index d6d3aff..3d717c0 100644 --- a/common/cmd_doc.c +++ b/common/cmd_doc.c @@ -11,9 +11,6 @@ #include <command.h> #include <malloc.h> #include <asm/io.h> - -#if defined(CONFIG_CMD_DOC) - #include <linux/mtd/nftl.h> #include <linux/mtd/doc2000.h>
@@ -1607,5 +1604,3 @@ void doc_probe(unsigned long physadr) puts ("No DiskOnChip found\n"); } } - -#endif diff --git a/common/cmd_dtt.c b/common/cmd_dtt.c index 8da95bf..2d8f2d4 100644 --- a/common/cmd_dtt.c +++ b/common/cmd_dtt.c @@ -25,8 +25,6 @@ #include <config.h> #include <command.h>
-#if defined(CONFIG_CMD_DTT) - #include <dtt.h> #include <i2c.h>
@@ -60,5 +58,3 @@ U_BOOT_CMD( "dtt - Digital Thermometer and Themostat\n", " - Read temperature from digital thermometer and thermostat.\n" ); - -#endif diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index e5000e9..2dfb249 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -42,8 +42,6 @@ #include <command.h> #include <i2c.h>
-#if defined(CFG_ENV_IS_IN_EEPROM) || defined(CONFIG_CMD_EEPROM) - extern void eeprom_init (void); extern int eeprom_read (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt); @@ -52,7 +50,6 @@ extern int eeprom_write (unsigned dev_addr, unsigned offset, #if defined(CFG_EEPROM_WREN) extern int eeprom_write_enable (unsigned dev_addr, int state); #endif -#endif
#if defined(CFG_EEPROM_X40430) @@ -121,8 +118,6 @@ int do_eeprom ( cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) * 0x00000nxx for EEPROM address selectors and page number at n. */
-#if defined(CFG_ENV_IS_IN_EEPROM) || defined(CONFIG_CMD_EEPROM) - #ifndef CONFIG_SPI #if !defined(CFG_I2C_EEPROM_ADDR_LEN) || CFG_I2C_EEPROM_ADDR_LEN < 1 || CFG_I2C_EEPROM_ADDR_LEN > 2 #error CFG_I2C_EEPROM_ADDR_LEN must be 1 or 2 @@ -397,7 +392,6 @@ eeprom_probe (unsigned dev_addr, unsigned offset)
return (i2c_probe (chip)); } -#endif
/*----------------------------------------------------------------------- * Set default values diff --git a/common/cmd_elf.c b/common/cmd_elf.c index 63a5593..2eb7453 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -23,8 +23,6 @@ DECLARE_GLOBAL_DATA_PTR; #endif
-#if defined(CONFIG_CMD_ELF) - #ifndef MAX #define MAX(a,b) ((a) > (b) ? (a) : (b)) #endif @@ -323,5 +321,3 @@ U_BOOT_CMD( "bootvx - Boot vxWorks from an ELF image\n", " [address] - load address of vxWorks ELF image.\n" ); - -#endif diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 8bd2b47..f569406 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -34,8 +34,6 @@ */ #include <common.h> #include <part.h> - -#if defined(CONFIG_CMD_EXT2) #include <config.h> #include <command.h> #include <image.h> @@ -259,5 +257,3 @@ U_BOOT_CMD( " - load binary file 'filename' from 'dev' on 'interface'\n" " to address 'addr' from ext2 filesystem\n" ); - -#endif diff --git a/common/cmd_fat.c b/common/cmd_fat.c index 54f0f9f..60fda78 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -30,13 +30,9 @@ #include <net.h> #include <ata.h> #include <part.h> - -#if defined(CONFIG_CMD_FAT) - -#undef DEBUG - #include <fat.h>
+#undef DEBUG
