[PATCH v5 0/3] rockchip: sdhci: Add HS400 Enhanced Strobe support
This series implements support for the HS400 Enhanced Strobe mode on the Rockchip SDHCI driver, for both RK3399 and RK3568. To test, I'm building for chromebook_kevin with the following configs enabled:
+CONFIG_MMC_SPEED_MODE_SET=y [...] CONFIG_MMC_PWRSEQ=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y
and running roughly:
$ mmc rescan [0|1|3|10|11|12] $ mmc info $ mmc part $ load mmc 0:1 0xd0000000 256MiB.bin $ load mmc 0:1 0xd0000000 16MiB.bin $ load mmc 0:1 0xd0000000 8MiB.bin
Here's the differences in info and speeds I get with this:
Mode | Bus Speed | Bus Width -----------------------+--------------+-------------- MMC Legacy | 25000000 | 8-bit MMC High Speed (26MHz) | 26000000 | 8-bit MMC High Speed (52MHz) | 52000000 | 8-bit HS200 (200MHz) | 200000000 | 8-bit HS400 (200MHz) | 200000000 | 8-bit DDR HS400ES (200MHz) | 200000000 | 8-bit DDR
Mode | 256 MiB Load | 16 MiB Load | 8 MiB Load -----------------------+--------------+--------------+-------------- MMC Legacy | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (26MHz) | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (52MHz) | ~43.7 MiB/s | ~42.8 MiB/s | ~41.7 MiB/s HS200 (200MHz) | ~161.2 MiB/s | ~149.5 MiB/s | ~137.9 MiB/s HS400 (200MHz) | ~254.5 MiB/s | ~235.3 MiB/s | ~216.2 MiB/s HS400ES (200MHz) | ~254.7 MiB/s | ~238.8 MiB/s | ~216.2 MiB/s
Hope I haven't missed anything. Enabling the configs above for each board is left to board maintainers as I can't test on those boards.
Changes in v5: - Incorporate RK3568 HS400ES fixes from Yifeng Zhao: - Use DWCMSHC_CTRL_HS400 = 0x7, instead of SDHCI_CTRL_HS400 = 0x5 - Configure DWCMSHC_CARD_IS_EMMC in rk3568_sdhci_set_ios_post() - Configure DLL_STRBIN and DLL_TXCLK for HS400. - Drop re-init fix already merged to master
v4: https://patchwork.ozlabs.org/project/uboot/list/?series=283482&state=*
Changes in v4: - Add comment for SDHCI set_enhanced_strobe() operation - Add comment for Rockchip SDHCI set_enhanced_strobe() driver data op
v3: https://patchwork.ozlabs.org/project/uboot/list/?series=281327&state=*
Changes in v3: - Set DWCMSHC_CARD_IS_EMMC bit in rk3568_emmc_phy_init()
v2: https://patchwork.ozlabs.org/project/uboot/list/?series=280494&state=*
Changes in v2: - Unset ES bit in rk3399 set_control_reg() to fix a reinit issue - Don't use unnecessary & for function pointer in ops struct - Rename rk3399_set_enhanced_strobe -> rk3399_sdhci_set_enhanced_strobe - Rename rk3568_set_enhanced_strobe -> rk3568_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES - Rewrote cover letter
v1: https://patchwork.ozlabs.org/project/uboot/list/?series=269768&state=*
Alper Nebi Yasak (3): mmc: sdhci: Add HS400 Enhanced Strobe support rockchip: sdhci: Add HS400 Enhanced Strobe support for RK3399 rockchip: sdhci: Add HS400 Enhanced Strobe support for RK3568
drivers/mmc/rockchip_sdhci.c | 117 +++++++++++++++++++++++++++++++++-- drivers/mmc/sdhci.c | 18 ++++++ include/sdhci.h | 12 ++++ 3 files changed, 141 insertions(+), 6 deletions(-)
Delegate setting the Enhanced Strobe configuration to individual drivers if they set a function for it. Return -ENOTSUPP if they do not, like what the MMC uclass does.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
(no changes since v4)
Changes in v2: - Add tag: "Reviewed-by: Jaehoon Chung jh80.chung@samsung.com"
