[U-Boot] [PATCH v1 0/1] Factorize ARM startup code as mush as possible.
File crt0.S is introduced which contains the C runtime framework, that is, the assembly code responsible for setting up the C environments needed by board_init_*() and relocate_code(). Corresponding code is removed from all start.S files in arch/arm.
This precedes further factorization, e.g. relocate_code() and possibly also the exception handlers.
This has the nice side effect of turning board_init_*() and relocate_code() into normal C functions, too.
Albert ARIBAUD (1): arm: move generic startup code in crt0.S
arch/arm/cpu/arm1136/start.S | 62 ++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 179 +++++++++++++++++++++++++++++ include/common.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 20 files changed, 322 insertions(+), 673 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- arch/arm/cpu/arm1136/start.S | 62 ++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 179 +++++++++++++++++++++++++++++ include/common.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 20 files changed, 322 insertions(+), 673 deletions(-) create mode 100644 arch/arm/lib/crt0.S
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 3752af9..fb1fcab 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -161,13 +161,7 @@ next: bl cpu_init_crit #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - - bl board_init_f + bl _main
@@ -184,14 +178,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -243,48 +233,9 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif /* #ifndef CONFIG_SPL_BUILD */ - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 +relocate_done:
-_nand_boot_ofs: - .word nand_boot -#else -jump_2_ram: - ldr r0, _board_init_r_ofs - ldr r1, _TEXT_BASE - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -293,6 +244,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 667a0e0..40df4b1 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -224,12 +224,7 @@ skip_tcmdisable: */ bl lowlevel_init /* go setup pll,mux,memory */
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -246,14 +241,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -343,49 +334,9 @@ mmu_enable: skip_hw_init: #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#ifndef CONFIG_NAND_SPL - bl coloured_LED_init - bl red_led_on -#endif -#endif +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr pc, _nand_boot - -_nand_boot: .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -399,6 +350,11 @@ _mmu_table_base: .word mmu_table #endif
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + #ifndef CONFIG_NAND_SPL /* * we assume that cache operation is done before. (eg. cleanup_before_linux()) diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index c2a7763..771d386 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -147,12 +147,7 @@ reset: bl cpu_init_crit #endif
@@ -169,14 +164,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -228,43 +219,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: - - bl coloured_LED_init - bl red_led_on -#endif +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -272,6 +230,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 14c9156..511d21d 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -182,12 +182,7 @@ copyex: bl cpu_init_crit #endif
@@ -204,14 +199,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -263,51 +254,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: - - bl coloured_LED_init - bl red_led_on -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 +relocate_done:
-_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -315,6 +265,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 3a483f6..82f5b8b 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -176,12 +176,7 @@ poll1: bl cpu_init_crit #endif
@@ -198,14 +193,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -257,51 +248,10 @@ fixnext: blo fixloop #endif
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -309,6 +259,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 2188f7e..5dfd49a 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -198,20 +198,7 @@ reset: bl cpu_init_crit #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: -#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) -#else -#ifdef CONFIG_SPL_BUILD - ldr sp, =(CONFIG_SPL_STACK) -#else - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) -#endif -#endif - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -229,15 +216,11 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start sub r9, r6, r0 /* r9 <- relocation offset */ cmp r0, r6 - moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + moveq r9, #0 /* no relocation. offset(r9) = 0 */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -289,56 +272,9 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifdef CONFIG_SPL_BUILD - /* No relocation for SPL */ - ldr r0, =__bss_start - ldr r1, =__bss_end__ -#else - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 -#endif - mov r2, #0x00000000 /* clear */ +relocate_done:
-clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: - -#ifndef CONFIG_SPL_BUILD - bl coloured_LED_init - bl red_led_on -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 - -_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - ldr r1, _TEXT_BASE - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -346,8 +282,14 @@ _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start + #endif
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 30e2183..a7a98a4 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -147,12 +147,7 @@ reset: bl cpu_init_crit #endif
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -228,46 +219,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr pc, _nand_boot +relocate_done:
-_nand_boot: .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -275,6 +230,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index a133d19..c189849 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -143,12 +143,7 @@ reset: bl cpu_init_crit #endif
@@ -165,14 +160,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -224,50 +215,9 @@ fixnext: blo fixloop #endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 - -_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -276,6 +226,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 7df97c5..dcc1f83 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -155,12 +155,7 @@ reset: bl cpu_init_crit #endif
@@ -177,14 +172,10 @@ ENTRY(relocate_code) mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -233,34 +224,22 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop - b clear_bss + +relocate_done: + + bx lr + _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start +ENDPROC(relocate_code)
-clear_bss: - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: +#endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -jump_2_ram: +ENTRY(c_runtime_cpu_setup) /* * If I-cache is enabled invalidate it */ @@ -279,20 +258,9 @@ jump_2_ram: mcr p15, 0, r0, c12, c0, 0 @Set VBAR #endif /* !Tegra20 */
- ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -ENDPROC(relocate_code) -#endif + bx lr + +ENDPROC(c_runtime_cpu_setup)
/************************************************************************* * diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index c12f1a7..efb5a40 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -245,12 +245,7 @@ reset: orr r0,r0,#0x13 msr cpsr,r0
-/* Set initial stackpointer in SDRAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -267,14 +262,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -326,42 +317,9 @@ fixnext: blo fixloop #endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -370,6 +328,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /****************************************************************************/ /* */ /* Interrupt handling */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 536cf5c..72af869 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -164,12 +164,7 @@ reset: bl lock_cache_for_stack #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0, =0x00000000 - bl board_init_f + bl _main
/*------------------------------------------------------------------------------*/ #ifndef CONFIG_SPL_BUILD @@ -186,10 +181,6 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - /* Disable the Dcache RAM lock for stack now */ #ifdef CONFIG_CPU_PXA25X bl cpu_init_crit @@ -198,7 +189,7 @@ stack_setup: adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -250,48 +241,9 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif /* #ifndef CONFIG_SPL_BUILD */ +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_ONENAND_SPL - ldr r0, _onenand_boot_ofs - mov pc, r0 - -_onenand_boot_ofs: - .word onenand_boot -#else -jump_2_ram: - ldr r0, _board_init_r_ofs - ldr r1, _TEXT_BASE - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -299,7 +251,14 @@ _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start + #endif + + .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 323b923..4528c91 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -128,12 +128,7 @@ reset: bl lowlevel_init #endif
@@ -150,14 +145,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -209,42 +200,9 @@ fixnext: blo fixloop #endif