int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -323,5 +319,3 @@ void hexdump (int cnt, unsigned char *data) } } #endif /* NOT_IMPLEMENTED_YET */ - -#endif diff --git a/common/cmd_fdc.c b/common/cmd_fdc.c index 7349412..e29b501 100644 --- a/common/cmd_fdc.c +++ b/common/cmd_fdc.c @@ -51,9 +51,6 @@ /*#include <rtc.h> */ /*#endif */
-#if defined(CONFIG_CMD_FDC) || defined(CONFIG_CMD_FDOS) - - typedef struct { int flags; /* connected drives ect */ unsigned long blnr; /* Logical block nr */ @@ -893,4 +890,3 @@ U_BOOT_CMD( "fdcboot - boot from floppy device\n", "loadAddr drive\n" ); -#endif diff --git a/common/cmd_fdos.c b/common/cmd_fdos.c index f9da98d..b3dbd19 100644 --- a/common/cmd_fdos.c +++ b/common/cmd_fdos.c @@ -31,8 +31,6 @@ #include <command.h> #include <fdc.h>
-#if defined(CONFIG_CMD_FDOS) - /*----------------------------------------------------------------------------- * do_fdosboot -- *----------------------------------------------------------------------------- @@ -153,5 +151,3 @@ U_BOOT_CMD( "fdosls - list files in a directory\n", "[directory]\n" ); - -#endif diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 571b8f1..0003a7a 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -29,8 +29,6 @@ #include <linux/ctype.h> #include <linux/types.h>
-#ifdef CONFIG_OF_LIBFDT - #include <asm/global_data.h> #include <fdt.h> #include <libfdt.h> @@ -692,5 +690,3 @@ U_BOOT_CMD( " fdt print /cpus "#address-cells"\n" " fdt set /cpus "#address-cells" "[00 00 00 01]"\n" ); - -#endif /* CONFIG_OF_LIBFDT */ diff --git a/common/cmd_flash.c b/common/cmd_flash.c index 11c8857..f56443e 100644 --- a/common/cmd_flash.c +++ b/common/cmd_flash.c @@ -31,8 +31,6 @@ #include <dataflash.h> #endif
-#if defined(CONFIG_CMD_FLASH) - #if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) #include <jffs2/jffs2.h>
@@ -731,5 +729,3 @@ U_BOOT_CMD( #undef TMP_ERASE #undef TMP_PROT_ON #undef TMP_PROT_OFF - -#endif diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index a684a58..10cab46 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -86,9 +86,6 @@ #include <i2c.h> #include <asm/byteorder.h>
-#if defined(CONFIG_CMD_I2C) - - /* Display values from last command. * Memory modify remembered values are different from display memory. */ @@ -1024,5 +1021,3 @@ U_BOOT_CMD( " (valid chip values 50..57)\n" ); #endif - -#endif diff --git a/common/cmd_ide.c b/common/cmd_ide.c index bb064ea..fccf666 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -72,8 +72,6 @@ DECLARE_GLOBAL_DATA_PTR; # define SYNC /* nothing */ #endif
-#if defined(CONFIG_CMD_IDE) - #ifdef CONFIG_IDE_8xx_DIRECT /* Timings for IDE Interface * @@ -2085,5 +2083,3 @@ U_BOOT_CMD( "diskboot- boot from IDE device\n", "loadAddr dev:part\n" ); - -#endif diff --git a/common/cmd_immap.c b/common/cmd_immap.c index ae95758..ba12c5f 100644 --- a/common/cmd_immap.c +++ b/common/cmd_immap.c @@ -27,10 +27,6 @@
#include <common.h> #include <command.h> - -#if defined(CONFIG_CMD_IMMAP) && \ - (defined(CONFIG_8xx) || defined(CONFIG_8260)) - #if defined(CONFIG_8xx) #include <asm/8xx_immap.h> #include <commproc.h> @@ -718,6 +714,3 @@ U_BOOT_CMD( "mccinfo - print MCC registers\n", NULL ); - - -#endif diff --git a/common/cmd_itest.c b/common/cmd_itest.c index 8e20517..ce98872 100644 --- a/common/cmd_itest.c +++ b/common/cmd_itest.c @@ -32,8 +32,6 @@ #include <config.h> #include <command.h>
