[U-Boot-Users] [PATCH] Fix printf errors.
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then corrects the resulting compiler warnings in several files. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments in common/cmd_fdt.c. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones.
I can only compile for ppc architecture so have not tested much of the source code for further warnings.
common/cmd_fdt.c common/common/main.c cpu/mpc85xx/traps.c include/common.h lib_ppc/bootm.c net/tftp.c --- common/cmd_fdt.c | 8 ++++---- common/main.c | 2 +- cpu/mpc85xx/traps.c | 8 ++++---- include/common.h | 15 ++++++++++----- lib_ppc/bootm.c | 8 ++++---- net/tftp.c | 2 +- 6 files changed, 24 insertions(+), 19 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 97b9dd7..d3b19dd 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -451,14 +451,14 @@ static int fdt_valid(void) if (err == -FDT_ERR_BADVERSION) { if (fdt_version(working_fdt) < FDT_FIRST_SUPPORTED_VERSION) { - printf (" - too old, fdt $d < %d", + printf (" - too old, fdt %d < %d", fdt_version(working_fdt), FDT_FIRST_SUPPORTED_VERSION); working_fdt = NULL; } if (fdt_last_comp_version(working_fdt) > FDT_LAST_SUPPORTED_VERSION) { - printf (" - too new, fdt $d > %d", + printf (" - too new, fdt %d > %d", fdt_version(working_fdt), FDT_LAST_SUPPORTED_VERSION); working_fdt = NULL; @@ -546,7 +546,7 @@ static int fdt_parse_prop(char **newval, int count, char *data, int *len) newp = newval[++stridx]; } if (*newp != ']') { - printf("Unexpected character '%c'\n", *newval); + printf("Unexpected character '%c'\n", *newp); return 1; } } else { @@ -763,7 +763,7 @@ static int fdt_print(const char *pathp, char *prop, int depth) } break; case FDT_NOP: - printf("/* NOP */\n", &tabs[MAX_LEVEL - level]); + printf("%s/* NOP */\n", &tabs[MAX_LEVEL - level]); break; case FDT_END: return 1; diff --git a/common/main.c b/common/main.c index 046da6f..79ad291 100644 --- a/common/main.c +++ b/common/main.c @@ -509,7 +509,7 @@ void reset_cmd_timeout(void) */
#define putnstr(str,n) do { \ - printf ("%.*s", n, str); \ + printf ("%.*s", (int)n, str); \ } while (0)
#define CTL_CH(c) ((c) - 'a' + 1) diff --git a/cpu/mpc85xx/traps.c b/cpu/mpc85xx/traps.c index fd36658..0eab694 100644 --- a/cpu/mpc85xx/traps.c +++ b/cpu/mpc85xx/traps.c @@ -216,10 +216,10 @@ MachineCheckException(struct pt_regs *regs)
if (machinecheck_count > 1) { regs->nip += 4; /* skip offending instruction */ - printf("Skipping current instr, Returning to 0x%08x\n", + printf("Skipping current instr, Returning to 0x%08lx\n", regs->nip); } else { - printf("Returning back to 0x%08x\n",regs->nip); + printf("Returning back to 0x%08lx\n",regs->nip); } }
@@ -302,7 +302,7 @@ ExtIntException(struct pt_regs *regs) printf("External Interrupt Exception at PC: %lx, SR: %lx, vector=%lx", regs->nip, regs->msr, regs->trap); vect = pic->iack0; - printf(" irq IACK0@%05x=%d\n",&pic->iack0,vect); + printf(" irq IACK0@%05x=%d\n",(int)&pic->iack0,vect); show_regs(regs); print_backtrace((unsigned long *)regs->gpr[1]); machinecheck_count++; @@ -310,7 +310,7 @@ ExtIntException(struct pt_regs *regs) printf("Returning back to 0x%08x\n",regs->nip); #else regs->nip += 4; /* skip offending instruction */ - printf("Skipping current instr, Returning to 0x%08x\n",regs->nip); + printf("Skipping current instr, Returning to 0x%08lx\n",regs->nip); #endif
