[U-Boot] Coldfire 5235 flexbus.h
The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with the 5235 processor. The registers in struct fbcs are different sizes from those in the 5235. Also, the defines are a little different.
This is what I have so far. Comments?
--- u-boot-denx/arch/m68k/include/asm/coldfire/flexbus.h 2011-03-02 11:02:14.000000000 -0500 +++ u-boot/include/asm-m68k/coldfire/flexbus.h 2011-02-24 13:40:07.000000000 -0500 @@ -30,6 +30,57 @@ * FlexBus Chip Selects (FBCS) *********************************************************************/
+#ifdef CONFIG_M5235 +typedef struct fbcs { + u16 csar0; /* Chip-select Address */ + u16 res1; + u32 csmr0; /* Chip-select Mask */ + u16 res2; + u16 cscr0; /* Chip-select Control */ + + u16 csar1; + u16 res3; + u32 csmr1; + u16 res4; + u16 cscr1; + + u16 csar2; + u16 res5; + u32 csmr2; + u16 res6; + u16 cscr2; + + u16 csar3; + u16 res7; + u32 csmr3; + u16 res8; + u16 cscr3; + + u16 csar4; + u16 res9; + u32 csmr4; + u16 res10; + u16 cscr4; + + u16 csar5; + u16 res11; + u32 csmr5; + u16 res12; + u16 cscr5; + + u16 csar6; + u16 res13; + u32 csmr6; + u16 res14; + u16 cscr6; + + u16 csar7; + u16 res15; + u32 csmr7; + u16 res16; + u16 cscr7; +} fbcs_t; +#else typedef struct fbcs { u32 csar0; /* Chip-select Address */ u32 csmr0; /* Chip-select Mask */ @@ -56,6 +107,7 @@ u32 csmr7; u32 cscr7; } fbcs_t; +#endif
#define FBCS_CSAR_BA(x) ((x) & 0xFFFF0000)
@@ -94,6 +146,22 @@ #endif #define FBCS_CSMR_V (0x00000001) /* Valid bit */
+#ifdef CONFIG_M5235 +#define FBCS_CSCR_SRWS(x) (((x) & 0x3) << 14) +#define FBCS_CSCR_IWS(x) (((x) & 0xF) << 10) +#define FBCS_CSCR_AA_ON (1 << 8) +#define FBCS_CSCR_AA_OFF (0 << 8) +#define FBCS_CSCR_PS_32 (0 << 6) +#define FBCS_CSCR_PS_16 (2 << 6) +#define FBCS_CSCR_PS_8 (1 << 6) +#define FBCS_CSCR_BEM_ON (1 << 5) +#define FBCS_CSCR_BEM_OFF (0 << 5) +#define FBCS_CSCR_BSTR_ON (1 << 4) +#define FBCS_CSCR_BSTR_OFF (0 << 4) +#define FBCS_CSCR_BSTW_ON (1 << 3) +#define FBCS_CSCR_BSTW_OFF (0 << 3) +#define FBCS_CSCR_SWWS(x) (((x) & 0x7) << 0) +#else #define FBCS_CSCR_SWS(x) (((x) & 0x3F) << 26) #define FBCS_CSCR_SWS_MASK (0x03FFFFFF) #define FBCS_CSCR_SWSEN (0x00800000) @@ -116,5 +184,6 @@ #define FBCS_CSCR_PS_16 (0x00000080) #define FBCS_CSCR_PS_8 (0x00000040) #define FBCS_CSCR_PS_32 (0x00000000) +#endif
#endif /* __FLEXBUS_H */
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Jate Sujjavanich Sent: Thursday, March 03, 2011 2:44 AM To: 'u-boot@lists.denx.de' Subject: [U-Boot] Coldfire 5235 flexbus.h
--- u-boot-denx/arch/m68k/include/asm/coldfire/flexbus.h 2011-03-02 11:02:14.000000000 -0500 +++ u-boot/include/asm-m68k/coldfire/flexbus.h 2011-02-24 13:40:07.000000000 - 0500 @@ -30,6 +30,57 @@
- FlexBus Chip Selects (FBCS)
[snip]
- u16 cscr7;
+} fbcs_t; +#else
There are some different bit definition for the chip select module on all the ColdFire chips but the address is aligned for all the chips. Write to those reserved bit have no effect. Usually these configuration registers were initialized very only and the value write to them are defined by the platform with macro, So please try to hide the bit difference in the platform macro definition.
[snip]
If the bit operation for the chip select module is needed, Please try to define it align with the common fbcs_t structure, Thanks.
Best Regards, Jason
So this simpler patch is appropriate.
--- u-boot-denx/arch/m68k/include/asm/coldfire/flexbus.h 2011-03-02 11:02:14.000000000 -0500 +++ u-boot/include/asm-m68k/coldfire/flexbus.h 2011-03-25 11:42:46.000000000 -0400 @@ -94,6 +94,12 @@ #endif #define FBCS_CSMR_V (0x00000001) /* Valid bit */
+#ifdef CONFIG_M5235 +#define FBCS_CSCR_SRWS(x) (((x) & 0x3) << 14) +#define FBCS_CSCR_IWS(x) (((x) & 0xF) << 10) +#define FBCS_CSCR_SWWS(x) (((x) & 0x7) << 0) +#endif + #define FBCS_CSCR_SWS(x) (((x) & 0x3F) << 26) #define FBCS_CSCR_SWS_MASK (0x03FFFFFF) #define FBCS_CSCR_SWSEN (0x00800000)
-----Original Message----- From: Jin Zhengxiong-R64188 [mailto:R64188@freescale.com] Sent: Tuesday, March 22, 2011 2:52 AM To: Jate Sujjavanich; 'u-boot@lists.denx.de' Subject: RE: Coldfire 5235 flexbus.h
[snip]
- u16 cscr7;
+} fbcs_t; +#else
[snip]
Best Regards, Jason
************************************************************************************ This footnote confirms that this email message has been scanned by PineApp Mail-SeCure for the presence of malicious code, vandals & computer viruses. ************************************************************************************
Dear Jate Sujjavanich,
In message 6C2434209962DC46B88345CA85C334A2A44B0014EF@Courier.syntech.org you wrote:
Please don't top post / full quote. And see http://www.denx.de/wiki/U-Boot/Patches for patch submission rules.
Jate Sujjavanich
Jate Sujjavanich