-#if defined(CONFIG_CMD_ITEST) - #define EQ 0 #define NE 1 #define LT 2 @@ -197,4 +195,3 @@ U_BOOT_CMD( "itest\t- return true/false on integer compare\n", "[.b, .w, .l, .s] [*]value1 <op> [*]value2\n" ); -#endif diff --git a/common/cmd_jffs2.c b/common/cmd_jffs2.c index 513a226..6adc93f 100644 --- a/common/cmd_jffs2.c +++ b/common/cmd_jffs2.c @@ -93,9 +93,6 @@ #include <jffs2/jffs2.h> #include <linux/list.h> #include <linux/ctype.h> - -#if defined(CONFIG_CMD_JFFS2) - #include <cramfs/cramfs_fs.h>
#if defined(CONFIG_CMD_NAND) @@ -2189,7 +2186,3 @@ U_BOOT_CMD( "<ro-flag> := when set to 'ro' makes partition read-only (not used, passed to kernel)\n" ); #endif /* #ifdef CONFIG_JFFS2_CMDLINE */ - -/***************************************************/ - -#endif diff --git a/common/cmd_log.c b/common/cmd_log.c index fba8bd8..e593dbe 100644 --- a/common/cmd_log.c +++ b/common/cmd_log.c @@ -48,8 +48,6 @@
-#if defined(CONFIG_LOGBUFFER) - /* Local prototypes */ static void logbuff_putc (const char c); static void logbuff_puts (const char *s); @@ -287,5 +285,3 @@ static int logbuff_printk(const char *line) } return i; } - -#endif /* (CONFIG_LOGBUFFER) */ diff --git a/common/cmd_mac.c b/common/cmd_mac.c index 0add432..3e4ad51 100644 --- a/common/cmd_mac.c +++ b/common/cmd_mac.c @@ -24,8 +24,6 @@ #include <common.h> #include <command.h>
-#ifdef CFG_ID_EEPROM - extern int do_mac(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
U_BOOT_CMD( @@ -63,4 +61,3 @@ U_BOOT_CMD( "mac 7\n" " - program the MAC address for port 7\n" ); -#endif /* CFG_ID_EEPROM */ diff --git a/common/cmd_mfsl.c b/common/cmd_mfsl.c index 8d4c1a3..5ce3aae 100644 --- a/common/cmd_mfsl.c +++ b/common/cmd_mfsl.c @@ -29,8 +29,6 @@ #include <common.h> #include <config.h> #include <command.h> - -#if defined(CONFIG_CMD_MFSL) #include <asm/asm.h>
int do_frd (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) @@ -413,5 +411,3 @@ U_BOOT_CMD (rspr, 3, 1, do_rspr, " 0 - MSR - Machine status register\n" " 1 - EAR - Exception address register\n" " 2 - ESR - Exception status register\n"); - -#endif diff --git a/common/cmd_mii.c b/common/cmd_mii.c index 72e11d5..b876841 100644 --- a/common/cmd_mii.c +++ b/common/cmd_mii.c @@ -27,8 +27,6 @@
#include <common.h> #include <command.h> - -#if defined(CONFIG_CMD_MII) #include <miiphy.h>
#ifdef CONFIG_TERSE_MII @@ -594,5 +592,3 @@ U_BOOT_CMD( );
#endif /* CONFIG_TERSE_MII */ - -#endif diff --git a/common/cmd_misc.c b/common/cmd_misc.c index c0c6b8f..126b538 100644 --- a/common/cmd_misc.c +++ b/common/cmd_misc.c @@ -27,8 +27,6 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_CMD_MISC) - int do_sleep (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { ulong start = get_timer(0); @@ -68,5 +66,3 @@ U_BOOT_CMD( "N\n" " - delay execution for N seconds (N is _decimal_ !!!)\n" ); - -#endif diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 069c6d0..25c9702 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -23,9 +23,6 @@
