[PATCH v1 00/20] SoCFPGA: Add Boot Support for Agilex 5 in U-Boot
This patch set introduces boot support for the Altera SoCFPGA Agilex 5 platform in U-Boot. The changes include: 1. Board-specific configurations and setup required to enable Agilex 5 operation in U-Boot. 2. Integration of cache coherency unit (CCU) initialization routine, including CCU conguration in DT. 3. Clock, firewall (configured in DT), SMMU, low level initialization specific to Agilex 5. 4. Integration of memory initialization routine, including DDR setup.
This patch set has been tested on Agilex 5 devkit with QSPI boot (UBI/UBIFS) and RAM boot (TFTP & ARM DS debugger).
Alif Zakuan Yuslaimi (1): configs: socfpga: soc64: agilex5: Enable QSPI boot with UBI / UBIFS
Tien Fong Chee (18): arm: socfpga: agilex5: Add new system manager base addresses arm: socfpga: Add support for agilex5 clock manager linker: Add SPL linker script for SoC64 devices arm: socfpga: agilex5: Add low level initialization arm: socfpga: Add handoff data support for SoCFPGA Agilex5 device arm: dts: agilex5: Add HPS cache coherency unit configuration settings arm: dts: agilex5: Add firewall configure settings arm: dts: agilex5: Enable XGMAC sysreset: Add reset support to SoCFPGA Agilex5 device arm: socfpga: agilex5: Enable cache flush for system memory cache in CCU arm: socfpga: agilex5: Add SMMU initialization arm: socfpga: agilex5: Update CPU info arm: socfpga: Export board ID as U-Boot environment variable configs: agilex5: Add configuration for malloc pool arm: socfpga: smc: Add memory coherency support to mailbox command arm: socfpga: agilex5: Add SPL for Agilex5 SoCFPGA configs: socfpga: soc64: agilex5: Enable XGMAC arm: socfpga: soc64: Add support for board_boot_order()
Tingting Meng (1): ddr: altera: Add DDR driver for Agilex5 series
MAINTAINERS | 2 + arch/arm/Kconfig | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 660 ++++++++++++++++++ arch/arm/dts/socfpga_agilex5.dtsi | 7 + .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 33 + arch/arm/mach-socfpga/Makefile | 6 + arch/arm/mach-socfpga/ccu_ncore3.c | 64 ++ arch/arm/mach-socfpga/include/mach/firewall.h | 23 +- .../mach-socfpga/include/mach/handoff_soc64.h | 4 +- arch/arm/mach-socfpga/include/mach/misc.h | 1 + .../include/mach/reset_manager_soc64.h | 12 +- .../include/mach/system_manager_soc64.h | 129 ++-- arch/arm/mach-socfpga/lowlevel_init_agilex5.S | 57 ++ arch/arm/mach-socfpga/misc.c | 24 +- arch/arm/mach-socfpga/misc_soc64.c | 12 +- arch/arm/mach-socfpga/smc_api.c | 13 +- arch/arm/mach-socfpga/spl_agilex5.c | 84 +++ arch/arm/mach-socfpga/spl_soc64.c | 120 +++- arch/arm/mach-socfpga/u-boot-spl-soc64.lds | 80 +++ arch/arm/mach-socfpga/wrap_handoff_soc64.c | 10 +- configs/socfpga_agilex5_defconfig | 6 + drivers/ddr/altera/Makefile | 1 + drivers/ddr/altera/iossm_mailbox.c | 613 ++++++++++++++++ drivers/ddr/altera/iossm_mailbox.h | 186 +++++ drivers/ddr/altera/sdram_agilex5.c | 377 ++++++++++ drivers/ddr/altera/sdram_soc64.c | 78 ++- drivers/ddr/altera/sdram_soc64.h | 32 +- drivers/sysreset/Kconfig | 7 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_socfpga_agilex5.c | 47 ++ include/configs/socfpga_soc64_common.h | 5 + 31 files changed, 2605 insertions(+), 90 deletions(-) create mode 100644 arch/arm/mach-socfpga/ccu_ncore3.c create mode 100644 arch/arm/mach-socfpga/lowlevel_init_agilex5.S create mode 100644 arch/arm/mach-socfpga/spl_agilex5.c create mode 100644 arch/arm/mach-socfpga/u-boot-spl-soc64.lds create mode 100644 drivers/ddr/altera/iossm_mailbox.c create mode 100644 drivers/ddr/altera/iossm_mailbox.h create mode 100644 drivers/ddr/altera/sdram_agilex5.c create mode 100644 drivers/sysreset/sysreset_socfpga_agilex5.c
Initial creation of new system manager base addresses for Agilex5.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- .../include/mach/system_manager_soc64.h | 129 +++++++++++------- 1 file changed, 83 insertions(+), 46 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h b/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h index a8009664fee..b1ef4a70641 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2019-2021 Intel Corporation <www.intel.com> + * Copyright (C) 2019-2024 Intel Corporation <www.intel.com> */
#ifndef _SYSTEM_MANAGER_SOC64_H_ @@ -11,22 +11,43 @@ void sysmgr_pinmux_init(void); void populate_sysmgr_fpgaintf_module(void); void populate_sysmgr_pinmux(void);
-#define SYSMGR_SOC64_WDDBG 0x08 -#define SYSMGR_SOC64_DMA 0x20 -#define SYSMGR_SOC64_DMA_PERIPH 0x24 -#define SYSMGR_SOC64_SDMMC 0x28 -#define SYSMGR_SOC64_SDMMC_L3MASTER 0x2c -#define SYSMGR_SOC64_EMAC_GLOBAL 0x40 -#define SYSMGR_SOC64_EMAC0 0x44 -#define SYSMGR_SOC64_EMAC1 0x48 -#define SYSMGR_SOC64_EMAC2 0x4c -#define SYSMGR_SOC64_EMAC0_ACE 0x50 -#define SYSMGR_SOC64_EMAC1_ACE 0x54 -#define SYSMGR_SOC64_EMAC2_ACE 0x58 +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define SYSMGR_SOC64_SILICONID_1 0x00 +#define SYSMGR_SOC64_SILICONID_2 0x04 +#define SYSMGR_SOC64_MPU_STATUS 0x10 +#define SYSMGR_SOC64_COMBOPHY_DFISEL 0xfc +#define SYSMGR_SOC64_COMBOPHY_DFISEL_SDMMC 0x1 +#define SYSMGR_SOC64_NANDGRP_L3MASTER 0x34 +#define SYSMGR_SOC64_USB0_L3MASTER 0x38 +#define SYSMGR_SOC64_USB1_L3MASTER 0x3c +#define SYSMGR_SOC64_DMAC0_L3_MASTER 0x74 +#define SYSMGR_SOC64_ETR_L3_MASTER 0x78 +#define SYSMGR_SOC64_DMAC1_L3_MASTER 0x7C +#define SYSMGR_SOC64_SEC_CTRL_SLT 0x80 +#define SYSMGR_SOC64_OSC_TRIM 0x84 +#define SYSMGR_SOC64_DMAC0_CTRL_STATUS_REG 0x88 +#define SYSMGR_SOC64_DMAC1_CTRL_STATUS_REG 0x8C +#define SYSMGR_SOC64_ECC_INTMASK_VALUE 0x90 +#define SYSMGR_SOC64_ECC_INTMASK_SET 0x94 +#define SYSMGR_SOC64_ECC_INTMASK_CLR 0x98 +#define SYSMGR_SOC64_ECC_INTMASK_SERR 0x9C +#define SYSMGR_SOC64_ECC_INTMASK_DERR 0xA0 +#define SYSMGR_SOC64_MPFE_CONFIG 0x228 +#define SYSMGR_SOC64_BOOT_SCRATCH_POR0 0x258 +#define SYSMGR_SOC64_BOOT_SCRATCH_POR1 0x25C +#define SYSMGR_SCRATCH_REG_0_QSPI_REFCLK_MASK GENMASK(31, 0) +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_RESET_TYPE_MASK GENMASK(31, 29) +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_RESET_TYPE_SHIFT 29 +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_PORT_INFO_MASK BIT(27) +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_EMIF_INFO_MASK BIT(28) +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_PORT_EMIF_INFO_MASK GENMASK(28, 27) +#define ALT_SYSMGR_SCRATCH_REG_3_DDR_DBE_MASK BIT(1) +#define ALT_SYSMGR_SCRATCH_REG_3_OCRAM_DBE_MASK BIT(0) +#define ALT_SYSMGR_SCRATCH_REG_POR_0_DDR_PROGRESS_MASK BIT(0) +#define ALT_SYSMGR_SCRATCH_REG_POR_1_REVA_WORKAROUND_USER_MODE_MASK BIT(0) +#define ALT_SYSMGR_SCRATCH_REG_POR_1_REVA_WORKAROUND_MASK BIT(1) +#else #define SYSMGR_SOC64_NAND_AXUSER 0x5c -#define SYSMGR_SOC64_FPGAINTF_EN1 0x68 -#define SYSMGR_SOC64_FPGAINTF_EN2 0x6c -#define SYSMGR_SOC64_FPGAINTF_EN3 0x70 #define SYSMGR_SOC64_DMA_L3MASTER 0x74 #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #define SYSMGR_SOC64_DDR_MODE 0xb8 @@ -34,39 +55,56 @@ void populate_sysmgr_pinmux(void); #define SYSMGR_SOC64_HMC_CLK 0xb4 #define SYSMGR_SOC64_IO_PA_CTRL 0xb8 #endif -#define SYSMGR_SOC64_NOC_TIMEOUT 0xc0 -#define SYSMGR_SOC64_NOC_IDLEREQ_SET 0xc4 -#define SYSMGR_SOC64_NOC_IDLEREQ_CLR 0xc8 -#define SYSMGR_SOC64_NOC_IDLEREQ_VAL 0xcc -#define SYSMGR_SOC64_NOC_IDLEACK 0xd0 -#define SYSMGR_SOC64_NOC_IDLESTATUS 0xd4 -#define SYSMGR_SOC64_FPGA2SOC_CTRL 0xd8 -#define SYSMGR_SOC64_FPGA_CONFIG 0xdc #define SYSMGR_SOC64_IOCSRCLK_GATE 0xe0 #define SYSMGR_SOC64_GPO 0xe4 #define SYSMGR_SOC64_GPI 0xe8 #define SYSMGR_SOC64_MPU 0xf0 -/* - * Bits[31:28] reserved for N5X DDR retention, bits[27:0] reserved for SOC 64-bit - * storing qspi ref clock (kHz) - */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD0 0x200 -/* store osc1 clock freq */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD1 0x204 -/* store fpga clock freq */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD2 0x208 -/* reserved for customer use */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD3 0x20c -/* store PSCI_CPU_ON value */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD4 0x210 -/* store PSCI_CPU_ON value */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD5 0x214 -/* store VBAR_EL3 value */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD6 0x218 -/* store VBAR_EL3 value */ -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD7 0x21c -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD8 0x220 -#define SYSMGR_SOC64_BOOT_SCRATCH_COLD9 0x224 +#define SYSMGR_SCRATCH_REG_0_QSPI_REFCLK_MASK GENMASK(27, 0) +#endif /*CONFIG_TARGET_SOCFPGA_AGILEX5*/ + +#define SYSMGR_SOC64_DMA 0x20 +#define SYSMGR_SOC64_DMA_PERIPH 0x24 +#define SYSMGR_SOC64_WDDBG 0x08 +#define SYSMGR_SOC64_SDMMC 0x28 +#define SYSMGR_SOC64_SDMMC_L3MASTER 0x2C +#define SYSMGR_SOC64_FPGAINTF_EN1 0x68 +#define SYSMGR_SOC64_FPGAINTF_EN2 0x6C +#define SYSMGR_SOC64_FPGAINTF_EN3 0x70 +#define SYSMGR_SOC64_NOC_TIMEOUT 0xC0 +#define SYSMGR_SOC64_NOC_IDLEREQ_SET 0xC4 +#define SYSMGR_SOC64_NOC_IDLEREQ_CLR 0xC8 +#define SYSMGR_SOC64_NOC_IDLEREQ_VAL 0xCC +#define SYSMGR_SOC64_NOC_IDLEACK 0xd0 +#define SYSMGR_SOC64_NOC_IDLESTATUS 0xD4 +#define SYSMGR_SOC64_FPGA2SOC_CTRL 0xD8 +#define SYSMGR_SOC64_FPGA_CONFIG 0xDC + +#define SYSMGR_SOC64_TSN_GLOBAL 0x40 +#define SYSMGR_SOC64_TSN_0 0x44 +#define SYSMGR_SOC64_TSN_1 0x48 +#define SYSMGR_SOC64_TSN_2 0x4C +#define SYSMGR_SOC64_TSN_0_ACE 0x50 +#define SYSMGR_SOC64_TSN_1_ACE 0x54 +#define SYSMGR_SOC64_TSN_2_ACE 0x58 +#define SYSMGR_SOC64_EMAC_GLOBAL SYSMGR_SOC64_TSN_GLOBAL +#define SYSMGR_SOC64_EMAC0 SYSMGR_SOC64_TSN_0 +#define SYSMGR_SOC64_EMAC1 SYSMGR_SOC64_TSN_1 +#define SYSMGR_SOC64_EMAC2 SYSMGR_SOC64_TSN_2 +#define SYSMGR_SOC64_EMAC0_ACE SYSMGR_SOC64_TSN_0_ACE +#define SYSMGR_SOC64_EMAC1_ACE SYSMGR_SOC64_TSN_1_ACE +#define SYSMGR_SOC64_EMAC2_ACE SYSMGR_SOC64_TSN_2_ACE + +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD0 0x200 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD1 0x204 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD2 0x208 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD3 0x20C +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD4 0x210 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD5 0x214 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD6 0x218 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD7 0x21C +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD8 0x220 +#define SYSMGR_SOC64_BOOT_SCRATCH_COLD9 0x224 + #define SYSMGR_SOC64_PINSEL0 0x1000 #define SYSMGR_SOC64_IOCTRL0 0x1130 #define SYSMGR_SOC64_EMAC0_USEFPGA 0x1300 @@ -97,7 +135,6 @@ void populate_sysmgr_pinmux(void); * Bits[31:28] reserved for DM DDR retention, bits[27:0] reserved for SOC 64-bit * storing qspi ref clock (kHz) */ -#define SYSMGR_SCRATCH_REG_0_QSPI_REFCLK_MASK GENMASK(27, 0) #define ALT_SYSMGR_SCRATCH_REG_0_DDR_RETENTION_MASK BIT(31) #define ALT_SYSMGR_SCRATCH_REG_0_DDR_SHA_MASK BIT(30) #define ALT_SYSMGR_SCRATCH_REG_0_DDR_RESET_TYPE_MASK (BIT(29) | BIT(28))
How much of this can be converted to DT probing ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:47 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 01/20] arm: socfpga: agilex5: Add new system manager base addresses
Yes, we have dedicated resource is working to convert this to DT in conjunction with syscon support to provide System-wide configuration.
I can pull in this for Agilex5 first if you want to see it here or separate submission on the changes since it impacts all devices, more tests are needed to cover all devices.
Let me know your preference.
Thanks.
Regards, Tien Fong.
Either option is fine as long as this is moving toward DT probing, thanks .
Adding mechanism to retrieve base address for Agilex5 Clock Mananger.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/misc.c | 24 ++++++++++++++---------- 1 file changed, 14 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 495ba2a0d41..6cf2ee60038 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2024 Altera Corporation <www.altera.com> */
#include <config.h> @@ -252,15 +252,19 @@ void socfpga_get_managers_addr(void) if (ret) hang();
-#ifdef CONFIG_TARGET_SOCFPGA_AGILEX - ret = socfpga_get_base_addr("intel,agilex-clkmgr", - &socfpga_clkmgr_base); -#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) - ret = socfpga_get_base_addr("intel,n5x-clkmgr", - &socfpga_clkmgr_base); -#else - ret = socfpga_get_base_addr("altr,clk-mgr", &socfpga_clkmgr_base); -#endif + if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX)) + ret = socfpga_get_base_addr("intel,agilex-clkmgr", + &socfpga_clkmgr_base); + else if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X)) + ret = socfpga_get_base_addr("intel,n5x-clkmgr", + &socfpga_clkmgr_base); + else if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)) + ret = socfpga_get_base_addr("intel,agilex5-clkmgr", + &socfpga_clkmgr_base); + else + ret = socfpga_get_base_addr("altr,clk-mgr", + &socfpga_clkmgr_base); + if (ret) hang(); }
Can this be turned into clock driver and probe from DT ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:48 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 02/20] arm: socfpga: Add support for agilex5 clock manager
I will remove this patch, because I just noticed the clk driver for Agilex 5 is already in driver model (DT).
Regards, Tien Fong.
