[U-Boot] [PATCH V3 1/4] add TI DA8xx support: DA8xx includes
Provides initial support for TI OMAP-L1x/DA8xx SoC devices. See http://www.ti.com
The DA8xx devices are similar to DaVinci devices but have a differing memory map and updated peripheral versions.
Signed-off-by: Nick Thompson nick.thompson@gefanuc.com --- Applies to u-boot-ti
diff --git a/include/asm-arm/arch-davinci/hardware.h b/include/asm-arm/arch-davinci/hardware.h index acf12ea..3071384 100644 --- a/include/asm-arm/arch-davinci/hardware.h +++ b/include/asm-arm/arch-davinci/hardware.h @@ -36,9 +36,10 @@ #include <config.h> #include <asm/sizes.h>
+/* required by davinci drivers */ #define REG(addr) (*(volatile unsigned int *)(addr)) -#define REG_P(addr) ((volatile unsigned int *)(addr))
+/* required by davinci drivers */ typedef volatile unsigned int dv_reg; typedef volatile unsigned int * dv_reg_p;
@@ -49,6 +50,8 @@ typedef volatile unsigned int * dv_reg_p; * on other DaVinci chips. Double check them before you try * using the addresses ... or PSC module identifiers, etc. */ +#ifndef CONFIG_SOC_DA8XX + #define DAVINCI_DMA_3PCC_BASE (0x01c00000) #define DAVINCI_DMA_3PTC0_BASE (0x01c10000) #define DAVINCI_DMA_3PTC1_BASE (0x01c10400) @@ -116,10 +119,61 @@ typedef volatile unsigned int * dv_reg_p;
#endif
+#else /* CONFIG_SOC_DA8XX */ + +#define DAVINCI_UART0_BASE 0x01c42000 +#define DAVINCI_UART1_BASE 0x01d0c000 +#define DAVINCI_UART2_BASE 0x01d0d000 +#define DAVINCI_I2C0_BASE 0x01c22000 +#define DAVINCI_I2C1_BASE 0x01e28000 +#define DAVINCI_TIMER0_BASE 0x01c20000 +#define DAVINCI_TIMER1_BASE 0x01c21000 +#define DAVINCI_WDOG_BASE 0x01c21000 +#define DAVINCI_PLL_CNTRL0_BASE 0x01c11000 +#define DAVINCI_PSC0_BASE 0x01c10000 +#define DAVINCI_PSC1_BASE 0x01e27000 +#define DAVINCI_SPI0_BASE 0x01c41000 +#define DAVINCI_USB_OTG_BASE 0x01e00000 +#define DAVINCI_SPI1_BASE 0x01e12000 +#define DAVINCI_GPIO_BASE 0x01e26000 +#define DAVINCI_EMAC_CNTRL_REGS_BASE 0x01e23000 +#define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE 0x01e22000 +#define DAVINCI_EMAC_WRAPPER_RAM_BASE 0x01e20000 +#define DAVINCI_MDIO_CNTRL_REGS_BASE 0x01e24000 +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x68000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE 0x40000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE 0x60000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE3_BASE 0x62000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE4_BASE 0x64000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE5_BASE 0x66000000 +#define DAVINCI_DDR_EMIF_CTRL_BASE 0xb0000000 +#define DAVINCI_DDR_EMIF_DATA_BASE 0xc0000000 +#define DAVINCI_INTC_BASE 0xfffee000 +#define DAVINCI_BOOTCFG_BASE 0x01c14000 + +#endif /* CONFIG_SOC_DA8XX */ + +#ifdef CONFIG_SOC_DA8XX + +/* Clock IDs */ +#define DAVINCI_PLLM_CLKID (0xFF + 0) +#define DAVINCI_PLLC_CLKID (0xFF + 1) +#define DAVINCI_AUXCLK_CLKID (0xFF + 2) +#define DAVINCI_MDIO_CLKID 4 +#define DAVINCI_SPI0_CLKID 2 +#define DAVINCI_UART2_CLKID 2 +#define DAVINCI_ARM_CLKID 6 + +int clk_get(unsigned int id); + +#endif /* CONFIG_SOC_DA8XX */ + /* Power and Sleep Controller (PSC) Domains */ #define DAVINCI_GPSC_ARMDOMAIN 0 #define DAVINCI_GPSC_DSPDOMAIN 1
