[U-Boot] [PATCH v3 0/16] Introduce driver model serial uclass
This series adds support for a serial uclass, enabling serial drivers to be converted to use driver model.
Unfortunately this is quite a complicated process for a number of reasons:
- serial is used before relocation, but driver model does not support this - stdio member functions are not passed a device pointer, but driver model requires this (so does serial, but it uses an ugly work-around) - driver model requires malloc() but this is not available before relocation - for sandbox, if something goes wrong with the console, we still need to get an error message out through the fallback console
So this series relies on quite a few patches to address the above, as well as the serial uclass and an implementation for sandbox.
If you have limited time, please take a look at least at the uclass patch which is 'dm: Add a uclass for serial devices' (see include/serial.h).
With v3, exynos boards all build and an attempt has been made to add Tegra support via the ns16550 driver. This is so-far untested but is offered for review.
To see the current state of driver model, look at u-boot-dm.git branch 'working'.
Changes in v3: - Add new change to enhance lists_bind_fdt() - Add new patch for tegra serial port details - Add new patch to collect common baud rate code in ns16550 - Add new patch to enable driver model for seial on tegra - Add new patch to move baud rate calculation to ns16550.c - Add new patch to support driver model in ns16550 - Add new patch to use V_NS16550_CLK only in SPL builds - Automatically bind the console even if not marked for pre-relocation - Avoid reordering functions - Change pre-reloc fdt property to 'u-boot,dm-pre-reloc' - Fix typo in commit message
Changes in v2: - Add exynos serial support - Remove RFC status - Rename struct device to struct udevice - Split out core driver model patches into a separate set
Simon Glass (16): serial: Set up the 'priv' pointer when creating a serial device dm: Adjust lists_bind_fdt() to return the bound device dm: Add a uclass for serial devices Set up stdio earlier when using driver model sandbox: Convert serial driver to use driver model sandbox: serial: Support a coloured console sandbox: dts: Add a serial console node dm: exynos: Mark exynos5 console as pre-reloc dm: exynos: Move serial to driver model dm: Make driver model available before board_init() dm: serial: Move baud rate calculation to ns16550.c dm: serial: Collect common baud rate code in ns16550 dm: serial: Add driver model support for ns16550 tegra: dts: Add serial port details RFC: dm: tegra: Enable driver model for serial dm: tegra: Use V_NS16550_CLK only in SPL builds
arch/arm/dts/exynos5.dtsi | 1 + arch/arm/dts/tegra114-dalmore.dts | 1 + arch/arm/dts/tegra114.dtsi | 40 +++++ arch/arm/dts/tegra124-jetson-tk1.dts | 1 + arch/arm/dts/tegra124-venice2.dts | 1 + arch/arm/dts/tegra124.dtsi | 40 +++++ arch/arm/dts/tegra20-colibri_t20_iris.dts | 1 + arch/arm/dts/tegra20-harmony.dts | 1 + arch/arm/dts/tegra20-medcom-wide.dts | 1 + arch/arm/dts/tegra20-paz00.dts | 1 + arch/arm/dts/tegra20-plutux.dts | 1 + arch/arm/dts/tegra20-seaboard.dts | 1 + arch/arm/dts/tegra20-tec.dts | 1 + arch/arm/dts/tegra20-trimslice.dts | 1 + arch/arm/dts/tegra20-ventana.dts | 1 + arch/arm/dts/tegra20-whistler.dts | 1 + arch/arm/dts/tegra20.dtsi | 15 +- arch/arm/dts/tegra30-beaver.dts | 1 + arch/arm/dts/tegra30-cardhu.dts | 1 + arch/arm/dts/tegra30-tamonten.dtsi | 1 + arch/arm/dts/tegra30.dtsi | 40 +++++ arch/sandbox/dts/sandbox.dts | 10 ++ common/board_r.c | 19 ++- common/stdio.c | 18 +- doc/device-tree-bindings/serial/ns16550.txt | 10 ++ drivers/core/lists.c | 10 +- drivers/core/root.c | 2 +- drivers/serial/Makefile | 6 +- drivers/serial/ns16550.c | 224 +++++++++++++++++++++--- drivers/serial/sandbox.c | 140 ++++++++++++--- drivers/serial/serial-uclass.c | 211 +++++++++++++++++++++++ drivers/serial/serial.c | 1 + drivers/serial/serial_ns16550.c | 23 +-- drivers/serial/serial_s5p.c | 255 ++++++++-------------------- include/configs/exynos-common.h | 1 + include/configs/sandbox.h | 3 + include/configs/tegra-common.h | 8 +- include/configs/tegra124-common.h | 2 + include/configs/tegra20-common.h | 2 + include/configs/tegra30-common.h | 2 + include/dm/lists.h | 6 +- include/dm/uclass-id.h | 1 + include/ns16550.h | 37 ++++ include/serial.h | 92 ++++++++++ include/stdio_dev.h | 24 ++- 45 files changed, 987 insertions(+), 272 deletions(-) create mode 100644 doc/device-tree-bindings/serial/ns16550.txt create mode 100644 drivers/serial/serial-uclass.c
The stdio_dev structure has a private pointer for its creator, but it is not set up by the serial system. Set it to point to the serial device so that it can be found by code called by stdio.
Changes in v3: - Fix typo in commit message
Changes in v2: None
drivers/serial/serial.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index d2eb752..bbe60af 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -320,6 +320,7 @@ void serial_stdio_init(void) dev.puts = serial_stub_puts; dev.getc = serial_stub_getc; dev.tstc = serial_stub_tstc; + dev.priv = s;
stdio_register(&dev);
Allow the caller to find out the device that was bound in response to this call.
Changes in v2: None
drivers/core/lists.c | 10 +++++++--- drivers/core/root.c | 2 +- include/dm/lists.h | 6 +++++- 3 files changed, 13 insertions(+), 5 deletions(-)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index 0f08bfd..699f94b 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -118,7 +118,8 @@ static int driver_check_compatible(const void *blob, int offset, return -ENOENT; }
-int lists_bind_fdt(struct udevice *parent, const void *blob, int offset) +int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, + struct udevice **devp) { struct driver *driver = ll_entry_start(struct driver, driver); const int n_ents = ll_entry_count(struct driver, driver); @@ -130,6 +131,8 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset) int ret = 0;
dm_dbg("bind node %s\n", fdt_get_name(blob, offset, NULL)); + if (devp) + *devp = NULL; for (entry = driver; entry != driver + n_ents; entry++) { ret = driver_check_compatible(blob, offset, entry->of_match); name = fdt_get_name(blob, offset, NULL); @@ -149,10 +152,11 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset) ret = device_bind(parent, entry, name, NULL, offset, &dev); if (ret) { dm_warn("Error binding driver '%s'\n", entry->name); - if (!result || ret != -ENOENT) - result = ret; + return ret; } else { found = true; + if (devp) + *devp = dev; } break; } diff --git a/drivers/core/root.c b/drivers/core/root.c index 393dd98..a328a48 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -91,7 +91,7 @@ int dm_scan_fdt_node(struct udevice *parent, const void *blob, int offset, if (pre_reloc_only && !fdt_getprop(blob, offset, "u-boot,dm-pre-reloc", NULL)) continue; - err = lists_bind_fdt(parent, blob, offset); + err = lists_bind_fdt(parent, blob, offset, NULL); if (err && !ret) ret = err; } diff --git a/include/dm/lists.h b/include/dm/lists.h index 87a3af5..2356895 100644 --- a/include/dm/lists.h +++ b/include/dm/lists.h @@ -53,7 +53,11 @@ int lists_bind_drivers(struct udevice *parent, bool pre_reloc_only); * @parent: parent driver (root) * @blob: device tree blob * @offset: offset of this device tree node + * @devp: if non-NULL, returns a pointer to the bound device + * @return 0 if device was bound, -EINVAL if the device tree is invalid, + * other -ve value on error */ -int lists_bind_fdt(struct udevice *parent, const void *blob, int offset); +int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, + struct udevice **devp);
#endif
Serial devices support simple byte input/output and a few operations to find out whether data is available. Add a basic uclass for serial devices to be used by drivers that are converted to driver model.