Add a new .data section for preserving the original state of the .data section of SoC64 SPL. This new .data section is required to make SPL reentrant after warm reset.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/u-boot-spl-soc64.lds | 80 ++++++++++++++++++++++ 1 file changed, 80 insertions(+) create mode 100644 arch/arm/mach-socfpga/u-boot-spl-soc64.lds
diff --git a/arch/arm/mach-socfpga/u-boot-spl-soc64.lds b/arch/arm/mach-socfpga/u-boot-spl-soc64.lds new file mode 100644 index 00000000000..91cf8dd3139 --- /dev/null +++ b/arch/arm/mach-socfpga/u-boot-spl-soc64.lds @@ -0,0 +1,80 @@ +/* + * (C) Copyright 2013 + * David Feng fenghua@phytium.com.cn + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") +OUTPUT_ARCH(aarch64) +ENTRY(_start) +SECTIONS +{ + __image_copy_start = ADDR(.text); + .text : { + . = ALIGN(8); + CPUDIR/start.o (.text*) + *(.text*) + } >.sram + + .rodata : { + . = ALIGN(8); + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } >.sram + + .data : { + . = ALIGN(8); + /* Run time .data section starting at this location */ + __data_start = .; + *(.data*) + /* Run time .data section ending at this location */ + __data_end = .; + } >.sram + + . = ALIGN(8); + /* Preserve original .data section starting at this location */ + __preserve_data_start = .; + . = __preserve_data_start + (__data_end - __data_start); + /* Preserve original .data section ending at this location */ + __preserve_data_end = .; + + . = ALIGN(8); + __u_boot_list . : { + KEEP(*(SORT(__u_boot_list*))); + } >.sram + + . = ALIGN(8); + __image_copy_end = .; + + _end = .; + + _image_binary_end = .; + + .bss : { + __bss_start = .; + *(.bss*) + . = ALIGN(8); + __bss_end = .; + } >.sdram + + /DISCARD/ : { *(.dynsym) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +}
Where is the linker script copied from ? What is the original file name and path ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:49 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 03/20] linker: Add SPL linker script for SoC64 devices
I think the script is copied from arch/arm/cpu/armv8/u-boot-spl.lds .
Regards, Tien Fong.
Can arch/arm/cpu/armv8/u-boot-spl.lds be extended somehow instead , or are there too many differences ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, September 25, 2024 2:36 AM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 03/20] linker: Add SPL linker script for SoC64 devices
We think can use arch/arm/cpu/armv8/u-boot-spl.lds, because we just noticed the CONFIG_SPL_RECOVER_DATA_SECTION was added into lds and this should be the same design with current patch.
Thanks.
Best regards, Tien Fong
Excellent !
Create new low level initialization for Agile5 due to the new ARM core composition and warm reset behavior.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + .../include/mach/reset_manager_soc64.h | 12 +++- arch/arm/mach-socfpga/lowlevel_init_agilex5.S | 57 +++++++++++++++++++ 3 files changed, 68 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-socfpga/lowlevel_init_agilex5.S
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 67c6a8dfec5..53c91d1d2a5 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -58,6 +58,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 obj-y += clock_manager_agilex5.o +obj-y += lowlevel_init_agilex5.o obj-y += mailbox_s10.o obj-y += misc_soc64.o obj-y += mmu-arm64_s10.o diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_soc64.h b/arch/arm/mach-socfpga/include/mach/reset_manager_soc64.h index c8bb727aa2b..d373ec0dc70 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_soc64.h @@ -1,15 +1,17 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2016-2019 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> */
#ifndef _RESET_MANAGER_SOC64_H_ #define _RESET_MANAGER_SOC64_H_
+#ifndef __ASSEMBLY__ void reset_deassert_peripherals_handoff(void); int cpu_has_been_warmreset(void); void print_reset_info(void); void socfpga_bridges_reset(int enable); +#endif
#define RSTMGR_SOC64_STATUS 0x00 #define RSTMGR_SOC64_MPUMODRST 0x20 @@ -23,14 +25,20 @@ void socfpga_bridges_reset(int enable); #define RSTMGR_BRGMODRST_FPGA2SOC_MASK 0x00000004
/* SDM, Watchdogs and MPU warm reset mask */ -#define RSTMGR_STAT_SDMWARMRST BIT(1) +#define RSTMGR_STAT_SDMWARMRST 0x2 #define RSTMGR_STAT_MPU0RST_BITPOS 8 #define RSTMGR_STAT_L4WD0RST_BITPOS 16 +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define RSTMGR_STAT_L4WD0RST_BIT 0x1F0000 +#define RSTMGR_L4WD_MPU_WARMRESET_MASK (RSTMGR_STAT_SDMWARMRST | \ + RSTMGR_STAT_L4WD0RST_BIT) +#else #define RSTMGR_L4WD_MPU_WARMRESET_MASK (RSTMGR_STAT_SDMWARMRST | \ GENMASK(RSTMGR_STAT_MPU0RST_BITPOS + 3, \ RSTMGR_STAT_MPU0RST_BITPOS) | \ GENMASK(RSTMGR_STAT_L4WD0RST_BITPOS + 3, \ RSTMGR_STAT_L4WD0RST_BITPOS)) +#endif
/* * SocFPGA Stratix10 reset IDs, bank mapping is as follows: diff --git a/arch/arm/mach-socfpga/lowlevel_init_agilex5.S b/arch/arm/mach-socfpga/lowlevel_init_agilex5.S new file mode 100644 index 00000000000..27430577719 --- /dev/null +++ b/arch/arm/mach-socfpga/lowlevel_init_agilex5.S @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Intel Corporation. All rights reserved + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/arch/reset_manager_soc64.h> +#include <asm/macro.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + mov x29, lr /* Save LR */ + + /* Enable Async */ + msr daifclr, #4 + +#ifdef CONFIG_SPL_BUILD + branch_if_slave x0, 3f + + /* Check rstmgr.stat for warm reset status */ + ldr w1, =SOCFPGA_RSTMGR_ADDRESS + ldr w0, [x1] + /* Check whether any L4 watchdogs or SDM had triggered warm reset */ + ldr x2, =RSTMGR_L4WD_MPU_WARMRESET_MASK + ands x0, x0, x2 + /* + * If current Reset Manager's status is warm reset just reload the + * .data section by copying the data from data preserve section. + * Otherwise, copy the .data section to the data preserve section to + * keep an original copy of .data section. This ensure SPL is + * reentrant after warm reset. + */ + b.ne reload_data_section + /* Copy from .data to preserved .data to backup the SPL state */ + ldr x0, =__data_start + ldr x1, =__preserve_data_start + ldr x2, =__preserve_data_end + b copy_loop +reload_data_section: + /* Copy from preserved .data to .data to restore the SPL state */ + ldr x0, =__preserve_data_start + ldr x1, =__data_start + ldr x2, =__data_end +copy_loop: + ldr w3, [x0] + add x0, x0, #4 + str w3, [x1] + add x1, x1, #4 + cmp x1, x2 + b.ne copy_loop +3: +#endif + + mov lr, x29 /* Restore LR */ + ret +ENDPROC(lowlevel_init)
Can this be wired into existing early hook function, like s_init or so ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:49 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 04/20] arm: socfpga: agilex5: Add low level initialization
100644
I cannot find the caller for s_init, wonder where is the s_init is called? What's concern with lowlevel_init()? It's also wired into existing early hook function which's located inside start.S
Regards, Tien Fong.
100644
arch/arm/cpu/armv7/lowlevel_init.S:.pushsection .text.s_init, "ax" arch/arm/cpu/armv7/lowlevel_init.S:WEAK(s_init) arch/arm/cpu/armv7/lowlevel_init.S:ENDPROC(s_init) arch/arm/cpu/armv7/lowlevel_init.S: bl s_init
Maybe such a default lowlevel_init for armv8 could also have an s_init ?
I would like to avoid duplicating lowlevel_init functionality as much as possible , common lowlevel_init would be very welcome .
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, September 25, 2024 2:32 AM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 04/20] arm: socfpga: agilex5: Add low level initialization
100644
Sure, I can add the s_init to common lowlevel_init and moving the codes to s_init.
Thanks.
Regards, Tien Fong
Thanks. Then the question is, how much of this stuff can be removed because it is part of generic lowlevel_init, I hope a lot.
s_init. Thanks. Then the question is, how much of this stuff can be removed because it is part of generic lowlevel_init, I hope a lot.
I'm not sure I completely understand your question, but I can share what we're going to do. Declaring a weak s_init function at lowlevel_init.S
.pushsection .text.s_init, "ax" WEAK(s_init) bx lr ENDPROC(s_init) .popsection
Calling s_init before lowlevel_init returned to parent call [...] bl s_init move lr, x29 ret
We will move the codes to s_init which is declared in our platform driver, arch/arm/mach-socfpga .
The codes is needed to backup the data section as earlier as possible to support warm reset / watchdog due to warm reset use case, where reloading SPL would be skipped after reset.
Thanks.
Regards, Tien Fong
I am wondering if some of the code here can be deduplicated by using the generic lowlevel_init.S , i.e. if some of the code in lowlevel_init.S is duplicate of the code in this custom lowlevel_init.S implementation.
If you need to run code very early and back up critical data, look at save_boot_params .
we're going to do.
No duplicate codes in both common lowlevel_init.S and custom lowlevel_init.S.
reloading SPL would be skipped after reset. If you need to run code very early and back up critical data, look at save_boot_params .
Thanks for suggesting this, we will try this out.
Regards, Tien Fong
Agilex5 supports both HPS handoff data and DDR handoff data. Existing HPS handoff functions are restructured to support both existing devices and Agilex5 device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/handoff_soc64.h | 4 ++-- arch/arm/mach-socfpga/wrap_handoff_soc64.c | 10 ++++++++-- 3 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 53c91d1d2a5..e0ada69dd5a 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -63,6 +63,7 @@ obj-y += mailbox_s10.o obj-y += misc_soc64.o obj-y += mmu-arm64_s10.o obj-y += reset_manager_s10.o +obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
diff --git a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h index d839f288411..918d25a1b61 100644 --- a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h @@ -17,9 +17,9 @@ #define SOC64_HANDOFF_MAGIC_FPGA 0x46504741 #define SOC64_HANDOFF_MAGIC_DELAY 0x444C4159 #define SOC64_HANDOFF_MAGIC_CLOCK 0x434C4B53 +#define SOC64_HANDOFF_MAGIC_SDRAM 0x5344524d #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) #define SOC64_HANDOFF_MAGIC_PERI 0x50455249 -#define SOC64_HANDOFF_MAGIC_SDRAM 0x5344524d #else #define SOC64_HANDOFF_MAGIC_MISC 0x4D495343 #endif @@ -68,7 +68,7 @@ #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) #define SOC64_HANDOFF_PERI (SOC64_HANDOFF_BASE + 0x620) #define SOC64_HANDOFF_SDRAM (SOC64_HANDOFF_BASE + 0x634) -#define SOC64_HANDOFF_SDRAM_LEN 1 +#define SOC64_HANDOFF_SDRAM_LEN 5 #endif
#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) diff --git a/arch/arm/mach-socfpga/wrap_handoff_soc64.c b/arch/arm/mach-socfpga/wrap_handoff_soc64.c index 92051d19b73..c8456c8dd6a 100644 --- a/arch/arm/mach-socfpga/wrap_handoff_soc64.c +++ b/arch/arm/mach-socfpga/wrap_handoff_soc64.c @@ -1,15 +1,16 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2024 Intel Corporation <www.intel.com> * */
+#include <errno.h> #include <asm/arch/handoff_soc64.h> #include <asm/io.h> -#include <errno.h> #include "log.h"
#ifndef __ASSEMBLY__ +#include <asm/types.h> enum endianness { LITTLE_ENDIAN = 0, BIG_ENDIAN, @@ -26,7 +27,12 @@ static enum endianness check_endianness(u32 handoff) case SOC64_HANDOFF_MAGIC_FPGA: case SOC64_HANDOFF_MAGIC_DELAY: case SOC64_HANDOFF_MAGIC_CLOCK: + case SOC64_HANDOFF_MAGIC_SDRAM: +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + case SOC64_HANDOFF_MAGIC_PERI: +#else case SOC64_HANDOFF_MAGIC_MISC: +#endif return BIG_ENDIAN; #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) case SOC64_HANDOFF_DDR_UMCTL2_MAGIC:
These configuration settings are required to enable cache maintenance and access between initiators and targets.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 209 +++++++++++++++++++++++ 1 file changed, 209 insertions(+)
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi index a8167e5c14a..ec42fd01a9c 100644 --- a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -13,6 +13,215 @@ #size-cells = <2>; bootph-all; }; + + soc { + bootph-all; + + socfpga_ccu_config: socfpga-ccu-config { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* DSU */ + i_ccu_caiu0@1c000000 { + reg = <0x1c000000 0x00001000>; + intel,offset-settings = + /* CAIUMIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* DII2_GICREGS */ + <0x00000424 0x0001d000 0xffffffff>, + <0x00000428 0x00000000 0x000000ff>, + <0x00000420 0xc0800400 0xc1f03e1f>, + /* NCAIU0_LWSOC2FPGA */ + <0x00000444 0x00020000 0xffffffff>, + <0x00000448 0x00000000 0x000000ff>, + <0x00000440 0xc1100006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_1G */ + <0x00000454 0x00040000 0xffffffff>, + <0x00000458 0x00000000 0x000000ff>, + <0x00000450 0xc1200006 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* NCAIU0_SOC2FPGA_16G */ + <0x00000474 0x00400000 0xffffffff>, + <0x00000478 0x00000000 0x000000ff>, + <0x00000470 0xc1600006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* NCAIU0_SOC2FPGA_256G */ + <0x00000494 0x04000000 0xffffffff>, + <0x00000498 0x00000000 0x000000ff>, + <0x00000490 0xc1a00006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* FPGA2SOC */ + i_ccu_ncaiu0@1c001000 { + reg = <0x1c001000 0x00001000>; + intel,offset-settings = + /* NCAIU0MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* PSS */ + <0x00000404 0x00010000 0xffffffff>, + <0x00000408 0x00000000 0x000000ff>, + <0x00000400 0xC0F00000 0xc1f03e1f>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* NCAIU0_LWSOC2FPGA */ + <0x00000444 0x00020000 0xffffffff>, + <0x00000448 0x00000000 0x000000ff>, + <0x00000440 0xc1100006 0xc1f03e1f>, + /* NCAIU0_SOC2FPGA_1G */ + <0x00000454 0x00040000 0xffffffff>, + <0x00000458 0x00000000 0x000000ff>, + <0x00000450 0xc1200006 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* NCAIU0_SOC2FPGA_16G */ + <0x00000474 0x00400000 0xffffffff>, + <0x00000478 0x00000000 0x000000ff>, + <0x00000470 0xc1600006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* NCAIU0_SOC2FPGA_256G */ + <0x00000494 0x04000000 0xffffffff>, + <0x00000498 0x00000000 0x000000ff>, + <0x00000490 0xc1a00006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* GIC_M */ + i_ccu_ncaiu1@1c002000 { + reg = <0x1c002000 0x00001000>; + intel,offset-settings = + /* NCAIU1MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* SMMU */ + i_ccu_ncaiu2@1c003000 { + reg = <0x1c003000 0x00001000>; + intel,offset-settings = + /* NCAIU2MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* PSS NOC */ + i_ccu_ncaiu3@1c004000 { + reg = <0x1c004000 0x00001000>; + intel,offset-settings = + /* NCAIU3MIFSR */ + <0x000003c4 0x00000000 0x07070777>, + /* DII1_MPFEREGS */ + <0x00000414 0x00018000 0xffffffff>, + <0x00000418 0x00000000 0x000000ff>, + <0x00000410 0xc0e00200 0xc1f03e1f>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* DCE0 */ + i_ccu_dce0@1c005000 { + reg = <0x1c005000 0x00001000>; + intel,offset-settings = + /* DCEUMIFSR0 */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* DCE1 */ + i_ccu_dce1@1c006000 { + reg = <0x1c006000 0x00001000>; + intel,offset-settings = + /* DCEUMIFSR1 */ + <0x000003c4 0x00000000 0x07070777>, + /* DMI_SDRAM_2G */ + <0x00000464 0x00080000 0xffffffff>, + <0x00000468 0x00000000 0x000000ff>, + /* DMI_SDRAM_30G */ + <0x00000484 0x00800000 0xffffffff>, + <0x00000488 0x00000000 0x000000ff>, + /* DMI_SDRAM_480G */ + <0x000004a4 0x08000000 0xffffffff>, + <0x000004a8 0x00000000 0x000000ff>; + bootph-all; + }; + + /* DMI0 */ + i_ccu_dmi0@1c007000 { + reg = <0x1c007000 0x00001000>; + intel,offset-settings = + /* DMIUSMCTCR */ + <0x00000300 0x00000001 0x00000003>, + <0x00000300 0x00000003 0x00000003>; + bootph-all; + }; + + /* DMI1 */ + i_ccu_dmi0@1c008000 { + reg = <0x1c008000 0x00001000>; + intel,offset-settings = + /* DMIUSMCTCR */ + <0x00000300 0x00000001 0x00000003>, + <0x00000300 0x00000003 0x00000003>; + bootph-all; + }; + }; + }; };
&clkmgr {
These firewall configure settings are needed to disable firewall on respective hardware component so both secure and non-secure transactions are allowed.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 166 +++++++++++++++++++++++ 1 file changed, 166 insertions(+)