+#ifndef CONFIG_SOC_DA8XX + #define DAVINCI_LPSC_VPSSMSTR 0 #define DAVINCI_LPSC_VPSSSLV 1 #define DAVINCI_LPSC_TPCC 2 @@ -166,6 +220,52 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_DM646X_LPSC_UART0 26 #define DAVINCI_DM646X_LPSC_I2C 31
+#else /* CONFIG_SOC_DA8XX */ + +/* LPSCs in PSC0 */ +#define DAVINCI_LPSC_TPCC 0 +#define DAVINCI_LPSC_TPTC0 1 +#define DAVINCI_LPSC_TPTC1 2 +#define DAVINCI_LPSC_AEMIF 3 +#define DAVINCI_LPSC_SPI0 4 +#define DAVINCI_LPSC_MMC_SD 5 +#define DAVINCI_LPSC_AINTC 6 +#define DAVINCI_LPSC_ARM_RAM_ROM 7 +#define DAVINCI_LPSC_SECCTL_KEYMGR 8 +#define DAVINCI_LPSC_UART0 9 +#define DAVINCI_LPSC_SCR0 10 +#define DAVINCI_LPSC_SCR1 11 +#define DAVINCI_LPSC_SCR2 12 +#define DAVINCI_LPSC_DMAX 13 +#define DAVINCI_LPSC_ARM 14 +#define DAVINCI_LPSC_GEM 15 + +/* for LPSCs in PSC1, 32 + actual id is being used for differentiation */ +#define DAVINCI_LPSC_BASE 32 +#define DAVINCI_LPSC_USB11 (DAVINCI_LPSC_BASE + 1) +#define DAVINCI_LPSC_USB20 (DAVINCI_LPSC_BASE + 2) +#define DAVINCI_LPSC_GPIO (DAVINCI_LPSC_BASE + 3) +#define DAVINCI_LPSC_UHPI (DAVINCI_LPSC_BASE + 4) +#define DAVINCI_LPSC_EMAC (DAVINCI_LPSC_BASE + 5) +#define DAVINCI_LPSC_DDR_EMIF (DAVINCI_LPSC_BASE + 6) +#define DAVINCI_LPSC_McASP0 (DAVINCI_LPSC_BASE + 7) +#define DAVINCI_LPSC_McASP1 (DAVINCI_LPSC_BASE + 8) +#define DAVINCI_LPSC_McASP2 (DAVINCI_LPSC_BASE + 9) +#define DAVINCI_LPSC_SPI1 (DAVINCI_LPSC_BASE + 10) +#define DAVINCI_LPSC_I2C1 (DAVINCI_LPSC_BASE + 11) +#define DAVINCI_LPSC_UART1 (DAVINCI_LPSC_BASE + 12) +#define DAVINCI_LPSC_UART2 (DAVINCI_LPSC_BASE + 13) +#define DAVINCI_LPSC_LCDC (DAVINCI_LPSC_BASE + 16) +#define DAVINCI_LPSC_ePWM (DAVINCI_LPSC_BASE + 17) +#define DAVINCI_LPSC_eCAP (DAVINCI_LPSC_BASE + 20) +#define DAVINCI_LPSC_eQEP (DAVINCI_LPSC_BASE + 21) +#define DAVINCI_LPSC_SCR_P0 (DAVINCI_LPSC_BASE + 22) +#define DAVINCI_LPSC_SCR_P1 (DAVINCI_LPSC_BASE + 23) +#define DAVINCI_LPSC_CR_P3 (DAVINCI_LPSC_BASE + 26) +#define DAVINCI_LPSC_L3_CBA_RAM (DAVINCI_LPSC_BASE + 31) + +#endif /* CONFIG_SOC_DA8XX */ + void lpsc_on(unsigned int id); void dsp_on(void);
@@ -174,6 +274,8 @@ void davinci_enable_emac(void); void davinci_enable_i2c(void); void davinci_errata_workarounds(void);
+#ifndef CONFIG_SOC_DA8XX + /* Some PSC defines */ #define PSC_CHP_SHRTSW (0x01c40038) #define PSC_GBLCTL (0x01c41010) @@ -194,6 +296,22 @@ void davinci_errata_workarounds(void);
#define PSC_SILVER_BULLET (0x01c41a20)