Changes in v3: - Automatically bind the console even if not marked for pre-relocation
Changes in v2: - Rename struct device to struct udevice
drivers/serial/Makefile | 4 + drivers/serial/serial-uclass.c | 211 +++++++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/serial.h | 92 ++++++++++++++++++ 4 files changed, 308 insertions(+) create mode 100644 drivers/serial/serial-uclass.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 571c18f..4720e1d 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -5,7 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifdef CONFIG_DM_SERIAL +obj-y += serial-uclass.o +else obj-y += serial.o +endif
obj-$(CONFIG_ALTERA_UART) += altera_uart.o obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c new file mode 100644 index 0000000..64e0c94 --- /dev/null +++ b/drivers/serial/serial-uclass.c @@ -0,0 +1,211 @@ +/* + * Copyright (c) 2014 The Chromium OS Authors. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <os.h> +#include <serial.h> +#include <stdio_dev.h> +#include <dm/lists.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* The currently-selected console serial device */ +struct udevice *cur_dev __attribute__ ((section(".data"))); + +#ifndef CONFIG_SYS_MALLOC_F_LEN +#error "Serial is required before relocation - define CONFIG_SYS_MALLOC_F_LEN to make this work" +#endif + +static void serial_find_console_or_panic(void) +{ + int node; + + /* Check for a console alias */ + node = fdtdec_get_alias_node(gd->fdt_blob, "console"); + if (!uclass_get_device_by_of_offset(UCLASS_SERIAL, node, &cur_dev)) + return; + + /* + * If the console is not marked to be bound before relocation, bind + * it anyway. + */ + if (node > 0 && + !lists_bind_fdt(gd->dm_root, gd->fdt_blob, node, &cur_dev)) { + if (!device_probe(cur_dev)) + return; + cur_dev = NULL; + } + + /* + * Failing that, get the device with sequence number 0, or in extremis + * just the first serial device we can find. But we insist on having + * a console (even if it is silent). + */ + if (uclass_get_device_by_seq(UCLASS_SERIAL, 0, &cur_dev) && + (uclass_first_device(UCLASS_SERIAL, &cur_dev) || !cur_dev)) + panic("No serial driver found"); +} + +/* Called prior to relocation */ +int serial_init(void) +{ + serial_find_console_or_panic(); + gd->flags |= GD_FLG_SERIAL_READY; + + return 0; +} + +/* Called after relocation */ +void serial_initialize(void) +{ + serial_find_console_or_panic(); +} + +void serial_putc(char ch) +{ + struct dm_serial_ops *ops = serial_get_ops(cur_dev); + int err; + + do { + err = ops->putc(cur_dev, ch); + } while (err == -EAGAIN); + if (ch == '\n') + serial_putc('\r'); +} + +void serial_setbrg(void) +{ + struct dm_serial_ops *ops = serial_get_ops(cur_dev); + + if (ops->setbrg) + ops->setbrg(cur_dev, gd->baudrate); +} + +void serial_puts(const char *str) +{ + while (*str) + serial_putc(*str++); +} + +int serial_tstc(void) +{ + struct dm_serial_ops *ops = serial_get_ops(cur_dev); + + if (ops->pending) + return ops->pending(cur_dev, true); + + return 1; +} + +int serial_getc(void) +{ + struct dm_serial_ops *ops = serial_get_ops(cur_dev); + int err; + + do { + err = ops->getc(cur_dev); + } while (err == -EAGAIN); + + return err >= 0 ? err : 0; +} + +void serial_stdio_init(void) +{ +} + +void serial_stub_putc(struct stdio_dev *sdev, const char ch) +{ + struct udevice *dev = sdev->priv; + struct dm_serial_ops *ops = serial_get_ops(dev); + + ops->putc(dev, ch); +} + +void serial_stub_puts(struct stdio_dev *sdev, const char *str) +{ + while (*str) + serial_stub_putc(sdev, *str++); +} + +int serial_stub_getc(struct stdio_dev *sdev) +{ + struct udevice *dev = sdev->priv; + struct dm_serial_ops *ops = serial_get_ops(dev); + + int err; + + do { + err = ops->getc(dev); + } while (err == -EAGAIN); + + return err >= 0 ? err : 0; +} + +int serial_stub_tstc(struct stdio_dev *sdev) +{ + struct udevice *dev = sdev->priv; + struct dm_serial_ops *ops = serial_get_ops(dev); + + if (ops->pending) + return ops->pending(dev, true); + + return 1; +} + +static int serial_post_probe(struct udevice *dev) +{ + struct stdio_dev sdev; + struct dm_serial_ops *ops = serial_get_ops(dev); + struct serial_dev_priv *upriv = dev->uclass_priv; + int ret; + + /* Set the baud rate */ + if (ops->setbrg) { + ret = ops->setbrg(dev, gd->baudrate); + if (ret) + return ret; + } + + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + + memset(&sdev, '\0', sizeof(sdev)); + + strncpy(sdev.name, dev->name, sizeof(sdev.name)); + sdev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT; + sdev.priv = dev; + sdev.putc = serial_stub_putc; + sdev.puts = serial_stub_puts; + sdev.getc = serial_stub_getc; + sdev.tstc = serial_stub_tstc; + stdio_register_dev(&sdev, &upriv->sdev); + + return 0; +} + +static int serial_pre_remove(struct udevice *dev) +{ +#ifdef CONFIG_SYS_STDIO_DEREGISTER + struct serial_dev_priv *upriv = dev->uclass_priv; + + if (stdio_deregister_dev(upriv->sdev)) + return -EPERM; +#endif + + return 0; +} + +UCLASS_DRIVER(serial) = { + .id = UCLASS_SERIAL, + .name = "serial", + .post_probe = serial_post_probe, + .pre_remove = serial_pre_remove, + .per_device_auto_alloc_size = sizeof(struct serial_dev_priv), +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index dd95fca..7f0e37b 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -21,6 +21,7 @@ enum uclass_id {
/* U-Boot uclasses start here */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ + UCLASS_SERIAL, /* Serial UART */
UCLASS_COUNT, UCLASS_INVALID = -1, diff --git a/include/serial.h b/include/serial.h index d232d47..8f574e4 100644 --- a/include/serial.h +++ b/include/serial.h @@ -72,4 +72,96 @@ extern int write_port(struct stdio_dev *port, char *buf); extern int read_port(struct stdio_dev *port, char *buf, int size); #endif
+struct udevice; + +/** + * struct struct dm_serial_ops - Driver model serial operations + * + * The uclass interface is implemented by all serial devices which use + * driver model. + */ +struct dm_serial_ops { + /** + * setbrg() - Set up the baud rate generator + * + * Adjust baud rate divisors to set up a new baud rate for this + * device. Not all devices will support all rates. If the rate + * cannot be supported, the driver is free to select the nearest + * available rate. or return -EINVAL if this is not possible. + * + * @dev: Device pointer + * @baudrate: New baud rate to use + * @return 0 if OK, -ve on error + */ + int (*setbrg)(struct udevice *dev, int baudrate); + /** + * getc() - Read a character and return it + * + * If no character is available, this should return -EAGAIN without + * waiting. + * + * @dev: Device pointer + * @return character (0..255), -ve on error + */ + int (*getc)(struct udevice *dev); + /** + * putc() - Write a character + * + * @dev: Device pointer + * @ch: character to write + * @return 0 if OK, -ve on error + */ + int (*putc)(struct udevice *dev, const char ch); + /** + * pending() - Check if input/output characters are waiting + * + * This can be used to return an indication of the number of waiting + * characters if the driver knows this (e.g. by looking at the FIFO + * level). It is acceptable to return 1 if an indeterminant number + * of characters is waiting. + * + * This method is optional. + * + * @dev: Device pointer + * @input: true to check input characters, false for output + * @return number of waiting characters, 0 for none, -ve on error + */ + int (*pending)(struct udevice *dev, bool input); + /** + * clear() - Clear the serial FIFOs/holding registers + * + * This method is optional. + * + * This quickly clears any input/output characters from the UART. + * If this is not possible, but characters still exist, then it + * is acceptable to return -EAGAIN (try again) or -EINVAL (not + * supported). + * + * @dev: Device pointer + * @return 0 if OK, -ve on error + */ + int (*clear)(struct udevice *dev); +#if CONFIG_POST & CONFIG_SYS_POST_UART + /** + * loop() - Control serial device loopback mode + * + * @dev: Device pointer + * @on: 1 to turn loopback on, 0 to turn if off + */ + int (*loop)(struct udevice *dev, int on); +#endif +}; + +/** + * struct serial_dev_priv - information about a device used by the uclass + * + * @sdev: stdio device attached to this uart + */ +struct serial_dev_priv { + struct stdio_dev *sdev; +}; + +/* Access the serial operations for a device */ +#define serial_get_ops(dev) ((struct dm_serial_ops *)(dev)->driver->ops) + #endif
Since driver model registers itself with the stdio subsystem, and we want to avoid delayed registration and other complexity associated with the current serial console, move the stdio subsystem init earlier when driver model is used for serial.
This simplifies the implementation. Should there be any problems with this approach they can be dealt with as boards are converted over to use driver model for serial.
common/board_r.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 8e7a3ac..2eed569 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -726,6 +726,15 @@ init_fnc_t init_sequence_r[] = { set_cpu_clk_info, /* Setup clock information */ #endif initr_reloc_global_data, + initr_barrier, + initr_malloc, + bootstage_relocate, +#ifdef CONFIG_DM_SERIAL + stdio_init, +#endif +#ifdef CONFIG_DM + initr_dm, +#endif initr_serial, initr_announce, INIT_FUNC_WATCHDOG_RESET @@ -762,12 +771,6 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_WINBOND_83C553 initr_w83c553f, #endif - initr_barrier, - initr_malloc, - bootstage_relocate, -#ifdef CONFIG_DM - initr_dm, -#endif #ifdef CONFIG_ARCH_EARLY_INIT_R arch_early_init_r, #endif @@ -817,7 +820,9 @@ init_fnc_t init_sequence_r[] = { */ initr_pci, #endif +#ifndef CONFIG_DM_SERIAL stdio_init, +#endif initr_jumptable, #ifdef CONFIG_API initr_api,
Adjust the sandbox serial driver to use the new driver model uclass. The driver works much as before, but within the new framework.