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -253,6 +211,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 1ea92d1..3144299 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -132,12 +132,7 @@ reset: bl cpu_init_crit #endif
@@ -154,14 +149,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -213,40 +204,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif +relocate_done:
-_board_init_r_ofs: - .word board_init_r - _start - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -254,6 +215,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 3422ac1..07baee2 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -36,6 +36,8 @@ GLSOBJS += _umodsi3.o
GLCOBJS += div0.o
+SOBJS-y += crt0.o + ifndef CONFIG_SPL_BUILD COBJS-y += board.o COBJS-y += bootm.o diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 92cad9a..ad96d7e 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -272,11 +272,6 @@ void board_init_f(ulong bootflag)
bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_F, "board_init_f");
- /* Pointer is writable since we allocated a register for it */ - gd = (gd_t *) ((CONFIG_SYS_INIT_SP_ADDR) & ~0x07); - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("": : :"memory"); - memset((void *)gd, 0, sizeof(gd_t));
gd->mon_len = _bss_end_ofs; @@ -458,10 +453,6 @@ void board_init_f(ulong bootflag) gd->fdt_blob = new_fdt; } memcpy(id, (void *)gd, sizeof(gd_t)); - - relocate_code(addr_sp, id, addr); - - /* NOTREACHED - relocate_code() does not return */ }
#if !defined(CONFIG_SYS_NO_FLASH) @@ -486,8 +477,6 @@ void board_init_r(gd_t *id, ulong dest_addr) ulong flash_size; #endif
- gd = id; - gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */ bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r");
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S new file mode 100644 index 0000000..0874e92 --- /dev/null +++ b/arch/arm/lib/crt0.S @@ -0,0 +1,179 @@ +/* + * crt0 - C-runtime startup Code for ARM U-Boot + * + * Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm-offsets.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure. In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from DDR. As DDR may not be available, board_init_f() + * must use GD to store any data which must be passed on to later, + * stages, including the reloction destination and the new stack + * pointer address, below which the stack resides and above it the + * new GD resides. + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in DDR, but BSS and initialized + * non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in DDR. + * GD has but retained values set by board_init_f(). Some CPUs + * have some work to do at this point, so call c_runtime_cpu_setup. + * + * 6. Call noard_init_r(). If the function returns, reset the board. + */ + +/* + * offset of the nand_boot() function for SPL crt + */ + +#if defined(CONFIG_NAND_SPL) + +.globl nand_boot +_nand_boot: + .word nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + +/* + * offset of the board_init_r() function for non-SPL crt + */ + +.globl board_init_r +_board_init_r: + .word board_init_r + +#endif + +/* + * start and end of BSS + */ + +.globl __bss_start +.globl __bss_end__ + +/* + * entry point of crt0 sequence + */ + +.global _main + +_main: + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + +#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#elif CONFIG_SPL_BUILD + ldr sp, =(CONFIG_SPL_STACK) +#else + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r8, sp /* GD is above SP */ + mov r0, #0 + bl board_init_f + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_sp, gd, addr_moni). Trick here is that + * we'll return 'here' but relocated. + */ + + ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ + ldr r8, [r8, #GD_BD] /* r8 = gd->bd */ + sub r8, r8, #GD_SIZE /* new GD is below bd */ + +#ifndef CONFIG_SPL_BUILD + + adr lr, here + ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ + add lr, lr, r0 + ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ + mov r1, r8 /* r1 = gd */ + ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + b relocate_code +here: + +#endif + +/* Set up final (full) environment */ + + bl c_runtime_cpu_setup /* we still call old routine here */ + + ldr r0, =__bss_start /* this is auto-relocated! */ + ldr r1, =__bss_end__ /* this is aotu-relocated! */ + + mov r2, #0x00000000 /* prepare zero to clear BSS */ + +clbss_l:cmp r0, r1 /* while not at end of BSS */ + strlo r2, [r0] /* clear 32-bit BSS word */ + addlo r0, r0, #4 /* move to next + bhs clbss_l + +#ifdef CONFIG_SPL_BUILD + + bl coloured_LED_init + bl red_led_on + +#endif + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + + mov lr, pc + +#if defined(CONFIG_NAND_SPL) + ldr pc, _nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + + /* setup parameters for board_init_r */ + mov r0, r8 /* gd_t */ + ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ + /* call board_init_r */ + ldr pc, _board_init_r /* this is auto-relocated! */ + +#endif + + /* we should not return. */ diff --git a/include/common.h b/include/common.h index b23e90b..230bc9f 100644 --- a/include/common.h +++ b/include/common.h @@ -300,7 +300,7 @@ int abortboot(int bootdelay); extern char console_buffer[];
/* arch/$(ARCH)/lib/board.c */ -void board_init_f (ulong) __attribute__ ((noreturn)); +void board_init_f(ulong); void board_init_r (gd_t *, ulong) __attribute__ ((noreturn)); int checkboard (void); int checkflash (void); diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index c88f5d4..764e27b 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -28,5 +28,15 @@ int main(void) DEFINE(GENERATED_BD_INFO_SIZE, (sizeof(struct bd_info) + 15) & ~15);
+ DEFINE(GD_SIZE, sizeof(struct global_data)); + + DEFINE(GD_BD, offsetof(struct global_data, bd)); + + DEFINE(GD_RELOCADDR, offsetof(struct global_data, relocaddr)); + + DEFINE(GD_RELOC_OFF, offsetof(struct global_data, reloc_off)); + + DEFINE(GD_START_ADDR_SP, offsetof(struct global_data, start_addr_sp)); + return 0; } diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile index 43e72c4..2793aef 100644 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -12,11 +12,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
-SOBJS = start.o lowlevel_init.o +SOBJS = start.o crt0.o lowlevel_init.o COBJS = nand_boot_fsl_nfc.o
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm1136/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -49,6 +50,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm1136/%.S $(CC) $(AFLAGS) -c -o $@ $<
+$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S + $(CC) $(AFLAGS) -c -o $@ $< + $(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S $(CC) $(AFLAGS) -c -o $@ $<
diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile index becf7fa..825f06d 100644 --- a/nand_spl/board/karo/tx25/Makefile +++ b/nand_spl/board/karo/tx25/Makefile @@ -33,11 +33,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/karo/tx25/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -70,6 +71,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S $(CC) $(AFLAGS) -c -o $@ $<
+$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S + $(CC) $(AFLAGS) -c -o $@ $< + $(obj)%.o: $(SRCTREE)/board/karo/tx25/%.S $(CC) $(AFLAGS) -c -o $@ $<
Dear Albert ARIBAUD,
In message 1352001421-25913-2-git-send-email-albert.u.boot@aribaud.net you wrote:
Please move the patch description from the cover letter to this commit message.
Hi Wolfgang,
Will do. Also, V2 will have a second patch for some start.S scrubbing and will have fixes for a few targets.
Amicalement,
The goal of this series is to scrub the start.S files which have proliferated across arch/arm and eliminate code redundancy.
Currently this series only factorizes the C runtime framework, that is, the assembly code responsible for setting up the C environments needed by board_init_*() and relocate_code().
Further factorization is possible: relocate_code() can be moved out and possibly rewritten in C now that it has plain C function semantics; exception handlers should also be pretty much cpu-independent.
Eventually, start.S files should disappear or contain CPU-specific code only.
The new C runtime setup sequence has been validated step by step on target versatileqemu using toolchain ELDK4.2.
The whole changes have been build-tested across all ARM targets using MAKEALL -a arm.
Changes in v2: - moved description from cover letter to patch commit msg - added note about tests in the cover letter - fixed baords with CONFIG_SPL but not CONFIG_SPL_STACK - introduced in V2
Albert ARIBAUD (2): arm: move C runtime setup code in crt0.S arm: remove useless code in start.S files
arch/arm/cpu/arm1136/start.S | 62 ++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 65 ++--------- arch/arm/cpu/arm926ejs/start.S | 86 ++------------ arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 180 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 324 insertions(+), 684 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Move all the C runtime setup code from every start.S in arch/arm into arch/arm/lib/crt0.S. This covers the code sequence from isetting up the initial stack to calling into board_init_r().
Also, rewrite the C runtime setup and make functions board_init_*() and relocate_code() behave according to normal C semantics (no jumping across the C stack any more, etc).