drivers/mmc/sdhci.c | 18 ++++++++++++++++++ include/sdhci.h | 12 ++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 766e4a6b0c5e..bf989a594f7e 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -513,6 +513,7 @@ void sdhci_set_uhs_timing(struct sdhci_host *host) reg |= SDHCI_CTRL_UHS_SDR104; break; case MMC_HS_400: + case MMC_HS_400_ES: reg |= SDHCI_CTRL_HS400; break; default: @@ -666,6 +667,7 @@ static int sdhci_set_ios(struct mmc *mmc) mmc->selected_mode == MMC_DDR_52 || mmc->selected_mode == MMC_HS_200 || mmc->selected_mode == MMC_HS_400 || + mmc->selected_mode == MMC_HS_400_ES || mmc->selected_mode == UHS_SDR25 || mmc->selected_mode == UHS_SDR50 || mmc->selected_mode == UHS_SDR104 || @@ -799,6 +801,19 @@ static int sdhci_wait_dat0(struct udevice *dev, int state, return -ETIMEDOUT; }
+#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) +static int sdhci_set_enhanced_strobe(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); + struct sdhci_host *host = mmc->priv; + + if (host->ops && host->ops->set_enhanced_strobe) + return host->ops->set_enhanced_strobe(host); + + return -ENOTSUPP; +} +#endif + const struct dm_mmc_ops sdhci_ops = { .send_cmd = sdhci_send_command, .set_ios = sdhci_set_ios, @@ -808,6 +823,9 @@ const struct dm_mmc_ops sdhci_ops = { .execute_tuning = sdhci_execute_tuning, #endif .wait_dat0 = sdhci_wait_dat0, +#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) + .set_enhanced_strobe = sdhci_set_enhanced_strobe, +#endif }; #else static const struct mmc_ops sdhci_ops = { diff --git a/include/sdhci.h b/include/sdhci.h index c8d69f5a63f7..88f1917480b6 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -272,6 +272,18 @@ struct sdhci_ops { int (*platform_execute_tuning)(struct mmc *host, u8 opcode); int (*set_delay)(struct sdhci_host *host); int (*deferred_probe)(struct sdhci_host *host); + + /** + * set_enhanced_strobe() - Set HS400 Enhanced Strobe config + * + * This is called after setting the card speed and mode to + * HS400 ES, and should set any host-specific configuration + * necessary for it. + * + * @host: SDHCI host structure + * Return: 0 if successful, -ve on error + */ + int (*set_enhanced_strobe)(struct sdhci_host *host); };
#define ADMA_MAX_LEN 65532
HI Alper,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v4:
Changes in v2:
- case MMC_HS_400_ES: reg |= SDHCI_CTRL_HS400; break; default:
mmc->selected_mode == UHS_SDR25 || mmc->selected_mode == UHS_SDR50 || mmc->selected_mode == UHS_SDR104 ||mmc->selected_mode == MMC_HS_400_ES ||
- struct mmc *mmc = mmc_get_mmc_dev(dev);
- struct sdhci_host *host = mmc->priv;
- if (host->ops && host->ops->set_enhanced_strobe)
- return -ENOTSUPP;
+} +#endif
- const struct dm_mmc_ops sdhci_ops = { .send_cmd = sdhci_send_command, .set_ios = sdhci_set_ios,
- .set_enhanced_strobe = sdhci_set_enhanced_strobe,
* necessary for it.
On RK3399, a register bit must be set to enable Enhanced Strobe. Let the Rockchip SDHCI driver set it when Enhanced Strobe configuration is requested. However, having it set makes the lower-speed modes stop working and makes reinitialization fail, so let it be unset as needed in set_control_reg().
This is mostly ported from Linux's Arasan SDHCI driver which happens to be the underlying IP. (drivers/mmc/host/sdhci-of-arasan.c in Linux tree).