Changes in v3: None Changes in v2: - Rename struct device to struct udevice
drivers/serial/sandbox.c | 67 +++++++++++++++++++++++++---------------------- include/configs/sandbox.h | 3 +++ 2 files changed, 39 insertions(+), 31 deletions(-)
diff --git a/drivers/serial/sandbox.c b/drivers/serial/sandbox.c index 51fd871..ac54e01 100644 --- a/drivers/serial/sandbox.c +++ b/drivers/serial/sandbox.c @@ -11,12 +11,16 @@ */
#include <common.h> +#include <dm.h> +#include <fdtdec.h> #include <lcd.h> #include <os.h> #include <serial.h> #include <linux/compiler.h> #include <asm/state.h>
+DECLARE_GLOBAL_DATA_PTR; + /* * * serial_buf: A buffer that holds keyboard characters for the @@ -30,27 +34,21 @@ static char serial_buf[16]; static unsigned int serial_buf_write; static unsigned int serial_buf_read;
-static int sandbox_serial_init(void) +static int sandbox_serial_probe(struct udevice *dev) { struct sandbox_state *state = state_get_current();
if (state->term_raw != STATE_TERM_COOKED) os_tty_raw(0, state->term_raw == STATE_TERM_RAW_WITH_SIGS); - return 0; -}
-static void sandbox_serial_setbrg(void) -{ + return 0; }
-static void sandbox_serial_putc(const char ch) +static int sandbox_serial_putc(struct udevice *dev, const char ch) { os_write(1, &ch, 1); -}
-static void sandbox_serial_puts(const char *str) -{ - os_write(1, str, strlen(str)); + return 0; }
static unsigned int increment_buffer_index(unsigned int index) @@ -58,12 +56,15 @@ static unsigned int increment_buffer_index(unsigned int index) return (index + 1) % ARRAY_SIZE(serial_buf); }
-static int sandbox_serial_tstc(void) +static int sandbox_serial_pending(struct udevice *dev, bool input) { const unsigned int next_index = increment_buffer_index(serial_buf_write); ssize_t count;
+ if (!input) + return 0; + os_usleep(100); #ifdef CONFIG_LCD lcd_sync(); @@ -74,38 +75,42 @@ static int sandbox_serial_tstc(void) count = os_read_no_block(0, &serial_buf[serial_buf_write], 1); if (count == 1) serial_buf_write = next_index; + return serial_buf_write != serial_buf_read; }
-static int sandbox_serial_getc(void) +static int sandbox_serial_getc(struct udevice *dev) { int result;
- while (!sandbox_serial_tstc()) - ; /* buffer empty */ + if (!sandbox_serial_pending(dev, true)) + return -EAGAIN; /* buffer empty */
result = serial_buf[serial_buf_read]; serial_buf_read = increment_buffer_index(serial_buf_read); return result; }
-static struct serial_device sandbox_serial_drv = { - .name = "sandbox_serial", - .start = sandbox_serial_init, - .stop = NULL, - .setbrg = sandbox_serial_setbrg, - .putc = sandbox_serial_putc, - .puts = sandbox_serial_puts, - .getc = sandbox_serial_getc, - .tstc = sandbox_serial_tstc, +static const struct dm_serial_ops sandbox_serial_ops = { + .putc = sandbox_serial_putc, + .pending = sandbox_serial_pending, + .getc = sandbox_serial_getc, };
-void sandbox_serial_initialize(void) -{ - serial_register(&sandbox_serial_drv); -} +static const struct udevice_id sandbox_serial_ids[] = { + { .compatible = "sandbox,serial" }, + { } +};
-__weak struct serial_device *default_serial_console(void) -{ - return &sandbox_serial_drv; -} +U_BOOT_DRIVER(serial_sandbox) = { + .name = "serial_sandbox", + .id = UCLASS_SERIAL, + .of_match = sandbox_serial_ids, + .probe = sandbox_serial_probe, + .ops = &sandbox_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DEVICE(serial_sandbox_non_fdt) = { + .name = "serial_sandbox", +}; diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index bf2d25c..f5fa4b3 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -31,6 +31,9 @@ #define CONFIG_DM_DEMO_SHAPE #define CONFIG_DM_GPIO #define CONFIG_DM_TEST +#define CONFIG_DM_SERIAL + +#define CONFIG_SYS_STDIO_DEREGISTER
/* Number of bits in a C 'long' on this architecture */ #define CONFIG_SANDBOX_BITS_PER_LONG 64
The current sandbox serial driver is a pretty trivial example and does not have the featues that might be needed for other board serial drivers. To help provide a better example, add a text colour property to the device tree for sandbox. This uses platform data, a device tree node, driver private data and a remove() method.
drivers/serial/sandbox.c | 83 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 83 insertions(+)
diff --git a/drivers/serial/sandbox.c b/drivers/serial/sandbox.c index ac54e01..9139104 100644 --- a/drivers/serial/sandbox.c +++ b/drivers/serial/sandbox.c @@ -34,19 +34,67 @@ static char serial_buf[16]; static unsigned int serial_buf_write; static unsigned int serial_buf_read;
+struct sandbox_serial_platdata { + int colour; /* Text colour to use for output, -1 for none */ +}; + +struct sandbox_serial_priv { + bool start_of_line; +}; + +/** + * output_ansi_colour() - Output an ANSI colour code + * + * @colour: Colour to output (0-7) + */ +static void output_ansi_colour(int colour) +{ + char ansi_code[] = "\x1b[1;3Xm"; + + ansi_code[5] = '0' + colour; + os_write(1, ansi_code, sizeof(ansi_code) - 1); +} + +static void output_ansi_reset(void) +{ + os_write(1, "\x1b[0m", 4); +} + static int sandbox_serial_probe(struct udevice *dev) { struct sandbox_state *state = state_get_current(); + struct sandbox_serial_priv *priv = dev_get_priv(dev);
if (state->term_raw != STATE_TERM_COOKED) os_tty_raw(0, state->term_raw == STATE_TERM_RAW_WITH_SIGS); + priv->start_of_line = 0; + + return 0; +} + +static int sandbox_serial_remove(struct udevice *dev) +{ + struct sandbox_serial_platdata *plat = dev->platdata; + + if (plat->colour != -1) + output_ansi_reset();
return 0; }
static int sandbox_serial_putc(struct udevice *dev, const char ch) { + struct sandbox_serial_priv *priv = dev_get_priv(dev); + struct sandbox_serial_platdata *plat = dev->platdata; + + if (priv->start_of_line && plat->colour != -1) { + priv->start_of_line = false; + output_ansi_colour(plat->colour); + } + os_write(1, &ch, 1); + if (ch == '\n') + priv->start_of_line = true;
return 0; } @@ -91,6 +139,32 @@ static int sandbox_serial_getc(struct udevice *dev) return result; }
+static const char * const ansi_colour[] = { + "black", "red", "green", "yellow", "blue", "megenta", "cyan", + "white", +}; + +static int sandbox_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct sandbox_serial_platdata *plat = dev->platdata; + const char *colour; + int i; + + plat->colour = -1; + colour = fdt_getprop(gd->fdt_blob, dev->of_offset, "text-colour", + NULL); + if (colour) { + for (i = 0; i < ARRAY_SIZE(ansi_colour); i++) { + if (!strcmp(colour, ansi_colour[i])) { + plat->colour = i; + break; + } + } + } + + return 0; +} + static const struct dm_serial_ops sandbox_serial_ops = { .putc = sandbox_serial_putc, .pending = sandbox_serial_pending, @@ -106,11 +180,20 @@ U_BOOT_DRIVER(serial_sandbox) = { .name = "serial_sandbox", .id = UCLASS_SERIAL, .of_match = sandbox_serial_ids, + .ofdata_to_platdata = sandbox_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sandbox_serial_platdata), + .priv_auto_alloc_size = sizeof(struct sandbox_serial_priv), .probe = sandbox_serial_probe, + .remove = sandbox_serial_remove, .ops = &sandbox_serial_ops, .flags = DM_FLAG_PRE_RELOC, };
+static const struct sandbox_serial_platdata platdata_non_fdt = { + .colour = -1, +}; + U_BOOT_DEVICE(serial_sandbox_non_fdt) = { .name = "serial_sandbox", + .platdata = &platdata_non_fdt, };
If the sandbox device tree is provided to U-Boot (with the -d flag) then it will use the device tree version in preference to the built-in device. The only difference is the colour.
Changes in v3: - Change pre-reloc fdt property to 'u-boot,dm-pre-reloc'
Changes in v2: None
arch/sandbox/dts/sandbox.dts | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index efffacb..fd2b44b 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -1,6 +1,16 @@ /dts-v1/;
/ { + aliases { + console = "/serial"; + }; + + uart0: serial { + compatible = "sandbox,serial"; + u-boot,dm-pre-reloc; + text-colour = "cyan"; + }; + triangle { compatible = "demo-shape"; colour = "cyan";
- uart0: serial {
Shouldn't that be handled by the driver. It's certainly something that's only relevant to the internals of U-Boot, and hence inappropriate to put into DT.
That's property should likely have a uboot, prefix, since it's non-standard.
Hi Stephen,
uart0: serial {
Hence the u-boot prefix. This is described in the driver model docs. I have found a work-around (which forces a driver to be inited pre-reloc if none is found) but I'm not 100% happy with it.
Can I not just declare a binding for 'sandbox,serial'?
On 07/31/2014 04:13 PM, Simon Glass wrote:
Hi Stephen,
uart0: serial {
I'm arguing that the property shouldn't exist in DT at all. DT is supposed to be a pure description of the HW, and not encode details that are specific to the implementation of particular SW. The fact that U-Boot performs relocation of its code during boot is completely irrelevant to a HW description.
As such, the issue isn't whether there is a u-boot, prefix on that property, but whether it's there at all.
Properties that are relevant only to a particular binding, rather than being something quite generic an applicable to a whole class of devices, typically have a vendor prefix.
A binding should/must exist for every node or compatible value. So, whether you actually write the binding document or not makes no difference to the names or vendor prefixes of the properties the binding uses.
uart0: serial {
Right. And I've arguing that U-Boot should use exactly the same descriptions that are in the Kernel even. Those DTS descriptions should be common, applicable to both or neither, exactly because they do describe the HW and are agnostic WRT the SW that is using them.
HTH, jdl
On Fri, Aug 01, 2014 at 10:46:31AM -0500, Jon Loeliger wrote:
uart0: serial {
I also agree with this. We'll have to sort out the fall-out.
uart0: serial {
As mentioned I think I have found a way (with serial at least) to work around this - when the serial probe files, this series has code which forces binding of the node referenced by the 'console' alias. It's a bit of a hack but it might be good enough...