+#else /* CONFIG_SOC_DA8XX */ + +#define PSC0_MDCTL (DAVINCI_PSC0_BASE + 0xa00) +#define PSC0_MDSTAT (DAVINCI_PSC0_BASE + 0x800) +#define PSC0_PTCMD (DAVINCI_PSC0_BASE + 0x120) +#define PSC0_PTSTAT (DAVINCI_PSC0_BASE + 0x128) + +#define PSC1_MDCTL (DAVINCI_PSC1_BASE + 0xa00) +#define PSC1_MDSTAT (DAVINCI_PSC1_BASE + 0x800) +#define PSC1_PTCMD (DAVINCI_PSC1_BASE + 0x120) +#define PSC1_PTSTAT (DAVINCI_PSC1_BASE + 0x128) + +#endif /* CONFIG_SOC_DA8XX */ + +#ifndef CONFIG_SOC_DA8XX + /* Miscellania... */ #define VBPR (0x20000020)
@@ -206,4 +324,75 @@ void davinci_errata_workarounds(void); #define PINMUX3 0x01c4000c #define PINMUX4 0x01c40010
+#endif /* CONFIG_SOC_DA8XX */ + +#ifdef CONFIG_SOC_DA8XX + +/* Some PLL defines */ +#define PLL0_PLLCTL (DAVINCI_PLL_CNTRL0_BASE + 0x100) +#define PLL0_PLLM (DAVINCI_PLL_CNTRL0_BASE + 0x110) +#define PLL0_PREDIV (DAVINCI_PLL_CNTRL0_BASE + 0x114) +#define PLL0_POSTDIV (DAVINCI_PLL_CNTRL0_BASE + 0x128) +#define PLL0_DIV1 (DAVINCI_PLL_CNTRL0_BASE + 0x118) +#define PLL0_DIV2 (DAVINCI_PLL_CNTRL0_BASE + 0x11c) +#define PLL0_DIV3 (DAVINCI_PLL_CNTRL0_BASE + 0x120) +#define PLL0_DIV4 (DAVINCI_PLL_CNTRL0_BASE + 0x160) +#define PLL0_DIV5 (DAVINCI_PLL_CNTRL0_BASE + 0x164) +#define PLL0_DIV6 (DAVINCI_PLL_CNTRL0_BASE + 0x168) +#define PLL0_DIV7 (DAVINCI_PLL_CNTRL0_BASE + 0x16c) +#define PLL0_DIV8 (DAVINCI_PLL_CNTRL0_BASE + 0x170) +#define PLL0_DIV9 (DAVINCI_PLL_CNTRL0_BASE + 0x114) + +/* Boot config */ +#define PINMUX0 (DAVINCI_BOOTCFG_BASE + 0x120) +#define PINMUX1 (DAVINCI_BOOTCFG_BASE + 0x124) +#define PINMUX2 (DAVINCI_BOOTCFG_BASE + 0x128) +#define PINMUX3 (DAVINCI_BOOTCFG_BASE + 0x12c) +#define PINMUX4 (DAVINCI_BOOTCFG_BASE + 0x130) +#define PINMUX5 (DAVINCI_BOOTCFG_BASE + 0x134) +#define PINMUX6 (DAVINCI_BOOTCFG_BASE + 0x138) +#define PINMUX7 (DAVINCI_BOOTCFG_BASE + 0x13c) +#define PINMUX8 (DAVINCI_BOOTCFG_BASE + 0x140) +#define PINMUX9 (DAVINCI_BOOTCFG_BASE + 0x144) +#define PINMUX10 (DAVINCI_BOOTCFG_BASE + 0x148) +#define PINMUX11 (DAVINCI_BOOTCFG_BASE + 0x14c) +#define PINMUX12 (DAVINCI_BOOTCFG_BASE + 0x150) +#define PINMUX13 (DAVINCI_BOOTCFG_BASE + 0x154) +#define PINMUX14 (DAVINCI_BOOTCFG_BASE + 0x158) +#define PINMUX15 (DAVINCI_BOOTCFG_BASE + 0x15C) +#define PINMUX16 (DAVINCI_BOOTCFG_BASE + 0x160) +#define PINMUX17 (DAVINCI_BOOTCFG_BASE + 0x164) +#define PINMUX18 (DAVINCI_BOOTCFG_BASE + 0x168) +#define PINMUX19 (DAVINCI_BOOTCFG_BASE + 0x16c) +#define SUSPSRC (DAVINCI_BOOTCFG_BASE + 0x170) +#define CFGCHIP0 (DAVINCI_BOOTCFG_BASE + 0x17c) +#define CFGCHIP2 (DAVINCI_BOOTCFG_BASE + 0x184) + +/* Interrupt controller */ +#define INTC_GLB_EN (DAVINCI_INTC_BASE + 0x10) +#define INTC_HINT_EN (DAVINCI_INTC_BASE + 0x1500) +#define INTC_EN_CLR0 (DAVINCI_INTC_BASE + 0x380) + +/* GPIO */ +#define GPIO_BANK4_ADDR 0x01E26000 +#define GPIO_BANK4_REG_DIR_ADDR (GPIO_BANK4_ADDR + 0x60) +#define GPIO_BANK4_REG_OPDATA_ADDR (GPIO_BANK4_ADDR + 0x64) +#define GPIO_BANK4_REG_SET_ADDR (GPIO_BANK4_ADDR + 0x68) +#define GPIO_BANK4_REG_CLR_ADDR (GPIO_BANK4_ADDR + 0x6C) + +/* Emulation suspend bits */ +#define SUSPSRC_EMAC (1 << 5) +#define SUSPSRC_I2C (1 << 16) +#define SUSPSRC_SPI0 (1 << 21) +#define SUSPSRC_UART2 (1 << 20) +#define