#include <common.h> #include <command.h> - -#if defined(CONFIG_CMD_MMC) - #include <mmc.h>
int do_mmc (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -42,5 +39,3 @@ U_BOOT_CMD( "mmcinit - init mmc card\n", NULL ); - -#endif diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 254a775..96512c4 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -17,10 +17,6 @@ * New NAND support * */ -#include <common.h> - -#if defined(CONFIG_CMD_NAND) - #include <command.h> #include <watchdog.h> #include <malloc.h> @@ -633,8 +629,6 @@ U_BOOT_CMD(nboot, 4, 1, do_nandboot, "nboot - boot from NAND device\n", "[.jffs2] [partition] | [[[loadAddr] dev] offset]\n");
-#endif - #else /* CFG_NAND_LEGACY */ /* * @@ -653,7 +647,6 @@ U_BOOT_CMD(nboot, 4, 1, do_nandboot, # define show_boot_progress(arg) #endif
-#if defined(CONFIG_CMD_NAND) #include <linux/mtd/nand_legacy.h> #if 0 #include <linux/mtd/nand_ids.h> @@ -1017,7 +1010,4 @@ U_BOOT_CMD( "nboot - boot from NAND device\n", "loadAddr dev\n" ); - -#endif - #endif /* CFG_NAND_LEGACY */ diff --git a/common/cmd_net.c b/common/cmd_net.c index 0715fbc..21682c0 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -28,8 +28,6 @@ #include <command.h> #include <net.h>
-#if defined(CONFIG_CMD_NET) - extern int do_bootm (cmd_tbl_t *, int, int, char *[]);
static int netboot_common (proto_t, cmd_tbl_t *, int , char *[]); @@ -343,5 +341,3 @@ U_BOOT_CMD( "[NTP server IP]\n" ); #endif - -#endif diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 8be6da9..82d9717 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -30,16 +30,11 @@ */
#include <common.h> - -#ifdef CONFIG_PCI - #include <command.h> #include <asm/processor.h> #include <asm/io.h> #include <pci.h>
-#if defined(CONFIG_CMD_PCI) - extern int cmd_get_data_size(char* arg, int default_size);
unsigned char ShortPCIListing = 1; @@ -564,7 +559,3 @@ U_BOOT_CMD( "pci write[.b, .w, .l] b.d.f address value\n" " - write to CFG address\n" ); - -#endif - -#endif /* CONFIG_PCI */ diff --git a/common/cmd_portio.c b/common/cmd_portio.c index bfe33e3..a06cac0 100644 --- a/common/cmd_portio.c +++ b/common/cmd_portio.c @@ -30,8 +30,6 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_CMD_PORTIO) - extern int cmd_get_data_size (char *arg, int default_size);
/* Display values from last command. @@ -165,5 +163,3 @@ U_BOOT_CMD( "[.b, .w, .l] port\n" " - read datum from IO port\n" ); - -#endif diff --git a/common/cmd_reginfo.c b/common/cmd_reginfo.c index 17e9cd9..f7a5719 100644 --- a/common/cmd_reginfo.c +++ b/common/cmd_reginfo.c @@ -33,8 +33,6 @@ #include <mpc5xxx.h> #endif
-#if defined(CONFIG_CMD_REGINFO) - int do_reginfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { #if defined(CONFIG_8xx) @@ -335,17 +333,9 @@ int do_reginfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#endif - - /**************************************************/
