[PATCH] arm64: dts: rockchip: rk3568: Add ODROID-M1 board support
Add ODROID-M1 board support. Board device tree rk3568-odroid-m1.dts from v6.4.
Signed-off-by: Stefan Agner stefan@agner.ch --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi | 29 + arch/arm/dts/rk3568-odroid-m1.dts | 744 ++++++++++++++++++++++ configs/odroid-m1_defconfig | 84 +++ 4 files changed, 858 insertions(+) create mode 100644 arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-odroid-m1.dts create mode 100644 configs/odroid-m1_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60..11028c3a5e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -169,6 +169,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \ rk3566-anbernic-rgxx3.dtb \ rk3566-radxa-cm3-io.dtb \ rk3568-evb.dtb \ + rk3568-odroid-m1.dts \ rk3568-rock-3a.dtb
dtb-$(CONFIG_ROCKCHIP_RK3588) += \ diff --git a/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi b/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi new file mode 100644 index 0000000000..3d75dd403b --- /dev/null +++ b/arch/arm/dts/rk3568-odroid-m1-u-boot.dtsi @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 Rockchip Electronics Co., Ltd + * (C) Copyright 2023 Akash Gajjar gajjar04akash@gmail.com + * (C) Copyright 2023 Stefan Agner stefan@agner.ch + */ + +#include "rk356x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc0; + }; +}; + +&sdmmc0 { + status = "okay"; +}; + +&sdhci { + status = "okay"; +}; + +&uart2 { + clock-frequency = <24000000>; + bootph-all; + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3568-odroid-m1.dts b/arch/arm/dts/rk3568-odroid-m1.dts new file mode 100644 index 0000000000..59ecf868db --- /dev/null +++ b/arch/arm/dts/rk3568-odroid-m1.dts @@ -0,0 +1,744 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Hardkernel Co., Ltd. + * + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3568.dtsi" + +/ { + model = "Hardkernel ODROID-M1"; + compatible = "rockchip,rk3568-odroid-m1", "rockchip,rk3568"; + + aliases { + ethernet0 = &gmac0; + i2c0 = &i2c3; + i2c3 = &i2c0; + mmc0 = &sdhci; + mmc1 = &sdmmc0; + serial0 = &uart1; + serial1 = &uart0; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + dc_12v: dc-12v-regulator { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + hdmi-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_receiver_pin>; + }; + + leds { + compatible = "gpio-leds"; + + led_power: led-0 { + gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_RED>; + default-state = "keep"; + linux,default-trigger = "default-on"; + pinctrl-names = "default"; + pinctrl-0 = <&led_power_pin>; + }; + led_work: led-1 { + gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_HEARTBEAT; + color = <LED_COLOR_ID_BLUE>; + linux,default-trigger = "heartbeat"; + pinctrl-names = "default"; + pinctrl-0 = <&led_work_pin>; + }; + }; + + rk809-sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&hp_det_pin>; + simple-audio-card,name = "Analog RK817"; + simple-audio-card,format = "i2s"; + simple-audio-card,hp-det-gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,widgets = + "Headphone", "Headphones", + "Speaker", "Speaker"; + simple-audio-card,routing = + "Headphones", "HPOL", + "Headphones", "HPOR", + "Speaker", "SPKO"; + + simple-audio-card,cpu { + sound-dai = <&i2s1_8ch>; + }; + + simple-audio-card,codec { + sound-dai = <&rk809>; + }; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_pcie"; + enable-active-high; + gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc3v3_pcie_en_pin>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <5000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_usb_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb_host"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_host_en_pin>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb_otg"; + enable-active-high; + gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_otg_en_pin>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy0 { + /* Used for USB3 */ + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&combphy1 { + /* Used for USB3 */ + phy-supply = <&vcc5v0_usb_otg>; + status = "okay"; +}; + +&combphy2 { + /* used for SATA */ + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gmac0 { + assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; + assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>; + assigned-clock-rates = <0>, <125000000>; + clock_in_out = "output"; + phy-handle = <&rgmii_phy0>; + phy-mode = "rgmii"; + phy-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac0_miim + &gmac0_tx_bus2 + &gmac0_rx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus>; + status = "okay"; + + tx_delay = <0x4f>; + rx_delay = <0x2d>; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vdda0v9_image>; + avdd-1v8-supply = <&vcca1v8_image>; + status = "okay"; +}; + +&hdmi_in { + hdmi_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi>; + }; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + assigned-clocks = <&cru I2S1_MCLKOUT_TX>; + assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; + #clock-cells = <1>; + clock-names = "mclk"; + clocks = <&cru I2S1_MCLKOUT_TX>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>; + rockchip,system-power-controller; + #sound-dai-cells = <0>; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&i2s0_8ch { + status = "okay"; +}; + +&i2s1_8ch { + rockchip,trcm-sync-tx-only; + status = "okay"; +}; + +&mdio0 { + rgmii_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x0>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x2 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_reset_pin>; + reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pinctrl { + fspi { + fspi_dual_io_pins: fspi-dual-io-pins { + rockchip,pins = + /* fspi_clk */ + <1 RK_PD0 1 &pcfg_pull_none>, + /* fspi_cs0n */ + <1 RK_PD3 1 &pcfg_pull_none>, + /* fspi_d0 */ + <1 RK_PD1 1 &pcfg_pull_none>, + /* fspi_d1 */ + <1 RK_PD2 1 &pcfg_pull_none>; + }; + }; + + ir-receiver { + ir_receiver_pin: ir-receiver-pin { + /* external pullup to VCC3V3_SYS */ + rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + led_power_pin: led-power-pin { + rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + led_work_pin: led-work-pin { + rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie_reset_pin: pcie-reset-pin { + rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + vcc3v3_pcie_en_pin: vcc3v3-pcie-en-pin { + rockchip,pins = <4 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rk809 { + hp_det_pin: hp-det-pin { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + vcc5v0_usb_host_en_pin: vcc5v0-usb-host-en-pin { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + vcc5v0_usb_otg_en_pin: vcc5v0-usb-dr-en-pin { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_1v8>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_3v3>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8>; + status = "okay"; +}; + +&sata2 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdmmc0 { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; + sd-uhs-sdr50; + vmmc-supply = <&vcc3v3_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&sfc { + /* Dual I/O mode as the D2 pin conflicts with the eMMC */ + pinctrl-0 = <&fspi_dual_io_pins>; + pinctrl-names = "default"; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <100000000>; + spi-rx-bus-width = <2>; + spi-tx-bus-width = <1>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "SPL"; + reg = <0x0 0xe0000>; + }; + partition@e0000 { + label = "U-Boot Env"; + reg = <0xe0000 0x20000>; + }; + partition@100000 { + label = "U-Boot"; + reg = <0x100000 0x200000>; + }; + partition@300000 { + label = "splash"; + reg = <0x300000 0x100000>; + }; + partition@400000 { + label = "Filesystem"; + reg = <0x400000 0xc00000>; + }; + }; + }; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "host"; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy0_otg { + phy-supply = <&vcc5v0_usb_otg>; + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&usb2phy1_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy1_otg { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi_in_vp0>; + }; +}; diff --git a/configs/odroid-m1_defconfig b/configs/odroid-m1_defconfig new file mode 100644 index 0000000000..c9f0165502 --- /dev/null +++ b/configs/odroid-m1_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3568-odroid-m1" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-odroid-m1.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_ERRNO_STR=y
I sent out a series that add support for ODROID-M1 a few days ago. Please see https://patchwork.ozlabs.org/project/uboot/list/?series=362045
Regards, Jonas
Cool, thanks for the hint! I've checked master branch but not the ML :)
-- Stefan
Regards, Jonas
Jonas Karlman
Stefan Agner