SUSPSRC_TIMER0 (1 << 27) + +/* UART PWREMU_MGMT definitions */ +#define PWREMU_MGMT_BASE (0x30) +#define PWREMU_MGMT_FREE (1 << 0) +#define PWREMU_MGMT_URRST (1 << 13) +#define PWREMU_MGMT_UTRST (1 << 14) + +#endif /* CONFIG_SOC_DA8XX */ + #endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/include/asm-arm/arch-davinci/i2c_defs.h b/include/asm-arm/arch-davinci/i2c_defs.h index 2e902e1..0655d89 100644 --- a/include/asm-arm/arch-davinci/i2c_defs.h +++ b/include/asm-arm/arch-davinci/i2c_defs.h @@ -28,7 +28,11 @@ #define I2C_WRITE 0 #define I2C_READ 1
+#ifndef CONFIG_SOC_DA8XX #define I2C_BASE 0x01c21000 +#else +#define I2C_BASE 0x01c22000 +#endif
#define I2C_OA (I2C_BASE + 0x00) #define I2C_IE (I2C_BASE + 0x04) @@ -88,6 +92,9 @@ #define I2C_CON_XA (1 << 8) /* Expand address */ #define I2C_CON_STP (1 << 11) /* Stop condition (master mode only) */ #define I2C_CON_STT (1 << 13) /* Start condition (master mode only) */ +#ifdef CONFIG_SOC_DA8XX +#define I2C_CON_FREE (1 << 14) /* Free run on emulation */ +#endif
#define I2C_TIMEOUT 0xffff0000 /* Timeout mask for poll_i2c_irq() */
diff --git a/include/common.h b/include/common.h index f7c93bf..39765e6 100644 --- a/include/common.h +++ b/include/common.h @@ -107,6 +107,9 @@ typedef volatile unsigned char vu_char; #ifdef CONFIG_BLACKFIN #include <asm/blackfin.h> #endif +#ifdef CONFIG_SOC_DA8XX +#include <asm/arch/hardware.h> +#endif
#include <part.h> #include <flash.h> diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h new file mode 100644 index 0000000..2a2cd20 --- /dev/null +++ b/include/configs/da830evm.h @@ -0,0 +1,244 @@ +/* + * Copyright (C) 2008 Texas Instruments, Inc <www.ti.com> + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Board + */ + +/* + * SoC Configuration + */ +#define CONFIG_MACH_DAVINCI_DA830_EVM +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT /* to a proper address, init done */ + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* SDRAM size 64MB */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start addr */ +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) /* 16MB test */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * I2C Configuration + */ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 25000 /* 100Kbps won't work, H/W bug */ +#define CONFIG_SYS_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */ + +/* + * I2C EEPROM definitions for catalyst 24W256 EEPROM chip + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 + +/* + * Network & Ethernet Configuration + */ +#ifdef CONFIG_DRIVER_TI_EMAC +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#endif + +/* + * Flash & Environment + */ +#ifdef CONFIG_USE_NAND +#undef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ +#define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_SYS_CLE_MASK 0x10 +#define CONFIG_SYS_ALE_MASK 0x8 +#define CONFIG_SYS_NAND_HW_ECC +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_MAX_CHIPS 