-#if ( defined(CONFIG_8xx) || defined(CONFIG_405GP) || \ - defined(CONFIG_405EP) || defined(CONFIG_MPC5200) ) && \ - defined(CONFIG_CMD_REGINFO) - U_BOOT_CMD( reginfo, 2, 1, do_reginfo, "reginfo - print register information\n", ); -#endif diff --git a/common/cmd_reiser.c b/common/cmd_reiser.c index 1ba3929..b7395d7 100644 --- a/common/cmd_reiser.c +++ b/common/cmd_reiser.c @@ -27,8 +27,6 @@ * Reiserfs support */ #include <common.h> - -#if defined(CONFIG_CMD_REISER) #include <config.h> #include <command.h> #include <image.h> @@ -239,5 +237,3 @@ U_BOOT_CMD( " - load binary file 'filename' from 'dev' on 'interface'\n" " to address 'addr' from dos filesystem\n" ); - -#endif diff --git a/common/cmd_sata.c b/common/cmd_sata.c index bd4c11f..e28a32f 100644 --- a/common/cmd_sata.c +++ b/common/cmd_sata.c @@ -34,7 +34,6 @@ #include <ide.h> #include <ata.h>
-#ifdef CFG_SATA_SUPPORTED /*For debug prints set macro DEBUG_SATA to 1 */ #define DEBUG_SATA 0 /*Macro for SATA library specific declarations */ @@ -708,5 +707,3 @@ U_BOOT_CMD (sata, 5, 1, do_sata, "sata dev device\n" "sata read addr blk# cnt\n" "sata write addr blk# cnt\n", "cmd for init,rw and dev-info\n"); - -#endif diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index f563931..3e9fd8a 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -34,8 +34,6 @@ #include <image.h> #include <pci.h>
-#if defined(CONFIG_CMD_SCSI) - #ifdef CONFIG_SCSI_SYM53C8XX #define SCSI_VEND_ID 0x1000 #ifndef CONFIG_SCSI_DEV_ID @@ -608,5 +606,3 @@ U_BOOT_CMD( "scsiboot- boot from SCSI device\n", "loadAddr dev:part\n" ); - -#endif diff --git a/common/cmd_spi.c b/common/cmd_spi.c index 3118d27..7604422 100644 --- a/common/cmd_spi.c +++ b/common/cmd_spi.c @@ -29,8 +29,6 @@ #include <command.h> #include <spi.h>
-#if defined(CONFIG_CMD_SPI) - /*----------------------------------------------------------------------- * Definitions */ @@ -139,5 +137,3 @@ U_BOOT_CMD( "<bit_len> - Number of bits to send (base 10)\n" "<dout> - Hexadecimal string that gets sent\n" ); - -#endif diff --git a/common/cmd_universe.c b/common/cmd_universe.c index 8bf0b1f..ea97782 100644 --- a/common/cmd_universe.c +++ b/common/cmd_universe.c @@ -28,8 +28,6 @@
#include <universe.h>
-#if defined(CONFIG_CMD_UNIVERSE) - #define PCI_VENDOR PCI_VENDOR_ID_TUNDRA #define PCI_DEVICE PCI_DEVICE_ID_TUNDRA_CA91C042
@@ -386,5 +384,3 @@ U_BOOT_CMD( " 02 -> D16 Data Width\n" " 03 -> D32 Data Width\n" ); - -#endif diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 45e07f1..c6b17c2 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -29,9 +29,6 @@ #include <command.h> #include <asm/byteorder.h> #include <part.h> - -#if defined(CONFIG_CMD_USB) - #include <usb.h>
#ifdef CONFIG_USB_STORAGE @@ -608,12 +605,6 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
- -#endif - - -#if defined(CONFIG_CMD_USB) - #ifdef CONFIG_USB_STORAGE U_BOOT_CMD( usb, 5, 1, do_usb, @@ -645,4 +636,3 @@ U_BOOT_CMD( "usb info [dev] - show available USB devices\n" ); #endif -#endif diff --git a/common/cmd_vfd.c b/common/cmd_vfd.c index 29c349d..719215e 100644 --- a/common/cmd_vfd.c +++ b/common/cmd_vfd.c @@ -34,9 +34,6 @@ */ #include <common.h> #include <command.h> - -#if defined(CONFIG_CMD_VFD) - #include <vfd_logo.h> #define VFD_TEST_LOGO_BMPNR 0 #define VFD_REMOTE_LOGO_BMPNR 1 @@ -103,4 +100,3 @@ int trab_vfd (ulong bitmap) transfer_pic(3, addr, VFD_LOGO_HEIGHT, VFD_LOGO_WIDTH); return 0; } -#endif /* CONFIG_VFD */ diff --git a/common/docecc.c b/common/docecc.c index 5daa6fc..3412aff 100644 --- a/common/docecc.c +++ b/common/docecc.c @@ -31,8 +31,6 @@ #undef ECC_DEBUG #undef PSYCHO_DEBUG
