[PATCH] configs: Orange Pi Win: enable ethernet
Orange Pi Win has gigabit ethernet port, but default U-Boot configuration for that board didn't enable it.
Fix that.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- configs/orangepi_win_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index ad74febe10..7a713ff0e2 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_MACH_SUN50I=y +CONFIG_MACPWR="PD14" CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_SPL_SPI_SUNXI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set @@ -12,6 +13,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_PHY_REALTEK=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y
On Sun, Jan 26, 2020 at 6:09 PM Jernej Skrabec jernej.skrabec@siol.net wrote:
Fix that.
The missing one is ethernet phy not the ethernet since sun8i_emac already enabled? if agree I will update commit message while applying?
Dne nedelja, 26. januar 2020 ob 15:03:55 CET je Jagan Teki napisal(a):
Fix that.
Agreed, thank you.
Best regards, Jernej
On Sun, Jan 26, 2020 at 7:42 PM Jernej Škrabec jernej.skrabec@siol.net wrote:
Fix that.
Agreed, thank you.
Applied to u-boot-sunxi/master
Jagan Teki
Jernej Skrabec
Jernej Škrabec
