[PATCH u-boot-marvell] arm: mvebu: turris_{omnia, mox}: ensure running bootcmd_rescue always works
One of the points of putting the rescue boot command into default environment is that user can invoke it without physical access to the board (without having to press the factory reset button), by running run bootcmd_rescue in U-Boot's console.
Therefore we have to ensure that bootcmd_rescue is always set to default value, regardless of whether the factory reset button was pressed. Otherwise the variable will be empty for example after upgrade from previous U-Boot.
Fixes: ec3784d62646 ("arm: mvebu: turris_mox: add support for board rescue mode") Fixes: 176c3e7760a2 ("arm: mvebu: turris_omnia: support invoking rescue boot from console") Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz --- board/CZ.NIC/turris_mox/turris_mox.c | 14 +++++++++++--- board/CZ.NIC/turris_omnia/turris_omnia.c | 13 ++++++++++--- 2 files changed, 21 insertions(+), 6 deletions(-)
diff --git a/board/CZ.NIC/turris_mox/turris_mox.c b/board/CZ.NIC/turris_mox/turris_mox.c index 44c272c7cb..428cd23a19 100644 --- a/board/CZ.NIC/turris_mox/turris_mox.c +++ b/board/CZ.NIC/turris_mox/turris_mox.c @@ -440,10 +440,18 @@ static bool read_reset_button(void)
static void handle_reset_button(void) { + const char * const vars[1] = { "bootcmd_rescue", }; + + /* + * Ensure that bootcmd_rescue has always stock value, so that running + * run bootcmd_rescue + * always works correctly. + */ + env_set_default_vars(1, (char * const *)vars, 0); + if (read_reset_button()) { - const char * const vars[3] = { + const char * const vars[2] = { "bootcmd", - "bootcmd_rescue", "distro_bootcmd", };
@@ -451,7 +459,7 @@ static void handle_reset_button(void) * Set the above envs to their default values, in case the user * managed to break them. */ - env_set_default_vars(3, (char * const *)vars, 0); + env_set_default_vars(2, (char * const *)vars, 0);
/* Ensure bootcmd_rescue is used by distroboot */ env_set("boot_targets", "rescue"); diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index ade923f599..8b2f94f959 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -339,9 +339,17 @@ static int set_regdomain(void)
static void handle_reset_button(void) { + const char * const vars[1] = { "bootcmd_rescue", }; int ret; u8 reset_status;
+ /* + * Ensure that bootcmd_rescue has always stock value, so that running + * run bootcmd_rescue + * always works correctly. + */ + env_set_default_vars(1, (char * const *)vars, 0); + ret = omnia_mcu_read(CMD_GET_RESET, &reset_status, 1); if (ret) { printf("omnia_mcu_read failed: %i, reset status unknown!\n", @@ -352,9 +360,8 @@ static void handle_reset_button(void) env_set_ulong("omnia_reset", reset_status);
if (reset_status) { - const char * const vars[3] = { + const char * const vars[2] = { "bootcmd", - "bootcmd_rescue", "distro_bootcmd", };
@@ -362,7 +369,7 @@ static void handle_reset_button(void) * Set the above envs to their default values, in case the user * managed to break them. */ - env_set_default_vars(3, (char * const *)vars, 0); + env_set_default_vars(2, (char * const *)vars, 0);
Hi Stefan,
Pali discovered this issue with the bootcmd_rescue code for Omnia & MOX. The patch is a therefore a fix. Is is still possible to send this for v2021.07 ? Sorry for the inconvenience.
Marek
Hi Marek,
On 14.06.21 16:49, Marek Behun wrote:
Hi Stefan,
No problem. I'll integrate it soon and will send a new pull request. Should be possible.
Thanks, Stefan
Thanks, Stefan
- const char * const vars[1] = { "bootcmd_rescue", };
- env_set_default_vars(1, (char * const *)vars, 0);
- if (read_reset_button()) {
};"bootcmd_rescue", "distro_bootcmd",
if (reset_status) {
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
if (reset_status) {
Viele Grüße, Stefan
Marek Behun
Marek Behún
Stefan Roese