-#if defined(CONFIG_CMD_DOC) - #include <linux/mtd/doc2000.h>
/* need to undef it (from asm/termbits.h) */ @@ -513,5 +511,3 @@ int doc_decode_ecc(unsigned char sector[SECTOR_SIZE], unsigned char ecc1[6]) free(Index_of); return nb_errors; } - -#endif diff --git a/common/env_dataflash.c b/common/env_dataflash.c index 93fff29..17d45fd 100644 --- a/common/env_dataflash.c +++ b/common/env_dataflash.c @@ -18,9 +18,6 @@ * */ #include <common.h> - -#if defined(CFG_ENV_IS_IN_DATAFLASH) /* Environment is in DataFlash */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> diff --git a/common/env_eeprom.c b/common/env_eeprom.c index 2adc129..76e9d92 100644 --- a/common/env_eeprom.c +++ b/common/env_eeprom.c @@ -25,9 +25,6 @@ */
#include <common.h> - -#if defined(CFG_ENV_IS_IN_EEPROM) /* Environment is in EEPROM */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> @@ -110,5 +107,3 @@ int env_init(void)
return (0); } - -#endif /* CFG_ENV_IS_IN_EEPROM */ diff --git a/common/env_flash.c b/common/env_flash.c index eccfb62..4e56c89 100644 --- a/common/env_flash.c +++ b/common/env_flash.c @@ -27,9 +27,6 @@ /* #define DEBUG */
#include <common.h> - -#if defined(CFG_ENV_IS_IN_FLASH) /* Environment is in Flash */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> @@ -381,5 +378,3 @@ void env_relocate_spec (void) memcpy (env_ptr, (void*)flash_addr, CFG_ENV_SIZE); #endif /* ! ENV_IS_EMBEDDED || CFG_ENV_ADDR_REDUND */ } - -#endif /* CFG_ENV_IS_IN_FLASH */ diff --git a/common/env_nand.c b/common/env_nand.c index 38a07f8..724e2d1 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -30,9 +30,6 @@ /* #define DEBUG */
#include <common.h> - -#if defined(CFG_ENV_IS_IN_NAND) /* Environment is in Nand Flash */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> @@ -302,4 +299,3 @@ static void use_default() } #endif
-#endif /* CFG_ENV_IS_IN_NAND */ diff --git a/common/env_nowhere.c b/common/env_nowhere.c index 17ecc77..78e8f8e 100644 --- a/common/env_nowhere.c +++ b/common/env_nowhere.c @@ -25,9 +25,6 @@ */
#include <common.h> - -#if defined(CFG_ENV_IS_NOWHERE) /* Environment is nowhere */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> @@ -61,5 +58,3 @@ int env_init(void)
return (0); } - -#endif /* CFG_ENV_IS_NOWHERE) */ diff --git a/common/env_nvram.c b/common/env_nvram.c index 7c18896..2039bac 100644 --- a/common/env_nvram.c +++ b/common/env_nvram.c @@ -44,8 +44,6 @@