Some SPL targets had to be touched because they use start.S exolicitly or for some reason; the relevant maintainers and custodians are cc:ed.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v2: - moved description from cover letter to patch commit msg - added note about tests in the cover letter - fixed baords with CONFIG_SPL but not CONFIG_SPL_STACK
arch/arm/cpu/arm1136/start.S | 62 ++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 180 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 324 insertions(+), 674 deletions(-) create mode 100644 arch/arm/lib/crt0.S
GLCOBJS += div0.o
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S new file mode 100644 index 0000000..fd6bd92 --- /dev/null +++ b/arch/arm/lib/crt0.S @@ -0,0 +1,180 @@ +/* + * crt0 - C-runtime startup Code for ARM U-Boot + * + * Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm-offsets.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure. In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from DDR. As DDR may not be available, board_init_f() + * must use GD to store any data which must be passed on to later, + * stages, including the reloction destination and the new stack + * pointer address, below which the stack resides and above it the + * new GD resides. + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in DDR, but BSS and initialized + * non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in DDR. + * GD has but retained values set by board_init_f(). Some CPUs + * have some work to do at this point, so call c_runtime_cpu_setup. + * + * 6. Call noard_init_r(). If the function returns, reset the board. + */ + +/* + * offset of the nand_boot() function for SPL crt + */ + +#if defined(CONFIG_NAND_SPL) + +.globl nand_boot +_nand_boot: + .word nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + +/* + * offset of the board_init_r() function for non-SPL crt + */ + +.globl board_init_r +_board_init_r: + .word board_init_r + +#endif + +/* + * start and end of BSS + */ + +.globl __bss_start +.globl __bss_end__ + +/* + * entry point of crt0 sequence + */ + +.global _main + +_main: + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + +#if defined(CONFIG_NAND_SPL) + /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr sp, =(CONFIG_SPL_STACK) +#else + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r8, sp /* GD is above SP */ + mov r0, #0 + bl board_init_f + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_sp, gd, addr_moni). Trick here is that + * we'll return 'here' but relocated. + */ + + ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ + ldr r8, [r8, #GD_BD] /* r8 = gd->bd */ + sub r8, r8, #GD_SIZE /* new GD is below bd */ + +#ifndef CONFIG_SPL_BUILD + + adr lr, here + ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ + add lr, lr, r0 + ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ + mov r1, r8 /* r1 = gd */ + ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + b relocate_code +here: + +#endif + +/* Set up final (full) environment */ + + bl c_runtime_cpu_setup /* we still call old routine here */ + + ldr r0, =__bss_start /* this is auto-relocated! */ + ldr r1, =__bss_end__ /* this is aotu-relocated! */ + + mov r2, #0x00000000 /* prepare zero to clear BSS */ + +clbss_l:cmp r0, r1 /* while not at end of BSS */ + strlo r2, [r0] /* clear 32-bit BSS word */ + addlo r0, r0, #4 /* move to next + bhs clbss_l + +#ifdef CONFIG_SPL_BUILD + + bl coloured_LED_init + bl red_led_on + +#endif + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + + mov lr, pc + +#if defined(CONFIG_NAND_SPL) + ldr pc, _nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + + /* setup parameters for board_init_r */ + mov r0, r8 /* gd_t */ + ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ + /* call board_init_r */ + ldr pc, _board_init_r /* this is auto-relocated! */ + +#endif + + /* we should not return. */ diff --git a/include/common.h b/include/common.h index b23e90b..230bc9f 100644 --- a/include/common.h +++ b/include/common.h @@ -300,7 +300,7 @@ int abortboot(int bootdelay); extern char console_buffer[];
/* arch/$(ARCH)/lib/board.c */ -void board_init_f (ulong) __attribute__ ((noreturn)); +void board_init_f(ulong); void board_init_r (gd_t *, ulong) __attribute__ ((noreturn)); int checkboard (void); int checkflash (void); diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 42077bd..5633d2a 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -65,7 +65,7 @@ #define CONFIG_SYS_BOOTMAPSZ ((256*1024*1024) - (4*1024))
#define CONFIG_SPL_RAM_DEVICE -#define CONFIG_SPL_STACK (&__stack_start) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SYS_SPL_MALLOC_START ((unsigned long) (&__malloc_start)) #define CONFIG_SYS_SPL_MALLOC_SIZE (&__malloc_end - &__malloc_start)
Remove code such as unneeded includes or labels. These removals have no functional effect.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v2: - introduced in V2
arch/arm/cpu/arm925t/start.S | 4 ---- arch/arm/cpu/arm926ejs/start.S | 6 ------ 2 files changed, 10 deletions(-)
diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 82f5b8b..e8d6d71 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -34,10 +34,6 @@ #include <config.h> #include <version.h>
-#if defined(CONFIG_OMAP1510) -#include <./configs/omap1510.h> -#endif - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 5dfd49a..6b91535 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -36,12 +36,6 @@ #include <common.h> #include <version.h>
-#if defined(CONFIG_OMAP1610) -#include <./configs/omap1510.h> -#elif defined(CONFIG_OMAP730) -#include <./configs/omap730.h> -#endif - /* ************************************************************************* *
Hi Albert,
On Sun, 4 Nov 2012 12:32:04 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Argh. s/isetting/setting/ in V3...
Amicalement,
Hello Albert,
Signed-off-by: Albert ARIBAUDalbert.u.boot@aribaud.net
Changes in v2:
<snip>
- crt0 - C-runtime startup Code for ARM U-Boot
- Copyright (c) 2012 Albert ARIBAUDalbert.u.boot@aribaud.net
- project.
- MA 02111-1307 USA
+#include<config.h> +#include<asm-offsets.h>
- This file handles the target-independent stages of the U-Boot
- start-up where a C runtime environment is needed. Its entry point
- is _main and is branched into from the target's start.S file.
- _main execution sequence is:
- Set up initial environment for calling board_init_f().
- This environment only provides a stack and a place to store
- the GD ('global data') structure. In this context, VARIABLE
- global data, initialized or not (BSS), are UNAVAILABLE; only
- CONSTANT initialized data are available.
- Call board_init_f(). This function prepares the hardware for
- execution from DDR. As DDR may not be available, board_init_f()
- must use GD to store any data which must be passed on to later,
- stages, including the reloction destination and the new stack
- pointer address, below which the stack resides and above it the
- new GD resides.
- Set up intermediate environment where the stack and GD are the
- ones allocated by board_init_f() in DDR, but BSS and initialized
- non-const data are still not available.
- Call relocate_code(). This function relocates U-Boot from its
- current location into the relocation destination computed by
- board_init_f().
- Set up final environment for calling board_init_r(). This
- environment has BSS (initialized to 0), initialized non-const
- data (initialized to their intended value), and stack in DDR.
- GD has but retained values set by board_init_f(). Some CPUs
- have some work to do at this point, so call c_runtime_cpu_setup.
- Call noard_init_r(). If the function returns, reset the board.
s/noard_init_r/board_init_r
- offset of the nand_boot() function for SPL crt
- .word nand_boot
- offset of the board_init_r() function for non-SPL crt
- start and end of BSS
- entry point of crt0 sequence
+.global _main
+_main:
- Set up initial C runtime environment and call board_init_f(0).
- /* deprecated, use instead CONFIG_SPL_BUILD */
+#elif defined(CONFIG_SPL_BUILD)&& defined(CONFIG_SPL_STACK)
+#else
- mov r8, sp /* GD is above SP */
- mov r0, #0
- bl board_init_f
- Set up intermediate environment (new sp and gd) and call
- relocate_code(addr_sp, gd, addr_moni). Trick here is that
- we'll return 'here' but relocated.
- ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */
- ldr r8, [r8, #GD_BD] /* r8 = gd->bd */
- sub r8, r8, #GD_SIZE /* new GD is below bd */
In some places the other style is used. "!(defined)". Any particular reasons for switching b/w these two styles?
- adr lr, here
- ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */
- add lr, lr, r0
- ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */
- mov r1, r8 /* r1 = gd */
- ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */
- b relocate_code
+here:
- bl c_runtime_cpu_setup /* we still call old routine here */
- ldr r0, =__bss_start /* this is auto-relocated! */
- ldr r1, =__bss_end__ /* this is aotu-relocated! */
s/aotu/auto
Regards, Vikram
Hi Vikram,
On Sun, 04 Nov 2012 20:36:14 +0530, Vikram Narayanan vikram186@gmail.com wrote:
Hello Albert,
None except heterogeneity. In V3 I'll make sure 'defined()' is used everywhere in the new files or added code.
s/aotu/auto
Thanks for spotting this. Will fix in V3.
Regards, Vikram
Amicalement,
Dear Albert Aribaud,
Changes in v2:
<snip>
- Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net
- project.
- MA 02111-1307 USA
DDR means DRAM in general?
------------------------^ Full stop? The rest of the sentence makes no sense to me.
- new GD resides.
- board_init_f().
- .word nand_boot
+.global _main
+_main:
I wonder if we can emit a #warning here
+#else
- mov r0, #0
- bl board_init_f
- adr lr, here
- add lr, lr, r0
- b relocate_code
+here:
- mov r2, #0x00000000 /* prepare zero to clear BSS */
- strlo r2, [r0] /* clear 32-bit BSS word */
- addlo r0, r0, #4 /* move to next
- bhs clbss_l
I think this should be negated. The coloured LED stuff was enabled for non SPL builds before!
- bl red_led_on
- /* call board_init_r(gd_t *id, ulong dest_addr) */
Shouldn't this move down in the #elif path?
- mov lr, pc
- mov r0, r8 /* gd_t */
- ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */
- /* call board_init_r */
- ldr pc, _board_init_r /* this is auto-relocated! */
- /* we should not return. */
Best regards
Andreas Bießmann
Hi Andreas,
On Mon, 05 Nov 2012 09:31:55 +0100, "Andreas Bießmann" andreas.devel@googlemail.com wrote:
Yes -- but DRAM is no better, as it still describes a technology (class). I'm going tu use "system RAM" to describe it.
Fixed.
Rewritten.
Hmm... Will test and let people know how many boards stop compiling cleanly.
Correct.
- bl red_led_on
Moved.
Best regards
Andreas Bießmann
Thanks a lot for your review!