1 +#define DEF_BOOTM "" +#endif + +#ifdef CONFIG_USE_NOR +#define CONFIG_ENV_IS_IN_FLASH +#undef CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of flash banks */ +#define CONFIG_SYS_FLASH_SECT_SZ (64 << 10) /* 64KB */ +#define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_SECT_SZ*3) +#define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE +#define PHYS_FLASH_SIZE (32 << 20) /* Flash size 32MB */ +#define CONFIG_SYS_MAX_FLASH_SECT (PHYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ) +#define CONFIG_ENV_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ +#define CONFIG_SYS_FLASH_SPL_ACCESS +#endif + +#ifdef CONFIG_USE_SPIFLASH +#undef CONFIG_ENV_IS_IN_FLASH +#undef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE (16 << 10) +#define CONFIG_ENV_OFFSET (256 << 10) +#define CONFIG_ENV_SECT_SIZE 4096 +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_DAVINCI_SPI +#define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE +#define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define CONFIG_SYS_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + + +/* + * U-Boot general configuration + */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#undef CONFIG_MISC_INIT_R +#undef CONFIG_BOOTDELAY +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "DA830-evm > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_MEMTEST_START + 0x700000) +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE /* Won't work with hush so far, may be later */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "mem=32M console=ttyS2,115200n8 root=/dev/mtdblock/2 rw noinitrd ip=dhcp" +#define CONFIG_BOOTCOMMAND "" +#define CONFIG_BOOTDELAY 3 + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#define CONFIG_CMD_EEPROM + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +#ifdef CONFIG_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#endif + +#ifdef CONFIG_USE_SPIFLASH +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SAVEENV +#endif + +#if !defined(CONFIG_USE_NAND) && \ + !defined(CONFIG_USE_NOR) && \ + !defined(CONFIG_USE_SPIFLASH) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_SIZE (16 << 10) +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_ENV +#endif + +#ifdef CONFIG_USB_DA8XX +#define CONFIG_CMD_USB /* include support for usb */ +#define CONFIG_CMD_STORAGE /* include support for usb */ +#define CONFIG_CMD_FAT /* include support for FAT/storage*/ +#define CONFIG_DOS_PARTITION /* include support for FAT/storage*/ +#endif + +#endif /* __CONFIG_H */
diff --git a/include/asm-arm/arch-davinci/hardware.h b/include/asm- arm/arch-davinci/hardware.h index acf12ea..3071384 100644 --- a/include/asm-arm/arch-davinci/hardware.h +++ b/include/asm-arm/arch-davinci/hardware.h @@ -36,9 +36,10 @@ #include <config.h> #include <asm/sizes.h>
- on other DaVinci chips. Double check them before you try
- using the addresses ... or PSC module identifiers, etc.