Hi Stephen,
Hi Stephen,
uart0: serial {
I completely agree in theory, although in practice this can become a huge pain. I'm open to suggestions. On the other hand as you well know I'm more inclined to use a convenient solution and iterate/improve later than sit on my hands and fret :-) Please check the dm README for the issue involved.
So here you are saying it should be:
sandbox,text-colour = "cyan";
Is that right?
On 08/01/2014 03:40 PM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
uart0: serial {
Is that right?
I think that sounds right yes.
We will need the console before relocation, so mark it that way.
Changes in v2: None
arch/arm/dts/exynos5.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi index dc5405b..e539068 100644 --- a/arch/arm/dts/exynos5.dtsi +++ b/arch/arm/dts/exynos5.dtsi @@ -244,6 +244,7 @@ compatible = "samsung,exynos4210-uart"; reg = <0x12C30000 0x100>; interrupts = <0 54 0>; + u-boot,dm-pre-reloc; id = <3>; };
Change the Exynos serial driver to work with driver model and switch over all Exynos5 boards to use it.
Changes in v3: - Avoid reordering functions
Changes in v2: None
drivers/serial/serial_s5p.c | 255 ++++++++++++---------------------------- include/configs/exynos-common.h | 1 + 2 files changed, 73 insertions(+), 183 deletions(-)
diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 98c62b4..8469afd 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -9,6 +9,8 @@ */
#include <common.h> +#include <dm.h> +#include <errno.h> #include <fdtdec.h> #include <linux/compiler.h> #include <asm/io.h> @@ -18,26 +20,18 @@
-#define RX_FIFO_COUNT_MASK 0xff -#define RX_FIFO_FULL_MASK (1 << 8) -#define TX_FIFO_FULL_MASK (1 << 24) +#define RX_FIFO_COUNT_SHIFT 0 +#define RX_FIFO_COUNT_MASK (0xff << RX_FIFO_COUNT_SHIFT) +#define RX_FIFO_FULL (1 << 8) +#define TX_FIFO_COUNT_SHIFT 16 +#define TX_FIFO_COUNT_MASK (0xff << TX_FIFO_COUNT_SHIFT) +#define TX_FIFO_FULL (1 << 24)
/* Information about a serial port */ -struct fdt_serial { - u32 base_addr; /* address of registers in physical memory */ +struct s5p_serial_platdata { + struct s5p_uart *reg; /* address of registers in physical memory */ u8 port_id; /* uart port number */ - u8 enabled; /* 1 if enabled, 0 if disabled */ -} config __attribute__ ((section(".data"))); - -static inline struct s5p_uart *s5p_get_base_uart(int dev_index) -{ -#ifdef CONFIG_OF_CONTROL - return (struct s5p_uart *)(config.base_addr); -#else - u32 offset = dev_index * sizeof(struct s5p_uart); - return (struct s5p_uart *)(samsung_get_base_uart() + offset); -#endif -} +};
/* * The coefficient, used to calculate the baudrate on S5P UARTs is @@ -65,23 +59,13 @@ static const int udivslot[] = { 0xffdf, };
-static void serial_setbrg_dev(const int dev_index) +int s5p_serial_setbrg(struct udevice *dev, int baudrate) { - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); - u32 uclk = get_uart_clk(dev_index); - u32 baudrate = gd->baudrate; + struct s5p_serial_platdata *plat = dev->platdata; + struct s5p_uart *const uart = plat->reg; + u32 uclk = get_uart_clk(plat->port_id); u32 val;
-#if defined(CONFIG_SILENT_CONSOLE) && \ - defined(CONFIG_OF_CONTROL) && \ - !defined(CONFIG_SPL_BUILD) - if (fdtdec_get_config_int(gd->fdt_blob, "silent_console", 0)) - gd->flags |= GD_FLG_SILENT; -#endif - - if (!config.enabled) - return; - val = uclk / baudrate;
writel(val / 16 - 1, &uart->ubrdiv); @@ -90,15 +74,14 @@ static void serial_setbrg_dev(const int dev_index) writew(udivslot[val % 16], &uart->rest.slot); else writeb(val % 16, &uart->rest.value); + + return 0; }
-/* - * Initialise the serial port with the given baudrate. The settings - * are always 8 data bits, no parity, 1 stop bit, no start bits. - */ -static int serial_init_dev(const int dev_index) +static int s5p_serial_probe(struct udevice *dev) { - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); + struct s5p_serial_platdata *plat = dev->platdata; + struct s5p_uart *const uart = plat->reg;
/* enable FIFOs, auto clear Rx FIFO */ writel(0x3, &uart->ufcon); @@ -108,14 +91,11 @@ static int serial_init_dev(const int dev_index) /* No interrupts, no DMA, pure polling */ writel(0x245, &uart->ucon);
- serial_setbrg_dev(dev_index); - return 0; }
-static int serial_err_check(const int dev_index, int op) +static int serial_err_check(const struct s5p_uart *const uart, int op) { - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); unsigned int mask;
/* @@ -133,169 +113,78 @@ static int serial_err_check(const int dev_index, int op) return readl(&uart->uerstat) & mask; }
-/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -static int serial_getc_dev(const int dev_index) +static int s5p_serial_getc(struct udevice *dev) { - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); - - if (!config.enabled) - return 0; + struct s5p_serial_platdata *plat = dev->platdata; + struct s5p_uart *const uart = plat->reg;
- /* wait for character to arrive */ - while (!(readl(&uart->ufstat) & (RX_FIFO_COUNT_MASK | - RX_FIFO_FULL_MASK))) { - if (serial_err_check(dev_index, 0)) - return 0; - } + if (!(readl(&uart->ufstat) & RX_FIFO_COUNT_MASK)) + return -EAGAIN;
+ serial_err_check(uart, 0); return (int)(readb(&uart->urxh) & 0xff); }
-/* - * Output a single byte to the serial port. - */ -static void serial_putc_dev(const char c, const int dev_index) +static int s5p_serial_putc(struct udevice *dev, const char ch) { - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); - - if (!config.enabled) - return; - - /* wait for room in the tx FIFO */ - while ((readl(&uart->ufstat) & TX_FIFO_FULL_MASK)) { - if (serial_err_check(dev_index, 1)) - return; - } + struct s5p_serial_platdata *plat = dev->platdata; + struct s5p_uart *const uart = plat->reg;
- writeb(c, &uart->utxh); + if (readl(&uart->ufstat) & TX_FIFO_FULL) + return -EAGAIN;
- /* If \n, also do \r */ - if (c == '\n') - serial_putc('\r'); -} - -/* - * Test whether a character is in the RX buffer - */ -static int serial_tstc_dev(const int dev_index) -{ - struct s5p_uart *const uart = s5p_get_base_uart(dev_index); + writeb(ch, &uart->utxh); + serial_err_check(uart, 1);
- if (!config.enabled) - return 0; - - return (int)(readl(&uart->utrstat) & 0x1); + return 0; }
-static void serial_puts_dev(const char *s, const int dev_index) +static int s5p_serial_pending(struct udevice *dev, bool input) { - while (*s) - serial_putc_dev(*s++, dev_index); -} + struct s5p_serial_platdata *plat = dev->platdata; + struct s5p_uart *const uart = plat->reg; + uint32_t ufstat = readl(&uart->ufstat);
-/* Multi serial device functions */ -#define DECLARE_S5P_SERIAL_FUNCTIONS(port) \ -static int s5p_serial##port##_init(void) { return serial_init_dev(port); } \ -static void s5p_serial##port##_setbrg(void) { serial_setbrg_dev(port); } \ -static int s5p_serial##port##_getc(void) { return serial_getc_dev(port); } \ -static int s5p_serial##port##_tstc(void) { return serial_tstc_dev(port); } \ -static void s5p_serial##port##_putc(const char c) { serial_putc_dev(c, port); } \ -static void s5p_serial##port##_puts(const char *s) { serial_puts_dev(s, port); } - -#define INIT_S5P_SERIAL_STRUCTURE(port, __name) { \ - .name = __name, \ - .start = s5p_serial##port##_init, \ - .stop = NULL, \ - .setbrg = s5p_serial##port##_setbrg, \ - .getc = s5p_serial##port##_getc, \ - .tstc = s5p_serial##port##_tstc, \ - .putc = s5p_serial##port##_putc, \ - .puts = s5p_serial##port##_puts, \ + if (input) + return (ufstat & RX_FIFO_COUNT_MASK) >> RX_FIFO_COUNT_SHIFT; + else + return (ufstat & TX_FIFO_COUNT_MASK) >> TX_FIFO_COUNT_SHIFT; }
-DECLARE_S5P_SERIAL_FUNCTIONS(0); -struct serial_device s5p_serial0_device = - INIT_S5P_SERIAL_STRUCTURE(0, "s5pser0"); -DECLARE_S5P_SERIAL_FUNCTIONS(1); -struct serial_device s5p_serial1_device = - INIT_S5P_SERIAL_STRUCTURE(1, "s5pser1"); -DECLARE_S5P_SERIAL_FUNCTIONS(2); -struct serial_device s5p_serial2_device = - INIT_S5P_SERIAL_STRUCTURE(2, "s5pser2"); -DECLARE_S5P_SERIAL_FUNCTIONS(3); -struct serial_device s5p_serial3_device = - INIT_S5P_SERIAL_STRUCTURE(3, "s5pser3"); - -#ifdef CONFIG_OF_CONTROL -int fdtdec_decode_console(int *index, struct fdt_serial *uart) +static int s5p_serial_ofdata_to_platdata(struct udevice *dev) { - const void *blob = gd->fdt_blob; - int node; + struct s5p_serial_platdata *plat = dev->platdata; + fdt_addr_t addr;
- node = fdt_path_offset(blob, "console"); - if (node < 0) - return node; + addr = fdtdec_get_addr(gd->fdt_blob, dev->of_offset, "reg"); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL;
- uart->base_addr = fdtdec_get_addr(blob, node, "reg"); - if (uart->base_addr == FDT_ADDR_T_NONE) - return -FDT_ERR_NOTFOUND; - - uart->port_id = fdtdec_get_int(blob, node, "id", -1); - uart->enabled = fdtdec_get_is_enabled(blob, node); + plat->reg = (struct s5p_uart *)addr; + plat->port_id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "id", -1);
return 0; } -#endif
-__weak struct serial_device *default_serial_console(void) -{ -#ifdef CONFIG_OF_CONTROL - int index = 0; - - if ((!config.base_addr) && (fdtdec_decode_console(&index, &config))) { - debug("Cannot decode default console node\n"); - return NULL; - } - - switch (config.port_id) { - case 0: - return &s5p_serial0_device; - case 1: - return &s5p_serial1_device; - case 2: - return &s5p_serial2_device; - case 3: - return &s5p_serial3_device; - default: - debug("Unknown config.port_id: %d", config.port_id); - break; - } - - return NULL; -#else - config.enabled = 1; -#if defined(CONFIG_SERIAL0) - return &s5p_serial0_device; -#elif defined(CONFIG_SERIAL1) - return &s5p_serial1_device; -#elif defined(CONFIG_SERIAL2) - return &s5p_serial2_device; -#elif defined(CONFIG_SERIAL3) - return &s5p_serial3_device; -#else -#error "CONFIG_SERIAL? missing." -#endif -#endif -} +static const struct dm_serial_ops s5p_serial_ops = { + .putc = s5p_serial_putc, + .pending = s5p_serial_pending, + .getc = s5p_serial_getc, + .setbrg = s5p_serial_setbrg, +};
-void s5p_serial_initialize(void) -{ - serial_register(&s5p_serial0_device); - serial_register(&s5p_serial1_device); - serial_register(&s5p_serial2_device); - serial_register(&s5p_serial3_device); -} +static const struct udevice_id s5p_serial_ids[] = { + { .compatible = "samsung,exynos4210-uart" }, + { } +}; + +U_BOOT_DRIVER(serial_s5p) = { + .name = "serial_s5p", + .id = UCLASS_SERIAL, + .of_match = s5p_serial_ids, + .ofdata_to_platdata = s5p_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct s5p_serial_platdata), + .probe = s5p_serial_probe, + .ops = &s5p_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 79dd9dc..b8d81c5 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -20,6 +20,7 @@ #define CONFIG_DM #define CONFIG_CMD_DM #define CONFIG_DM_GPIO +#define CONFIG_DM_SERIAL
#define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO
Changes in v3:
Yay.