Amicalement,
Reviewing myself:
Unclosed comment here. This causes the following code to be ignored:
- bhs clbss_l
- bl red_led_on
Which might explain why SPL builds did not complain about LED calls and why some boards failed.
Also:
The #elif is wrong, as it causes CONFIG_SPL_BUILD builds to not call board_init_f() at all; actually, they overrun into whatever follows. This might have been what Sughosh (Cc:) hit with the hawkboard.
Amicalement,
Hi Tom,
On Sun, 4 Nov 2012 12:32:03 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
I know this came a bit late in early nov 4th, but I really would like it to be considered for 2013.01. Would you agree to make an exception for it? Thanks in advance.
Amicalement,
On Sun, Nov 04, 2012 at 12:43:12PM +0100, Albert ARIBAUD wrote:
Hi Tom,
If you can collect a diverse set of Tested-by's, yes.
Hi Tom,
I have not gone through the patch, but will test it in a day or two on the hawkboard, and report the findings.
The hawkboard comes with the arm926ejs core, so that part of the code would be tested.
-sughosh
hi Albert,
Hi Tom,
I tried the 1st patch of the series, and with that u-boot does not come up on the board. It is also printing out some random values for the dram and nand sizes.
The patch was applied on top of commit 1cc619be8b7. Also, with the mentioned commit, u-boot boots up fine on the board. Also to be noted is that the spl image compiled with these changes is booting up fine, loading the main u-boot image, and jumping to it -- the issue is with booting the main u-boot image.
-sughosh
Hi Sughosh,
On Thu, 8 Nov 2012 19:50:28 +0530, Sughosh Ganu urwithsughosh@gmail.com wrote:
hi Albert,
Hi Tom,
Thanks Sughosh. Can you build an U-Boot with the following defined in the hawkboard.h config file?
#define DEBUG #if defined(CONFIG_SPL_BUILD) && ! defined (__ASSEMBLY__) static inline int printf(const char *fmt, ...) { return 0; } #endif
Note: only the #define DEBUG matter to me, but with it alone, SPL build fails due to some code now requiring printf(). This is why I add a dummy printf definition for C code during SPL build -- ASM code does not need printf() and actually chokes on the definition, hence the condition on __ASSEMBLY__.
This debug U-Boot should print a lot more info. Can you please try it and copy/paste its output here? Thanks in advance.
Amicalement,
hi Albert,
On Sat, Nov 10, 2012 at 8:00 PM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Hi Sughosh,
hi Albert,
Hi Tom,
like
exception
Unfortunately i am currently on vacation, with no access to the board, and would be able to try out your suggested changes only after i am back, by the end of next week. In the meantime, i am also trying to get myself a jtag debugger -- it is quite frustrating to provide half baked information.
I had tried enabling DEBUG in the board.c file, and with that, i saw that board_init_f completes, and the board hangs after returning from the function. Now i really need a debugger to figure out where exactly is the problem, as it could be in the relocation part, or while trying to jump to the board_init_r after having relocated the code. Hopefully, with a jtag debugger, i will be able to provide you a lot more info.
-sughosh
Hi Sughosh,
On Tue, 13 Nov 2012 09:40:19 +0530, Sughosh Ganu urwithsughosh@gmail.com wrote:
hi Albert,
Hi Sughosh,
hi Albert,
Hi Tom,
> The goal of this series is to scrub the start.S files > which have proliferated across arch/arm and eliminate > code redundancy.
like
exception
-sughosh
Thanks for the feedback. Meanwhile, I have found two ugly bugs which would certainly affect execution past board_init_f(), so maybe your hawkboard was bitten by theses; next time please try v3, which fixes these bugs, or the latest patch version if v3 is obsolete by the time you come back.
Enjoy your vacation!
Amicalement,
hi Albert, On Tue Nov 13, 2012 at 08:55:23PM +0100, Albert ARIBAUD wrote:
<snip>
I tested the v4 of your patches on hawkboard, and now the board boots up fine. Sorry, i took a little longer than i had expected to be back, so this got a bit delayed.
-sughosh
Changes in v3: - various clarifications and typo fixes - fixed wrong LED calls conditional - fixed open comment eating some code - fixed code overrun in SPL case Series-changes: 2 - moved description from cover letter to patch commit msg - added note about tests in the cover letter - fixed baords with CONFIG_SPL but not CONFIG_SPL_STACK - no change
arch/arm/cpu/arm1136/start.S | 69 +++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 65 ++--------- arch/arm/cpu/arm926ejs/start.S | 86 ++------------ arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 180 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 329 insertions(+), 686 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v3: - various clarifications and typo fixes - fixed wrong LED calls conditional - fixed open comment eating some code - fixed code overrun in SPL case Series-changes: 2 - moved description from cover letter to patch commit msg - added note about tests in the cover letter - fixed baords with CONFIG_SPL but not CONFIG_SPL_STACK
arch/arm/cpu/arm1136/start.S | 69 +++-------- arch/arm/cpu/arm1176/start.S | 62 ++-------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++------- arch/arm/cpu/arm_intcm/start.S | 63 ++-------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++-------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------ arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 180 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 329 insertions(+), 676 deletions(-) create mode 100644 arch/arm/lib/crt0.S
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 5d3b4c2..d19c1ed 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -165,13 +165,7 @@ next: bl cpu_init_crit #endif
@@ -188,14 +182,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -255,52 +245,21 @@ _dynsym_start_ofs: .word __dynsym_start - _start #endif
-clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: + bx lr
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start
-_nand_boot_ofs: - .word nand_boot -#else -jump_2_ram: - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr
/* ************************************************************************* diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 667a0e0..40df4b1 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -224,12 +224,7 @@ skip_tcmdisable: */ bl lowlevel_init /* go setup pll,mux,memory */
GLCOBJS += div0.o
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S new file mode 100644 index 0000000..ad6c71d --- /dev/null +++ b/arch/arm/lib/crt0.S @@ -0,0 +1,180 @@ +/* + * crt0 - C-runtime startup Code for ARM U-Boot + * + * Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm-offsets.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure, both located in some readily + * available RAM (SRAM, locked cache...). In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from system RAM (DRAM, DDR...) As system RAM may not + * be available yet, , board_init_f() must use the current GD to + * store any data which must be passed on to later stages. These + * data include the relocation destination, the future stack, and + * the future GD location. + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in system RAM, but BSS and + * initialized non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in system + * RAM. GD has retained values set by board_init_f(). Some CPUs + * have some work left to do at this point regarding memory, so + * call c_runtime_cpu_setup. + * + * 6. Branch to either _nand_boot() or board_init_r(). + */ + +/* + * offset of the nand_boot() function for SPL crt + */ + +#if defined(CONFIG_NAND_SPL) + +.globl nand_boot +_nand_boot: + .word nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + +/* + * offset of the board_init_r() function for non-SPL crt + */ + +.globl board_init_r +_board_init_r: + .word board_init_r + +#endif + +/* + * start and end of BSS + */ + +.globl __bss_start +.globl __bss_end__ + +/* + * entry point of crt0 sequence + */ + +.global _main + +_main: + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + +#if defined(CONFIG_NAND_SPL) + /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr sp, =(CONFIG_SPL_STACK) +#else + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r8, sp /* GD is above SP */ + mov r0, #0 + bl board_init_f + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_sp, gd, addr_moni). Trick here is that + * we'll return 'here' but relocated. + */ + + ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ + ldr r8, [r8, #GD_BD] /* r8 = gd->bd */ + sub r8, r8, #GD_SIZE /* new GD is below bd */ + +#if ! defined(CONFIG_SPL_BUILD) + + adr lr, here + ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ + add lr, lr, r0 + ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ + mov r1, r8 /* r1 = gd */ + ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + b relocate_code +here: + +#endif + +/* Set up final (full) environment */ + + bl c_runtime_cpu_setup /* we still call old routine here */ + + ldr r0, =__bss_start /* this is auto-relocated! */ + ldr r1, =__bss_end__ /* this is auto-relocated! */ + + mov r2, #0x00000000 /* prepare zero to clear BSS */ + +clbss_l:cmp r0, r1 /* while not at end of BSS */ + strlo r2, [r0] /* clear 32-bit BSS word */ + addlo r0, r0, #4 /* move to next */ + bhs clbss_l + +#if ! defined(CONFIG_SPL_BUILD) + + bl coloured_LED_init + bl red_led_on + +#endif + +#if defined(CONFIG_NAND_SPL) + + /* call _nand_boot() */ + ldr pc, _nand_boot + +#else + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + mov r0, r8 /* gd_t */ + ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ + /* call board_init_r */ + ldr pc, _board_init_r /* this is auto-relocated! */ + +#endif + + /* we should not return here. */ diff --git a/include/common.h b/include/common.h index 5e3c5ee..69a1ccd 100644 --- a/include/common.h +++ b/include/common.h @@ -300,7 +300,7 @@ int abortboot(int bootdelay); extern char console_buffer[];
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v3: - no change
Hi Albert,
On Sat, Nov 10, 2012 at 9:00 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
I am very pleased to see this. My generic relocation series from some time ago is still hanging around. Your series tidies up some things which would make that series easier to do. I'm happy to take another look at it.