-#ifdef CFG_ENV_IS_IN_NVRAM /* Environment is in NVRAM */ - #include <command.h> #include <environment.h> #include <linux/stddef.h> @@ -159,5 +157,3 @@ int env_init (void) #endif return (0); } - -#endif /* CFG_ENV_IS_IN_NVRAM */ diff --git a/common/fdt_support.c b/common/fdt_support.c index 175d59e..040e1c6 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -24,9 +24,6 @@ #include <common.h> #include <linux/ctype.h> #include <linux/types.h> - -#ifdef CONFIG_OF_LIBFDT - #include <asm/global_data.h> #include <fdt.h> #include <libfdt.h> @@ -347,5 +344,3 @@ int fdt_bd_t(void *fdt) return 0; } #endif /* ifdef CONFIG_OF_HAS_BD_T */ - -#endif /* CONFIG_OF_LIBFDT */ diff --git a/common/hush.c b/common/hush.c index 582635c..096dd59 100644 --- a/common/hush.c +++ b/common/hush.c @@ -97,7 +97,6 @@ /*cmd_boot.c*/ extern int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); /* do_bootd */ #endif -#ifdef CFG_HUSH_PARSER #ifndef __U_BOOT__ #include <ctype.h> /* isalpha, isdigit */ #include <unistd.h> /* getpid */ @@ -3585,5 +3584,4 @@ static char * make_string(char ** inp) return str; }
-#endif /* CFG_HUSH_PARSER */ /****************************************************************************/ diff --git a/common/lcd.c b/common/lcd.c index 914dc2e..2765c0a 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -50,8 +50,6 @@ #include <lcdvideo.h> #endif
-#ifdef CONFIG_LCD - /************************************************************************/ /* ** FONT DATA */ /************************************************************************/ @@ -774,5 +772,3 @@ static void *lcd_logo (void)
/************************************************************************/ /************************************************************************/ - -#endif /* CONFIG_LCD */ diff --git a/common/lynxkdi.c b/common/lynxkdi.c index 76a271b..1d867d8 100644 --- a/common/lynxkdi.c +++ b/common/lynxkdi.c @@ -16,8 +16,6 @@ #include <common.h> #include <asm/processor.h> #include <image.h> - -#if defined(CONFIG_LYNXKDI) #include <lynxkdi.h>
DECLARE_GLOBAL_DATA_PTR; @@ -66,5 +64,3 @@ void lynxkdi_boot ( image_header_t *hdr ) #else #error "Lynx KDI support not implemented for configured CPU" #endif - -#endif /* CONFIG_LYNXKDI */ diff --git a/common/miiphybb.c b/common/miiphybb.c index 537c15d..6446012 100644 --- a/common/miiphybb.c +++ b/common/miiphybb.c @@ -30,9 +30,6 @@ #include <ioports.h> #include <ppc_asm.tmpl>
-#ifdef CONFIG_BITBANGMII - - /***************************************************************************** * * Utility to send the preamble, address, and register (common to read @@ -236,5 +233,3 @@ int bb_miiphy_write (char *devname, unsigned char addr,
return 0; } - -#endif /* CONFIG_BITBANGMII */ diff --git a/common/miiphyutil.c b/common/miiphyutil.c index c69501f..dc4f6ff 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -28,8 +28,6 @@
#include <common.h> #include <miiphy.h> - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) #include <asm/types.h> #include <linux/list.h> #include <malloc.h> @@ -469,5 +467,3 @@ int miiphy_link (char *devname, unsigned char addr) } } #endif - -#endif /* CONFIG_MII */ diff --git a/common/serial.c b/common/serial.c index 13e9f30..e5af3d5 100644 --- a/common/serial.c +++ b/common/serial.c @@ -27,8 +27,6 @@
-#if defined(CONFIG_SERIAL_MULTI) - static struct serial_device *serial_devices = NULL; static struct serial_device *serial_current = NULL;
@@ -227,5 +225,3 @@ void serial_puts (const char *s)