So setbrg is called elsewhere, in a more common area? That's documented somewhere right? This seems otherwise to be a straight-forward conversion. Things we used to loop for in the driver are now handled a bit higher up and otherwise we find what to talk to in a slightly different manner.
Hi Tom,
Changes in v3:
Yay.
Yes, and sort-of. Since you don't have a baud rate at init time you could only set a default value anyway. I'll add a comment to the serial.h uclass.
Yes it's not too bad, if you ignore all the multi-serial mush being deleted. I felt that looping in a driver waiting for a character was a bad idea (how serial_getc() used to work).
For some boards board_init() will change GPIOs, so we need to have driver model available before then. Adjust the board init to arrange this, but enable it for driver model only, just to be safe.
This does create additional #ifdef logic, but it is safer than trying to make a pervasive change which may cause some boards to break.
Changes in v3: None Changes in v2: - Add exynos serial support - Remove RFC status - Split out core driver model patches into a separate set
common/board_r.c | 24 +++++++++++------------- common/stdio.c | 18 ++++++++++++++++-- include/stdio_dev.h | 24 +++++++++++++++++++++++- 3 files changed, 50 insertions(+), 16 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 2eed569..e98ac9c 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -714,6 +714,15 @@ init_fnc_t init_sequence_r[] = { /* TODO: could x86/PPC have this also perhaps? */ #ifdef CONFIG_ARM initr_caches, +#endif + initr_reloc_global_data, + initr_barrier, + initr_malloc, + bootstage_relocate, +#ifdef CONFIG_DM + initr_dm, +#endif +#ifdef CONFIG_ARM board_init, /* Setup chipselects */ #endif /* @@ -725,16 +734,7 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_CLOCKS set_cpu_clk_info, /* Setup clock information */ #endif - initr_reloc_global_data, - initr_barrier, - initr_malloc, - bootstage_relocate, -#ifdef CONFIG_DM_SERIAL - stdio_init, -#endif -#ifdef CONFIG_DM - initr_dm, -#endif + stdio_init_tables, initr_serial, initr_announce, INIT_FUNC_WATCHDOG_RESET @@ -820,9 +820,7 @@ init_fnc_t init_sequence_r[] = { */ initr_pci, #endif -#ifndef CONFIG_DM_SERIAL - stdio_init, -#endif + stdio_add_devices, initr_jumptable, #ifdef CONFIG_API initr_api, diff --git a/common/stdio.c b/common/stdio.c index 692ca7f..c878103 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -215,7 +215,7 @@ int stdio_deregister(const char *devname) } #endif /* CONFIG_SYS_STDIO_DEREGISTER */
-int stdio_init (void) +int stdio_init_tables(void) { #if defined(CONFIG_NEEDS_MANUAL_RELOC) /* already relocated for current ARM implementation */ @@ -232,6 +232,11 @@ int stdio_init (void) /* Initialize the list */ INIT_LIST_HEAD(&(devs.list));
+ return 0; +} + +int stdio_add_devices(void) +{ #ifdef CONFIG_SYS_I2C i2c_init_all(); #else @@ -265,5 +270,14 @@ int stdio_init (void) #ifdef CONFIG_CBMEM_CONSOLE cbmemc_init(); #endif - return (0); + + return 0; +} + +int stdio_init(void) +{ + stdio_init_tables(); + stdio_add_devices(); + + return 0; } diff --git a/include/stdio_dev.h b/include/stdio_dev.h index a7d0825..268de8e 100644 --- a/include/stdio_dev.h +++ b/include/stdio_dev.h @@ -78,7 +78,29 @@ extern char *stdio_names[MAX_FILES]; */ int stdio_register (struct stdio_dev * dev); int stdio_register_dev(struct stdio_dev *dev, struct stdio_dev **devp); -int stdio_init (void); + +/** + * stdio_init_tables() - set up stdio tables ready for devices + * + * This does not add any devices, but just prepares stdio for use. + */ +int stdio_init_tables(void); + +/** + * stdio_add_devices() - Add stdio devices to the table + * + * This makes calls to all the various subsystems that use stdio, to make + * them register with stdio. + */ +int stdio_add_devices(void); + +/** + * stdio_init() - Sets up stdio ready for use + * + * This calls stdio_init_tables() and stdio_add_devices() + */ +int stdio_init(void); + void stdio_print_current_devices(void); #ifdef CONFIG_SYS_STDIO_DEREGISTER int stdio_deregister(const char *devname);
Move the function that calculates the baud rate divisor into ns16550.c so it can be used by that file.
Changes in v3: - Add new patch to move baud rate calculation to ns16550.c
Changes in v2: None
drivers/serial/ns16550.c | 18 +++++++++++++++++- drivers/serial/serial_ns16550.c | 23 ++++------------------- include/ns16550.h | 13 +++++++++++++ 3 files changed, 34 insertions(+), 20 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index f26979d..056210e 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -4,7 +4,7 @@ * modified to use CONFIG_SYS_ISA_MEM and new defines */
-#include <config.h> +#include <common.h> #include <ns16550.h> #include <watchdog.h> #include <linux/types.h> @@ -45,6 +45,22 @@ #define CONFIG_SYS_NS16550_IER 0x00 #endif /* CONFIG_SYS_NS16550_IER */
+int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate) +{ + const unsigned int mode_x_div = 16; + +#ifdef CONFIG_OMAP1510 + /* If can't cleanly clock 115200 set div to 1 */ + if ((clock == 12000000) && (baudrate == 115200)) { + port->osc_12m_sel = OSC_12M_SEL; /* enable 6.5 * divisor */ + return 1; /* return 1 for base divisor */ + } + port->osc_12m_sel = 0; /* clear if previsouly set */ +#endif + + return DIV_ROUND_CLOSEST(clock, mode_x_div * baudrate); +} + void NS16550_init(NS16550_t com_port, int baud_divisor) { #if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_OMAP34XX)) diff --git a/drivers/serial/serial_ns16550.c b/drivers/serial/serial_ns16550.c index 4413e69..632da4c 100644 --- a/drivers/serial/serial_ns16550.c +++ b/drivers/serial/serial_ns16550.c @@ -81,7 +81,8 @@ static NS16550_t serial_ports[6] = { static int eserial##port##_init(void) \ { \ int clock_divisor; \ - clock_divisor = calc_divisor(serial_ports[port-1]); \ + clock_divisor = ns16550_calc_divisor(serial_ports[port-1], \ + CONFIG_SYS_NS16550_CLK, gd->baudrate); \ NS16550_init(serial_ports[port-1], clock_divisor); \ return 0 ; \ } \ @@ -118,23 +119,6 @@ static NS16550_t serial_ports[6] = { .puts = eserial##port##_puts, \ }
-static int calc_divisor (NS16550_t port) -{ - const unsigned int mode_x_div = 16; - -#ifdef CONFIG_OMAP1510 - /* If can't cleanly clock 115200 set div to 1 */ - if ((CONFIG_SYS_NS16550_CLK == 12000000) && (gd->baudrate == 115200)) { - port->osc_12m_sel = OSC_12M_SEL; /* enable 6.5 * divisor */ - return (1); /* return 1 for base divisor */ - } - port->osc_12m_sel = 0; /* clear if previsouly set */ -#endif - - return DIV_ROUND_CLOSEST(CONFIG_SYS_NS16550_CLK, - mode_x_div * gd->baudrate); -} - void _serial_putc(const char c,const int port) { @@ -176,7 +160,8 @@ _serial_setbrg (const int port) { int clock_divisor;
- clock_divisor = calc_divisor(PORT); + clock_divisor = ns16550_calc_divisor(PORT, CONFIG_SYS_NS16550_CLK, + gd->baudrate); NS16550_reinit(PORT, clock_divisor); }
diff --git a/include/ns16550.h b/include/ns16550.h index 17f829f..b106f8a 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -177,3 +177,16 @@ void NS16550_putc(NS16550_t com_port, char c); char NS16550_getc(NS16550_t com_port); int NS16550_tstc(NS16550_t com_port); void NS16550_reinit(NS16550_t com_port, int baud_divisor); + +/** + * ns16550_calc_divisor() - calculate the divisor given clock and baud rate + * + * Given the UART input clock and required baudrate, calculate the divisor + * that should be used. + * + * @port: UART port + * @clock: UART input clock speed in Hz + * @baudrate: Required baud rate + * @return baud rate divisor that should be used + */ +int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate);
The same sequence is used in several places, so move it into a function. Note that UART_LCR_BKSE is an alias for UART_LCR_DLAB.