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi index ec42fd01a9c..bf30b3b8858 100644 --- a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -221,6 +221,172 @@ bootph-all; }; }; + + socfpga_firewall_config: socfpga-firewall-config { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* L4 peripherals firewall */ + noc_fw_l4_per@10d21000 { + reg = <0x10d21000 0x0000008c>; + intel,offset-settings = + /* NAND */ + <0x00000000 0x01010001 0x01010001>, + /* USB0 */ + <0x0000000c 0x01010001 0x01010001>, + /* USB1 */ + <0x00000010 0x01010001 0x01010001>, + /* SPI_MAIN0 */ + <0x0000001c 0x01010301 0x01010301>, + /* SPI_MAIN1 */ + <0x00000020 0x01010301 0x01010301>, + /* SPI_SECONDARY0 */ + <0x00000024 0x01010301 0x01010301>, + /* SPI_SECONDARY1 */ + <0x00000028 0x01010301 0x01010301>, + /* EMAC0 */ + <0x0000002c 0x01010001 0x01010001>, + /* EMAC1 */ + <0x00000030 0x01010001 0x01010001>, + /* EMAC2 */ + <0x00000034 0x01010001 0x01010001>, + /* SDMMC */ + <0x00000040 0x01010001 0x01010001>, + /* GPIO0 */ + <0x00000044 0x01010301 0x01010301>, + /* GPIO1 */ + <0x00000048 0x01010301 0x01010301>, + /* I2C0 */ + <0x00000050 0x01010301 0x01010301>, + /* I2C1 */ + <0x00000054 0x01010301 0x01010301>, + /* I2C2 */ + <0x00000058 0x01010301 0x01010301>, + /* I2C3 */ + <0x0000005c 0x01010301 0x01010301>, + /* I2C4 */ + <0x00000060 0x01010301 0x01010301>, + /* SP_TIMER0 */ + <0x00000064 0x01010301 0x01010301>, + /* SP_TIMER1 */ + <0x00000068 0x01010301 0x01010301>, + /* UART0 */ + <0x0000006c 0x01010301 0x01010301>, + /* UART1 */ + <0x00000070 0x01010301 0x01010301>, + /* I3C0 */ + <0x00000074 0x01010301 0x01010301>, + /* I3C1 */ + <0x00000078 0x01010301 0x01010301>, + /* DMA0 */ + <0x0000007c 0x01010001 0x01010001>, + /* DMA1 */ + <0x00000080 0x01010001 0x01010001>, + /* COMBO_PHY */ + <0x00000084 0x01010001 0x01010001>, + /* NAND_SDMA */ + <0x00000088 0x01010301 0x01010301>; + bootph-all; + }; + + /* L4 system firewall */ + noc_fw_l4_sys@10d21100 { + reg = <0x10d21100 0x00000098>; + intel,offset-settings = + /* DMA_ECC */ + <0x00000008 0x01010001 0x01010001>, + /* EMAC0RX_ECC */ + <0x0000000c 0x01010001 0x01010001>, + /* EMAC0TX_ECC */ + <0x00000010 0x01010001 0x01010001>, + /* EMAC1RX_ECC */ + <0x00000014 0x01010001 0x01010001>, + /* EMAC1TX_ECC */ + <0x00000018 0x01010001 0x01010001>, + /* EMAC2RX_ECC */ + <0x0000001c 0x01010001 0x01010001>, + /* EMAC2TX_ECC */ + <0x00000020 0x01010001 0x01010001>, + /* NAND_ECC */ + <0x0000002c 0x01010001 0x01010001>, + /* NAND_READ_ECC */ + <0x00000030 0x01010001 0x01010001>, + /* NAND_WRITE_ECC */ + <0x00000034 0x01010001 0x01010001>, + /* OCRAM_ECC */ + <0x00000038 0x01010001 0x01010001>, + /* SDMMC_ECC */ + <0x00000040 0x01010001 0x01010001>, + /* USB0_ECC */ + <0x00000044 0x01010001 0x01010001>, + /* USB1_CACHEECC */ + <0x00000048 0x01010001 0x01010001>, + /* CLOCK_MANAGER */ + <0x0000004c 0x01010001 0x01010001>, + /* IO_MANAGER */ + <0x00000054 0x01010001 0x01010001>, + /* RESET_MANAGER */ + <0x00000058 0x01010001 0x01010001>, + /* SYSTEM_MANAGER */ + <0x0000005c 0x01010001 0x01010001>, + /* OSC0_TIMER */ + <0x00000060 0x01010301 0x01010301>, + /* OSC1_TIMER0*/ + <0x00000064 0x01010301 0x01010301>, + /* WATCHDOG0 */ + <0x00000068 0x01010301 0x01010301>, + /* WATCHDOG1 */ + <0x0000006c 0x01010301 0x01010301>, + /* WATCHDOG2 */ + <0x00000070 0x01010301 0x01010301>, + /* WATCHDOG3 */ + <0x00000074 0x01010301 0x01010301>, + /* DAP */ + <0x00000078 0x03010001 0x03010001>, + /* WATCHDOG4 */ + <0x0000007c 0x01010301 0x01010301>, + /* POWER_MANAGER */ + <0x00000080 0x01010001 0x01010001>, + /* USB1_RXECC */ + <0x00000084 0x01010001 0x01010001>, + /* USB1_TXECC */ + <0x00000088 0x01010001 0x01010001>, + /* L4_NOC_PROBES */ + <0x00000090 0x01010001 0x01010001>, + /* L4_NOC_QOS */ + <0x00000094 0x01010001 0x01010001>; + bootph-all; + }; + + /* Light weight SoC2FPGA */ + noc_fw_lwsoc2fpga@10d21300 { + reg = <0x10d21300 0x0000004>; + intel,offset-settings = + /* LWSOC2FPGA_CSR */ + <0x00000000 0x0ffe0301 0x0ffe0301>; + bootph-all; + }; + + /* SoC2FPGA */ + noc_fw_soc2fpga@10d21200 { + reg = <0x10d21200 0x0000004>; + intel,offset-settings = + /* SOC2FPGA_CSR */ + <0x00000000 0x0ffe0301 0x0ffe0301>; + bootph-all; + }; + + /* TCU */ + noc_fw_tcu@10d21400 { + reg = <0x10d21400 0x0000004>; + intel,offset-settings = + /* TCU_CSR */ + <0x00000000 0x01010001 0x01010001>; + bootph-all; + }; + }; }; };
Enable XGMAC for SoCFPGA Agilex5 devkit.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 33 +++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi index 9eb21d65428..75ab05031bc 100644 --- a/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5_socdk-u-boot.dtsi @@ -122,3 +122,36 @@ bootph-all; };
+&gmac0 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&emac0_phy0>; + + max-frame-size = <9000>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwxgmac-mdio"; + emac0_phy0: ethernet-phy@0 { + reg = <0>; + }; + }; +}; + +&gmac2 { + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&emac2_phy0>; + + max-frame-size = <9000>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwxgmac-mdio"; + emac2_phy0: ethernet-phy@0 { + reg = <0>; + }; + }; +};
+&gmac0 {
- status = "okay";
- phy-mode = "rgmii";
- phy-handle = <&emac0_phy0>;
Shouldn't this be part of Linux DT already ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:51 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 08/20] arm: dts: agilex5: Enable XGMAC
+&gmac0 {
- status = "okay";
This enablement not yet in Linux DT, I believe our Linux team is still working on it.
Regards, Tien Fong
+&gmac0 {
- status = "okay";
Is there at least a patch posted upstream ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, September 25, 2024 2:36 AM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 08/20] arm: dts: agilex5: Enable XGMAC
+&gmac0 {
- status = "okay";
on it. Is there at least a patch posted upstream ?
Having two patches posted now in Linux mainline, but gmac device is still not yet added into these dt. https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/intel/socf... https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/intel/socf...
I think we can do a cleanup if the duplicated found in U-Boot later.
Thanks.
Regards, Tien Fong
+&gmac0 {
- status = "okay";
At least reference the two patches (lore links) in the V2 of this patch.
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Wednesday, September 25, 2024 8:51 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 08/20] arm: dts: agilex5: Enable XGMAC
+&gmac0 {
- status = "okay";
https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/inte l/socfpga_agilex5.dtsi https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/inte l/socfpga_agilex5_socdk.dts
Noted. Will do.
Thanks.
Regards, Tien Fong
The reset driver can support both cold reset and warm reset with SMCC to ATF.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/Kconfig | 1 + drivers/sysreset/Kconfig | 7 +++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_socfpga_agilex5.c | 47 +++++++++++++++++++++ 4 files changed, 56 insertions(+) create mode 100644 drivers/sysreset/sysreset_socfpga_agilex5.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ba0359fed5a..8e9a39e7d23 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1123,6 +1123,7 @@ config ARCH_SOCFPGA select SYSRESET_SOCFPGA if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select SYSRESET_SOCFPGA_SOC64 if !TARGET_SOCFPGA_AGILEX5 && \ TARGET_SOCFPGA_SOC64 + select SYSRESET_SOCFPGA_AGILEX5 if TARGET_SOCFPGA_AGILEX5 imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index 121194e4418..8dc1e7fec58 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -156,6 +156,13 @@ config SYSRESET_SOCFPGA_SOC64 This enables the system reset driver support for Intel SOCFPGA SoC64 SoCs.
+config SYSRESET_SOCFPGA_AGILEX5 + bool "Enable support for Intel SOCFPGA AGILEX5 device" + depends on ARCH_SOCFPGA && TARGET_SOCFPGA_AGILEX5 + help + This enables the system reset driver support for Intel SOCFPGA + AGILEX5 device. + config SYSRESET_TEGRA bool "Tegra PMC system reset driver" depends on ARCH_TEGRA diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index a6a0584585c..c090db48af4 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SBI) += sysreset_sbi.o obj-$(CONFIG_SYSRESET_SOCFPGA) += sysreset_socfpga.o obj-$(CONFIG_SYSRESET_SOCFPGA_SOC64) += sysreset_socfpga_soc64.o +obj-$(CONFIG_SYSRESET_SOCFPGA_AGILEX5) += sysreset_socfpga_agilex5.o obj-$(CONFIG_SYSRESET_TEGRA) += sysreset_tegra.o obj-$(CONFIG_SYSRESET_TI_SCI) += sysreset-ti-sci.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_TPS65910) += sysreset_tps65910.o diff --git a/drivers/sysreset/sysreset_socfpga_agilex5.c b/drivers/sysreset/sysreset_socfpga_agilex5.c new file mode 100644 index 00000000000..3cb7849ec88 --- /dev/null +++ b/drivers/sysreset/sysreset_socfpga_agilex5.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ + +#include <cpu_func.h> +#include <dm.h> +#include <env.h> +#include <errno.h> +#include <sysreset.h> +#include <asm/arch/reset_manager.h> +#include <asm/system.h> + +static int socfpga_sysreset_request(struct udevice *dev, + enum sysreset_t type) +{ +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) + const char *reset = env_get("reset"); + + if (reset && !strcmp(reset, "warm")) { + /* Ensure content in dcache is flushed to system memory */ + flush_dcache_all(); + + /* request a warm reset */ + puts("Do warm reset now...\n"); + + /* doing architecture system reset */ + psci_system_reset2(0, 0); + } else { + puts("Issuing cold reset REBOOT_HPS\n"); + psci_system_reset(); + } +#endif + + return -EINPROGRESS; +} + +static struct sysreset_ops socfpga_sysreset = { + .request = socfpga_sysreset_request, +}; + +U_BOOT_DRIVER(sysreset_socfpga) = { + .id = UCLASS_SYSRESET, + .name = "socfpga_sysreset", + .ops = &socfpga_sysreset, +};
- if (reset && !strcmp(reset, "warm")) {
flush_dcache_all();
Can this use SYSRESET_PSCI driver instead ?
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:52 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 09/20] sysreset: Add reset support to SoCFPGA Agilex5 device
flush_dcache_all();
This driver seems can be used after quick check, we will try out this.
Thanks.
Regards, Tien Fong
set/way instructions "dc cisw" ehich is used by the "dcache flush" command only flushing CPU data caches from L1 -> L2 -> L3 to system memory cache in cache coherency unit, hence this patch enables data flush from system memory cache of CCU into DDR memory.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/ccu_ncore3.c | 64 ++++++++++++++++++++++++++++++ 2 files changed, 65 insertions(+) create mode 100644 arch/arm/mach-socfpga/ccu_ncore3.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index e0ada69dd5a..32b3e7a57e2 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -65,6 +65,7 @@ obj-y += mmu-arm64_s10.o obj-y += reset_manager_s10.o obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o +obj-y += ccu_ncore3.o endif
ifdef CONFIG_TARGET_SOCFPGA_N5X diff --git a/arch/arm/mach-socfpga/ccu_ncore3.c b/arch/arm/mach-socfpga/ccu_ncore3.c new file mode 100644 index 00000000000..18667131eb9 --- /dev/null +++ b/arch/arm/mach-socfpga/ccu_ncore3.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ +#include <wait_bit.h> +#include <asm/arch/base_addr_soc64.h> +#include <linux/bitfield.h> + +#define CCU_DMI0_DMIUSMCTCR SOCFPGA_CCU_ADDRESS + 0x7300 +#define CCU_DMI0_DMIUSMCMCR SOCFPGA_CCU_ADDRESS + 0x7340 +#define CCU_DMI0_DMIUSMCMAR SOCFPGA_CCU_ADDRESS + 0x7344 +#define CCU_DMI0_DMIUSMCMCR_MNTOP GENMASK(3, 0) +#define MAX_DISTRIBUTED_MEM_INTERFACE 2 +#define FLUSH_ALL_ENTRIES 0x4 +#define CCU_DMI0_DMIUSMCMCR_ARRAY_ID GENMASK(21, 16) +#define ARRAY_ID_TAG 0x0 +#define ARRAY_ID_DATA 0x1 +#define CACHE_OPERATION_DONE BIT(0) +#define TIMEOUT_200MS 200 + +int __asm_flush_l3_dcache(void) +{ + int i; + int ret = 0; + + /* Flushing all entries in CCU system memory cache */ + for (i = 0; i < MAX_DISTRIBUTED_MEM_INTERFACE; i++) { + /* + * Skipping if the system memory cache is not enabled for + * particular DMI + */ + if (!readl((uintptr_t)(CCU_DMI0_DMIUSMCTCR + (i * 0x1000)))) + continue; + + writel(FIELD_PREP(CCU_DMI0_DMIUSMCMCR_MNTOP, FLUSH_ALL_ENTRIES) | + FIELD_PREP(CCU_DMI0_DMIUSMCMCR_ARRAY_ID, ARRAY_ID_TAG), + (uintptr_t)(CCU_DMI0_DMIUSMCMCR + (i * 0x1000))); + + /* Wait for cache maintenance operation done */ + ret = wait_for_bit_le32((const void *)(uintptr_t)(CCU_DMI0_DMIUSMCMAR + + (i * 0x1000)), CACHE_OPERATION_DONE, false, TIMEOUT_200MS, + false); + if (ret) { + debug("%s: Timeout while waiting for flushing tag in DMI%d done\n", + __func__, i); + return ret; + } + + writel(FIELD_PREP(CCU_DMI0_DMIUSMCMCR_MNTOP, FLUSH_ALL_ENTRIES) | + FIELD_PREP(CCU_DMI0_DMIUSMCMCR_ARRAY_ID, ARRAY_ID_DATA), + (uintptr_t)(CCU_DMI0_DMIUSMCMCR + (i * 0x1000))); + + /* Wait for cache maintenance operation done */ + ret = wait_for_bit_le32((const void *)(uintptr_t)(CCU_DMI0_DMIUSMCMAR + + (i * 0x1000)), CACHE_OPERATION_DONE, false, TIMEOUT_200MS, + false); + if (ret) + debug("%s: Timeout waiting for flushing data in DMI%d done\n", + __func__, i); + } + + return ret; +}
Allow non-secure accesses only with SMMU peripherals. This would protect the content in DDR secure region from accidentally modified by SMMU peripherals.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 34 ++++++++++++++++++++++++ arch/arm/mach-socfpga/spl_soc64.c | 17 +++++++++++- 2 files changed, 50 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi index bf30b3b8858..9baf2cbc525 100644 --- a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -387,6 +387,40 @@ bootph-all; }; }; + + socfpga_smmu_secure_config: socfpga-smmu-secure-config { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* System manager */ + i_sys_mgt_sysmgr_csr@10d12000 { + reg = <0x10d12000 0x00000500>; + intel,offset-settings = + /* dma_tbu_stream_ctrl_reg_0_dma0 */ + <0x0000017c 0x00000000 0x0000003f>, + /* dma_tbu_stream_ctrl_reg_0_dma1 */ + <0x00000180 0x00000000 0x0000003f>, + /* sdm_tbu_stream_ctrl_reg_1_sdm */ + <0x00000184 0x00000000 0x0000003f>, + /* io_tbu_stream_ctrl_reg_2_usb2 */ + <0x00000188 0x00000000 0x0000003f>, + /* io_tbu_stream_ctrl_reg_2_sdmmc */ + <0x00000190 0x00000000 0x0000003f>, + /* io_tbu_stream_ctrl_reg_2_nand */ + <0x00000194 0x00000000 0x0000003f>, + /* io_tbu_stream_ctrl_reg_2_etr */ + <0x00000198 0x00000000 0x0000003f>, + /* tsn_tbu_stream_ctrl_reg_3_tsn0 */ + <0x0000019c 0x00000000 0x0000003f>, + /* tsn_tbu_stream_ctrl_reg_3_tsn1 */ + <0x000001a0 0x00000000 0x0000003f>, + /* tsn_tbu_stream_ctrl_reg_3_tsn2 */ + <0x000001a4 0x00000000 0x0000003f>; + bootph-all; + }; + }; }; };
diff --git a/arch/arm/mach-socfpga/spl_soc64.c b/arch/arm/mach-socfpga/spl_soc64.c index 4fe67ea0811..3bfe4bb9dd3 100644 --- a/arch/arm/mach-socfpga/spl_soc64.c +++ b/arch/arm/mach-socfpga/spl_soc64.c @@ -1,10 +1,12 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Intel Corporation. All rights reserved + * Copyright (C) 2020-2024 Intel Corporation. All rights reserved * */
+#include <hang.h> #include <spl.h> +#include <dm/uclass.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -22,3 +24,16 @@ u32 spl_boot_mode(const u32 boot_device) return MMCSD_MODE_RAW; } #endif + +/* board specific function prior loading SSBL / U-Boot */ +void spl_perform_fixups(struct spl_image_info *spl_image) +{ + int ret; + struct udevice *dev; + + ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-smmu-secure-config", &dev); + if (ret) { + printf("HPS SMMU secure settings init failed: %d\n", ret); + hang(); + } +}
Update the print info per Agilex 5.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/misc_soc64.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/misc_soc64.c b/arch/arm/mach-socfpga/misc_soc64.c index a6cc78454da..95e1c07e39f 100644 --- a/arch/arm/mach-socfpga/misc_soc64.c +++ b/arch/arm/mach-socfpga/misc_soc64.c @@ -45,7 +45,12 @@ static Altera_desc altera_fpga[] = { #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - puts("CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53)\n"); + if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)) { + puts("CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A55/A76)"); + puts("\n"); + } else { + puts("CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53)\n"); + }
return 0; }
- if (IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)) {
puts("\n");
- } else {
printf("CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-%s)\n", IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) ? "A55/A76" : "A53");
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:53 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 12/20] arm: socfpga: agilex5: Update CPU info
A53)\n");
Cortex-A55/A76)");
puts("\n");
- } else {
We will fix it.
