[U-Boot] [PATCH] SPI: cmd_spi.c: add option to specify bus and mode
To facilitate better testing of SPI peripherals, add the possibility to specify bus and SPI mode to the "sspi" command
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- common/cmd_spi.c | 33 +++++++++++++++++++++++---------- 1 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/common/cmd_spi.c b/common/cmd_spi.c index bafa217..fd1b1f5 100644 --- a/common/cmd_spi.c +++ b/common/cmd_spi.c @@ -47,7 +47,9 @@ /* * Values from last command. */ -static unsigned int device; +static unsigned int bus; +static unsigned int cs; +static unsigned int mode; static int bitlen; static uchar dout[MAX_SPI_BYTES]; static uchar din[MAX_SPI_BYTES]; @@ -78,8 +80,18 @@ int do_spi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
if ((flag & CMD_FLAG_REPEAT) == 0) { - if (argc >= 2) - device = simple_strtoul(argv[1], NULL, 10); + if (argc >= 2) { + mode = CONFIG_DEFAULT_SPI_MODE; + bus = simple_strtoul(argv[1], &cp, 10); + if (*cp == ':') { + cs = simple_strtoul(cp+1, &cp, 10); + if (*cp == '.'); + mode = simple_strtoul(cp+1, NULL, 10); + } else { + cs = bus; + bus = CONFIG_DEFAULT_SPI_BUS; + } + } if (argc >= 3) bitlen = simple_strtoul(argv[2], NULL, 10); if (argc >= 4) { @@ -107,15 +119,13 @@ int do_spi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- /* FIXME: Make these parameters run-time configurable */ - slave = spi_setup_slave(CONFIG_DEFAULT_SPI_BUS, device, 1000000, - CONFIG_DEFAULT_SPI_MODE); + slave = spi_setup_slave(bus, cs, 1000000, mode); if (!slave) { - printf("Invalid device %d, giving up.\n", device); + printf("Invalid bus %d cs %d, giving up.\n", bus, cs); return 1; }
- debug ("spi chipsel = %08X\n", device); + debug ("spi bus=%02x cs=%02x\n", bus, cs);
spi_claim_bus(slave); if(spi_xfer(slave, bitlen, dout, din, @@ -139,8 +149,11 @@ int do_spi (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( sspi, 5, 1, do_spi, "SPI utility commands", - "<device> <bit_len> <dout> - Send <bit_len> bits from <dout> out the SPI\n" - "<device> - Identifies the chip select of the device\n" + "<cs> <bit_len> <dout> - Send <bit_len> bits from <dout> out the SPI\n" + "<bus>:<cs>[.<mode>] - extended form\n" + "<bus> - Identifies the SPI bus of the device\n" + "<cs> - Identifies the chip select of the device\n" + "<mode> - Identifies the SPI mode to use for the transfer\n" "<bit_len> - Number of bits to send (base 10)\n" "<dout> - Hexadecimal string that gets sent" );
- slave = spi_setup_slave(bus, cs, 1000000, mode);
if (!slave) {
- printf("Invalid bus %d cs %d, giving up.\n", bus, cs);
i would use the simple naming convention like so: printf("Invalid device %d:%d\n", bus, cs);
- "<cs> <bit_len> <dout> - Send <bit_len> bits from <dout> out the SPI\n"
- "<bus>:<cs>[.<mode>] - extended form\n"
- "<bus> - Identifies the SPI bus of the device\n"
- "<cs> - Identifies the chip select of the device\n"
- "<mode> - Identifies the SPI mode to use for the transfer\n"
this usage string no longer makes sense. how about: "[<bus>:]<cs>[.<mode>] <bit_len> <dout> - Send <bit_len> bits from <dout> out the SPI\n" -mike
were you going to send an updated version ? -mike
On Tuesday, August 24, 2010 04:05:19 Reinhard Meyer wrote:
Dear Mike Frysinger,
Soon. Currently I have other issues and a rather "dirty" working tree :)
dont sweat it. just wanted to make sure it wasnt lost/forgotten/ignored. -mike
The problem is, that without blowing up the parser even more, only 2 forms of the command are valid:
the classic form
or
<bus>:<cs>[.<mode>] <bit_len> <dout>
Since this command is mainly used for testing/debugging hardware, I saw no need to allow the form
<cs>.<mode> <bit_len> <dout>
If thats ok, I can make a patch with the help fixed.
Best Regards Reinhard
the classic form
or
how so ? the bus:cs.mode field is always going to be one argv, and your patch has it so that argv[1] is always parsed against this form. i dont see where this limitation is that you're seeing ... -mike
<bus>:<cs>[.<mode>]<bit_len> <dout>
Currently, without a ":", the "." part won't be handled. But I see that a simple rearrangement would solve this. I'll fix and test that.
Reinhard
Mike Frysinger
Reinhard Meyer