Changes in v3: - Add new patch to collect common baud rate code in ns16550
Changes in v2: None
drivers/serial/ns16550.c | 33 +++++++++++++-------------------- 1 file changed, 13 insertions(+), 20 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 056210e..9373c8d 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -61,6 +61,14 @@ int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate) return DIV_ROUND_CLOSEST(clock, mode_x_div * baudrate); }
+static void NS16550_setbrg(NS16550_t com_port, int baud_divisor) +{ + serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); + serial_out(baud_divisor & 0xff, &com_port->dll); + serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); + serial_out(UART_LCRVAL, &com_port->lcr); +} + void NS16550_init(NS16550_t com_port, int baud_divisor) { #if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_OMAP34XX)) @@ -71,10 +79,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) */ if ((serial_in(&com_port->lsr) & (UART_LSR_TEMT | UART_LSR_THRE)) == UART_LSR_THRE) { - serial_out(UART_LCR_DLAB, &com_port->lcr); - serial_out(baud_divisor & 0xff, &com_port->dll); - serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); - serial_out(UART_LCRVAL, &com_port->lcr); + NS16550_setbrg(com_port, baud_divisor); serial_out(0, &com_port->mdr1); } #endif @@ -87,16 +92,10 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) defined(CONFIG_TI81XX) || defined(CONFIG_AM43XX) serial_out(0x7, &com_port->mdr1); /* mode select reset TL16C750*/ #endif - serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); - serial_out(0, &com_port->dll); - serial_out(0, &com_port->dlm); - serial_out(UART_LCRVAL, &com_port->lcr); + NS16550_setbrg(com_port, 0); serial_out(UART_MCRVAL, &com_port->mcr); serial_out(UART_FCRVAL, &com_port->fcr); - serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); - serial_out(baud_divisor & 0xff, &com_port->dll); - serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); - serial_out(UART_LCRVAL, &com_port->lcr); + NS16550_setbrg(com_port, baud_divisor); #if (defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2)) || \ defined(CONFIG_AM33XX) || defined(CONFIG_SOC_DA8XX) || \ defined(CONFIG_TI81XX) || defined(CONFIG_AM43XX) @@ -113,16 +112,10 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) void NS16550_reinit(NS16550_t com_port, int baud_divisor) { serial_out(CONFIG_SYS_NS16550_IER, &com_port->ier); - serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); - serial_out(0, &com_port->dll); - serial_out(0, &com_port->dlm); - serial_out(UART_LCRVAL, &com_port->lcr); + NS16550_setbrg(com_port, 0); serial_out(UART_MCRVAL, &com_port->mcr); serial_out(UART_FCRVAL, &com_port->fcr); - serial_out(UART_LCR_BKSE, &com_port->lcr); - serial_out(baud_divisor & 0xff, &com_port->dll); - serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); - serial_out(UART_LCRVAL, &com_port->lcr); + NS16550_setbrg(com_port, baud_divisor); } #endif /* CONFIG_NS16550_MIN_FUNCTIONS */
Add driver model support so that ns16550 can support operation both with and without driver model.
Add a suitable device tree binding also.
Changes in v3: - Add new patch to support driver model in ns16550
Changes in v2: None
doc/device-tree-bindings/serial/ns16550.txt | 10 ++ drivers/serial/Makefile | 2 +- drivers/serial/ns16550.c | 177 +++++++++++++++++++++++++++- include/ns16550.h | 24 ++++ 4 files changed, 210 insertions(+), 3 deletions(-) create mode 100644 doc/device-tree-bindings/serial/ns16550.txt
diff --git a/doc/device-tree-bindings/serial/ns16550.txt b/doc/device-tree-bindings/serial/ns16550.txt new file mode 100644 index 0000000..ef0b9ae --- /dev/null +++ b/doc/device-tree-bindings/serial/ns16550.txt @@ -0,0 +1,10 @@ +NS16550 UART + +This UART driver supports many chip variants and is used in mamy SoCs. + +Required properties: +- compatible: "ns16550" or "nvidia,tegra20-uart" +- reg: start address and size of registers +- reg-shift: shift value indicating register size: 0=byte, 1=16bit,2=32bit etc. +- clock-frequency: input clock frequency for the UART (used to calculate the + baud rate divisor) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 4720e1d..5ae6416 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -9,6 +9,7 @@ ifdef CONFIG_DM_SERIAL obj-y += serial-uclass.o else obj-y += serial.o +obj-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o endif
obj-$(CONFIG_ALTERA_UART) += altera_uart.o @@ -20,7 +21,6 @@ obj-$(CONFIG_MCFUART) += mcfuart.o obj-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o obj-$(CONFIG_SYS_NS16550) += ns16550.o obj-$(CONFIG_S5P) += serial_s5p.o -obj-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o obj-$(CONFIG_IMX_SERIAL) += serial_imx.o obj-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o obj-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 9373c8d..c07a58c 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -5,17 +5,25 @@ */
#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> #include <ns16550.h> +#include <serial.h> #include <watchdog.h> #include <linux/types.h> #include <asm/io.h>
+DECLARE_GLOBAL_DATA_PTR; + #define UART_LCRVAL UART_LCR_8N1 /* 8 data, 1 stop, no parity */ #define UART_MCRVAL (UART_MCR_DTR | \ UART_MCR_RTS) /* RTS/DTR */ #define UART_FCRVAL (UART_FCR_FIFO_EN | \ UART_FCR_RXSR | \ UART_FCR_TXSR) /* Clear & enable FIFOs */ + +#ifndef CONFIG_DM_SERIAL #ifdef CONFIG_SYS_NS16550_PORT_MAPPED #define serial_out(x, y) outb(x, (ulong)y) #define serial_in(y) inb((ulong)y) @@ -29,6 +37,7 @@ #define serial_out(x, y) writeb(x, y) #define serial_in(y) readb(y) #endif +#endif /* !CONFIG_DM_SERIAL */
#if defined(CONFIG_K2HK_EVM) #define UART_REG_VAL_PWREMU_MGMT_UART_DISABLE 0 @@ -45,6 +54,58 @@ #define CONFIG_SYS_NS16550_IER 0x00 #endif /* CONFIG_SYS_NS16550_IER */
+#ifdef CONFIG_DM_SERIAL +void ns16550_writeb(NS16550_t port, int offset, int value) +{ + struct ns16550_platdata *plat = port->plat; + unsigned char *addr; + + offset *= 1 << plat->reg_shift; + addr = plat->base + offset; + /* + * As far as we know it doesn't make sense to support selection of + * these options at run-time, so use the existing CONFIG options. + */ +#ifdef CONFIG_SYS_NS16550_PORT_MAPPED + outb(value, addr); +#elif defined(CONFIG_SYS_NS16550_MEM32) && !defined(CONFIG_SYS_BIG_ENDIAN) + out_le32(addr, value); +#elif defined(CONFIG_SYS_NS16550_MEM32) && defined(CONFIG_SYS_BIG_ENDIAN) + out_be32(addr, value); +#elif defined(CONFIG_SYS_BIG_ENDIAN) + writeb(value, addr + (1 << plat->reg_shift) - 1); +#else + writeb(value, addr); +#endif +} + +int ns16550_readb(NS16550_t port, int offset) +{ + struct ns16550_platdata *plat = port->plat; + unsigned char *addr; + + offset *= 1 << plat->reg_shift; + addr = plat->base + offset; +#ifdef CONFIG_SYS_NS16550_PORT_MAPPED + return inb(addr); +#elif defined(CONFIG_SYS_NS16550_MEM32) && !defined(CONFIG_SYS_BIG_ENDIAN) + return in_le32(addr); +#elif defined(CONFIG_SYS_NS16550_MEM32) && defined(CONFIG_SYS_BIG_ENDIAN) + return in_be32(addr); +#elif defined(CONFIG_SYS_BIG_ENDIAN) + return readb(addr + (1 << plat->reg_shift) - 1); +#else + return readb(addr); +#endif +} + +/* We can clean these up once everything is moved to driver model */ +#define serial_out(value, addr) \ + ns16550_writeb(com_port, addr - (unsigned char *)com_port, value) +#define serial_in(addr) \ + ns16550_readb(com_port, addr - (unsigned char *)com_port) +#endif + int ns16550_calc_divisor(NS16550_t port, int clock, int baudrate) { const unsigned int mode_x_div = 16; @@ -79,7 +140,8 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) */ if ((serial_in(&com_port->lsr) & (UART_LSR_TEMT | UART_LSR_THRE)) == UART_LSR_THRE) { - NS16550_setbrg(com_port, baud_divisor); + if (baud_divisor != -1) + NS16550_setbrg(com_port, baud_divisor); serial_out(0, &com_port->mdr1); } #endif @@ -95,7 +157,8 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) NS16550_setbrg(com_port, 0); serial_out(UART_MCRVAL, &com_port->mcr); serial_out(UART_FCRVAL, &com_port->fcr); - NS16550_setbrg(com_port, baud_divisor); + if (baud_divisor != -1) + NS16550_setbrg(com_port, baud_divisor); #if (defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2)) || \ defined(CONFIG_AM33XX) || defined(CONFIG_SOC_DA8XX) || \ defined(CONFIG_TI81XX) || defined(CONFIG_AM43XX) @@ -154,3 +217,113 @@ int NS16550_tstc(NS16550_t com_port) }