Changes in v5: - Add tag: "Reviewed-by: Jaehoon Chung jh80.chung@samsung.com"
Changes in v4: - Add comment for Rockchip SDHCI set_enhanced_strobe() driver data op
Changes in v2: - Unset ES bit in rk3399 set_control_reg() to fix a reinit issue - Don't use unnecessary & for function pointer in ops struct - Rename rk3399_set_enhanced_strobe -> rk3399_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES
drivers/mmc/rockchip_sdhci.c | 53 ++++++++++++++++++++++++++++++++++++ 1 file changed, 53 insertions(+)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index b91df05de4ff..f4d5a59036a2 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -42,6 +42,9 @@ ((((x) >> PHYCTRL_DLLRDY_SHIFT) & PHYCTRL_DLLRDY_MASK) ==\ PHYCTRL_DLLRDY_DONE)
+#define ARASAN_VENDOR_REGISTER 0x78 +#define ARASAN_VENDOR_ENHANCED_STROBE BIT(0) + /* Rockchip specific Registers */ #define DWCMSHC_EMMC_DLL_CTRL 0x800 #define DWCMSHC_EMMC_DLL_CTRL_RESET BIT(1) @@ -117,6 +120,19 @@ struct sdhci_data { * Return: 0 if successful, -ve on error */ int (*set_ios_post)(struct sdhci_host *host); + + /** + * set_enhanced_strobe() - Set HS400 Enhanced Strobe config + * + * This is the set_enhanced_strobe() SDHCI operation that should + * be used for the hardware this driver data is associated with. + * Normally, this is used to set any host-specific configuration + * necessary for HS400 ES. + * + * @host: SDHCI host structure + * Return: 0 if successful, -ve on error + */ + int (*set_enhanced_strobe)(struct sdhci_host *host); };
static int rk3399_emmc_phy_init(struct udevice *dev) @@ -206,6 +222,21 @@ static int rk3399_emmc_get_phy(struct udevice *dev) return 0; }
+static int rk3399_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct mmc *mmc = host->mmc; + u32 vendor; + + vendor = sdhci_readl(host, ARASAN_VENDOR_REGISTER); + if (mmc->selected_mode == MMC_HS_400_ES) + vendor |= ARASAN_VENDOR_ENHANCED_STROBE; + else + vendor &= ~ARASAN_VENDOR_ENHANCED_STROBE; + sdhci_writel(host, vendor, ARASAN_VENDOR_REGISTER); + + return 0; +} + static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) { struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); @@ -217,6 +248,15 @@ static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) rk3399_emmc_phy_power_off(priv->phy);
sdhci_set_control_reg(host); + + /* + * Reinitializing the device tries to set it to lower-speed modes + * first, which fails if the Enhanced Strobe bit is set, making + * the device impossible to use. Set the correct value here to + * let reinitialization attempts succeed. + */ + if (CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT)) + rk3399_sdhci_set_enhanced_strobe(host); };
static int rk3399_sdhci_set_ios_post(struct sdhci_host *host) @@ -409,10 +449,22 @@ static int rockchip_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) return ret; }
+static int rockchip_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); + + if (data->set_enhanced_strobe) + return data->set_enhanced_strobe(host); + + return -ENOTSUPP; +} + static struct sdhci_ops rockchip_sdhci_ops = { .set_ios_post = rockchip_sdhci_set_ios_post, .platform_execute_tuning = &rockchip_sdhci_execute_tuning, .set_control_reg = rockchip_sdhci_set_control_reg, + .set_enhanced_strobe = rockchip_sdhci_set_enhanced_strobe, };
static int rockchip_sdhci_probe(struct udevice *dev) @@ -495,6 +547,7 @@ static const struct sdhci_data rk3399_data = { .emmc_phy_init = rk3399_emmc_phy_init, .set_control_reg = rk3399_sdhci_set_control_reg, .set_ios_post = rk3399_sdhci_set_ios_post, + .set_enhanced_strobe = rk3399_sdhci_set_enhanced_strobe, };
static const struct sdhci_data rk3568_data = {
Thanks, - Kever
Changes in v5:
Changes in v4:
Changes in v2:
- /* Rockchip specific Registers */ #define DWCMSHC_EMMC_DLL_CTRL 0x800 #define DWCMSHC_EMMC_DLL_CTRL_RESET BIT(1)
- struct mmc *mmc = host->mmc;
- u32 vendor;
- vendor = sdhci_readl(host, ARASAN_VENDOR_REGISTER);
- if (mmc->selected_mode == MMC_HS_400_ES)
- else
- sdhci_writel(host, vendor, ARASAN_VENDOR_REGISTER);
- static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) { struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host);
- struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host);
- struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev);
- if (data->set_enhanced_strobe)
- return -ENOTSUPP;
On RK3568, a register bit must be set to enable Enhanced Strobe. However, it appears that the address of this register may differ from vendor to vendor and should be read from the underlying MMC IP. Let the Rockchip SDHCI driver read this address and set the relevant bit when Enhanced Strobe configuration is requested.
The IP uses a custom mode select value (0x7) for HS400, use that instead of the common but non-standard SDHCI_CTRL_HS400 value (0x5). Also add some necessary DLL_STRBIN and DLL_TXCLK configuration for HS400.
Additionally, a bit signifying that the connected hardware is an eMMC chip must be set to enable Data Strobe for HS400 and HS400ES modes. Also make the driver set this bit as appropriate.