} diff --git a/include/common.h b/include/common.h index fd5adb3..51c2be8 100644 --- a/include/common.h +++ b/include/common.h @@ -607,8 +607,10 @@ ulong simple_strtoul(const char *cp,char **endp,unsigned int base); unsigned long long simple_strtoull(const char *cp,char **endp,unsigned int base); #endif long simple_strtol(const char *cp,char **endp,unsigned int base); -void panic(const char *fmt, ...); -int sprintf(char * buf, const char *fmt, ...); +void panic(const char *fmt, ...) + __attribute__ ((format (__printf__, 1, 2))); +int sprintf(char * buf, const char *fmt, ...) + __attribute__ ((format (__printf__, 2, 3))); int vsprintf(char *buf, const char *fmt, va_list args);
/* lib_generic/crc32.c */ @@ -630,7 +632,8 @@ int disable_ctrlc (int); /* 1 to disable, 0 to enable Control-C detect */ */
/* serial stuff */ -void serial_printf (const char *fmt, ...); +void serial_printf (const char *fmt, ...) + __attribute__ ((format (__printf__, 1, 2)));
/* stdin */ int getc(void); @@ -639,7 +642,8 @@ int tstc(void); /* stdout */ void putc(const char c); void puts(const char *s); -void printf(const char *fmt, ...); +void printf(const char *fmt, ...) + __attribute__ ((format (__printf__, 1, 2))); void vprintf(const char *fmt, va_list args);
/* stderr */ @@ -656,7 +660,8 @@ void vprintf(const char *fmt, va_list args); #define stderr 2 #define MAX_FILES 3
-void fprintf(int file, const char *fmt, ...); +void fprintf(int file, const char *fmt, ...) + __attribute__ ((format (__printf__, 2, 3))); void fputs(int file, const char *s); void fputc(int file, const char c); int ftstc(int file); diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 10a0b12..f92f7a8 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -101,7 +101,7 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[],
if (size < bootm_size) { ulong base = bootmap_base + size; - printf("WARNING: adjusting available memory to %x\n", size); + printf("WARNING: adjusting available memory to %lx\n", size); lmb_reserve(lmb, base, bootm_size - size); }
@@ -630,7 +630,7 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], */ fdt_blob = (char *)fdt_addr; debug ("* fdt: raw FDT blob\n"); - printf ("## Flattened Device Tree blob at %08lx\n", fdt_blob); + printf ("## Flattened Device Tree blob at %08lx\n", (long)fdt_blob); } break; default: @@ -638,7 +638,7 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], goto error; }
- printf (" Booting using the fdt blob at 0x%x\n", fdt_blob); + printf (" Booting using the fdt blob at 0x%x\n", (int)fdt_blob);
} else if (images->legacy_hdr_valid && image_check_type (&images->legacy_hdr_os_copy, IH_TYPE_MULTI)) { @@ -657,7 +657,7 @@ static int boot_get_fdt (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], if (fdt_len) {
fdt_blob = (char *)fdt_data; - printf (" Booting using the fdt at 0x%x\n", fdt_blob); + printf (" Booting using the fdt at 0x%x\n", (int)fdt_blob);
if (fdt_check_header (fdt_blob) != 0) { fdt_error ("image is not a fdt"); diff --git a/net/tftp.c b/net/tftp.c index ea8fea2..84d83ca 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -178,7 +178,7 @@ TftpSend (void) pkt += 5 /*strlen("octet")*/ + 1; strcpy ((char *)pkt, "timeout"); pkt += 7 /*strlen("timeout")*/ + 1; - sprintf((char *)pkt, "%d", TIMEOUT); + sprintf((char *)pkt, "%lu", TIMEOUT); #ifdef ET_DEBUG printf("send option "timeout %s"\n", (char *)pkt); #endif
common/cmd_fdt.c
cmd_fdt.c portion... Acked-by: Gerald Van Baren vanbaren@cideas.com
I'm embarrassed by the number of bugs I wrote into that function and apologize for being so sloppy. My thanks to Andrew and others for finding and fixing my screwups. :-(
Best regards, gvb
Very good. Thanks a lot - but could you please add your signed-off-by line, and clean up the commit message (move commnets for the posting that are not intended for the commit message _below_ the "---" line).
Andrew Klossner
Jerry Van Baren