Thanks for the good comment.
Regards, Tien Fong
Board ID is exported as environment variable for use to boot Linux with FIT configuration.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/misc.h | 1 + arch/arm/mach-socfpga/misc_soc64.c | 5 +++++ 2 files changed, 6 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 8460acb00d9..e62bea017b0 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -52,5 +52,6 @@ void set_regular_boot(unsigned int status); void socfpga_pl310_clear(void); void socfpga_get_managers_addr(void); int qspi_flash_software_reset(void); +u8 socfpga_get_board_id(void);
#endif /* _SOCFPGA_MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_soc64.c b/arch/arm/mach-socfpga/misc_soc64.c index 95e1c07e39f..e34c54518a3 100644 --- a/arch/arm/mach-socfpga/misc_soc64.c +++ b/arch/arm/mach-socfpga/misc_soc64.c @@ -60,10 +60,15 @@ int print_cpuinfo(void) int arch_misc_init(void) { char qspi_string[13]; + char id[3];
sprintf(qspi_string, "<0x%08x>", cm_get_qspi_controller_clk_hz()); env_set("qspi_clock", qspi_string);
+ /* Export board_id as environment variable */ + sprintf(id, "%u", socfpga_get_board_id()); + env_set("board_id", id); + return 0; } #endif
char id[3];
env_set_ulong()
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:54 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 13/20] arm: socfpga: Export board ID as U-Boot environment variable
char id[3];
env_set_ulong()
OK, we will change it.
Regards, Tien Fong
Adding configuration for SPL malloc pool.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- configs/socfpga_agilex5_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig index dc1cef3754e..81bbe967dcf 100644 --- a/configs/socfpga_agilex5_defconfig +++ b/configs/socfpga_agilex5_defconfig @@ -29,6 +29,10 @@ CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 initrd=0x90000000 root=/dev/ram0 rw init=/sbin/init ramdisk_size=10000000 earlycon panic=-1 nosmp kvm-arm.mode=nvhe" CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xbfa00000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_CACHE=y
As cache is enabled in U-Boot and disabled in ATF(BL31). We need to perform cache flush of buffers that are shared between U-Boot and ATF using secure monitor calls.
Signed-off-by: Mahesh Rao mahesh.rao@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/smc_api.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/smc_api.c b/arch/arm/mach-socfpga/smc_api.c index ebaa0b8fa17..dac888c399f 100644 --- a/arch/arm/mach-socfpga/smc_api.c +++ b/arch/arm/mach-socfpga/smc_api.c @@ -1,9 +1,10 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2020 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2024 Intel Corporation <www.intel.com> * */
+#include <cpu_func.h> #include <asm/ptrace.h> #include <asm/system.h> #include <linux/errno.h> @@ -40,10 +41,16 @@ int smc_send_mailbox(u32 cmd, u32 len, u32 *arg, u8 urgent, u32 *resp_buf_len, args[2] = len; args[3] = urgent; args[4] = (u64)resp_buf; - if (resp_buf_len) + + if (arg && len > 0) + flush_dcache_range((u64)arg, (u64)arg + len); + + if (resp_buf && resp_buf_len && *resp_buf_len > 0) { args[5] = *resp_buf_len; - else + flush_dcache_range((u64)resp_buf, (u64)resp_buf + *resp_buf_len); + } else { args[5] = 0; + }
ret = invoke_smc(INTEL_SIP_SMC_MBOX_SEND_CMD, args, ARRAY_SIZE(args), resp, ARRAY_SIZE(resp));
- Copyright (C) 2020 Intel Corporation <www.intel.com>
- Copyright (C) 2020-2024 Intel Corporation <www.intel.com>
- if (resp_buf_len)
- if (arg && len > 0)
If really needed, the cast should be some uintptr_t
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Saturday, September 21, 2024 9:59 PM To: Chee, Tien Fong tien.fong.chee@intel.com; u-boot@lists.denx.de Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Rao, Mahesh mahesh.rao@intel.com Subject: Re: [PATCH v1 15/20] arm: socfpga: smc: Add memory coherency support to mailbox command
- if (resp_buf_len)
Sure, we will fix it.
Regards, Tien Fong
Adding DDR driver support for Agilex5 series.
Signed-off-by: Tingting Meng tingting.meng@intel.com --- MAINTAINERS | 2 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 251 +++++++ arch/arm/dts/socfpga_agilex5.dtsi | 7 + arch/arm/mach-socfpga/include/mach/firewall.h | 23 +- drivers/ddr/altera/Makefile | 1 + drivers/ddr/altera/iossm_mailbox.c | 613 ++++++++++++++++++ drivers/ddr/altera/iossm_mailbox.h | 186 ++++++ drivers/ddr/altera/sdram_agilex5.c | 377 +++++++++++ drivers/ddr/altera/sdram_soc64.c | 78 ++- drivers/ddr/altera/sdram_soc64.h | 32 +- 10 files changed, 1547 insertions(+), 23 deletions(-) create mode 100644 drivers/ddr/altera/iossm_mailbox.c create mode 100644 drivers/ddr/altera/iossm_mailbox.h create mode 100644 drivers/ddr/altera/sdram_agilex5.c
diff --git a/MAINTAINERS b/MAINTAINERS index 2050ae24df8..1837d283b2f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -146,8 +146,10 @@ ARM ALTERA SOCFPGA M: Marek Vasut marex@denx.de M: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com M: Tien Fong Chee tien.fong.chee@intel.com +M: Tingting Meng tingting.meng@intel.com S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-socfpga.git +F: drivers/ddr/altera/ F: arch/arm/mach-socfpga/ F: drivers/sysreset/sysreset_socfpga*
diff --git a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi index 9baf2cbc525..1209a8da4b9 100644 --- a/arch/arm/dts/socfpga_agilex5-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex5-u-boot.dtsi @@ -388,6 +388,230 @@ }; };
+ socfpga_ccu_ddr_interleaving_off: socfpga-ccu-ddr-interleaving-off { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* DSU */ + i_ccu_caiu0@1c000000 { + reg = <0x1c000000 0x00001000>; + intel,offset-settings = + /* CAIUAMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* FPGA2SOC */ + i_ccu_ncaiu0@1c001000 { + reg = <0x1c001000 0x00001000>; + intel,offset-settings = + /* NCAIU0AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* GIC_M */ + i_ccu_ncaiu1@1c002000 { + reg = <0x1c002000 0x00001000>; + intel,offset-settings = + /* NCAIU1AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* SMMU */ + i_ccu_ncaiu2@1c003000 { + reg = <0x1c003000 0x00001000>; + intel,offset-settings = + /* NCAIU2AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* PSS NOC */ + i_ccu_ncaiu3@1c004000 { + reg = <0x1c004000 0x00001000>; + intel,offset-settings = + /* NCAIU3AMIGR */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE0 */ + i_ccu_dce0@1c005000 { + reg = <0x1c005000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR0 */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE1 */ + i_ccu_dce1@1c006000 { + reg = <0x1c006000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR1 */ + <0x000003c0 0x00000003 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81300006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81700006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81b00006 0xc1f03e1f>; + bootph-all; + }; + }; + + socfpga_ccu_ddr_interleaving_on: socfpga-ccu-ddr-interleaving-on { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* DSU */ + i_ccu_caiu0@1c000000 { + reg = <0x1c000000 0x00001000>; + intel,offset-settings = + /* CAIUAMIGR */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* FPGA2SOC */ + i_ccu_ncaiu0@1c001000 { + reg = <0x1c001000 0x00001000>; + intel,offset-settings = + /* NCAIU0AMIGR */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* GIC_M */ + i_ccu_ncaiu1@1c002000 { + reg = <0x1c002000 0x00001000>; + intel,offset-settings = + /* NCAIU1AMIGR */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* SMMU */ + i_ccu_ncaiu2@1c003000 { + reg = <0x1c003000 0x00001000>; + intel,offset-settings = + /* NCAIU2AMIGR */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* PSS NOC */ + i_ccu_ncaiu3@1c004000 { + reg = <0x1c004000 0x00001000>; + intel,offset-settings = + /* NCAIU3AMIGR */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE0 */ + i_ccu_dce0@1c005000 { + reg = <0x1c005000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR0 */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + + /* DCE1 */ + i_ccu_dce1@1c006000 { + reg = <0x1c006000 0x00001000>; + intel,offset-settings = + /* DCEUAMIGR1 */ + <0x000003c0 0x00000001 0x0000001f>, + /* DMI_SDRAM_2G */ + <0x00000460 0x81200006 0xc1f03e1f>, + /* DMI_SDRAM_30G */ + <0x00000480 0x81600006 0xc1f03e1f>, + /* DMI_SDRAM_480G */ + <0x000004a0 0x81a00006 0xc1f03e1f>; + bootph-all; + }; + }; + socfpga_smmu_secure_config: socfpga-smmu-secure-config { compatible = "intel,socfpga-dtreg"; #address-cells = <1>; @@ -421,6 +645,26 @@ bootph-all; }; }; + + socfpga_noc_fw_mpfe_csr: socfpga-noc-fw-mpfe-csr { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + /* noc fw mpfe csr */ + i_noc_fw_mpfe_csr@18000d00 { + reg = <0x18000d00 0x00000100>; + intel,offset-settings = + /* mpfe scr io96b0 reg*/ + <0x00000000 0x00000001 0x00010101>, + /* mpfe scr io96b1 reg*/ + <0x00000004 0x00000001 0x00010101>, + /* mpfe scr noc csr*/ + <0x00000008 0x00000001 0x00010101>; + bootph-all; + }; + }; }; };
@@ -466,6 +710,13 @@ bootph-all; };
+&sdr { + compatible = "intel,sdr-ctl-agilex5"; + reg = <0x18000000 0x400000>; + resets = <&rst DDRSCH_RESET>; + bootph-all; +}; + &sysmgr { compatible = "altr,sys-mgr", "syscon"; bootph-all; diff --git a/arch/arm/dts/socfpga_agilex5.dtsi b/arch/arm/dts/socfpga_agilex5.dtsi index 03b55040497..4f17d8fc21e 100644 --- a/arch/arm/dts/socfpga_agilex5.dtsi +++ b/arch/arm/dts/socfpga_agilex5.dtsi @@ -544,6 +544,13 @@ status = "disabled"; };
+ sdr: sdr@18000000 { + compatible = "intel,sdr-ctl-agilex5"; + reg = <0x18000000 0x400000>; + resets = <&rst DDRSCH_RESET>; + bootph-all; + }; + /* QSPI address not available yet */ qspi: spi@108d2000 { compatible = "cdns,qspi-nor"; diff --git a/arch/arm/mach-socfpga/include/mach/firewall.h b/arch/arm/mach-socfpga/include/mach/firewall.h index 5cb7f23f8f0..9c3f3313af6 100644 --- a/arch/arm/mach-socfpga/include/mach/firewall.h +++ b/arch/arm/mach-socfpga/include/mach/firewall.h @@ -1,7 +1,6 @@ -/* SPDX-License-Identifier: GPL-2.0 - * - * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> - * +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2017-2024 Intel Corporation <www.intel.com> */
#ifndef _FIREWALL_H_ @@ -126,11 +125,27 @@ struct socfpga_firwall_l4_sys { #define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMITEXT 0x9c #define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMITEXT_FIELD 0xff
+/* Firewall F2SDRAM DDR SCR registers */ +#define FW_F2SDRAM_DDR_SCR_EN 0x00 +#define FW_F2SDRAM_DDR_SCR_EN_SET 0x04 +#define FW_F2SDRAM_DDR_SCR_REGION0ADDR_BASE 0x10 +#define FW_F2SDRAM_DDR_SCR_REGION0ADDR_BASEEXT 0x14 +#define FW_F2SDRAM_DDR_SCR_REGION0ADDR_LIMIT 0x18 +#define FW_F2SDRAM_DDR_SCR_REGION0ADDR_LIMITEXT 0x1c + #define MPUREGION0_ENABLE BIT(0) #define NONMPUREGION0_ENABLE BIT(8)
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +#define FW_MPU_DDR_SCR_WRITEL(data, reg) \ + writel(data, SOCFPGA_FW_DDR_CCU_DMI0_ADDRESS + (reg)); \ + writel(data, SOCFPGA_FW_DDR_CCU_DMI1_ADDRESS + (reg)) +#define FW_F2SDRAM_DDR_SCR_WRITEL(data, reg) \ + writel(data, SOCFPGA_FW_TBU2NOC_ADDRESS + (reg)) +#else #define FW_MPU_DDR_SCR_WRITEL(data, reg) \ writel(data, SOCFPGA_FW_MPU_DDR_SCR_ADDRESS + (reg)) +#endif
void firewall_setup(void);
