[U-Boot-Users] [PATCH] CONFIG_ETHxADDR consolidation
Wolfgang,
Here is a patch that basically converts a scattering of
#if (defined CONFIG_PN62) || (defined CONFIG_PPCHAMELEONEVB) || \ (defined CONFIG_MPC8540ADS) || (defined CONFIG_MPC8560ADS) || \ (defined CONFIG_MPC8555CDS)
areas into this:
#if defined(CONFIG_ETH1ADDR)
This affects the files:
common/cmd_bdinfo.c include/asm-ppc/u-boot.h lib_ppc/board.c
and the following boards:
CFG_GT_6426x CONFIG_PN62 CONFIG_PPCHAMELEONEVB CONFIG_SXNI855T (Dave Ellis OK'ed) CONFIG_SVM_SC8xx CONFIG_MPC8540ADS (me) CONFIG_MPC8555CDS (me) CONFIG_MPC8560ADS (me) CONFIG_440_GX (Travis Sawyer OK'ed)
I didn't address the "CONFIG_HAS_ETH1" concept at all here. I don't know the intent of the owner of the PN62, the PPCHAMELEONVB, nor the SC8xx boards, so they may want to either verify these changes or contact me as needed.
Note that this patch affects CONFIG_ETH1ADDR, CONFIG_ETH2ADDR, and CONFIG_ETH3ADDR uniformly.
Thanks, jdl
* Patch by Jon Loeliger, 24-Aug-2004 Made the presence of ethXaddr be dependent on CONFIG_ETHxADDR rather than a collection of board CONFIG_ names.
diff -ruN --exclude=CVS u-boot-public-cvs/u-boot-20040823/common/cmd_bdinfo.c internal-development/u-boot-pq3/common/cmd_bdinfo.c --- u-boot-public-cvs/u-boot-20040823/common/cmd_bdinfo.c 2004-06-08 19:34:47.000000000 -0500 +++ internal-development/u-boot-pq3/common/cmd_bdinfo.c 2004-08-19 14:22:18.000000000 -0500 @@ -79,24 +79,33 @@ #endif print_str ("busfreq", strmhz(buf, bd->bi_busfreq)); #endif /* CONFIG_405GP, CONFIG_405CR, CONFIG_405EP, CONFIG_XILINX_ML300 */ + puts ("ethaddr ="); for (i=0; i<6; ++i) { printf ("%c%02X", i ? ':' : ' ', bd->bi_enetaddr[i]); } -#if (defined CONFIG_PN62) || (defined CONFIG_PPCHAMELEONEVB) || \ - (defined CONFIG_MPC8540ADS) || (defined CONFIG_MPC8560ADS) || \ - (defined CONFIG_MPC8555CDS) + +#if defined(CONFIG_ETH1ADDR) puts ("\neth1addr ="); for (i=0; i<6; ++i) { printf ("%c%02X", i ? ':' : ' ', bd->bi_enet1addr[i]); } -#endif /* CONFIG_PN62 */ -#if defined(CONFIG_MPC8540ADS) || defined(CONFIG_MPC8560ADS) || defined(CONFIG_MPC8555CDS) +#endif + +#if defined(CONFIG_ETH2ADDR) puts ("\neth2addr ="); for (i=0; i<6; ++i) { printf ("%c%02X", i ? ':' : ' ', bd->bi_enet2addr[i]); } #endif + +#if defined(CONFIG_ETH3ADDR) + puts ("\neth3addr ="); + for (i=0; i<6; ++i) { + printf ("%c%02X", i ? ':' : ' ', bd->bi_enet3addr[i]); + } +#endif + #ifdef CONFIG_HERMES print_str ("ethspeed", strmhz(buf, bd->bi_ethspeed)); #endif diff -ruN --exclude=CVS u-boot-public-cvs/u-boot-20040823/include/asm-ppc/u-boot.h internal-development/u-boot-pq3/include/asm-ppc/u-boot.h --- u-boot-public-cvs/u-boot-20040823/include/asm-ppc/u-boot.h 2004-06-08 19:51:51.000000000 -0500 +++ internal-development/u-boot-pq3/include/asm-ppc/u-boot.h 2004-08-19 14:28:54.000000000 -0500 @@ -77,27 +77,19 @@ #if defined(CONFIG_HYMOD) hymod_conf_t bi_hymod_conf; /* hymod configuration information */ #endif -#if defined(CFG_GT_6426x) || \ - defined(CONFIG_PN62) || \ - defined(CONFIG_PPCHAMELEONEVB) || \ - defined(CONFIG_SXNI855T) || \ - defined(CONFIG_SVM_SC8xx) || \ - defined(CONFIG_MPC8540ADS) || \ - defined(CONFIG_MPC8555CDS) || \ - defined(CONFIG_MPC8560ADS) || \ - defined(CONFIG_440_GX) + +#if defined(CONFIG_ETH1ADDR) /* second onboard ethernet port */ unsigned char bi_enet1addr[6]; #endif -#if defined(CFG_GT_6426x) || defined(CONFIG_SVM_SC8xx) || \ - defined(CONFIG_MPC8540ADS) || defined(CONFIG_MPC8560ADS) || \ - defined(CONFIG_MPC8555CDS) || defined(CONFIG_440_GX) +#if defined(CONFIG_ETH2ADDR) /* third onboard ethernet port */ unsigned char bi_enet2addr[6]; #endif -#if defined(CONFIG_440_GX) +#if defined(CONFIG_ETH3ADDR) unsigned char bi_enet3addr[6]; #endif + #if defined(CONFIG_405GP) || defined(CONFIG_405EP) || defined (CONFIG_440_GX) unsigned int bi_opbfreq; /* OPB clock in Hz */ int bi_iic_fast[2]; /* Use fast i2c mode */ diff -ruN --exclude=CVS u-boot-public-cvs/u-boot-20040823/lib_ppc/board.c internal-development/u-boot-pq3/lib_ppc/board.c --- u-boot-public-cvs/u-boot-20040823/lib_ppc/board.c 2004-08-01 17:48:22.000000000 -0500 +++ internal-development/u-boot-pq3/lib_ppc/board.c 2004-08-19 14:31:13.000000000 -0500 @@ -779,9 +779,7 @@ load_sernum_ethaddr (); #endif
-#if defined(CFG_GT_6426x) || defined(CONFIG_PN62) || defined(CONFIG_PPCHAMELEONEVB) || \ - defined(CONFIG_MPC8540ADS) || defined(CONFIG_MPC8555CDS) || \ - defined(CONFIG_MPC8560ADS) || defined(CONFIG_440_GX) +#if defined(CONFIG_ETH1ADDR) /* handle the 2nd ethernet address */
s = getenv ("eth1addr"); @@ -792,9 +790,7 @@ s = (*e) ? e + 1 : e; } #endif -#if defined(CFG_GT_6426x) || defined(CONFIG_MPC8540ADS) || \ - defined(CONFIG_MPC8555CDS) || defined(CONFIG_MPC8560ADS) || \ - defined(CONFIG_440_GX) +#if defined(CONFIG_ETH2ADDR) /* handle the 3rd ethernet address */
s = getenv ("eth2addr"); @@ -810,7 +806,7 @@ } #endif
-#if defined(CONFIG_440_GX) +#if defined(CONFIG_ETH3ADDR) /* handle 4th ethernet address */ s = getenv("eth3addr"); #if defined(CONFIG_XPEDITE1K)
What exactly do you mean? I can see no such define in the whole U-Boot code.
- Patch by Jon Loeliger, 24-Aug-2004 Made the presence of ethXaddr be dependent on CONFIG_ETHxADDR rather than a collection of board CONFIG_ names.
Added, thanks.
Jon Loeliger