#endif /* CONFIG_NS16550_MIN_FUNCTIONS */ + +#ifdef CONFIG_DM_SERIAL +static int ns16550_serial_putc(struct udevice *dev, const char ch) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + + if (!(serial_in(&com_port->lsr) & UART_LSR_THRE)) + return -EAGAIN; + serial_out(ch, &com_port->thr); + + /* + * Call watchdog_reset() upon newline. This is done here in putc + * since the environment code uses a single puts() to print the complete + * environment upon "printenv". So we can't put this watchdog call + * in puts(). + */ + if (ch == '\n') + WATCHDOG_RESET(); + + return 0; +} + +static int ns16550_serial_pending(struct udevice *dev, bool input) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + + if (input) + return serial_in(&com_port->lsr) & UART_LSR_DR ? 1 : 0; + else + return serial_in(&com_port->lsr) & UART_LSR_THRE ? 0 : 1; +} + +static int ns16550_serial_getc(struct udevice *dev) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + + if (!serial_in(&com_port->lsr) & UART_LSR_DR) + return -EAGAIN; + + return serial_in(&com_port->rbr); +} + +int ns16550_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + struct ns16550_platdata *plat = com_port->plat; + int clock_divisor; + + clock_divisor = ns16550_calc_divisor(com_port, plat->clock, baudrate); + + NS16550_setbrg(com_port, clock_divisor); + + return 0; +} + +static int ns16550_serial_probe(struct udevice *dev) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + + NS16550_init(com_port, -1); + + return 0; +} + +static int ns16550_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct NS16550 *const com_port = dev_get_priv(dev); + struct ns16550_platdata *plat = dev->platdata; + fdt_addr_t addr; + + addr = fdtdec_get_addr(gd->fdt_blob, dev->of_offset, "reg"); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = (unsigned char *)addr; + plat->reg_shift = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "reg-shift", 1); + plat->clock = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "clock-frequency", -1); + if (plat->clock == -1) + return -EINVAL; + com_port->plat = plat; + + return 0; +} + +static const struct dm_serial_ops ns16550_serial_ops = { + .putc = ns16550_serial_putc, + .pending = ns16550_serial_pending, + .getc = ns16550_serial_getc, + .setbrg = ns16550_serial_setbrg, +}; + +static const struct udevice_id ns16550_serial_ids[] = { + { .compatible = "ns16550" }, + { } +}; + +U_BOOT_DRIVER(serial_ns16550) = { + .name = "serial_ns16550", + .id = UCLASS_SERIAL, + .of_match = ns16550_serial_ids, + .ofdata_to_platdata = ns16550_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif /* CONFIG_DM_SERIAL */ diff --git a/include/ns16550.h b/include/ns16550.h index b106f8a..46ced93 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -23,6 +23,14 @@
+#ifdef CONFIG_DM_SERIAL +/* + * For driver model we always use one byte per register, and sort out the + * differences in the driver + */ +#define CONFIG_SYS_NS16550_REG_SIZE (-1) +#endif + #if !defined(CONFIG_SYS_NS16550_REG_SIZE) || (CONFIG_SYS_NS16550_REG_SIZE == 0) #error "Please define NS16550 registers size." #elif defined(CONFIG_SYS_NS16550_MEM32) @@ -37,6 +45,19 @@ unsigned char postpad_##x[-CONFIG_SYS_NS16550_REG_SIZE - 1]; #endif
+/** + * struct ns16550_platdata - information about a NS16550 port + * + * @base: Base register address + * @reg_shift: Shift size of registers (0=byte, 1=16bit, 2=32bit...) + * @clock: UART base clock speed in Hz + */ +struct ns16550_platdata { + unsigned char *base; + int reg_shift; + int clock; +}; + struct NS16550 { UART_REG(rbr); /* 0 */ UART_REG(ier); /* 1 */ @@ -67,6 +88,9 @@ struct NS16550 { UART_REG(reg12); /* 12*/ UART_REG(osc_12m_sel); /* 13*/ #endif +#ifdef CONFIG_DM_SERIAL + struct ns16550_platdata *plat; +#endif };
#define thr rbr
Some Tegra device tree files do not include information about the serial ports. Add this and also add information about the input clock speed.
The console alias needs to be set up to indicate which port is used for the console.
Also add a binding file since this is missing.
Changes in v3: - Add new patch for tegra serial port details
Changes in v2: None
arch/arm/dts/tegra114-dalmore.dts | 1 + arch/arm/dts/tegra114.dtsi | 40 +++++++++++++++++++++++++++++++ arch/arm/dts/tegra124-jetson-tk1.dts | 1 + arch/arm/dts/tegra124-venice2.dts | 1 + arch/arm/dts/tegra124.dtsi | 40 +++++++++++++++++++++++++++++++ arch/arm/dts/tegra20-colibri_t20_iris.dts | 1 + arch/arm/dts/tegra20-harmony.dts | 1 + arch/arm/dts/tegra20-medcom-wide.dts | 1 + arch/arm/dts/tegra20-paz00.dts | 1 + arch/arm/dts/tegra20-plutux.dts | 1 + arch/arm/dts/tegra20-seaboard.dts | 1 + arch/arm/dts/tegra20-tec.dts | 1 + arch/arm/dts/tegra20-trimslice.dts | 1 + arch/arm/dts/tegra20-ventana.dts | 1 + arch/arm/dts/tegra20-whistler.dts | 1 + arch/arm/dts/tegra20.dtsi | 15 ++++++++---- arch/arm/dts/tegra30-beaver.dts | 1 + arch/arm/dts/tegra30-cardhu.dts | 1 + arch/arm/dts/tegra30-tamonten.dtsi | 1 + arch/arm/dts/tegra30.dtsi | 40 +++++++++++++++++++++++++++++++ 20 files changed, 146 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/tegra114-dalmore.dts b/arch/arm/dts/tegra114-dalmore.dts index 435c01e..e2426ef 100644 --- a/arch/arm/dts/tegra114-dalmore.dts +++ b/arch/arm/dts/tegra114-dalmore.dts @@ -7,6 +7,7 @@ compatible = "nvidia,dalmore", "nvidia,tegra114";
aliases { + console = &uart_d; i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi index 59434e0..f8d740b 100644 --- a/arch/arm/dts/tegra114.dtsi +++ b/arch/arm/dts/tegra114.dtsi @@ -116,6 +116,46 @@ status = "disabled"; };
+ uart_a: serial@70006000 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006000 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 68 >; + }; + + uart_b: serial@70006040 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006040 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 69 >; + }; + + uart_c: serial@70006200 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006200 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 78 >; + }; + + uart_d: serial@70006300 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006300 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 122 >; + }; + + uart_e: serial@70006400 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006400 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 123 >; + }; + spi@7000d400 { compatible = "nvidia,tegra114-spi"; reg = <0x7000d400 0x200>; diff --git a/arch/arm/dts/tegra124-jetson-tk1.dts b/arch/arm/dts/tegra124-jetson-tk1.dts index 464287e..368caaa 100644 --- a/arch/arm/dts/tegra124-jetson-tk1.dts +++ b/arch/arm/dts/tegra124-jetson-tk1.dts @@ -7,6 +7,7 @@ compatible = "nvidia,jetson-tk1", "nvidia,tegra124";
aliases { + console = &uart_d; i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra124-venice2.dts b/arch/arm/dts/tegra124-venice2.dts index f003413..4444155 100644 --- a/arch/arm/dts/tegra124-venice2.dts +++ b/arch/arm/dts/tegra124-venice2.dts @@ -7,6 +7,7 @@ compatible = "nvidia,venice2", "nvidia,tegra124";
aliases { + console = &uart_a; i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra124.dtsi b/arch/arm/dts/tegra124.dtsi index 4561c5f..5037036 100644 --- a/arch/arm/dts/tegra124.dtsi +++ b/arch/arm/dts/tegra124.dtsi @@ -126,6 +126,46 @@ status = "disabled"; };
+ uart_a: serial@70006000 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006000 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 68 >; + }; + + uart_b: serial@70006040 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006040 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 69 >; + }; + + uart_c: serial@70006200 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006200 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 78 >; + }; + + uart_d: serial@70006300 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006300 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 122 >; + }; + + uart_e: serial@70006400 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006400 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 123 >; + }; + spi@7000d400 { compatible = "nvidia,tegra124-spi", "nvidia,tegra114-spi"; reg = <0x7000d400 0x200>; diff --git a/arch/arm/dts/tegra20-colibri_t20_iris.dts b/arch/arm/dts/tegra20-colibri_t20_iris.dts index c0e54af..fdf966b 100644 --- a/arch/arm/dts/tegra20-colibri_t20_iris.dts +++ b/arch/arm/dts/tegra20-colibri_t20_iris.dts @@ -7,6 +7,7 @@ compatible = "toradex,t20", "nvidia,tegra20";