I have tested your series on a Tegra seaboard, and got it running with a few changes. Please see comments below.
Changes in v3:
Series-changes: 2
[snip]
- project.
- MA 02111-1307 USA
- the GD ('global data') structure, both located in some readily
- available RAM (SRAM, locked cache...). In this context, VARIABLE
- execution from system RAM (DRAM, DDR...) As system RAM may not
- be available yet, , board_init_f() must use the current GD to
- store any data which must be passed on to later stages. These
- data include the relocation destination, the future stack, and
- the future GD location.
- ones allocated by board_init_f() in system RAM, but BSS and
- initialized non-const data are still not available.
- board_init_f().
- data (initialized to their intended value), and stack in system
- RAM. GD has retained values set by board_init_f(). Some CPUs
- have some work left to do at this point regarding memory, so
- call c_runtime_cpu_setup.
- Branch to either _nand_boot() or board_init_r().
.word nand_boot
.word board_init_r
+.global _main
+_main:
+#else
mov r0, #0
bl board_init_f
adr lr, here
add lr, lr, r0
b relocate_code
+here:
I noticed this last time around - really we should have __bss_end__, not __bss_end. Something to look at in future work, perhaps.
bhs clbss_l
I think this should be blo, not bhs. Otherwise the BSS does not get cleared and my seaboard doesn't boot properly.
bl red_led_on
ldr pc, _nand_boot
+#else
For my toolchain I need:
ldr pc, =board_init_r
otherwise I get:
crt0.S: Assembler messages: crt0.S:176: Error: internal_relocation (type: OFFSET_IMM) not fixed up
Also _board_init_r seems to be the wrong symbol name for me:
arch/arm/lib/libarm.o: In function `clbss_l': /home/sjg/trunk/src/third_party/u-boot/files/arch/arm/lib/crt0.S:176: undefined reference to `_board_init_r'
[snip]
Hi Simon,
On Thu, 15 Nov 2012 11:35:27 -0800, Simon Glass sjg@chromium.org wrote:
Hi Albert,
I do remember your series -- it is part of what gave me the incentive toput this patch series together. :)
Noted.
bhs clbss_l
Thanks -- not the first time I see these... I'll have a go at checking all loops.
otherwise I get:
Thanks -- this could well cure errors that Tom Warren reported to me for various toolchains.
Thanks a lot for the feedback and analysis! This should make V4 work on a much wider range of ARM boards.
Amicalement,
Hi Albert,
On Sat, 10 Nov 2012 18:00:11 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Changes in v3:
Note there is no warning for using 'deprecated' NAND_SPL yet. I'm running full MAKEALL -a arm on this and it'll be added in v4 depending on results.
Amicalement,
This series only factorizes the C runtime framework, that is, the assembly code responsible for setting up the C environments needed by board_init_*() and relocate_code().
Also, SPL currently makes board_init_f() perform all of the setting up, including BSS clearing and chain- loading. This could be streamlined by only putting basic inits in board_init_f(), letting crt0 do the BSS initialization and chain-loading U-Boot from inside board_init_r().
The new C runtime setup sequence has been validated step by step on targets versatileqemu using gcc version 4.2.2 from the ELDK4.2 toolchain, and wireless_space using gcc version 4.7.2 (Ubuntu/Linaro 4.7.2-1ubuntu1).
Changes in v4: - fixed bhs into blo in BSS init loop - switched from explicit literals to '=target' notation - fixed location of GD in initial environment - stopped SPL boot sequence at calling board_init_f
Changes in v2: - moved description from cover letter to patch commit msg - added note about tests in the cover letter - fixed baords with CONFIG_SPL but not CONFIG_SPL_STACK - removed useless includes in arm926ejs and arm925t
arch/arm/cpu/arm1136/start.S | 71 +++--------- arch/arm/cpu/arm1176/start.S | 62 ++--------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 65 ++--------- arch/arm/cpu/arm926ejs/start.S | 86 ++------------ arch/arm/cpu/arm946es/start.S | 56 ++-------- arch/arm/cpu/arm_intcm/start.S | 63 ++--------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++--------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------- arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 173 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 322 insertions(+), 688 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Move all the C runtime setup code from every start.S in arch/arm into arch/arm/lib/crt0.S. This covers the code sequence from setting up the initial stack to calling into board_init_r().
Some SPL targets had to be touched because they use start.S explicitly or for some reason; the relevant maintainers and custodians are cc:ed.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v4: - fixed bhs into blo in BSS init loop - switched from explicit literals to '=target' notation - fixed location of GD in initial environment - stopped SPL boot sequence at calling board_init_f
arch/arm/cpu/arm1136/start.S | 71 +++--------- arch/arm/cpu/arm1176/start.S | 62 ++--------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++-------- arch/arm/cpu/arm_intcm/start.S | 63 ++--------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++--------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------- arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 173 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 10 ++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 322 insertions(+), 678 deletions(-) create mode 100644 arch/arm/lib/crt0.S
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 5d3b4c2..a067b8a 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -165,13 +165,7 @@ next: bl cpu_init_crit #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - - bl board_init_f + bl _main
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -245,7 +235,15 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop - b clear_bss + bx lr + +#endif + +relocate_done: + + bx lr + +#ifndef CONFIG_SPL_BUILD
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -253,54 +251,13 @@ _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start -#endif
-clear_bss: -#ifdef CONFIG_SPL_BUILD - /* No relocation for SPL */ - ldr r0, =__bss_start - ldr r1, =__bss_end__ -#else - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 #endif - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 + .globl c_runtime_cpu_setup +c_runtime_cpu_setup:
-_nand_boot_ofs: - .word nand_boot -#else -jump_2_ram: - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -246,14 +241,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -343,49 +334,9 @@ mmu_enable: skip_hw_init: #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#ifndef CONFIG_NAND_SPL - bl coloured_LED_init - bl red_led_on -#endif -#endif +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr pc, _nand_boot - -_nand_boot: .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -399,6 +350,11 @@ _mmu_table_base: .word mmu_table #endif
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + #ifndef CONFIG_NAND_SPL /* * we assume that cache operation is done before. (eg. cleanup_before_linux()) diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index c2a7763..771d386 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -147,12 +147,7 @@ reset: bl cpu_init_crit #endif
@@ -169,14 +164,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -228,43 +219,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: - - bl coloured_LED_init - bl red_led_on -#endif +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -272,6 +230,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 14c9156..511d21d 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -182,12 +182,7 @@ copyex: bl cpu_init_crit #endif
@@ -204,14 +199,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -263,51 +254,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: - - bl coloured_LED_init - bl red_led_on -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 +relocate_done:
-_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -315,6 +265,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 3a483f6..82f5b8b 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -176,12 +176,7 @@ poll1: bl cpu_init_crit #endif
@@ -198,14 +193,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -257,51 +248,10 @@ fixnext: blo fixloop #endif
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -309,6 +259,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 2188f7e..3cdecd9 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -198,20 +198,7 @@ reset: bl cpu_init_crit #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: -#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) -#else -#ifdef CONFIG_SPL_BUILD - ldr sp, =(CONFIG_SPL_STACK) -#else - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) -#endif -#endif - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -229,15 +216,11 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start sub r9, r6, r0 /* r9 <- relocation offset */ cmp r0, r6 - moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + moveq r9, #0 /* no relocation. offset(r9) = 0 */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -289,56 +272,9 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifdef CONFIG_SPL_BUILD - /* No relocation for SPL */ - ldr r0, =__bss_start - ldr r1, =__bss_end__ -#else - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 -#endif - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: +relocate_done:
-#ifndef CONFIG_SPL_BUILD - bl coloured_LED_init - bl red_led_on -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 - -_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - ldr r1, _TEXT_BASE - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -346,8 +282,14 @@ _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start + #endif
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 30e2183..a7a98a4 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -147,12 +147,7 @@ reset: bl cpu_init_crit #endif
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -228,46 +219,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif - -/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr pc, _nand_boot +relocate_done:
-_nand_boot: .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ mov pc, lr
-_board_init_r_ofs: - .word board_init_r - _start -#endif - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -275,6 +230,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index a133d19..c189849 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -143,12 +143,7 @@ reset: bl cpu_init_crit #endif
@@ -165,14 +160,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -224,50 +215,9 @@ fixnext: blo fixloop #endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_NAND_SPL - ldr r0, _nand_boot_ofs - mov pc, r0 - -_nand_boot_ofs: - .word nand_boot -#else - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -276,6 +226,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 7df97c5..dcc1f83 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -155,12 +155,7 @@ reset: bl cpu_init_crit #endif
@@ -177,14 +172,10 @@ ENTRY(relocate_code) mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -233,34 +224,22 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop - b clear_bss + +relocate_done: + + bx lr + _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start +ENDPROC(relocate_code)
-clear_bss: - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: +#endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -jump_2_ram: +ENTRY(c_runtime_cpu_setup) /* * If I-cache is enabled invalidate it */ @@ -279,20 +258,9 @@ jump_2_ram: mcr p15, 0, r0, c12, c0, 0 @Set VBAR #endif /* !Tegra20 */
- ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -ENDPROC(relocate_code) -#endif + bx lr + +ENDPROC(c_runtime_cpu_setup)
/************************************************************************* * diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index c12f1a7..efb5a40 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -245,12 +245,7 @@ reset: orr r0,r0,#0x13 msr cpsr,r0
-/* Set initial stackpointer in SDRAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0,=0x00000000 - bl board_init_f + bl _main
@@ -267,14 +262,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -326,42 +317,9 @@ fixnext: blo fixloop #endif
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ - ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -370,6 +328,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /****************************************************************************/ /* */ /* Interrupt handling */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 536cf5c..72af869 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -164,12 +164,7 @@ reset: bl lock_cache_for_stack #endif
-/* Set stackpointer in internal RAM to call board_init_f */ -call_board_init_f: - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ - ldr r0, =0x00000000 - bl board_init_f + bl _main
/*------------------------------------------------------------------------------*/ #ifndef CONFIG_SPL_BUILD @@ -186,10 +181,6 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - /* Disable the Dcache RAM lock for stack now */ #ifdef CONFIG_CPU_PXA25X bl cpu_init_crit @@ -198,7 +189,7 @@ stack_setup: adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -250,48 +241,9 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif /* #ifndef CONFIG_SPL_BUILD */ +relocate_done:
-/* - * We are done. Do not return, instead branch to second part of board - * initialization, now running from RAM. - */ -#ifdef CONFIG_ONENAND_SPL - ldr r0, _onenand_boot_ofs - mov pc, r0 - -_onenand_boot_ofs: - .word onenand_boot -#else -jump_2_ram: - ldr r0, _board_init_r_ofs - ldr r1, _TEXT_BASE - add lr, r0, r1 - add lr, lr, r9 - /* setup parameters for board_init_r */ - mov r0, r5 /* gd_t */ - mov r1, r6 /* dest_addr */ - /* jump to it ... */ - mov pc, lr - -_board_init_r_ofs: - .word board_init_r - _start -#endif + bx lr
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -299,7 +251,14 @@ _rel_dyn_end_ofs: .word __rel_dyn_end - _start _dynsym_start_ofs: .word __dynsym_start - _start + #endif + + .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 323b923..4528c91 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -128,12 +128,7 @@ reset: bl lowlevel_init #endif
@@ -150,14 +145,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -209,42 +200,9 @@ fixnext: blo fixloop #endif
_rel_dyn_start_ofs: .word __rel_dyn_start - _start @@ -253,6 +211,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + bx lr + /* ************************************************************************* * diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 1ea92d1..3144299 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -132,12 +132,7 @@ reset: bl cpu_init_crit #endif
@@ -154,14 +149,10 @@ relocate_code: mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */
- /* Set up the stack */ -stack_setup: - mov sp, r4 - adr r0, _start cmp r0, r6 moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ - beq clear_bss /* skip relocation */ + beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -213,40 +204,10 @@ fixnext: blo fixloop #endif
-clear_bss: -#ifndef CONFIG_SPL_BUILD - ldr r0, _bss_start_ofs - ldr r1, _bss_end_ofs - mov r4, r6 /* reloc addr */ - add r0, r0, r4 - add r1, r1, r4 - mov r2, #0x00000000 /* clear */ - -clbss_l:cmp r0, r1 /* clear loop... */ - bhs clbss_e /* if reached end of bss, exit */ - str r2, [r0] - add r0, r0, #4 - b clbss_l -clbss_e: -#endif +relocate_done:
-_board_init_r_ofs: - .word board_init_r - _start - _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: @@ -254,6 +215,11 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
+ .globl c_runtime_cpu_setup +c_runtime_cpu_setup: + + mov pc, lr + /* ************************************************************************* * diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 3422ac1..07baee2 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -36,6 +36,8 @@ GLSOBJS += _umodsi3.o
GLCOBJS += div0.o
+SOBJS-y += crt0.o + ifndef CONFIG_SPL_BUILD COBJS-y += board.o COBJS-y += bootm.o diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 92cad9a..ad96d7e 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -272,11 +272,6 @@ void board_init_f(ulong bootflag)
bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_F, "board_init_f");
- /* Pointer is writable since we allocated a register for it */ - gd = (gd_t *) ((CONFIG_SYS_INIT_SP_ADDR) & ~0x07); - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("": : :"memory"); - memset((void *)gd, 0, sizeof(gd_t));
gd->mon_len = _bss_end_ofs; @@ -458,10 +453,6 @@ void board_init_f(ulong bootflag) gd->fdt_blob = new_fdt; } memcpy(id, (void *)gd, sizeof(gd_t)); - - relocate_code(addr_sp, id, addr); - - /* NOTREACHED - relocate_code() does not return */ }
#if !defined(CONFIG_SYS_NO_FLASH) @@ -486,8 +477,6 @@ void board_init_r(gd_t *id, ulong dest_addr) ulong flash_size; #endif
- gd = id; - gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */ bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r");