This is partly ported from Linux's Synopsys DWC MSHC driver which happens to be the underlying IP. (drivers/mmc/host/sdhci-of-dwcmshc.c in Linux tree).
Co-developed-by: Yifeng Zhao yifeng.zhao@rock-chips.com Signed-off-by: Yifeng Zhao yifeng.zhao@rock-chips.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- This is a fixed version I received off-list from Yifeng. I didn't modify the diff, but added a paragraph in the commit message mentioning their changes and adjusted the signoffs in the end.
Didn't add the Reviewed-by tag due to changes.
Changes in v2: - Rename rk3568_set_enhanced_strobe -> rk3568_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES
drivers/mmc/rockchip_sdhci.c | 64 ++++++++++++++++++++++++++++++++---- 1 file changed, 58 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index f4d5a59036a2..f3f9d83ba36f 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -22,6 +22,8 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/hardware.h>
+/* DWCMSHC specific Mode Select value */ +#define DWCMSHC_CTRL_HS400 0x7 /* 400KHz is max freq for card ID etc. Use that as min */ #define EMMC_MIN_FREQ 400000 #define KHz (1000) @@ -45,6 +47,14 @@ #define ARASAN_VENDOR_REGISTER 0x78 #define ARASAN_VENDOR_ENHANCED_STROBE BIT(0)
+/* DWC IP vendor area 1 pointer */ +#define DWCMSHC_P_VENDOR_AREA1 0xe8 +#define DWCMSHC_AREA1_MASK GENMASK(11, 0) +/* Offset inside the vendor area 1 */ +#define DWCMSHC_EMMC_CONTROL 0x2c +#define DWCMSHC_CARD_IS_EMMC BIT(0) +#define DWCMSHC_ENHANCED_STROBE BIT(8) + /* Rockchip specific Registers */ #define DWCMSHC_EMMC_DLL_CTRL 0x800 #define DWCMSHC_EMMC_DLL_CTRL_RESET BIT(1) @@ -60,8 +70,14 @@ #define DWCMSHC_EMMC_DLL_INC_VALUE 2 #define DWCMSHC_EMMC_DLL_INC 8 #define DWCMSHC_EMMC_DLL_DLYENA BIT(27) -#define DLL_TXCLK_TAPNUM_DEFAULT 0x10 -#define DLL_STRBIN_TAPNUM_DEFAULT 0x3 +#define DLL_TXCLK_TAPNUM_DEFAULT 0xA + +#define DLL_STRBIN_TAPNUM_DEFAULT 0x8 +#define DLL_STRBIN_TAPNUM_FROM_SW BIT(24) +#define DLL_STRBIN_DELAY_NUM_SEL BIT(26) +#define DLL_STRBIN_DELAY_NUM_OFFSET 16 +#define DLL_STRBIN_DELAY_NUM_DEFAULT 0x16 + #define DLL_TXCLK_TAPNUM_FROM_SW BIT(24) #define DWCMSHC_EMMC_DLL_LOCKED BIT(8) #define DWCMSHC_EMMC_DLL_TIMEOUT BIT(9) @@ -327,7 +343,8 @@ static int rk3568_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clo sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_TXCLK);
extra = DWCMSHC_EMMC_DLL_DLYENA | - DLL_STRBIN_TAPNUM_DEFAULT; + DLL_STRBIN_TAPNUM_DEFAULT | + DLL_STRBIN_TAPNUM_FROM_SW; sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_STRBIN); } else { /* reset the clock phase when the frequency is lower than 100MHz */ @@ -335,7 +352,15 @@ static int rk3568_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clo extra = DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL; sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK); sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_TXCLK); - sdhci_writel(host, 0, DWCMSHC_EMMC_DLL_STRBIN); + /* + * Before switching to hs400es mode, the driver will enable + * enhanced strobe first. PHY needs to configure the parameters + * of enhanced strobe first. + */ + extra = DWCMSHC_EMMC_DLL_DLYENA | + DLL_STRBIN_DELAY_NUM_SEL | + DLL_STRBIN_DELAY_NUM_DEFAULT << DLL_STRBIN_DELAY_NUM_OFFSET; + sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_STRBIN); }
return 0; @@ -346,11 +371,30 @@ static int rk3568_emmc_get_phy(struct udevice *dev) return 0; }
+static int rk3568_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct mmc *mmc = host->mmc; + u32 vendor; + int reg; + + reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK) + + DWCMSHC_EMMC_CONTROL; + + vendor = sdhci_readl(host, reg); + if (mmc->selected_mode == MMC_HS_400_ES) + vendor |= DWCMSHC_ENHANCED_STROBE; + else + vendor &= ~DWCMSHC_ENHANCED_STROBE; + sdhci_writel(host, vendor, reg); + + return 0; +} + static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; uint clock = mmc->tran_speed; - u32 reg; + u32 reg, vendor_reg;
