[PATCH 1/5] andes: csr.h: Clean up CSR definition
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/include/asm/arch-andes/csr.h | 19 ++++++++----------- 1 file changed, 8 insertions(+), 11 deletions(-)
diff --git a/arch/riscv/include/asm/arch-andes/csr.h b/arch/riscv/include/asm/arch-andes/csr.h index 393d51c6dd..93aa8b2343 100644 --- a/arch/riscv/include/asm/arch-andes/csr.h +++ b/arch/riscv/include/asm/arch-andes/csr.h @@ -15,17 +15,14 @@ #define CSR_MARCHID 0xf12 #define CSR_MCCTLCOMMAND 0x7cc
-#define MCACHE_CTL_IC_EN_OFFSET 0 -#define MCACHE_CTL_DC_EN_OFFSET 1 -#define MCACHE_CTL_CCTL_SUEN_OFFSET 8 -#define MCACHE_CTL_DC_COHEN_OFFSET 19 -#define MCACHE_CTL_DC_COHSTA_OFFSET 20 - -#define MCACHE_CTL_IC_EN BIT(MCACHE_CTL_IC_EN_OFFSET) -#define MCACHE_CTL_DC_EN BIT(MCACHE_CTL_DC_EN_OFFSET) -#define MCACHE_CTL_CCTL_SUEN BIT(MCACHE_CTL_CCTL_SUEN_OFFSET) -#define MCACHE_CTL_DC_COHEN BIT(MCACHE_CTL_DC_COHEN_OFFSET) -#define MCACHE_CTL_DC_COHSTA BIT(MCACHE_CTL_DC_COHSTA_OFFSET) +/* mcache_ctl register */ + +#define MCACHE_CTL_IC_EN BIT(0) +#define MCACHE_CTL_DC_EN BIT(1) +#define MCACHE_CTL_CCTL_SUEN BIT(8) +#define MCACHE_CTL_DC_COHEN BIT(19) +#define MCACHE_CTL_DC_COHSTA BIT(20) +
#define CCTL_L1D_WBINVAL_ALL 6
Kconfig provides SYS_[I|D]CACHE_OFF config options to switch off caches. Implement the corresponding options.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/andesv5/cpu.c | 9 +++++++-- board/AndesTech/ae350/ae350.c | 3 ++- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/cpu/andesv5/cpu.c b/arch/riscv/cpu/andesv5/cpu.c index 63bc24cdfc..50cd31905d 100644 --- a/arch/riscv/cpu/andesv5/cpu.c +++ b/arch/riscv/cpu/andesv5/cpu.c @@ -32,8 +32,13 @@ void harts_early_init(void) if (CONFIG_IS_ENABLED(RISCV_MMODE)) { unsigned long mcache_ctl_val = csr_read(CSR_MCACHE_CTL);
- mcache_ctl_val |= (MCACHE_CTL_DC_COHEN | MCACHE_CTL_IC_EN | - MCACHE_CTL_DC_EN | MCACHE_CTL_CCTL_SUEN); + mcache_ctl_val |= (MCACHE_CTL_DC_COHEN | MCACHE_CTL_CCTL_SUEN | \ + + if (!CONFIG_IS_ENABLED(SYS_ICACHE_OFF)) + mcache_ctl |= MCACHE_CTL_IC_EN; + + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) { + mcache_ctl |= MCACHE_CTL_DC_EN;
csr_write(CSR_MCACHE_CTL, mcache_ctl_val);
diff --git a/board/AndesTech/ae350/ae350.c b/board/AndesTech/ae350/ae350.c index 772c6bf1ee..bef9e3149e 100644 --- a/board/AndesTech/ae350/ae350.c +++ b/board/AndesTech/ae350/ae350.c @@ -102,7 +102,8 @@ void *board_fdt_blob_setup(int *err) void spl_board_init() { /* enable v5l2 cache */ - enable_caches(); + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + enable_caches(); } #endif
Andes CPU has memboost feature including prefetch, write-around and non-blocking load. Enable them by default.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/andesv5/cpu.c | 7 +++++++ arch/riscv/include/asm/arch-andes/csr.h | 6 ++++++ 2 files changed, 13 insertions(+)
diff --git a/arch/riscv/cpu/andesv5/cpu.c b/arch/riscv/cpu/andesv5/cpu.c index 50cd31905d..c9288dcb51 100644 --- a/arch/riscv/cpu/andesv5/cpu.c +++ b/arch/riscv/cpu/andesv5/cpu.c @@ -31,8 +31,11 @@ void harts_early_init(void) /* Enable I/D-cache in SPL */ if (CONFIG_IS_ENABLED(RISCV_MMODE)) { unsigned long mcache_ctl_val = csr_read(CSR_MCACHE_CTL); + unsigned long mmisc_ctl_val = csr_read(CSR_MMISC_CTL);
mcache_ctl_val |= (MCACHE_CTL_DC_COHEN | MCACHE_CTL_CCTL_SUEN | \ + MCACHE_CTL_IC_PREFETCH_EN | MCACHE_CTL_DC_PREFETCH_EN | \ + MCACHE_CTL_DC_WAROUND_EN | MCACHE_CTL_L2C_WAROUND_EN | \