diff --git a/drivers/ddr/altera/Makefile b/drivers/ddr/altera/Makefile index 9fa5d85a27e..117868b6d01 100644 --- a/drivers/ddr/altera/Makefile +++ b/drivers/ddr/altera/Makefile @@ -12,4 +12,5 @@ obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += sdram_arria10.o obj-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += sdram_soc64.o sdram_s10.o obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += sdram_soc64.o sdram_agilex.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += sdram_soc64.o sdram_n5x.o +obj-$(CONFIG_TARGET_SOCFPGA_AGILEX5) += sdram_soc64.o sdram_agilex5.o iossm_mailbox.o endif diff --git a/drivers/ddr/altera/iossm_mailbox.c b/drivers/ddr/altera/iossm_mailbox.c new file mode 100644 index 00000000000..5e76246dcca --- /dev/null +++ b/drivers/ddr/altera/iossm_mailbox.c @@ -0,0 +1,613 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include <hang.h> +#include <string.h> +#include <wait_bit.h> +#include <asm/arch/base_addr_soc64.h> +#include <asm/io.h> +#include <linux/bitfield.h> +#include "iossm_mailbox.h" + +#define ECC_INTSTATUS_SERR SOCFPGA_SYSMGR_ADDRESS + 0x9C +#define ECC_INISTATUS_DERR SOCFPGA_SYSMGR_ADDRESS + 0xA0 +#define ECC_UNCONRRECTABLE_ERROR_MASK \ + BIT(2) + BIT(3) + BIT(6) + BIT(10) + BIT(12) + BIT(13) +#define DDR_CSR_CLKGEN_LOCKED_IO96B0_MASK BIT(16) +#define DDR_CSR_CLKGEN_LOCKED_IO96B1_MASK BIT(17) + +#define IO96B_MB_REQ_SETUP(v, w, x, y, z) \ + usr_req.ip_type = v; \ + usr_req.ip_id = w; \ + usr_req.usr_cmd_type = x; \ + usr_req.usr_cmd_opcode = y; \ + usr_req.cmd_param[0] = z; \ + for (n = 1; n < NUM_CMD_PARAM; n++) \ + usr_req.cmd_param[n] = 0 +#define MAX_RETRY_COUNT 3 +#define NUM_CMD_RESPONSE_DATA 3 + +#define IO96B0_PLL_A_MASK BIT(0) +#define IO96B0_PLL_B_MASK BIT(1) +#define IO96B1_PLL_A_MASK BIT(2) +#define IO96B1_PLL_B_MASK BIT(3) + +/* supported DDR type list */ +static const char *ddr_type_list[7] = { + "DDR4", "DDR5", "DDR5_RDIMM", "LPDDR4", "LPDDR5", "QDRIV", "UNKNOWN" +}; + +static int is_ddr_csr_clkgen_locked(u8 io96b_pll) +{ + int ret = 0; + const char *pll_names[MAX_IO96B_SUPPORTED][2] = { + {"io96b_0 clkgenA", "io96b_0 clkgenB"}, + {"io96b_1 clkgenA", "io96b_1 clkgenB"} + }; + u32 masks[MAX_IO96B_SUPPORTED][2] = { + {IO96B0_PLL_A_MASK, IO96B0_PLL_B_MASK}, + {IO96B1_PLL_A_MASK, IO96B1_PLL_B_MASK} + }; + u32 lock_masks[MAX_IO96B_SUPPORTED] = { + DDR_CSR_CLKGEN_LOCKED_IO96B0_MASK, + DDR_CSR_CLKGEN_LOCKED_IO96B1_MASK + }; + + for (int i = 0; i < MAX_IO96B_SUPPORTED ; i++) { + /* Check for PLL_A */ + if (io96b_pll & masks[i][0]) { + ret = wait_for_bit_le32((const void *)(ECC_INTSTATUS_SERR), lock_masks[i], + true, TIMEOUT, false); + + if (ret) { + debug("%s: ddr csr %s locked is timeout\n", + __func__, pll_names[i][0]); + goto err; + } else { + debug("%s: ddr csr %s is successfully locked\n", + __func__, pll_names[i][0]); + } + } + + /* Check for PLL_B */ + if (io96b_pll & masks[i][1]) { + ret = wait_for_bit_le32((const void *)(ECC_INISTATUS_DERR), lock_masks[i], + true, TIMEOUT, false); + + if (ret) { + debug("%s: ddr csr %s locked is timeout\n", + __func__, pll_names[i][1]); + goto err; + } else { + debug("%s: ddr csr %s is successfully locked\n", + __func__, pll_names[i][1]); + } + } + } + +err: + return ret; +} + +/* + * Mailbox request function + * This function will send the request to IOSSM mailbox and wait for response return + * + * @io96b_csr_addr: CSR address for the target IO96B + * @req: Structure contain command request for IOSSM mailbox command + * @resp_data_len: User desire extra response data fields other than + * CMD_RESPONSE_DATA_SHORT field on CMD_RESPONSE_STATUS + * @resp: Structure contain responses returned from the requested IOSSM + * mailbox command + */ +int io96b_mb_req(phys_addr_t io96b_csr_addr, struct io96b_mb_req req, + u32 resp_data_len, struct io96b_mb_resp *resp) +{ + int i, ret; + u32 cmd_req; + + if (!resp) { + ret = -EINVAL; + goto err; + } + + /* Zero initialization for responses */ + resp->cmd_resp_status = 0; + + /* Ensure CMD_REQ is cleared before write any command request */ + ret = wait_for_bit_le32((const void *)(io96b_csr_addr + IOSSM_CMD_REQ_OFFSET), + GENMASK(31, 0), false, TIMEOUT, false); + if (ret) { + printf("%s: Timeout of waiting DDR mailbox ready to be functioned!\n", + __func__); + goto err; + } + + /* Write CMD_PARAM_* */ + for (i = 0; i < NUM_CMD_PARAM ; i++) { + switch (i) { + case 0: + if (req.cmd_param[0]) + writel(req.cmd_param[0], io96b_csr_addr + IOSSM_CMD_PARAM_0_OFFSET); + break; + case 1: + if (req.cmd_param[1]) + writel(req.cmd_param[1], io96b_csr_addr + IOSSM_CMD_PARAM_1_OFFSET); + break; + case 2: + if (req.cmd_param[2]) + writel(req.cmd_param[2], io96b_csr_addr + IOSSM_CMD_PARAM_2_OFFSET); + break; + case 3: + if (req.cmd_param[3]) + writel(req.cmd_param[3], io96b_csr_addr + IOSSM_CMD_PARAM_3_OFFSET); + break; + case 4: + if (req.cmd_param[4]) + writel(req.cmd_param[4], io96b_csr_addr + IOSSM_CMD_PARAM_4_OFFSET); + break; + case 5: + if (req.cmd_param[5]) + writel(req.cmd_param[5], io96b_csr_addr + IOSSM_CMD_PARAM_5_OFFSET); + break; + case 6: + if (req.cmd_param[6]) + writel(req.cmd_param[6], io96b_csr_addr + IOSSM_CMD_PARAM_6_OFFSET); + break; + default: + printf("%s: Invalid command parameter\n", __func__); + } + } + + /* Write CMD_REQ (IP_TYPE, IP_INSTANCE_ID, CMD_TYPE and CMD_OPCODE) */ + cmd_req = FIELD_PREP(CMD_TARGET_IP_TYPE_MASK, req.ip_type) | + FIELD_PREP(CMD_TARGET_IP_INSTANCE_ID_MASK, req.ip_id) | + FIELD_PREP(CMD_TYPE_MASK, req.usr_cmd_type) | + FIELD_PREP(CMD_OPCODE_MASK, req.usr_cmd_opcode); + writel(cmd_req, io96b_csr_addr + IOSSM_CMD_REQ_OFFSET); + + debug("%s: Write 0x%x to IOSSM_CMD_REQ_OFFSET 0x%llx\n", __func__, cmd_req, + io96b_csr_addr + IOSSM_CMD_REQ_OFFSET); + + /* Read CMD_RESPONSE_READY in CMD_RESPONSE_STATUS */ + ret = wait_for_bit_le32((const void *)(io96b_csr_addr + IOSSM_CMD_RESPONSE_STATUS_OFFSET), + IOSSM_STATUS_COMMAND_RESPONSE_READY, true, TIMEOUT, false); + + /* read CMD_RESPONSE_STATUS */ + resp->cmd_resp_status = readl(io96b_csr_addr + IOSSM_CMD_RESPONSE_STATUS_OFFSET); + + debug("%s: CMD_RESPONSE_STATUS 0x%llx: 0x%x\n", __func__, io96b_csr_addr + + IOSSM_CMD_RESPONSE_STATUS_OFFSET, resp->cmd_resp_status); + + if (ret) { + printf("%s: CMD_RESPONSE ERROR:\n", __func__); + + printf("%s: STATUS_GENERAL_ERROR: 0x%lx\n", __func__, + IOSSM_STATUS_GENERAL_ERROR(resp->cmd_resp_status)); + printf("%s: STATUS_CMD_RESPONSE_ERROR: 0x%lx\n", __func__, + IOSSM_STATUS_CMD_RESPONSE_ERROR(resp->cmd_resp_status)); + goto err; + } + + /* read CMD_RESPONSE_DATA_* */ + for (i = 0; i < resp_data_len; i++) { + switch (i) { + case 0: + resp->cmd_resp_data[i] = + readl(io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_0_OFFSET); + + debug("%s: IOSSM_CMD_RESPONSE_DATA_0_OFFSET 0x%llx: 0x%x\n", __func__, + io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_0_OFFSET, + resp->cmd_resp_data[i]); + break; + case 1: + resp->cmd_resp_data[i] = + readl(io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_1_OFFSET); + + debug("%s: IOSSM_CMD_RESPONSE_DATA_1_OFFSET 0x%llx: 0x%x\n", __func__, + io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_1_OFFSET, + resp->cmd_resp_data[i]); + break; + case 2: + resp->cmd_resp_data[i] = + readl(io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_2_OFFSET); + + debug("%s: IOSSM_CMD_RESPONSE_DATA_2_OFFSET 0x%llx: 0x%x\n", __func__, + io96b_csr_addr + IOSSM_CMD_RESPONSE_DATA_2_OFFSET, + resp->cmd_resp_data[i]); + break; + default: + resp->cmd_resp_data[i] = 0; + printf("%s: Invalid response data\n", __func__); + } + } + + /* write CMD_RESPONSE_READY = 0 */ + clrbits_le32((u32 *)(uintptr_t)(io96b_csr_addr + IOSSM_CMD_RESPONSE_STATUS_OFFSET), + IOSSM_STATUS_COMMAND_RESPONSE_READY); + + debug("%s: After clear CMD_RESPONSE_READY bit: 0x%llx: 0x%x\n", __func__, + io96b_csr_addr + IOSSM_CMD_RESPONSE_STATUS_OFFSET, + readl(io96b_csr_addr + IOSSM_CMD_RESPONSE_STATUS_OFFSET)); + +err: + return ret; +} + +/* + * Initial function to be called to set memory interface IP type and instance ID + * IP type and instance ID need to be determined before sending mailbox command + */ +void io96b_mb_init(struct io96b_info *io96b_ctrl) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + u8 ip_type_ret, instance_id_ret; + int i, j, k, n, ret; + + debug("%s: num_instance %d\n", __func__, io96b_ctrl->num_instance); + + for (i = 0; i < io96b_ctrl->num_instance; i++) { + debug("%s: get memory interface IO96B %d\n", __func__, i); + + IO96B_MB_REQ_SETUP(0, 0, CMD_GET_SYS_INFO, GET_MEM_INTF_INFO, 0); + + /* Get memory interface IP type and instance ID (IP identifier) */ + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, usr_req, 2, &usr_resp); + if (ret) { + printf("%s: get memory interface IO96B %d failed\n", __func__, i); + hang(); + } + + debug("%s: get response from memory interface IO96B %d\n", __func__, i); + + /* Retrieve number of memory interface(s) */ + io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface = + IOSSM_CMD_RESPONSE_DATA_SHORT(usr_resp.cmd_resp_status) & 0x3; + + debug("%s: IO96B %d: num_mem_interface: 0x%x\n", __func__, i, + io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface); + + /* Retrieve memory interface IP type and instance ID (IP identifier) */ + j = 0; + for (k = 0; k < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; k++) { + ip_type_ret = FIELD_GET(INTF_IP_TYPE_MASK, usr_resp.cmd_resp_data[k]); + instance_id_ret = FIELD_GET(INTF_INSTANCE_ID_MASK, + usr_resp.cmd_resp_data[k]); + + if (ip_type_ret) { + io96b_ctrl->io96b[i].mb_ctrl.ip_type[j] = ip_type_ret; + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j] = instance_id_ret; + + debug("%s: IO96B %d mem_interface %d: ip_type_ret: 0x%x\n", + __func__, i, j, ip_type_ret); + debug("%s: IO96B %d mem_interface %d: instance_id_ret: 0x%x\n", + __func__, i, j, instance_id_ret); + + j++; + } + } + } +} + +int io96b_cal_status(phys_addr_t addr) +{ + u32 cal_success, cal_fail; + phys_addr_t status_addr = addr + IOSSM_STATUS_OFFSET; + u32 start = get_timer(0); + + do { + if (get_timer(start) > TIMEOUT_60000MS) { + printf("%s: SDRAM calibration for IO96B instance 0x%llx timeout!\n", + __func__, status_addr); + hang(); + } + + udelay(1); + schedule(); + + /* Polling until getting any calibration result */ + cal_success = readl(status_addr) & IOSSM_STATUS_CAL_SUCCESS; + cal_fail = readl(status_addr) & IOSSM_STATUS_CAL_FAIL; + } while (!cal_success && !cal_fail); + + debug("%s: Calibration for IO96B instance 0x%llx done at %ld msec!\n", + __func__, status_addr, get_timer(start)); + + if (cal_success && !cal_fail) + return 0; + else + return -EPERM; +} + +void init_mem_cal(struct io96b_info *io96b_ctrl) +{ + int count, i, ret; + + /* Initialize overall calibration status */ + io96b_ctrl->overall_cal_status = false; + + if (io96b_ctrl->ckgen_lock) { + ret = is_ddr_csr_clkgen_locked(io96b_ctrl->io96b_pll); + if (ret) { + printf("%s: iossm IO96B ckgena_lock is not locked\n", __func__); + hang(); + } + } + + /* Check initial calibration status for the assigned IO96B */ + count = 0; + for (i = 0; i < io96b_ctrl->num_instance; i++) { + ret = io96b_cal_status(io96b_ctrl->io96b[i].io96b_csr_addr); + if (ret) { + io96b_ctrl->io96b[i].cal_status = false; + + printf("%s: Initial DDR calibration IO96B_%d failed %d\n", __func__, + i, ret); + + hang(); + } + + io96b_ctrl->io96b[i].cal_status = true; + + printf("%s: Initial DDR calibration IO96B_%d succeed\n", __func__, i); + + count++; + } + + if (count == io96b_ctrl->num_instance) + io96b_ctrl->overall_cal_status = true; +} + +int get_mem_technology(struct io96b_info *io96b_ctrl) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + int i, j, n, ret = 0; + u8 ddr_type_ret; + + /* Initialize ddr type */ + io96b_ctrl->ddr_type = ddr_type_list[6]; + + /* Get and ensure all memory interface(s) same DDR type */ + for (i = 0; i < io96b_ctrl->num_instance; i++) { + for (j = 0; j < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; j++) { + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_GET_MEM_INFO, GET_MEM_TECHNOLOGY, 0); + + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, usr_req, + 0, &usr_resp); + + if (ret) + goto err; + + ddr_type_ret = + IOSSM_CMD_RESPONSE_DATA_SHORT(usr_resp.cmd_resp_status) + & GENMASK(2, 0); + + if (!strcmp(io96b_ctrl->ddr_type, "UNKNOWN")) + io96b_ctrl->ddr_type = ddr_type_list[ddr_type_ret]; + + if (ddr_type_list[ddr_type_ret] != io96b_ctrl->ddr_type) { + printf("%s: Mismatch DDR type on IO96B_%d\n", __func__, i); + + ret = -EINVAL; + goto err; + } + } + } + +err: + return ret; +} + +int get_mem_width_info(struct io96b_info *io96b_ctrl) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + int i, j, n, ret = 0; + u16 memory_size; + u16 total_memory_size = 0; + + /* Get all memory interface(s) total memory size on all instance(s) */ + for (i = 0; i < io96b_ctrl->num_instance; i++) { + memory_size = 0; + for (j = 0; j < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; j++) { + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_GET_MEM_INFO, GET_MEM_WIDTH_INFO, 0); + + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, usr_req, + 2, &usr_resp); + + if (ret) + goto err; + + memory_size = memory_size + + (usr_resp.cmd_resp_data[1] & GENMASK(7, 0)); + } + + if (!memory_size) { + printf("%s: Failed to get valid memory size\n", __func__); + ret = -EINVAL; + goto err; + } + + io96b_ctrl->io96b[i].size = memory_size; + + total_memory_size = total_memory_size + memory_size; + } + + if (!total_memory_size) { + printf("%s: Failed to get valid memory size\n", __func__); + ret = -EINVAL; + } + + io96b_ctrl->overall_size = total_memory_size; + +err: + return ret; +} + +int ecc_enable_status(struct io96b_info *io96b_ctrl) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + int i, j, n, ret = 0; + bool ecc_stat_set = false; + bool ecc_stat; + + /* Initialize ECC status */ + io96b_ctrl->ecc_status = false; + + /* Get and ensure all memory interface(s) same ECC status */ + for (i = 0; i < io96b_ctrl->num_instance; i++) { + for (j = 0; j < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; j++) { + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_TRIG_CONTROLLER_OP, ECC_ENABLE_STATUS, 0); + + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, + usr_req, 0, &usr_resp); + + if (ret) + goto err; + + ecc_stat = (IOSSM_CMD_RESPONSE_DATA_SHORT(usr_resp.cmd_resp_status) + & GENMASK(1, 0)) == 0 ? false : true; + + if (!ecc_stat_set) { + io96b_ctrl->ecc_status = ecc_stat; + ecc_stat_set = true; + } + + if (ecc_stat != io96b_ctrl->ecc_status) { + printf("%s: Mismatch DDR ECC status on