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S new file mode 100644 index 0000000..4f60958 --- /dev/null +++ b/arch/arm/lib/crt0.S @@ -0,0 +1,173 @@ +/* + * crt0 - C-runtime startup Code for ARM U-Boot + * + * Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm-offsets.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure, both located in some readily + * available RAM (SRAM, locked cache...). In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from system RAM (DRAM, DDR...) As system RAM may not + * be available yet, , board_init_f() must use the current GD to + * store any data which must be passed on to later stages. These + * data include the relocation destination, the future stack, and + * the future GD location. + * + * (the following applies only to non-SPL builds) + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in system RAM, but BSS and + * initialized non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in system + * RAM. GD has retained values set by board_init_f(). Some CPUs + * have some work left to do at this point regarding memory, so + * call c_runtime_cpu_setup. + * + * 6. Branch to either nand_boot() or board_init_r(). + */ + +/* + * declare nand_boot() or board_init_r() to jump to at end of crt0 + */ + +#if defined(CONFIG_NAND_SPL) + +.globl nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + +.globl board_init_r + +#endif + +/* + * start and end of BSS + */ + +.globl __bss_start +.globl __bss_end__ + +/* + * entry point of crt0 sequence + */ + +.global _main + +_main: + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + +#if defined(CONFIG_NAND_SPL) + /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr sp, =(CONFIG_SPL_STACK) +#else + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + sub sp, #GD_SIZE /* allocate one GD above SP */ + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r8, sp /* GD is above SP */ + mov r0, #0 + bl board_init_f + +#if ! defined(CONFIG_SPL_BUILD) + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_sp, gd, addr_moni). Trick here is that + * we'll return 'here' but relocated. + */ + + ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + ldr r8, [r8, #GD_BD] /* r8 = gd->bd */ + sub r8, r8, #GD_SIZE /* new GD is below bd */ + + adr lr, here + ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ + add lr, lr, r0 + ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ + mov r1, r8 /* r1 = gd */ + ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + b relocate_code +here: + +/* Set up final (full) environment */ + + bl c_runtime_cpu_setup /* we still call old routine here */ + + ldr r0, =__bss_start /* this is auto-relocated! */ + ldr r1, =__bss_end__ /* this is auto-relocated! */ + + mov r2, #0x00000000 /* prepare zero to clear BSS */ + +clbss_l:cmp r0, r1 /* while not at end of BSS */ + strlo r2, [r0] /* clear 32-bit BSS word */ + addlo r0, r0, #4 /* move to next */ + blo clbss_l + + bl coloured_LED_init + bl red_led_on + +#if defined(CONFIG_NAND_SPL) + + /* call _nand_boot() */ + ldr pc, =nand_boot + +#else + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + mov r0, r8 /* gd_t */ + ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ + /* call board_init_r */ + ldr pc, =board_init_r /* this is auto-relocated! */ + +#endif + + /* we should not return here. */ + +#endif diff --git a/include/common.h b/include/common.h index 5e3c5ee..69a1ccd 100644 --- a/include/common.h +++ b/include/common.h @@ -300,7 +300,7 @@ int abortboot(int bootdelay); extern char console_buffer[];
diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index c88f5d4..764e27b 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -28,5 +28,15 @@ int main(void) DEFINE(GENERATED_BD_INFO_SIZE, (sizeof(struct bd_info) + 15) & ~15);
+ DEFINE(GD_SIZE, sizeof(struct global_data)); + + DEFINE(GD_BD, offsetof(struct global_data, bd)); + + DEFINE(GD_RELOCADDR, offsetof(struct global_data, relocaddr)); + + DEFINE(GD_RELOC_OFF, offsetof(struct global_data, reloc_off)); + + DEFINE(GD_START_ADDR_SP, offsetof(struct global_data, start_addr_sp)); + return 0; } diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile index 43e72c4..2793aef 100644 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -12,11 +12,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
-SOBJS = start.o lowlevel_init.o +SOBJS = start.o crt0.o lowlevel_init.o COBJS = nand_boot_fsl_nfc.o
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm1136/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -49,6 +50,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm1136/%.S $(CC) $(AFLAGS) -c -o $@ $<
+$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S + $(CC) $(AFLAGS) -c -o $@ $< + $(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S $(CC) $(AFLAGS) -c -o $@ $<
diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile index becf7fa..825f06d 100644 --- a/nand_spl/board/karo/tx25/Makefile +++ b/nand_spl/board/karo/tx25/Makefile @@ -33,11 +33,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/karo/tx25/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -70,6 +71,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S $(CC) $(AFLAGS) -c -o $@ $<
+$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S + $(CC) $(AFLAGS) -c -o $@ $< + $(obj)%.o: $(SRCTREE)/board/karo/tx25/%.S $(CC) $(AFLAGS) -c -o $@ $<
Remove code such as unneeded includes or labels. These removals have no functional effect.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v2: - removed useless includes in arm926ejs and arm925t
arch/arm/cpu/arm925t/start.S | 4 ---- arch/arm/cpu/arm926ejs/start.S | 6 ------ 2 files changed, 10 deletions(-)
diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 82f5b8b..e8d6d71 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -34,10 +34,6 @@ #include <config.h> #include <version.h>
-#if defined(CONFIG_OMAP1510) -#include <./configs/omap1510.h> -#endif - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 3cdecd9..66a8b65 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -36,12 +36,6 @@ #include <common.h> #include <version.h>
-#if defined(CONFIG_OMAP1610) -#include <./configs/omap1510.h> -#elif defined(CONFIG_OMAP730) -#include <./configs/omap730.h> -#endif - /* ************************************************************************* *
Changes in v2:
On beaglebone Rev A5 Tested-by: Tom Rini trini@ti.com Acked-by: Tom Rini trini@ti.com
Hi Albert,
On Tue, Nov 27, 2012 at 4:43 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Also, rewrite the C runtime setup and make functions board_init_*() and relocate_code() behave according to normal C semantics (no jumping across the C stack any more, etc).
I tested this on Seaboard (Tegra 20).
Tested-by: Simon Glass sjg@chromium.org
I tried to test it on a snow (exynos5250) but couldn't really sync up with our tree, so gave up. I am not completely sure about how the CONFIG_SPL_BUILD stuff fits together in start.S and I got a build error I wasn't sure how to correct (arch/arm/cpu/armv7/start.S:179: undefined reference to `relocate_done')
Hi Simon,
On Wed, 28 Nov 2012 13:18:57 -0800, Simon Glass sjg@chromium.org wrote:
Hi Albert,
Thansk Simon.
In file arch/arm/cpu/armv7/start.S, line 179 uses relocate_done and line 228 provides it, and there is no preprocessor conditional in-between, so I fail to see how you could get this error.
Is your tree (and branch) available so that I can try and see the issue for myself? Either it'll uncover a problem in my patch series, or it'll help you merge it (or both).
Amicalement,
Hi Albert,
On Wed, Nov 28, 2012 at 2:34 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Simon,
Hi Albert,
Thansk Simon.
OK I will try a bit harder and come back to you. Sorry I can't do that immediately but will be soon...
Amicalement,
Albert.
Hi Simon,
Thansk Simon.
Did you manage to reproduce or sort out this issue?
Amicalement,
Hi Albert,
On Sun, Dec 23, 2012 at 7:03 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Simon,
Thansk Simon.
No, I was hoping that I would be able to test upstream U-Boot on snow (waiting on some memory patches to appear), but that hasn't happened. I will have another go at working out the problem - either this week or next depending on when I can set aside the time for it. However, please don't hold up the series for it.
Amicalement,
Albert.
Hi Albert,
On Wed, Dec 26, 2012 at 12:41 PM, Simon Glass sjg@chromium.org wrote:
Hi Albert,
Hi Simon,
Thansk Simon.
I have tested this on snow at last. My problem was basically the distance between our tree and upstream - we are just coming up to a rebase so are at the furthest point.
Tested-by: Simon Glass sjg@chromium.org Acked-by: Simon Glass sjg@chromium.org
Amicalement,
Albert.
Tested on hawkboard. Spl and u-boot images boot up fine with these changes.
Tested-by: Sughosh Ganu urwithsughosh@gmail.com
-sughosh
Changes in v4:
Changes in v3:
Changes in v2:
This change breaks sandbox, powerpc, mips and m68k. I suspect fixing sandbox will be the easiest test-case and catch all of the others.
Hi Tom,
Changes in v4:
Changes in v3:
Changes in v2:
-- Tom
Ok, then, rolling back ARM and pushing v5 to fix breakage on non-ARM arches.
Amicalement,
The goal of this series is to scrub the start.S files which have proliferated across arch/arm and eliminate code redundancy.
Further factorization is possible: relocate_code() can be moved out and possibly rewritten in C now that it has plain C function semantics; exception handlers should also be pretty much cpu-independent.
Eventually, start.S files should disappear or contain CPU-specific code only.
The whole changes have been build-tested across all ARM targets using MAKEALL -a arm.