#endif
Is this not generating a compilation warning as you will be redefining PINMUX 0 to 5
There is a gpio_regs.h header file in /include/asm-arm/arch-davinci
#endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/include/asm-arm/arch-davinci/i2c_defs.h b/include/asm- arm/arch-davinci/i2c_defs.h index 2e902e1..0655d89 100644 --- a/include/asm-arm/arch-davinci/i2c_defs.h +++ b/include/asm-arm/arch-davinci/i2c_defs.h @@ -28,7 +28,11 @@ #define I2C_WRITE 0 #define I2C_READ 1
- Copyright (C) 2008 Texas Instruments, Inc <www.ti.com>
- Based on davinci_dvevm.h. Original Copyrights follow:
- Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net
- MA 02111-1307 USA
- Board
- SoC Configuration
- Memory Info
- Serial Driver info
- I2C Configuration
- I2C EEPROM definitions for catalyst 24W256 EEPROM chip
- Network & Ethernet Configuration
- Flash & Environment
- U-Boot general configuration
- Linux Information
- U-Boot commands
The issue with this patch is that, you are adding the config file which is definitely DA830 EVM specific.
The other stuff is all DA8xx SOC specific.
Wait for sometime before submitting the next set of patches. I am sure there will be other comments for your other patches.
Sandeep
Dear Nick Thompson,
Is this really an essential comment? Drop it!
Ditto.
I think you actually want to use a C struct here, like in many other places.
Please do not access device registers using plain pointers like (base address plus offet), but always use I/O accessors with C structs, so we can have strict type checking by the compiler.
One C struct with a pointer to it?
C struct!
C struct!
And so on. Please fix globally, also in the other patches.
- Memory Info
Please consider using get_ram_size() instead.
- U-Boot commands
Why?
Wolfgang Denk wrote:
Dear Nick Thompson,
Ditto.
As I mentioned in the patch introduction "[PATCH V3 0/4]..." there are several places where out of fashion code is present in these patches.
DA8xx SoC's are considered a member of the DaVinci family of SoC's and so these headers need to maintain compatibility with the relevant drivers already in the U-Boot git tree.
Those drivers do not use C structures and I/O accessors and so require the use of #defines as presented here.
Where possible I have not used legacy code forms in new code, but in the case of new code that also has to use these same registers, I have again opted for compatibility.
Of course I could duplicate the definitions as defines /and/ C structs, or even rewrite all the DaVinci family drivers, but I'm hoping neither of those options was the intention of your comments here.
Can you please confirm whether my assumptions as correct and acceptable in this case? I.e. (as Tom Rix put it) Can I get a pass on this one?
I think you have a point in the PINMUX cases below however, as I believe these #defines are only used in SoC specific code...
Best Regards, Nick
C struct!
C struct!
- Memory Info
- U-Boot commands
Why?
Dear Nick Thompson,
Ditto.
Best Regards, Nick
There are a large number of #define's in davinci that could be converted to structures. My opinion is that da8xx sharing code with davinci is a big enough change. The reworking of basic davici register calling through structs falls outside of what I expect.
The cleanup on the calling I am looking for is switching for direct access to registers to calling them through readl/writel.
Tom
Nick Thompson
Paulraj, Sandeep
Tom