if (!clock) clock = mmc->clock; @@ -360,8 +404,15 @@ static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) if (mmc->selected_mode == MMC_HS_400 || mmc->selected_mode == MMC_HS_400_ES) { reg = sdhci_readw(host, SDHCI_HOST_CONTROL2); reg &= ~SDHCI_CTRL_UHS_MASK; - reg |= SDHCI_CTRL_HS400; + reg |= DWCMSHC_CTRL_HS400; sdhci_writew(host, reg, SDHCI_HOST_CONTROL2); + + vendor_reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK) + + DWCMSHC_EMMC_CONTROL; + /* set CARD_IS_EMMC bit to enable Data Strobe for HS400 */ + reg = sdhci_readw(host, vendor_reg); + reg |= DWCMSHC_CARD_IS_EMMC; + sdhci_writew(host, reg, vendor_reg); } else { sdhci_set_uhs_timing(host); } @@ -554,6 +605,7 @@ static const struct sdhci_data rk3568_data = { .get_phy = rk3568_emmc_get_phy, .emmc_phy_init = rk3568_emmc_phy_init, .set_ios_post = rk3568_sdhci_set_ios_post, + .set_enhanced_strobe = rk3568_sdhci_set_enhanced_strobe, };
static const struct udevice_id sdhci_ids[] = {
Hi all,
This series have been tested successfully on the RK3568 EVB1.
Test info: => mmc list mmc@fe2b0000: 1 mmc@fe310000: 0 (eMMC) mmc info Device: mmc@fe310000 Manufacturer ID: 45 OEM: 100 Name: DA601 Bus Speed: 200000000 Mode: HS400ES (200MHz) Rd Block Len: 512 MMC version 5.1 High Capacity: Yes Capacity: 14.7 GiB Bus Width: 8-bit DDR Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 14.7 GiB WRREL Boot Capacity: 4 MiB ENH RPMB Capacity: 4 MiB ENH Boot area 0 is not write protected Boot area 1 is not write protected => mmc read 0x30000000 0 100000 MMC read: dev # 0, block # 0, count 1048576 ... 1048576 blocks read: OK => mmc write 0x30000000 0 100000 MMC write: dev # 0, block # 0, count 1048576 ... 1048576 blocks written: OK
Test config: diff --git a/arch/arm/dts/rk3568-u-boot.dtsi b/arch/arm/dts/rk3568-u-boot.dtsi index 5a80dda275..bd98bd6191 100644 --- a/arch/arm/dts/rk3568-u-boot.dtsi +++ b/arch/arm/dts/rk3568-u-boot.dtsi @@ -49,6 +49,8 @@ bus-width = <8>; u-boot,dm-spl; mmc-hs200-1_8v; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; status = "okay"; };
diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index 435be99edf..313f618723 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -41,6 +41,10 @@ CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_VERBOSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
Best regards, Yifeng
Changes in v5:
Changes in v3:
Changes in v2:
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index f4d5a59036a2..f3f9d83ba36f 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -22,6 +22,8 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/hardware.h> +/* DWCMSHC specific Mode Select value */ +#define DWCMSHC_CTRL_HS400 0x7 /* 400KHz is max freq for card ID etc. Use that as min */ #define EMMC_MIN_FREQ 400000 #define KHz (1000) @@ -45,6 +47,14 @@ #define ARASAN_VENDOR_REGISTER 0x78 #define ARASAN_VENDOR_ENHANCED_STROBE BIT(0) +/* DWC IP vendor area 1 pointer */ +#define DWCMSHC_P_VENDOR_AREA1 0xe8 +#define DWCMSHC_AREA1_MASK GENMASK(11, 0) +/* Offset inside the vendor area 1 */ +#define DWCMSHC_EMMC_CONTROL 0x2c +#define DWCMSHC_CARD_IS_EMMC BIT(0) +#define DWCMSHC_ENHANCED_STROBE BIT(8)
#define DLL_TXCLK_TAPNUM_FROM_SW BIT(24) #define DWCMSHC_EMMC_DLL_LOCKED BIT(8) #define DWCMSHC_EMMC_DLL_TIMEOUT BIT(9) @@ -327,7 +343,8 @@ static int rk3568_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clo sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_TXCLK); extra = DWCMSHC_EMMC_DLL_DLYENA |
- DLL_STRBIN_TAPNUM_DEFAULT |
- DLL_STRBIN_TAPNUM_FROM_SW;
- Before switching to hs400es mode, the driver will enable
- enhanced strobe first. PHY needs to configure the parameters
- of enhanced strobe first.