IO96B_%d\n", __func__, i); + + ret = -EINVAL; + goto err; + } + } + } + + debug("%s: ECC enable status: %d\n", __func__, io96b_ctrl->ecc_status); + +err: + return ret; +} + +int ecc_interrupt_status(struct io96b_info *io96b_ctrl, bool *ecc_error_flag) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + int i, j, n, ret = 0; + u32 uncorrectable_error; + + for (i = 0; i < io96b_ctrl->num_instance; i++) { + for (j = 0; j < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; j++) { + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_TRIG_CONTROLLER_OP, ECC_INTERRUPT_STATUS, 0); + + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, + usr_req, 1, &usr_resp); + + if (ret) + goto err; + + uncorrectable_error = (usr_resp.cmd_resp_data[0]) & + (ECC_UNCONRRECTABLE_ERROR_MASK); + debug("%s: IO96B %d mem_interface %d: ECC error status:0x%08x\n", + __func__, i, j, uncorrectable_error); + + if (uncorrectable_error) { + *ecc_error_flag = true; + printf("DDR: ECC un-correctable error detected on IO96B_%d\n", + i); + goto err; + } + } + } + + *ecc_error_flag = false; + +err: + return ret; +} + +int bist_mem_init_start(struct io96b_info *io96b_ctrl) +{ + struct io96b_mb_req usr_req; + struct io96b_mb_resp usr_resp; + int i, j, n, ret = 0; + bool bist_start, bist_success; + u32 start; + + /* Full memory initialization BIST performed on all memory interface(s) */ + for (i = 0; i < io96b_ctrl->num_instance; i++) { + for (j = 0; j < io96b_ctrl->io96b[i].mb_ctrl.num_mem_interface; j++) { + bist_start = false; + bist_success = false; + + /* Start memory initialization BIST on full memory address */ + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_TRIG_CONTROLLER_OP, BIST_MEM_INIT_START, + BIST_FULL_MEM); + + ret = io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, + usr_req, 0, &usr_resp); + if (ret) + goto err; + + bist_start = IOSSM_CMD_RESPONSE_DATA_SHORT(usr_resp.cmd_resp_status) + & BIT(0); + + if (!bist_start) { + printf("%s: Failed to initialize memory on IO96B_%d\n", __func__, + i); + printf("%s: BIST_MEM_INIT_START Error code 0x%lx\n", __func__, + IOSSM_STATUS_CMD_RESPONSE_ERROR(usr_resp.cmd_resp_status)); + + ret = -EINVAL; + goto err; + } + + /* Polling for the initiated memory initialization BIST status */ + start = get_timer(0); + while (!bist_success) { + IO96B_MB_REQ_SETUP(io96b_ctrl->io96b[i].mb_ctrl.ip_type[j], + io96b_ctrl->io96b[i].mb_ctrl.ip_id[j], + CMD_TRIG_CONTROLLER_OP, BIST_MEM_INIT_STATUS, 0); + + io96b_mb_req(io96b_ctrl->io96b[i].io96b_csr_addr, usr_req, 0, + &usr_resp); + + bist_success = + IOSSM_CMD_RESPONSE_DATA_SHORT(usr_resp.cmd_resp_status) + & BIT(0); + + if (!bist_success && (get_timer(start) > TIMEOUT)) { + printf("%s: Timeout initialize memory on IO96B_%d\n", + __func__, i); + printf("%s: BIST_MEM_INIT_STATUS Error code 0x%lx\n", + __func__, + IOSSM_STATUS_CMD_RESPONSE_ERROR(usr_resp.cmd_resp_status)); + + ret = -ETIMEDOUT; + goto err; + } + + udelay(1); + } + } + + debug("%s: Memory initialized successfully on IO96B_%d\n", __func__, i); + } + +err: + return ret; +} diff --git a/drivers/ddr/altera/iossm_mailbox.h b/drivers/ddr/altera/iossm_mailbox.h new file mode 100644 index 00000000000..49320f8211b --- /dev/null +++ b/drivers/ddr/altera/iossm_mailbox.h @@ -0,0 +1,186 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#define TIMEOUT_120000MS 120000 +#define TIMEOUT_60000MS 60000 +#define TIMEOUT TIMEOUT_120000MS +#define IOSSM_STATUS_CAL_SUCCESS BIT(0) +#define IOSSM_STATUS_CAL_FAIL BIT(1) +#define IOSSM_STATUS_CAL_BUSY BIT(2) +#define IOSSM_STATUS_COMMAND_RESPONSE_READY BIT(0) +#define IOSSM_CMD_RESPONSE_STATUS_OFFSET 0x45C +#define IOSSM_CMD_RESPONSE_DATA_0_OFFSET 0x458 +#define IOSSM_CMD_RESPONSE_DATA_1_OFFSET 0x454 +#define IOSSM_CMD_RESPONSE_DATA_2_OFFSET 0x450 +#define IOSSM_CMD_REQ_OFFSET 0x43C +#define IOSSM_CMD_PARAM_0_OFFSET 0x438 +#define IOSSM_CMD_PARAM_1_OFFSET 0x434 +#define IOSSM_CMD_PARAM_2_OFFSET 0x430 +#define IOSSM_CMD_PARAM_3_OFFSET 0x42C +#define IOSSM_CMD_PARAM_4_OFFSET 0x428 +#define IOSSM_CMD_PARAM_5_OFFSET 0x424 +#define IOSSM_CMD_PARAM_6_OFFSET 0x420 +#define IOSSM_STATUS_OFFSET 0x400 +#define IOSSM_CMD_RESPONSE_DATA_SHORT_MASK GENMASK(31, 16) +#define IOSSM_CMD_RESPONSE_DATA_SHORT(n) FIELD_GET(IOSSM_CMD_RESPONSE_DATA_SHORT_MASK, n) +#define IOSSM_STATUS_CMD_RESPONSE_ERROR_MASK GENMASK(7, 5) +#define IOSSM_STATUS_CMD_RESPONSE_ERROR(n) FIELD_GET(IOSSM_STATUS_CMD_RESPONSE_ERROR_MASK, n) +#define IOSSM_STATUS_GENERAL_ERROR_MASK GENMASK(4, 1) +#define IOSSM_STATUS_GENERAL_ERROR(n) FIELD_GET(IOSSM_STATUS_GENERAL_ERROR_MASK, n) +#define MAX_IO96B_SUPPORTED 2 +#define NUM_CMD_RESPONSE_DATA 3 +#define NUM_CMD_PARAM 6 + +/* supported mailbox command type */ +enum iossm_mailbox_cmd_type { + CMD_NOP, + CMD_GET_SYS_INFO, + CMD_GET_MEM_INFO, + CMD_GET_MEM_CAL_INFO, + CMD_TRIG_CONTROLLER_OP, + CMD_TRIG_MEM_CAL_OP +}; + +/* supported mailbox command opcode */ +enum iossm_mailbox_cmd_opcode { + GET_MEM_INTF_INFO = 0x0001, + GET_MEM_TECHNOLOGY, + GET_MEMCLK_FREQ_KHZ, + GET_MEM_WIDTH_INFO, + ECC_ENABLE_SET = 0x0101, + ECC_ENABLE_STATUS, + ECC_INTERRUPT_STATUS, + ECC_INTERRUPT_ACK, + ECC_INTERRUPT_MASK, + ECC_WRITEBACK_ENABLE, + ECC_GET_SBE_INFO, + ECC_GET_DBE_INFO, + ECC_INJECT_ERROR, + ECC_SCRUB_IN_PROGRESS_STATUS = 0x0201, + ECC_SCRUB_MODE_0_START, + ECC_SCRUB_MODE_1_START, + BIST_STANDARD_MODE_START = 0x0301, + BIST_RESULTS_STATUS, + BIST_MEM_INIT_START, + BIST_MEM_INIT_STATUS, + BIST_SET_DATA_PATTERN_UPPER, + BIST_SET_DATA_PATTERN_LOWER, + TRIG_MEM_CAL = 0x000a, + GET_MEM_CAL_STATUS +}; + +/* response data of cmd opcode GET_MEM_INTF_INFO */ +#define INTF_IP_TYPE_MASK GENMASK(31, 29) +#define INTF_INSTANCE_ID_MASK GENMASK(28, 24) + +/* response data of cmd opcode GET_MEM_CAL_STATUS */ +#define INTF_UNUSED 0x0 +#define INTF_MEM_CAL_STATUS_SUCCESS 0x1 +#define INTF_MEM_CAL_STATUS_FAIL 0x2 +#define INTF_MEM_CAL_STATUS_ONGOING 0x4 + +/* cmd opcode BIST_MEM_INIT_START, BIST performed on full memory address range */ +#define BIST_FULL_MEM BIT(6) + +/* + * IOSSM mailbox required information + * + * @num_mem_interface: Number of memory interfaces instantiated + * @ip_type: IP type implemented on the IO96B + * @ip_instance_id: IP identifier for every IP instance implemented on the IO96B + */ +struct io96b_mb_ctrl { + u32 num_mem_interface; + u32 ip_type[2]; + u32 ip_id[2]; +}; + +/* CMD_REQ Register Definition */ +#define CMD_TARGET_IP_TYPE_MASK GENMASK(31, 29) +#define CMD_TARGET_IP_INSTANCE_ID_MASK GENMASK(28, 24) +#define CMD_TYPE_MASK GENMASK(23, 16) +#define CMD_OPCODE_MASK GENMASK(15, 0) + +/* + * IOSSM mailbox request + * @ip_type: IP type for the specified memory interface + * @ip_id: IP instance ID for the specified memory interface + * @usr_cmd_type: User desire IOSSM mailbox command type + * @usr_cmd_opcode: User desire IOSSM mailbox command opcode + * @cmd_param_*: Parameters (if applicable) for the requested IOSSM mailbox command + */ +struct io96b_mb_req { + u32 ip_type; + u32 ip_id; + u32 usr_cmd_type; + u32 usr_cmd_opcode; + u32 cmd_param[NUM_CMD_PARAM]; +}; + +/* + * IOSSM mailbox response outputs + * + * @cmd_resp_status: Command Interface status + * @cmd_resp_data_*: More spaces for command response + */ +struct io96b_mb_resp { + u32 cmd_resp_status; + u32 cmd_resp_data[NUM_CMD_RESPONSE_DATA]; +}; + +/* + * IO96B instance specific information + * + * @size: Memory size + * @io96b_csr_addr: IO96B instance CSR address + * @cal_status: IO96B instance calibration status + * @mb_ctrl: IOSSM mailbox required information + */ +struct io96b_instance { + u16 size; + phys_addr_t io96b_csr_addr; + bool cal_status; + struct io96b_mb_ctrl mb_ctrl; +}; + +/* + * Overall IO96B instance(s) information + * + * @num_instance: Number of instance(s) assigned to HPS + * @overall_cal_status: Overall calibration status for all IO96B instance(s) + * @ddr_type: DDR memory type + * @ecc_status: ECC enable status (false = disabled, true = enabled) + * @overall_size: Total DDR memory size + * @io96b[]: IO96B instance specific information + * @ckgen_lock: IO96B GEN PLL lock (false = not locked, true = locked) + * @num_port: Number of IO96B port. + * @io96b_pll: Selected IO96B PLL. Example bit 0: EMIF0 PLL A selected, + * bit 1: EMIF0 PLL B selected, bit 2 - EMIF1 PLL A selected, + * bit 3: EMIF1 PLL B selected + */ +struct io96b_info { + u8 num_instance; + bool overall_cal_status; + const char *ddr_type; + bool ecc_status; + u16 overall_size; + struct io96b_instance io96b[MAX_IO96B_SUPPORTED]; + bool ckgen_lock; + u8 num_port; + u8 io96b_pll; +}; + +int io96b_mb_req(phys_addr_t io96b_csr_addr, struct io96b_mb_req req, + u32 resp_data_len, struct io96b_mb_resp *resp); + +/* Supported IOSSM mailbox function */ +void io96b_mb_init(struct io96b_info *io96b_ctrl); +int io96b_cal_status(phys_addr_t addr); +void init_mem_cal(struct io96b_info *io96b_ctrl); +int get_mem_technology(struct io96b_info *io96b_ctrl); +int get_mem_width_info(struct io96b_info *io96b_ctrl); +int ecc_enable_status(struct io96b_info *io96b_ctrl); +int bist_mem_init_start(struct io96b_info *io96b_ctrl); +int ecc_interrupt_status(struct io96b_info *io96b_ctrl, bool *ecc_error_flag); diff --git a/drivers/ddr/altera/sdram_agilex5.c b/drivers/ddr/altera/sdram_agilex5.c new file mode 100644 index 00000000000..160b945b55f --- /dev/null +++ b/drivers/ddr/altera/sdram_agilex5.c @@ -0,0 +1,377 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include <div64.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <hang.h> +#include <log.h> +#include <ram.h> +#include <reset.h> +#include <wait_bit.h> +#include <wdt.h> +#include <linux/bitfield.h> +#include <linux/sizes.h> +#include <asm/arch/firewall.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include "iossm_mailbox.h" +#include "sdram_soc64.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* MPFE NOC registers */ +#define F2SDRAM_SIDEBAND_FLAGOUTSET0 0x50 +#define F2SDRAM_SIDEBAND_FLAGOUTSTATUS0 0x58 +#define SIDEBANDMGR_FLAGOUTSET0_REG SOCFPGA_F2SDRAM_MGR_ADDRESS +\ + F2SDRAM_SIDEBAND_FLAGOUTSET0 +#define SIDEBANDMGR_FLAGOUTSTATUS0_REG SOCFPGA_F2SDRAM_MGR_ADDRESS +\ + F2SDRAM_SIDEBAND_FLAGOUTSTATUS0 + +#define BOOT_SCRATCH_COLD3_REG (socfpga_get_sysmgr_addr() +\ + SYSMGR_SOC64_BOOT_SCRATCH_COLD3) + +#define PORT_EMIF_CONFIG_OFFSET 4 +#define EMIF_PLL_MASK GENMASK(19, 16) + +#define IO96B0_DUAL_PORT_MASK BIT(0) +#define IO96B0_DUAL_EMIF_MASK BIT(1) + +#define FIREWALL_MPFE_SCR_IO96B0_REG 0x18000d00 +#define FIREWALL_MPFE_SCR_IO96B1_REG 0x18000d04 +#define FIREWALL_MPFE_NOC_CSR_REG 0x18000d08 + +/* Reset type */ +enum reset_type { + POR_RESET, + WARM_RESET, + COLD_RESET, + NCONFIG, + JTAG_CONFIG, + RSU_RECONFIG +}; + +phys_addr_t io96b_csr_reg_addr[] = { + 0x18400000, /* IO96B_0 CSR registers address */ + 0x18800000 /* IO96B_1 CSR registers address */ +}; + +static enum reset_type get_reset_type(u32 reg) +{ + return FIELD_GET(ALT_SYSMGR_SCRATCH_REG_3_DDR_RESET_TYPE_MASK, reg); +} + +static void update_io96b_assigned_to_hps(bool dual_port_flag, bool dual_emif_flag) +{ + clrsetbits_le32(BOOT_SCRATCH_COLD3_REG, + ALT_SYSMGR_SCRATCH_REG_3_DDR_PORT_EMIF_INFO_MASK, + FIELD_PREP(ALT_SYSMGR_SCRATCH_REG_3_DDR_PORT_INFO_MASK, dual_port_flag) | + FIELD_PREP(ALT_SYSMGR_SCRATCH_REG_3_DDR_EMIF_INFO_MASK, dual_emif_flag)); + + debug("%s: update dual port dual emif info: 0x%x\n", __func__, + readl(BOOT_SCRATCH_COLD3_REG)); +} + +static void set_mpfe_config(void) +{ + /* Set mpfe_lite_intfcsel */ + setbits_le32(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_MPFE_CONFIG, BIT(2)); + + /* Set mpfe_lite_active */ + setbits_le32(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_MPFE_CONFIG, BIT(8)); + + debug("%s: mpfe_config: 0x%x\n", __func__, + readl(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_MPFE_CONFIG)); +} + +static bool is_ddr_init_hang(void) +{ + u32 reg = readl(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_POR0); + + debug("%s: 0x%x\n", __func__, reg); + + if (reg & ALT_SYSMGR_SCRATCH_REG_POR_0_DDR_PROGRESS_MASK) + return true; + + return false; +} + +static void ddr_init_inprogress(bool start) +{ + if (start) + setbits_le32(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_POR0, + ALT_SYSMGR_SCRATCH_REG_POR_0_DDR_PROGRESS_MASK); + else + clrbits_le32(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_POR0, + ALT_SYSMGR_SCRATCH_REG_POR_0_DDR_PROGRESS_MASK); +} + +static void populate_ddr_handoff(struct udevice *dev, struct io96b_info *io96b_ctrl) +{ + struct altera_sdram_plat *plat = dev_get_plat(dev); + int i; + u32 len = SOC64_HANDOFF_SDRAM_LEN; + u32 handoff_table[len]; + + /* Read handoff for DDR configuration */ + socfpga_handoff_read((void *)SOC64_HANDOFF_SDRAM, handoff_table, len); + + /* Read handoff - dual port */ + plat->dualport = FIELD_GET(IO96B0_DUAL_PORT_MASK, handoff_table[PORT_EMIF_CONFIG_OFFSET]); + debug("%s: dualport from handoff: 0x%x\n", __func__, plat->dualport); + + if (plat->dualport) + io96b_ctrl->num_port = 2; + else + io96b_ctrl->num_port = 1; + + /* Read handoff - dual EMIF */ + plat->dualemif = FIELD_GET(IO96B0_DUAL_EMIF_MASK, handoff_table[PORT_EMIF_CONFIG_OFFSET]); + debug("%s: dualemif from handoff: 0x%x\n", __func__, plat->dualemif); + + if (plat->dualemif) + io96b_ctrl->num_instance = 2; + else + io96b_ctrl->num_instance = 1; + + io96b_ctrl->io96b_pll = FIELD_GET(EMIF_PLL_MASK, + handoff_table[PORT_EMIF_CONFIG_OFFSET]); + debug("%s: io96b enabled pll from handoff: 0x%x\n", __func__, io96b_ctrl->io96b_pll); + + update_io96b_assigned_to_hps(plat->dualport, plat->dualemif); + + /* Assign IO96B CSR base address if it is valid */ + for (i = 0; i < io96b_ctrl->num_instance; i++) { + io96b_ctrl->io96b[i].io96b_csr_addr = io96b_csr_reg_addr[i]; + debug("%s: IO96B 0x%llx CSR enabled\n", __func__, + io96b_ctrl->io96b[i].io96b_csr_addr); + } +} + +static void config_mpfe_sideband_mgr(struct udevice *dev) +{ + struct altera_sdram_plat *plat = dev_get_plat(dev); + + /* Dual port setting */ + if (plat->dualport) + setbits_le32(SIDEBANDMGR_FLAGOUTSET0_REG, BIT(4)); + + /* Dual EMIF setting */ + if (plat->dualemif) { + set_mpfe_config(); + setbits_le32(SIDEBANDMGR_FLAGOUTSET0_REG, BIT(5)); + } + + debug("%s: SIDEBANDMGR_FLAGOUTSTATUS0: 0x%x\n", __func__, + readl(SIDEBANDMGR_FLAGOUTSTATUS0_REG)); +} + +static void config_ccu_mgr(struct udevice *dev) +{ + int ret = 0; + struct altera_sdram_plat *plat = dev_get_plat(dev); + + if (plat->dualport || plat->dualemif) { + debug("%s: config interleaving on ccu reg\n", __func__); + ret = uclass_get_device_by_name(UCLASS_NOP, + "socfpga-ccu-ddr-interleaving-on", &dev); + } else { + debug("%s: config interleaving off ccu reg\n", __func__); + ret = uclass_get_device_by_name(UCLASS_NOP, + "socfpga-ccu-ddr-interleaving-off", &dev); + } + + if (ret) { + printf("interleaving on/off ccu settings init failed: %d\n", ret); + hang(); + } +} + +static void config_firewall_mpfe_csr(struct udevice *dev) +{ + int ret = 0; + + debug("%s: config Firewall setting for MPFE CSR\n", __func__); + ret = uclass_get_device_by_name(UCLASS_NOP, + "socfpga-noc-fw-mpfe-csr", &dev); + + if (ret) { + printf("Firewall setting for MPFE CSR init failed: %d\n", ret); + hang(); + } +} + +static bool hps_ocram_dbe_status(void) +{ + u32 reg = readl(BOOT_SCRATCH_COLD3_REG); + + if (reg & ALT_SYSMGR_SCRATCH_REG_3_OCRAM_DBE_MASK) + return true; + + return false; +} + +int sdram_mmr_init_full(struct udevice *dev) +{ + int ret = 0; + phys_size_t hw_size; + struct bd_info bd = {0}; + struct altera_sdram_plat *plat = dev_get_plat(dev); + struct altera_sdram_priv *priv = dev_get_priv(dev); + struct io96b_info *io96b_ctrl = malloc(sizeof(*io96b_ctrl)); + + u32 reg = readl(BOOT_SCRATCH_COLD3_REG); + enum reset_type reset_t = get_reset_type(reg); + bool full_mem_init = false; + + /* DDR initialization progress status tracking */ + bool is_ddr_hang_be4_rst = is_ddr_init_hang(); + + debug("DDR: SDRAM init in progress ...\n"); + ddr_init_inprogress(true); + + debug("DDR: Address MPFE 0x%llx\n", plat->mpfe_base_addr); + + /* Populating DDR handoff data */ + debug("DDR: Checking SDRAM configuration in progress ...\n"); + populate_ddr_handoff(dev, io96b_ctrl); + + /* Configuring MPFE sideband manager registers - dual port & dual emif*/ + config_mpfe_sideband_mgr(dev); + + /* Configuring Interleave/Non-interleave ccu registers */ + config_ccu_mgr(dev); + + /* Configure if polling is needed for IO96B GEN PLL locked */ + io96b_ctrl->ckgen_lock = true; + + /* Ensure calibration status passing */ + init_mem_cal(io96b_ctrl); + + printf("DDR: Calibration success\n"); + + /* Initiate IOSSM mailbox */ + io96b_mb_init(io96b_ctrl); + + /* DDR type, DDR size and ECC status) */ + ret = get_mem_technology(io96b_ctrl); + if (ret) { + printf("DDR: Failed to get DDR type\n"); + + goto err; + } + + ret = get_mem_width_info(io96b_ctrl); + if (ret) { + printf("DDR: Failed to get DDR size\n"); + + goto err; + } + + hw_size = (phys_size_t)io96b_ctrl->overall_size * SZ_1G / SZ_8; + + /* Get bank configuration from devicetree */ + ret = fdtdec_decode_ram_size(gd->fdt_blob, NULL, 0, NULL, + (phys_size_t *)&gd->ram_size, &bd); + if (ret) { + puts("DDR: Failed to decode memory node\n"); + ret = -ENXIO; + + goto err; + } + + if (gd->ram_size != hw_size) { + printf("DDR: Warning: DRAM size from device tree (%lld MiB)\n", + gd->ram_size >> 20); + printf(" mismatch with hardware (%lld MiB).\n", + hw_size >> 20); + } + + if (gd->ram_size > hw_size) { + printf("DDR: Error: DRAM size from device tree is greater\n"); + printf(" than hardware size.\n"); + hang(); + } + + printf("%s: %lld MiB\n", io96b_ctrl->ddr_type, gd->ram_size >> 20); + + ret = ecc_enable_status(io96b_ctrl); + if (ret) { + printf("DDR: Failed to get ECC enabled status\n"); + + goto err; + } + + /* Is HPS cold or warm reset? If yes, Skip full memory initialization if ECC + * enabled to preserve memory content + */ + if (io96b_ctrl->ecc_status) { + bool ecc_error_flag; + + ret = ecc_interrupt_status(io96b_ctrl, &ecc_error_flag); + if (ret) { + printf("DDR: Failed to get ECC interrupt status\n"); + + goto err; + } + + if (ecc_error_flag) { + if (CONFIG_IS_ENABLED(WDT)) { + struct udevice *wdt; + + printf("DDR: ECC error recover start now\n"); + ret = uclass_first_device_err(UCLASS_WDT, &wdt); + if (ret) { + printf("DDR: Failed to trigger watchdog reset\n"); + hang(); + } + + wdt_expire_now(wdt, 0); + } + hang(); + } + + full_mem_init = hps_ocram_dbe_status() | is_ddr_hang_be4_rst; + if (full_mem_init || !(reset_t == WARM_RESET || reset_t == COLD_RESET)) { + ret = bist_mem_init_start(io96b_ctrl); + if (ret) { + printf("DDR: Failed to fully initialize DDR memory\n"); + + goto err; + } + } + + printf("SDRAM-ECC: Initialized success\n"); + } + + sdram_size_check(&bd); + printf("DDR: size check success\n"); + + sdram_set_firewall(&bd); + + /* Firewall setting for MPFE CSR */ + config_firewall_mpfe_csr(dev); + + printf("DDR: firewall init success\n"); + + priv->info.base = bd.bi_dram[0].start; + priv->info.size = gd->ram_size; + + /* Ending DDR driver initialization success tracking */ + ddr_init_inprogress(false); + + printf("DDR: init success\n"); + +err: + free(io96b_ctrl); + + return ret; +} diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 9e57c2ecfa4..ce286cc2e76 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -1,7 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2016-2022 Intel Corporation <www.intel.com> - * + * Copyright (C) 2016-2024 Intel Corporation <www.intel.com> */
#include <cpu_func.h> @@ -27,6 +26,7 @@
#define PGTABLE_OFF 0x4000
+#if !IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) u32 hmc_readl(struct altera_sdram_plat *plat, u32 reg) { return readl(plat->iomhc + reg); @@ -98,8 +98,9 @@ int emif_reset(struct altera_sdram_plat *plat) debug("DDR: %s triggered successly\n", __func__); return 0; } +#endif
-#if !IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +#if !(IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) || IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5)) int poll_hmc_clock_status(void) { return wait_for_bit_le32((const void *)(socfpga_get_sysmgr_addr() + @@ -251,7 +252,7 @@ phys_size_t sdram_calculate_size(struct altera_sdram_plat *plat) return size; }
-void sdram_set_firewall(struct bd_info *bd) +static void sdram_set_firewall_non_f2sdram(struct bd_info *bd) { u32 i; phys_size_t value; @@ -287,7 +288,7 @@ void sdram_set_firewall(struct bd_info *bd) FW_MPU_DDR_SCR_NONMPUREGION0ADDR_BASEEXT + (i * 4 * sizeof(u32)));
- /* Setting non-secure MPU limit and limit extexded */ + /* Setting non-secure MPU limit and limit extended */ value = bd->bi_dram[i].start + bd->bi_dram[i].size - 1;
lower = lower_32_bits(value); @@ -300,7 +301,7 @@ void sdram_set_firewall(struct bd_info *bd) FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMITEXT + (i * 4 * sizeof(u32)));
- /* Setting non-secure Non-MPU limit and limit extexded */ + /* Setting non-secure Non-MPU limit and limit extended */ FW_MPU_DDR_SCR_WRITEL(lower, FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMIT + (i * 4 * sizeof(u32))); @@ -313,6 +314,61 @@ void sdram_set_firewall(struct bd_info *bd) } }
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +static void sdram_set_firewall_f2sdram(struct bd_info *bd) +{ + u32 i, lower, upper; + phys_size_t value; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + if (!bd->bi_dram[i].size) + continue; + + value = bd->bi_dram[i].start; + + /* Keep first 1MB of SDRAM memory region as secure region when + * using ATF flow, where the ATF code is located. + */ + if (IS_ENABLED(CONFIG_SPL_ATF) && i == 0) + value += SZ_1M; + + /* Setting base and base extended */ + lower = lower_32_bits(value); + upper = upper_32_bits(value); + FW_F2SDRAM_DDR_SCR_WRITEL(lower, + FW_F2SDRAM_DDR_SCR_REGION0ADDR_BASE + + (i * 4 * sizeof(u32))); + FW_F2SDRAM_DDR_SCR_WRITEL(upper & 0xff, + FW_F2SDRAM_DDR_SCR_REGION0ADDR_BASEEXT + + (i * 4 * sizeof(u32))); + + /* Setting limit and limit extended */ + value = bd->bi_dram[i].start + bd->bi_dram[i].size - 1; + + lower = lower_32_bits(value); + upper = upper_32_bits(value); + + FW_F2SDRAM_DDR_SCR_WRITEL(lower, + FW_F2SDRAM_DDR_SCR_REGION0ADDR_LIMIT + + (i * 4 * sizeof(u32))); + FW_F2SDRAM_DDR_SCR_WRITEL(upper & 0xff, + FW_F2SDRAM_DDR_SCR_REGION0ADDR_LIMITEXT + + (i * 4 * sizeof(u32))); + + FW_F2SDRAM_DDR_SCR_WRITEL(BIT(i), FW_F2SDRAM_DDR_SCR_EN_SET); + } +} +#endif + +void sdram_set_firewall(struct bd_info *bd) +{ + sdram_set_firewall_non_f2sdram(bd); + +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + sdram_set_firewall_f2sdram(bd); +#endif +} + static int altera_sdram_of_to_plat(struct udevice *dev) { struct altera_sdram_plat *plat = dev_get_plat(dev); @@ -321,7 +377,12 @@ static int altera_sdram_of_to_plat(struct udevice *dev) /* These regs info are part of DDR handoff in bitstream */ #if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) return 0; -#endif +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->mpfe_base_addr = addr; +#else
addr = dev_read_addr_index(dev, 0); if (addr == FDT_ADDR_T_NONE) @@ -337,7 +398,7 @@ static int altera_sdram_of_to_plat(struct udevice *dev) if (addr == FDT_ADDR_T_NONE) return -EINVAL; plat->hmc = (void __iomem *)addr; - +#endif return 0; }
@@ -384,6 +445,7 @@ static const struct udevice_id altera_sdram_ids[] = { { .compatible = "altr,sdr-ctl-s10" }, { .compatible = "intel,sdr-ctl-agilex" }, { .compatible = "intel,sdr-ctl-n5x" }, + { .compatible = "intel,sdr-ctl-agilex5" }, { /* sentinel */ } };
diff --git a/drivers/ddr/altera/sdram_soc64.h b/drivers/ddr/altera/sdram_soc64.h index 87a70a861ba..f75a1e47cc3 100644 --- a/drivers/ddr/altera/sdram_soc64.h +++ b/drivers/ddr/altera/sdram_soc64.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> + * Copyright (C) 2017-2024 Intel Corporation <www.intel.com> */
#ifndef _SDRAM_SOC64_H_ @@ -13,11 +13,19 @@ struct altera_sdram_priv { struct reset_ctl_bulk resets; };
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX5) +struct altera_sdram_plat { + fdt_addr_t mpfe_base_addr; + bool dualport; + bool dualemif; +}; +#else struct altera_sdram_plat { void __iomem *hmc; void __iomem *ddr_sch; void __iomem *iomhc; }; +#endif
/* ECC HMC registers */ #define DDRIOCTRL 0x8 @@ -65,6 +73,8 @@ struct altera_sdram_plat { #define CTRLCFG0 0x28 #define CTRLCFG1 0x2c #define CTRLCFG3 0x34 +#define CTRLCFG5 0x3c +#define CTRLCFG6 0x40 #define DRAMTIMING0 0x50 #define CALTIMING0 0x7c #define CALTIMING1 0x80 @@ -79,7 +89,7 @@ struct altera_sdram_plat { #define NIOSRESERVED2 0x118
#define DRAMADDRW_CFG_COL_ADDR_WIDTH(x) \ - (((x) >> 0) & 0x1F) + ((x) & 0x1F) #define DRAMADDRW_CFG_ROW_ADDR_WIDTH(x) \ (((x) >> 5) & 0x1F) #define DRAMADDRW_CFG_BANK_ADDR_WIDTH(x) \ @@ -90,7 +100,7 @@ struct altera_sdram_plat { (((x) >> 16) & 0x7)
#define CTRLCFG0_CFG_MEMTYPE(x) \ - (((x) >> 0) & 0xF) + ((x) & 0xF) #define CTRLCFG0_CFG_DIMM_TYPE(x) \ (((x) >> 4) & 0x7) #define CTRLCFG0_CFG_AC_POS(x) \ @@ -99,17 +109,17 @@ struct altera_sdram_plat { (((x) >> 9) & 0x1F)
#define CTRLCFG1_CFG_DBC3_BURST_LEN(x) \ - (((x) >> 0) & 0x1F) + ((x) & 0x1F) #define CTRLCFG1_CFG_ADDR_ORDER(x) \ (((x) >> 5) & 0x3) #define CTRLCFG1_CFG_CTRL_EN_ECC(x) \ (((x) >> 7) & 0x1)
#define DRAMTIMING0_CFG_TCL(x) \ - (((x) >> 0) & 0x7F) + ((x) & 0x7F)
#define CALTIMING0_CFG_ACT_TO_RDWR(x) \ - (((x) >> 0) & 0x3F) + ((x) & 0x3F) #define CALTIMING0_CFG_ACT_TO_PCH(x) \ (((x) >> 6) & 0x3F) #define CALTIMING0_CFG_ACT_TO_ACT(x) \ @@ -118,7 +128,7 @@ struct altera_sdram_plat { (((x) >> 18) & 0x3F)
#define CALTIMING1_CFG_RD_TO_RD(x) \ - (((x) >> 0) & 0x3F) + ((x) & 0x3F) #define CALTIMING1_CFG_RD_TO_RD_DC(x) \ (((x) >> 6) & 0x3F) #define CALTIMING1_CFG_RD_TO_RD_DB(x) \ @@ -129,7 +139,7 @@ struct altera_sdram_plat { (((x) >> 24) & 0x3F)
