[U-Boot] UMS - maintain connection
Hello All,
I am using ums (USB Mass Storage) in u-boot to expose the storage of my device into my host machine. Everything works okay except when the host machine wakeup from the sleep - my device got disconnect from host after it received an resume signal.
I tried the g_mass_storage driver in the kernel and it works fine. It never disconnect when the host machine goes to sleep and wake it up.
Does anyone have encountered the said issue?. How did you fix it?.
Regards,
John
Hi John Tobias,
Hello All,
Frankly speaking, I did not anticipate such test case.
You probably connect to your laptop, which may go sleep?
(For now) no solution... I need to investigate this issue.
Regards,
John
Best regards, Łukasz Majewski
Hi Łukasz Majewski,
On Mon, Aug 15, 2016 at 6:17 AM, Lukasz Majewski l.majewski@majess.pl wrote:
Hi John Tobias,
Hello All,
Yes, that is correct.
Btw, problem happened in iMX6 processor.
Regards,
John
Hi Łukasz Majewski,
I got it working. I may submit a fix soon.
Regards,
John
Hi John Tobias,
Hello All,
Regards,
John
Hi John,
On Wed, Aug 17, 2016 at 5:01 PM, John Tobias john.tobias.ph@gmail.com wrote:
Hi Łukasz Majewski,
Care to submit your fix?
Regards,
Fabio Estevam
Fabio Estevam
John Tobias
Lukasz Majewski