Changes in v5: - Fixed build on non-ARM architectures
Albert ARIBAUD (2): arm: move C runtime setup code in crt0.S arm: remove useless code in start.S files
arch/arm/cpu/arm1136/start.S | 71 +++--------- arch/arm/cpu/arm1176/start.S | 62 ++--------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 65 ++--------- arch/arm/cpu/arm926ejs/start.S | 86 ++------------ arch/arm/cpu/arm946es/start.S | 56 ++-------- arch/arm/cpu/arm_intcm/start.S | 63 ++--------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++--------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------- arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 173 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 14 +++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 326 insertions(+), 688 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v5: - Fixed build on non-ARM architectures
arch/arm/cpu/arm1136/start.S | 71 +++--------- arch/arm/cpu/arm1176/start.S | 62 ++--------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 61 ++-------- arch/arm/cpu/arm926ejs/start.S | 80 ++----------- arch/arm/cpu/arm946es/start.S | 56 ++-------- arch/arm/cpu/arm_intcm/start.S | 63 ++--------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++--------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------- arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 173 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 14 +++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 326 insertions(+), 678 deletions(-) create mode 100644 arch/arm/lib/crt0.S
GLCOBJS += div0.o
+SOBJS-y += crt0.o + ifndef CONFIG_SPL_BUILD COBJS-y += board.o COBJS-y += bootm.o diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index e0cb635..0459d0c 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -279,11 +279,6 @@ void board_init_f(ulong bootflag)
gd->mon_len = _bss_end_ofs; @@ -465,10 +460,6 @@ void board_init_f(ulong bootflag) gd->fdt_blob = new_fdt; } memcpy(id, (void *)gd, sizeof(gd_t)); - - relocate_code(addr_sp, id, addr); - - /* NOTREACHED - relocate_code() does not return */ }
#if !defined(CONFIG_SYS_NO_FLASH) @@ -493,8 +484,6 @@ void board_init_r(gd_t *id, ulong dest_addr) ulong flash_size; #endif
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S new file mode 100644 index 0000000..4f60958 --- /dev/null +++ b/arch/arm/lib/crt0.S @@ -0,0 +1,173 @@ +/* + * crt0 - C-runtime startup Code for ARM U-Boot + * + * Copyright (c) 2012 Albert ARIBAUD albert.u.boot@aribaud.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm-offsets.h> + +/* + * This file handles the target-independent stages of the U-Boot + * start-up where a C runtime environment is needed. Its entry point + * is _main and is branched into from the target's start.S file. + * + * _main execution sequence is: + * + * 1. Set up initial environment for calling board_init_f(). + * This environment only provides a stack and a place to store + * the GD ('global data') structure, both located in some readily + * available RAM (SRAM, locked cache...). In this context, VARIABLE + * global data, initialized or not (BSS), are UNAVAILABLE; only + * CONSTANT initialized data are available. + * + * 2. Call board_init_f(). This function prepares the hardware for + * execution from system RAM (DRAM, DDR...) As system RAM may not + * be available yet, , board_init_f() must use the current GD to + * store any data which must be passed on to later stages. These + * data include the relocation destination, the future stack, and + * the future GD location. + * + * (the following applies only to non-SPL builds) + * + * 3. Set up intermediate environment where the stack and GD are the + * ones allocated by board_init_f() in system RAM, but BSS and + * initialized non-const data are still not available. + * + * 4. Call relocate_code(). This function relocates U-Boot from its + * current location into the relocation destination computed by + * board_init_f(). + * + * 5. Set up final environment for calling board_init_r(). This + * environment has BSS (initialized to 0), initialized non-const + * data (initialized to their intended value), and stack in system + * RAM. GD has retained values set by board_init_f(). Some CPUs + * have some work left to do at this point regarding memory, so + * call c_runtime_cpu_setup. + * + * 6. Branch to either nand_boot() or board_init_r(). + */ + +/* + * declare nand_boot() or board_init_r() to jump to at end of crt0 + */ + +#if defined(CONFIG_NAND_SPL) + +.globl nand_boot + +#elif ! defined(CONFIG_SPL_BUILD) + +.globl board_init_r + +#endif + +/* + * start and end of BSS + */ + +.globl __bss_start +.globl __bss_end__ + +/* + * entry point of crt0 sequence + */ + +.global _main + +_main: + +/* + * Set up initial C runtime environment and call board_init_f(0). + */ + +#if defined(CONFIG_NAND_SPL) + /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr sp, =(CONFIG_SPL_STACK) +#else + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + sub sp, #GD_SIZE /* allocate one GD above SP */ + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r8, sp /* GD is above SP */ + mov r0, #0 + bl board_init_f + +#if ! defined(CONFIG_SPL_BUILD) + +/* + * Set up intermediate environment (new sp and gd) and call + * relocate_code(addr_sp, gd, addr_moni). Trick here is that + * we'll return 'here' but relocated. + */ + + ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + ldr r8, [r8, #GD_BD] /* r8 = gd->bd */ + sub r8, r8, #GD_SIZE /* new GD is below bd */ + + adr lr, here + ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ + add lr, lr, r0 + ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ + mov r1, r8 /* r1 = gd */ + ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + b relocate_code +here: + +/* Set up final (full) environment */ + + bl c_runtime_cpu_setup /* we still call old routine here */ + + ldr r0, =__bss_start /* this is auto-relocated! */ + ldr r1, =__bss_end__ /* this is auto-relocated! */ + + mov r2, #0x00000000 /* prepare zero to clear BSS */ + +clbss_l:cmp r0, r1 /* while not at end of BSS */ + strlo r2, [r0] /* clear 32-bit BSS word */ + addlo r0, r0, #4 /* move to next */ + blo clbss_l + + bl coloured_LED_init + bl red_led_on + +#if defined(CONFIG_NAND_SPL) + + /* call _nand_boot() */ + ldr pc, =nand_boot + +#else + + /* call board_init_r(gd_t *id, ulong dest_addr) */ + mov r0, r8 /* gd_t */ + ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ + /* call board_init_r */ + ldr pc, =board_init_r /* this is auto-relocated! */ + +#endif + + /* we should not return here. */ + +#endif diff --git a/include/common.h b/include/common.h index d0bf1e8..2f2578b 100644 --- a/include/common.h +++ b/include/common.h @@ -300,7 +300,7 @@ int abortboot(int bootdelay); extern char console_buffer[];
/* arch/$(ARCH)/lib/board.c */ -void board_init_f (ulong) __attribute__ ((noreturn)); +void board_init_f(ulong); void board_init_r (gd_t *, ulong) __attribute__ ((noreturn)); int checkboard (void); int checkflash (void); diff --git a/include/configs/socfpga_cyclone5.h b/include/configs/socfpga_cyclone5.h index 42077bd..5633d2a 100644 --- a/include/configs/socfpga_cyclone5.h +++ b/include/configs/socfpga_cyclone5.h @@ -65,7 +65,7 @@ #define CONFIG_SYS_BOOTMAPSZ ((256*1024*1024) - (4*1024))
#define CONFIG_SPL_RAM_DEVICE -#define CONFIG_SPL_STACK (&__stack_start) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SYS_SPL_MALLOC_START ((unsigned long) (&__malloc_start)) #define CONFIG_SYS_SPL_MALLOC_SIZE (&__malloc_end - &__malloc_start)
diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index c88f5d4..8546a52 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -28,5 +28,19 @@ int main(void) DEFINE(GENERATED_BD_INFO_SIZE, (sizeof(struct bd_info) + 15) & ~15);
+ DEFINE(GD_SIZE, sizeof(struct global_data)); + + DEFINE(GD_BD, offsetof(struct global_data, bd)); + +#if defined(CONFIG_ARM) + + DEFINE(GD_RELOCADDR, offsetof(struct global_data, relocaddr)); + + DEFINE(GD_RELOC_OFF, offsetof(struct global_data, reloc_off)); + + DEFINE(GD_START_ADDR_SP, offsetof(struct global_data, start_addr_sp)); + +#endif + return 0; } diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile index f67ed09..fd0dfc1 100644 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -12,11 +12,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm1136/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -50,6 +51,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm1136/%.S $(CC) $(AFLAGS) -c -o $@ $<
diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile index b27189d..82489d2 100644 --- a/nand_spl/board/karo/tx25/Makefile +++ b/nand_spl/board/karo/tx25/Makefile @@ -33,11 +33,12 @@ LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S +SRCS += $(SRCTREE)/arch/arm/lib/crt0.S SRCS += $(SRCTREE)/board/karo/tx25/lowlevel_init.S OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) __OBJS := $(SOBJS) $(COBJS) @@ -71,6 +72,9 @@ $(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) $(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S $(CC) $(AFLAGS) -c -o $@ $<
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - removed useless includes in arm926ejs and arm925t
Hi Albert,
On Tue, 8 Jan 2013 21:18:01 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Changes in v5:
Changes in v4:
Changes in v3:
- various clarifications and typo fixes
- fixed wrong LED calls conditional
- fixed open comment eating some code
- fixed code overrun in SPL case
Changes in v2:
Applied to u-boot-arm/master with a rollback from the Marvell PR and v4 of this patch series.
Amicalement,
On Tue, 27 Nov 2012 13:43:24 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Changes in v4:
Changes in v3:
Changes in v2:
-- 1.7.10.4
Tom,
These have been tested on several boards. Can it go in? If it can, then I would like to take it in u-boot-arm/master with your Acked-By.
Amicalement,
Changes in v4:
Changes in v3:
Changes in v2:
Applied to u-boot-arm/master.
Amicalement,
participants (7)
Albert ARIBAUD
Andreas Bießmann
Sughosh Ganu
Vikram Narayanan