#define CALTIMING2_CFG_RD_TO_WR_DB(x) \ - (((x) >> 0) & 0x3F) + ((x) & 0x3F) #define CALTIMING2_CFG_RD_TO_WR_PCH(x) \ (((x) >> 6) & 0x3F) #define CALTIMING2_CFG_RD_AP_TO_VALID(x) \ @@ -140,7 +150,7 @@ struct altera_sdram_plat { (((x) >> 24) & 0x3F)
#define CALTIMING3_CFG_WR_TO_WR_DB(x) \ - (((x) >> 0) & 0x3F) + ((x) & 0x3F) #define CALTIMING3_CFG_WR_TO_RD(x) \ (((x) >> 6) & 0x3F) #define CALTIMING3_CFG_WR_TO_RD_DC(x) \ @@ -151,7 +161,7 @@ struct altera_sdram_plat { (((x) >> 24) & 0x3F)
#define CALTIMING4_CFG_WR_AP_TO_VALID(x) \ - (((x) >> 0) & 0x3F) + ((x) & 0x3F) #define CALTIMING4_CFG_PCH_TO_VALID(x) \ (((x) >> 6) & 0x3F) #define CALTIMING4_CFG_PCH_ALL_TO_VALID(x) \ @@ -162,7 +172,7 @@ struct altera_sdram_plat { (((x) >> 26) & 0x3F)
#define CALTIMING9_CFG_4_ACT_TO_ACT(x) \ - (((x) >> 0) & 0xFF) + ((x) & 0xFF)
/* Firewall DDR scheduler MPFE */ #define FW_HMC_ADAPTOR_REG_ADDR 0xf8020004
Add SPL support for Agilex5 SoCFPGA.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 3 ++ arch/arm/mach-socfpga/spl_agilex5.c | 84 +++++++++++++++++++++++++++++ 2 files changed, 87 insertions(+) create mode 100644 arch/arm/mach-socfpga/spl_agilex5.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 32b3e7a57e2..3fbe3d4fa63 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -66,6 +66,8 @@ obj-y += reset_manager_s10.o obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o obj-y += ccu_ncore3.o +obj-y += system_manager_soc64.o +obj-y += timer_s10.o endif
ifdef CONFIG_TARGET_SOCFPGA_N5X @@ -109,6 +111,7 @@ obj-y += spl_n5x.o endif ifdef CONFIG_TARGET_SOCFPGA_AGILEX5 obj-y += spl_soc64.o +obj-y += spl_agilex5.o endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o diff --git a/arch/arm/mach-socfpga/spl_agilex5.c b/arch/arm/mach-socfpga/spl_agilex5.c new file mode 100644 index 00000000000..2852112f788 --- /dev/null +++ b/arch/arm/mach-socfpga/spl_agilex5.c @@ -0,0 +1,84 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + * + */ + +#include <init.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <hang.h> +#include <spl.h> +#include <asm/arch/base_addr_soc64.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/mailbox_s10.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <wdt.h> +#include <dm/uclass.h> + +DECLARE_GLOBAL_DATA_PTR; + +void board_init_f(ulong dummy) +{ + int ret; + struct udevice *dev; + + ret = spl_early_init(); + if (ret) + hang(); + + socfpga_get_managers_addr(); + + sysmgr_pinmux_init(); + + /* Ensure watchdog is paused when debugging is happening */ + writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, + socfpga_get_sysmgr_addr() + SYSMGR_SOC64_WDDBG); + + timer_init(); + + ret = uclass_get_device(UCLASS_CLK, 0, &dev); + if (ret) { + debug("Clock init failed: %d\n", ret); + hang(); + } + + /* + * Enable watchdog as early as possible before initializing other + * component. Watchdog need to be enabled after clock driver because + * it will retrieve the clock frequency from clock driver. + */ + if (CONFIG_IS_ENABLED(WDT)) + initr_watchdog(); + + preloader_console_init(); + print_reset_info(); + cm_print_clock_quick_summary(); + + ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-ccu-config", &dev); + if (ret) { + printf("HPS CCU settings init failed: %d\n", ret); + hang(); + } + + ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-firewall-config", &dev); + if (ret) { + printf("HPS firewall settings init failed: %d\n", ret); + hang(); + } + + if (IS_ENABLED(CONFIG_SPL_ALTERA_SDRAM)) { + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + hang(); + } + } + + mbox_init(); + + if (IS_ENABLED(CONFIG_CADENCE_QSPI)) + mbox_qspi_open(); +}
Enable XGMAC for SoCFPGA Agilex5 devkit.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- configs/socfpga_agilex5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig index 81bbe967dcf..a4a5064d9c2 100644 --- a/configs/socfpga_agilex5_defconfig +++ b/configs/socfpga_agilex5_defconfig @@ -92,3 +92,4 @@ CONFIG_WDT=y CONFIG_PANIC_HANG=y CONFIG_SPL_CRC32=y # CONFIG_EFI_LOADER is not set +CONFIG_DWC_ETH_XGMAC=y
Add board_boot_order() to retrieve the list of boot devices from spl-boot-order property in device tree. This board_boot_order() would be used for all Intel SOC64 devices.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/spl_soc64.c | 103 ++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+)
diff --git a/arch/arm/mach-socfpga/spl_soc64.c b/arch/arm/mach-socfpga/spl_soc64.c index 3bfe4bb9dd3..9bfa15e9ded 100644 --- a/arch/arm/mach-socfpga/spl_soc64.c +++ b/arch/arm/mach-socfpga/spl_soc64.c @@ -15,6 +15,109 @@ u32 spl_boot_device(void) return BOOT_DEVICE_MMC1; }
+/* This function is to map specified node onto SPL boot devices */ +static int spl_node_to_boot_device(int node) +{ + const void *blob = gd->fdt_blob; + struct udevice *parent; + const char *prop; + + if (!uclass_get_device_by_of_offset(UCLASS_MMC, node, &parent)) + return BOOT_DEVICE_MMC1; + else if (!uclass_get_device_by_of_offset(UCLASS_SPI_FLASH, node, &parent)) + return BOOT_DEVICE_SPI; + else if (!uclass_get_device_by_of_offset(UCLASS_MTD, node, &parent)) + return BOOT_DEVICE_NAND; + + prop = fdt_getprop(blob, node, "device_type", NULL); + if (prop) { + if (!strcmp(prop, "memory")) + return BOOT_DEVICE_RAM; + + printf("%s: unknown device_type %s\n", __func__, prop); + } + + return -ENODEV; +} + +static void default_spl_boot_list(u32 *spl_boot_list, int length) +{ + spl_boot_list[0] = spl_boot_device(); + + if (length > 1) + spl_boot_list[1] = BOOT_DEVICE_SPI; + + if (length > 2) + spl_boot_list[2] = BOOT_DEVICE_NAND; +} + +void board_boot_order(u32 *spl_boot_list) +{ + int idx = 0; + const void *blob = gd->fdt_blob; + int chosen_node = fdt_path_offset(blob, "/chosen"); + const char *conf; + int elem; + int boot_device; + int node; + int length; + + /* expect valid initialized spl_boot_list */ + if (!spl_boot_list) + return; + + length = 1; + while (spl_boot_list[length] == spl_boot_list[length - 1]) + length++; + + debug("%s: chosen_node is %d\n", __func__, chosen_node); + if (chosen_node < 0) { + printf("%s: /chosen not found, using default\n", __func__); + default_spl_boot_list(spl_boot_list, length); + return; + } + + for (elem = 0; + (conf = fdt_stringlist_get(blob, chosen_node, + "u-boot,spl-boot-order", elem, NULL)); + elem++) { + if (idx >= length) { + printf("%s: limit %d to spl_boot_list exceeded\n", __func__, + length); + break; + } + + /* Resolve conf item as a path in device tree */ + node = fdt_path_offset(blob, conf); + if (node < 0) { + debug("%s: could not find %s in FDT\n", __func__, conf); + continue; + } + + /* Try to map spl node back onto SPL boot devices */ + boot_device = spl_node_to_boot_device(node); + if (boot_device < 0) { + debug("%s: could not map node @%x to a boot-device\n", + __func__, node); + continue; + } + + spl_boot_list[idx] = boot_device; + debug("%s: spl_boot_list[%d] = %u\n", __func__, idx, + spl_boot_list[idx]); + idx++; + } + + if (idx == 0) { + if (!conf && !elem) { + printf("%s: spl-boot-order invalid, using default\n", __func__); + default_spl_boot_list(spl_boot_list, length); + } else { + printf("%s: no valid element spl-boot-order list\n", __func__); + } + } +} + #if IS_ENABLED(CONFIG_SPL_MMC) u32 spl_boot_mode(const u32 boot_device) {
From: Alif Zakuan Yuslaimi alif.zakuan.yuslaimi@intel.com
Add the required configuration in the U-Boot env to enable Linux QSPI boot with UBI / UBIFS.
Signed-off-by: Alif Zakuan Yuslaimi alif.zakuan.yuslaimi@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- configs/socfpga_agilex5_defconfig | 1 + include/configs/socfpga_soc64_common.h | 5 +++++ 2 files changed, 6 insertions(+)
diff --git a/configs/socfpga_agilex5_defconfig b/configs/socfpga_agilex5_defconfig index a4a5064d9c2..4ac118f1fec 100644 --- a/configs/socfpga_agilex5_defconfig +++ b/configs/socfpga_agilex5_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_FLASH_MTD=y +CONFIG_SPL_MTD=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x04000000 CONFIG_SPL_ATF=y diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index b7ee1dbf201..7a44f042165 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -56,6 +56,11 @@
#define BOOTENV_DEV_QSPI(devtypeu, devtypel, instance) \ "bootcmd_qspi=ubi detach; sf probe && " \ + "setenv mtdids 'nor0=nor0,nand0=nand.0' && " \ + "setenv mtdparts 'mtdparts=nor0:66m(u-boot),190m(root); " \ + "nand.0:2m(nand_uboot),500m(nand_root)' && " \ + "env select UBI; saveenv && " \ + "ubi part root && " \ "if ubi part root && ubi readvol ${scriptaddr} script; " \ "then echo QSPI: Running script from UBIFS; " \ "elif sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize}; " \
On Fri, 20 Sept 2024 at 09:03, tien.fong.chee@intel.com wrote:
This patch set introduces boot support for the Altera SoCFPGA Agilex 5 platform in U-Boot. The changes include: 1. Board-specific configurations and setup required to enable Agilex 5 operation in U-Boot. 2. Integration of cache coherency unit (CCU) initialization routine, including CCU conguration in DT. 3. Clock, firewall (configured in DT), SMMU, low level initialization specific to Agilex 5. 4. Integration of memory initialization routine, including DDR setup.
This patch set has been tested on Agilex 5 devkit with QSPI boot (UBI/UBIFS) and RAM boot (TFTP & ARM DS debugger).
Alif Zakuan Yuslaimi (1): configs: socfpga: soc64: agilex5: Enable QSPI boot with UBI / UBIFS
Tien Fong Chee (18): arm: socfpga: agilex5: Add new system manager base addresses arm: socfpga: Add support for agilex5 clock manager linker: Add SPL linker script for SoC64 devices arm: socfpga: agilex5: Add low level initialization arm: socfpga: Add handoff data support for SoCFPGA Agilex5 device arm: dts: agilex5: Add HPS cache coherency unit configuration settings arm: dts: agilex5: Add firewall configure settings arm: dts: agilex5: Enable XGMAC sysreset: Add reset support to SoCFPGA Agilex5 device arm: socfpga: agilex5: Enable cache flush for system memory cache in CCU arm: socfpga: agilex5: Add SMMU initialization arm: socfpga: agilex5: Update CPU info arm: socfpga: Export board ID as U-Boot environment variable configs: agilex5: Add configuration for malloc pool arm: socfpga: smc: Add memory coherency support to mailbox command arm: socfpga: agilex5: Add SPL for Agilex5 SoCFPGA configs: socfpga: soc64: agilex5: Enable XGMAC arm: socfpga: soc64: Add support for board_boot_order()
Tingting Meng (1): ddr: altera: Add DDR driver for Agilex5 series
MAINTAINERS | 2 + arch/arm/Kconfig | 1 + arch/arm/dts/socfpga_agilex5-u-boot.dtsi | 660 ++++++++++++++++++ arch/arm/dts/socfpga_agilex5.dtsi | 7 + .../arm/dts/socfpga_agilex5_socdk-u-boot.dtsi | 33 + arch/arm/mach-socfpga/Makefile | 6 + arch/arm/mach-socfpga/ccu_ncore3.c | 64 ++ arch/arm/mach-socfpga/include/mach/firewall.h | 23 +- .../mach-socfpga/include/mach/handoff_soc64.h | 4 +- arch/arm/mach-socfpga/include/mach/misc.h | 1 + .../include/mach/reset_manager_soc64.h | 12 +- .../include/mach/system_manager_soc64.h | 129 ++-- arch/arm/mach-socfpga/lowlevel_init_agilex5.S | 57 ++ arch/arm/mach-socfpga/misc.c | 24 +- arch/arm/mach-socfpga/misc_soc64.c | 12 +- arch/arm/mach-socfpga/smc_api.c | 13 +- arch/arm/mach-socfpga/spl_agilex5.c | 84 +++ arch/arm/mach-socfpga/spl_soc64.c | 120 +++- arch/arm/mach-socfpga/u-boot-spl-soc64.lds | 80 +++ arch/arm/mach-socfpga/wrap_handoff_soc64.c | 10 +- configs/socfpga_agilex5_defconfig | 6 + drivers/ddr/altera/Makefile | 1 + drivers/ddr/altera/iossm_mailbox.c | 613 ++++++++++++++++ drivers/ddr/altera/iossm_mailbox.h | 186 +++++ drivers/ddr/altera/sdram_agilex5.c | 377 ++++++++++ drivers/ddr/altera/sdram_soc64.c | 78 ++- drivers/ddr/altera/sdram_soc64.h | 32 +-
Can we please put RAM drivers in drivers/ram ? Also, do make sure they actually use UCLASS_RAM
drivers/sysreset/Kconfig | 7 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_socfpga_agilex5.c | 47 ++ include/configs/socfpga_soc64_common.h | 5 + 31 files changed, 2605 insertions(+), 90 deletions(-) create mode 100644 arch/arm/mach-socfpga/ccu_ncore3.c create mode 100644 arch/arm/mach-socfpga/lowlevel_init_agilex5.S create mode 100644 arch/arm/mach-socfpga/spl_agilex5.c create mode 100644 arch/arm/mach-socfpga/u-boot-spl-soc64.lds create mode 100644 drivers/ddr/altera/iossm_mailbox.c create mode 100644 drivers/ddr/altera/iossm_mailbox.h create mode 100644 drivers/ddr/altera/sdram_agilex5.c create mode 100644 drivers/sysreset/sysreset_socfpga_agilex5.c
-- 2.25.1
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Friday, September 20, 2024 3:26 PM To: Chee, Tien Fong tien.fong.chee@intel.com Cc: u-boot@lists.denx.de; Marek Vasut marex@denx.de; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Meng, Tingting tingting.meng@intel.com; Yuslaimi, Alif Zakuan alif.zakuan.yuslaimi@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com Subject: Re: [PATCH v1 00/20] SoCFPGA: Add Boot Support for Agilex 5 in U- Boot
The RAM here means for DDR, and UCLASS_RAM is used in DDR driver.
Regards, Tien Fong
Chee, Tien Fong