serial_current->puts (s); } - -#endif /* CONFIG_SERIAL_MULTI */ diff --git a/common/soft_i2c.c b/common/soft_i2c.c index c5d7e20..6bfc010 100644 --- a/common/soft_i2c.c +++ b/common/soft_i2c.c @@ -41,8 +41,6 @@ #endif #include <i2c.h>
-#if defined(CONFIG_SOFT_I2C) - /* #define DEBUG_I2C */
#ifdef DEBUG_I2C @@ -422,6 +420,3 @@ void i2c_reg_write(uchar i2c_addr, uchar reg, uchar val) { i2c_write(i2c_addr, reg, 1, &val, 1); } - - -#endif /* CONFIG_SOFT_I2C */ diff --git a/common/soft_spi.c b/common/soft_spi.c index e425061..5a1f1b2 100644 --- a/common/soft_spi.c +++ b/common/soft_spi.c @@ -27,8 +27,6 @@ #include <common.h> #include <spi.h>
-#if defined(CONFIG_SOFT_SPI) - /*----------------------------------------------------------------------- * Definitions */ @@ -131,5 +129,3 @@ int spi_xfer(spi_chipsel_type chipsel, int bitlen, uchar *dout, uchar *din)
return(0); } - -#endif /* CONFIG_SOFT_SPI */ diff --git a/common/usb.c b/common/usb.c index 933afa9..bd067ef 100644 --- a/common/usb.c +++ b/common/usb.c @@ -48,9 +48,6 @@ #include <command.h> #include <asm/processor.h> #include <linux/ctype.h> - -#if defined(CONFIG_CMD_USB) - #include <usb.h> #ifdef CONFIG_4xx #include <405gp_pci.h> @@ -1246,7 +1243,3 @@ int usb_hub_probe(struct usb_device *dev, int ifnum) ret=usb_hub_configure(dev); return ret; } - -#endif - -/* EOF */ diff --git a/common/usb_kbd.c b/common/usb_kbd.c index aec558a..ae01534 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -26,9 +26,6 @@ */ #include <common.h> #include <devices.h> - -#ifdef CONFIG_USB_KEYBOARD - #include <usb.h>
#undef USB_KBD_DEBUG @@ -728,5 +725,3 @@ static int usb_kbd_get_hid_desc(struct usb_device *dev)
#endif - -#endif /* CONFIG_USB_KEYBOARD */ diff --git a/common/usb_storage.c b/common/usb_storage.c index 0f79f36..3c06efe 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -53,14 +53,9 @@ #include <common.h> #include <command.h> #include <asm/processor.h> - - -#if defined(CONFIG_CMD_USB) #include <part.h> #include <usb.h>
-#ifdef CONFIG_USB_STORAGE - #undef USB_STOR_DEBUG #undef BBB_COMDAT_TRACE #undef BBB_XPORT_TRACE @@ -1247,6 +1242,3 @@ int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t USB_STOR_PRINTF("partype: %d\n",dev_desc->part_type); return 1; } - -#endif /* CONFIG_USB_STORAGE */ -#endif diff --git a/config.mk b/config.mk index 582df32..4b2ac8b 100644 --- a/config.mk +++ b/config.mk @@ -90,6 +90,7 @@ endif ifdef BOARD sinclude $(TOPDIR)/board/$(BOARDDIR)/config.mk # include board specific rules endif +sinclude $(TOPDIR)/include/config.mk # include generated board config
diff --git a/include/configs/pf5200.h b/include/configs/pf5200.h index 18d0c87..470b607 100644 --- a/include/configs/pf5200.h +++ b/include/configs/pf5200.h @@ -203,7 +203,7 @@ * Environment settings */ #if 1 /* test-only */ -#define CFG_ENV_IS_IN_FLASH 0 +#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_SIZE 0x10000 #define CFG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_OVERWRITE 1
On Wed, 05 Sep 2007 08:00:10 -0600 Grant Likely grant.likely@secretlab.ca wrote:
total ack. and to the gitignore patch, of course.
Kim
Grant Likely
Kim Phillips