if (!CONFIG_IS_ENABLED(SYS_ICACHE_OFF)) mcache_ctl |= MCACHE_CTL_IC_EN; @@ -51,4 +54,8 @@ void harts_early_init(void) while (!(csr_read(CSR_MCACHE_CTL) & MCACHE_CTL_DC_COHSTA)); } } + mmisc_ctl_val |= MMISC_CTL_NON_BLOCKING_EN; + + csr_write(CSR_MMISC_CTL, mmisc_ctl_val); + } } diff --git a/arch/riscv/include/asm/arch-andes/csr.h b/arch/riscv/include/asm/arch-andes/csr.h index 93aa8b2343..755504c3c4 100644 --- a/arch/riscv/include/asm/arch-andes/csr.h +++ b/arch/riscv/include/asm/arch-andes/csr.h @@ -20,9 +20,15 @@ #define MCACHE_CTL_IC_EN BIT(0) #define MCACHE_CTL_DC_EN BIT(1) #define MCACHE_CTL_CCTL_SUEN BIT(8) +#define MCACHE_CTL_IC_PREFETCH_EN BIT(9) +#define MCACHE_CTL_DC_PREFETCH_EN BIT(10) +#define MCACHE_CTL_DC_WAROUND_EN BIT(13) +#define MCACHE_CTL_L2C_WAROUND_EN BIT(15) #define MCACHE_CTL_DC_COHEN BIT(19) #define MCACHE_CTL_DC_COHSTA BIT(20)
+/* mmisc_ctl register */ +#define MMISC_CTL_NON_BLOCKING_EN BIT(8)
Andes CPU supports cache and TLB ECC. Enable them by default.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/cpu/andesv5/cpu.c | 1 + arch/riscv/include/asm/arch-andes/csr.h | 3 +++ 2 files changed, 4 insertions(+)
diff --git a/arch/riscv/cpu/andesv5/cpu.c b/arch/riscv/cpu/andesv5/cpu.c index c9288dcb51..c011c00a94 100644 --- a/arch/riscv/cpu/andesv5/cpu.c +++ b/arch/riscv/cpu/andesv5/cpu.c @@ -36,6 +36,7 @@ void harts_early_init(void) mcache_ctl_val |= (MCACHE_CTL_DC_COHEN | MCACHE_CTL_CCTL_SUEN | \ MCACHE_CTL_IC_PREFETCH_EN | MCACHE_CTL_DC_PREFETCH_EN | \ MCACHE_CTL_DC_WAROUND_EN | MCACHE_CTL_L2C_WAROUND_EN | \ + MCACHE_CTL_IC_ECCEN | MCACHE_CTL_DC_ECCEN | MCACHE_CTL_TLB_ECCEN);
if (!CONFIG_IS_ENABLED(SYS_ICACHE_OFF)) mcache_ctl |= MCACHE_CTL_IC_EN; diff --git a/arch/riscv/include/asm/arch-andes/csr.h b/arch/riscv/include/asm/arch-andes/csr.h index 755504c3c4..1a34618066 100644 --- a/arch/riscv/include/asm/arch-andes/csr.h +++ b/arch/riscv/include/asm/arch-andes/csr.h @@ -19,11 +19,14 @@
#define MCACHE_CTL_IC_EN BIT(0) #define MCACHE_CTL_DC_EN BIT(1) +#define MCACHE_CTL_IC_ECCEN BIT(3) +#define MCACHE_CTL_DC_ECCEN BIT(5) #define MCACHE_CTL_CCTL_SUEN BIT(8) #define MCACHE_CTL_IC_PREFETCH_EN BIT(9) #define MCACHE_CTL_DC_PREFETCH_EN BIT(10) #define MCACHE_CTL_DC_WAROUND_EN BIT(13) #define MCACHE_CTL_L2C_WAROUND_EN BIT(15) +#define MCACHE_CTL_TLB_ECCEN BIT(18) #define MCACHE_CTL_DC_COHEN BIT(19) #define MCACHE_CTL_DC_COHSTA BIT(20)
Detect CPU name through marchid and then save it to env.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- board/AndesTech/ae350/ae350.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/board/AndesTech/ae350/ae350.c b/board/AndesTech/ae350/ae350.c index bef9e3149e..9faf46d96e 100644 --- a/board/AndesTech/ae350/ae350.c +++ b/board/AndesTech/ae350/ae350.c @@ -28,6 +28,26 @@ DECLARE_GLOBAL_DATA_PTR; * Miscellaneous platform dependent initializations */
+int misc_init_r(void) +{ + long csr_marchid = 0; + const long mask_64 = 0x8000; + const long mask_cpu = 0xff; + char cpu_name[10] = {}; + +#if CONFIG_IS_ENABLED(RISCV_SMODE) + sbi_get_marchid(&csr_marchid); +#elif CONFIG_IS_ENABLED(RISCV_MMODE) + csr_marchid = csr_read(CSR_MARCHID); +#endif + if (mask_64 & csr_marchid) + snprintf(cpu_name, sizeof(cpu_name), "ax%lx", (mask_cpu & csr_marchid)); + else + snprintf(cpu_name, sizeof(cpu_name), "a%lx", (mask_cpu & csr_marchid)); + + return env_set("cpu", cpu_name); +} + #if CONFIG_IS_ENABLED(LOAD_FIT) || CONFIG_IS_ENABLED(LOAD_FIT_FULL) #define ANDES_SPL_FDT_ADDR (CONFIG_TEXT_BASE - 0x100000) void spl_perform_fixups(struct spl_image_info *spl_image)
Leo Yu-Chi Liang