- extra = DWCMSHC_EMMC_DLL_DLYENA |
- DLL_STRBIN_DELAY_NUM_SEL |
- DLL_STRBIN_DELAY_NUM_DEFAULT << DLL_STRBIN_DELAY_NUM_OFFSET;
- sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_STRBIN);
} return 0; @@ -346,11 +371,30 @@ static int rk3568_emmc_get_phy(struct udevice *dev) return 0; } +static int rk3568_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{
- u32 vendor;
- int reg;
- reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK)
- vendor = sdhci_readl(host, reg);
- vendor |= DWCMSHC_ENHANCED_STROBE;
- else
- vendor &= ~DWCMSHC_ENHANCED_STROBE;
- sdhci_writel(host, vendor, reg);
- u32 reg;
- u32 reg, vendor_reg;
- reg |= DWCMSHC_CTRL_HS400;
- vendor_reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK)
- /* set CARD_IS_EMMC bit to enable Data Strobe for HS400 */
- reg = sdhci_readw(host, vendor_reg);
- reg |= DWCMSHC_CARD_IS_EMMC;
- sdhci_writew(host, reg, vendor_reg);
- .set_enhanced_strobe = rk3568_sdhci_set_enhanced_strobe,
}; static const struct udevice_id sdhci_ids[] = { -- 2.35.1
Thanks, - Kever
Changes in v5:
Changes in v3:
Changes in v2:
- #define DLL_TXCLK_TAPNUM_FROM_SW BIT(24) #define DWCMSHC_EMMC_DLL_LOCKED BIT(8) #define DWCMSHC_EMMC_DLL_TIMEOUT BIT(9)
sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_STRBIN); } else { /* reset the clock phase when the frequency is lower than 100MHz */DLL_STRBIN_TAPNUM_FROM_SW;
- u32 vendor;
- int reg;
- else
- static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; uint clock = mmc->tran_speed;
- u32 reg;
sdhci_writew(host, reg, SDHCI_HOST_CONTROL2);reg |= DWCMSHC_CTRL_HS400;
} else { sdhci_set_uhs_timing(host); }sdhci_writew(host, reg, vendor_reg);
Mode | Bus Speed | Bus Width -----------------------+--------------+-------------- MMC Legacy | 25000000 | 8-bit MMC High Speed (26MHz) | 26000000 | 8-bit MMC High Speed (52MHz) | 52000000 | 8-bit HS200 (200MHz) | 200000000 | 8-bit HS400 (200MHz) | 200000000 | 8-bit DDR HS400ES (200MHz) | 200000000 | 8-bit DDR Mode | 256 MiB Load | 16 MiB Load | 8 MiB Load -----------------------+--------------+--------------+-------------- MMC Legacy | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (26MHz) | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (52MHz) | ~43.7 MiB/s | ~42.8 MiB/s | ~41.7 MiB/s HS200 (200MHz) | ~161.2 MiB/s | ~149.5 MiB/s | ~137.9 MiB/s HS400 (200MHz) | ~254.5 MiB/s | ~235.3 MiB/s | ~216.2 MiB/s HS400ES (200MHz) | ~254.7 MiB/s | ~238.8 MiB/s | ~216.2 MiB/s
Changes in v5:
v4: https://protect2.fireeye.com/v1/url?k=1188e6ba-7003f38c-11896df5-74fe485cbff...
Changes in v4:
v3: https://protect2.fireeye.com/v1/url?k=e0d60bb1-815d1e87-e0d780fe-74fe485cbff...
Changes in v3:
v2: https://protect2.fireeye.com/v1/url?k=418d7235-20066703-418cf97a-74fe485cbff...
Changes in v2:
v1: https://protect2.fireeye.com/v1/url?k=7057862b-11dc931d-70560d64-74fe485cbff...
Applied to u-boot-mmc.
Best Regards, Jaehoon Chung
Alper Nebi Yasak
Jaehoon Chung
Kever Yang
zyf@rock-chips.com