aliases { + console = &uart_a; usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; usb2 = "/usb@c5004000"; diff --git a/arch/arm/dts/tegra20-harmony.dts b/arch/arm/dts/tegra20-harmony.dts index b115f87..565045b 100644 --- a/arch/arm/dts/tegra20-harmony.dts +++ b/arch/arm/dts/tegra20-harmony.dts @@ -7,6 +7,7 @@ compatible = "nvidia,harmony", "nvidia,tegra20";
aliases { + console = &uart_d; usb0 = "/usb@c5008000"; usb1 = "/usb@c5004000"; sdhci0 = "/sdhci@c8000600"; diff --git a/arch/arm/dts/tegra20-medcom-wide.dts b/arch/arm/dts/tegra20-medcom-wide.dts index a9a07f9..b400ce8 100644 --- a/arch/arm/dts/tegra20-medcom-wide.dts +++ b/arch/arm/dts/tegra20-medcom-wide.dts @@ -7,6 +7,7 @@ compatible = "ad,medcom-wide", "nvidia,tegra20";
aliases { + console = &uart_d; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; }; diff --git a/arch/arm/dts/tegra20-paz00.dts b/arch/arm/dts/tegra20-paz00.dts index 780203c..95b1ed4 100644 --- a/arch/arm/dts/tegra20-paz00.dts +++ b/arch/arm/dts/tegra20-paz00.dts @@ -7,6 +7,7 @@ compatible = "compal,paz00", "nvidia,tegra20";
aliases { + console = &uart_a; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; sdhci1 = "/sdhci@c8000000"; diff --git a/arch/arm/dts/tegra20-plutux.dts b/arch/arm/dts/tegra20-plutux.dts index 20016f2..a4ec20f 100644 --- a/arch/arm/dts/tegra20-plutux.dts +++ b/arch/arm/dts/tegra20-plutux.dts @@ -7,6 +7,7 @@ compatible = "ad,plutux", "nvidia,tegra20";
aliases { + console = &uart_d; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; }; diff --git a/arch/arm/dts/tegra20-seaboard.dts b/arch/arm/dts/tegra20-seaboard.dts index c0e2e1e..85d485a 100644 --- a/arch/arm/dts/tegra20-seaboard.dts +++ b/arch/arm/dts/tegra20-seaboard.dts @@ -11,6 +11,7 @@ };
aliases { + console = &uart_d; /* This defines the order of our ports */ usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; diff --git a/arch/arm/dts/tegra20-tec.dts b/arch/arm/dts/tegra20-tec.dts index 4c1b08d..0e06100 100644 --- a/arch/arm/dts/tegra20-tec.dts +++ b/arch/arm/dts/tegra20-tec.dts @@ -7,6 +7,7 @@ compatible = "ad,tec", "nvidia,tegra20";
aliases { + console = &uart_d; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; }; diff --git a/arch/arm/dts/tegra20-trimslice.dts b/arch/arm/dts/tegra20-trimslice.dts index ee31476..4506e8a 100644 --- a/arch/arm/dts/tegra20-trimslice.dts +++ b/arch/arm/dts/tegra20-trimslice.dts @@ -7,6 +7,7 @@ compatible = "compulab,trimslice", "nvidia,tegra20";
aliases { + console = &uart_a; usb0 = "/usb@c5008000"; usb1 = "/usb@c5000000"; sdhci0 = "/sdhci@c8000600"; diff --git a/arch/arm/dts/tegra20-ventana.dts b/arch/arm/dts/tegra20-ventana.dts index 1a526ba..61b45f3 100644 --- a/arch/arm/dts/tegra20-ventana.dts +++ b/arch/arm/dts/tegra20-ventana.dts @@ -7,6 +7,7 @@ compatible = "nvidia,ventana", "nvidia,tegra20";
aliases { + console = &uart_d; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; sdhci1 = "/sdhci@c8000400"; diff --git a/arch/arm/dts/tegra20-whistler.dts b/arch/arm/dts/tegra20-whistler.dts index eb92264..6eb68b5 100644 --- a/arch/arm/dts/tegra20-whistler.dts +++ b/arch/arm/dts/tegra20-whistler.dts @@ -7,6 +7,7 @@ compatible = "nvidia,whistler", "nvidia,tegra20";
aliases { + console = &uart_a; i2c0 = "/i2c@7000d000"; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index a524f6e..e3e2fbd 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -189,38 +189,43 @@ dma-channel = < 1 >; };
- serial@70006000 { + uart_a: serial@70006000 { compatible = "nvidia,tegra20-uart"; reg = <0x70006000 0x40>; reg-shift = <2>; + clock-frequency = <216000000>; interrupts = < 68 >; };
- serial@70006040 { + uart_b: serial@70006040 { compatible = "nvidia,tegra20-uart"; reg = <0x70006040 0x40>; reg-shift = <2>; + clock-frequency = <216000000>; interrupts = < 69 >; };
- serial@70006200 { + uart_c: serial@70006200 { compatible = "nvidia,tegra20-uart"; reg = <0x70006200 0x100>; reg-shift = <2>; + clock-frequency = <216000000>; interrupts = < 78 >; };
- serial@70006300 { + uart_d: serial@70006300 { compatible = "nvidia,tegra20-uart"; reg = <0x70006300 0x100>; reg-shift = <2>; + clock-frequency = <216000000>; interrupts = < 122 >; };
- serial@70006400 { + uart_e: serial@70006400 { compatible = "nvidia,tegra20-uart"; reg = <0x70006400 0x100>; reg-shift = <2>; + clock-frequency = <216000000>; interrupts = < 123 >; };
diff --git a/arch/arm/dts/tegra30-beaver.dts b/arch/arm/dts/tegra30-beaver.dts index 85e62e9..79a9fff 100644 --- a/arch/arm/dts/tegra30-beaver.dts +++ b/arch/arm/dts/tegra30-beaver.dts @@ -7,6 +7,7 @@ compatible = "nvidia,beaver", "nvidia,tegra30";
aliases { + console = &uart_a; i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra30-cardhu.dts b/arch/arm/dts/tegra30-cardhu.dts index ea2cf76..3f829ba 100644 --- a/arch/arm/dts/tegra30-cardhu.dts +++ b/arch/arm/dts/tegra30-cardhu.dts @@ -7,6 +7,7 @@ compatible = "nvidia,cardhu", "nvidia,tegra30";
aliases { + console = &uart_a; i2c0 = "/i2c@7000d000"; i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra30-tamonten.dtsi b/arch/arm/dts/tegra30-tamonten.dtsi index 50d5762..e9ed61c 100644 --- a/arch/arm/dts/tegra30-tamonten.dtsi +++ b/arch/arm/dts/tegra30-tamonten.dtsi @@ -9,6 +9,7 @@ };
aliases { + console = &uart_d; i2c0 = "/i2c@7000c000"; i2c1 = "/i2c@7000c700"; i2c2 = "/i2c@7000c400"; diff --git a/arch/arm/dts/tegra30.dtsi b/arch/arm/dts/tegra30.dtsi index 7be3791..ddd7f4a 100644 --- a/arch/arm/dts/tegra30.dtsi +++ b/arch/arm/dts/tegra30.dtsi @@ -122,6 +122,46 @@ status = "disabled"; };
+ uart_a: serial@70006000 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006000 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 68 >; + }; + + uart_b: serial@70006040 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006040 0x40>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 69 >; + }; + + uart_c: serial@70006200 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006200 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 78 >; + }; + + uart_d: serial@70006300 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006300 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 122 >; + }; + + uart_e: serial@70006400 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006400 0x100>; + reg-shift = <2>; + clock-frequency = <408000000>; + interrupts = < 123 >; + }; + spi@7000d400 { compatible = "nvidia,tegra30-slink", "nvidia,tegra20-slink"; reg = <0x7000d400 0x200>;
aliases {
console = &uart_d;
I don't think that's a standard alias name. There was some recent discussion in the devicetree mailing list re: using some property in /chosen for this purpose instead. U-Boot and the kernel should use the same representation here.
- uart_a: serial@70006000 {
This property needs to include both the specific HW (i.e. Tegra114) and any HW it's compatible with (i.e. Tegra20).
reg-shift = <2>;
This isn't a property that's defined by the Tegra serial binding. This information should be obtained by looking up the relevant clock, and querying its rate.
For reference, here's the DT node for this UART in the kernel DT, which complies with the relevant binding document:
uarta: serial@70006000 { compatible = "nvidia,tegra114-uart", "nvidia,tegra20-uart"; reg = <0x70006000 0x40>; reg-shift = <2>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; clocks = <&tegra_car TEGRA114_CLK_UARTA>; resets = <&tegra_car 6>; reset-names = "serial"; dmas = <&apbdma 8>, <&apbdma 8>; dma-names = "rx", "tx"; status = "disabled"; };
All the comment above apply to all the files in this patch.
Hi Stephen,
aliases {
console = &uart_d;
This is U-Boot's approach at present, if we change it then we should change it everywhere. I worry that 'chosen' is for Linux rather than U-Boot and we might get very confused about what chosen is for?
So something like this?
reg-shift = <2>;
We can't do that in the ns16550 driver as yet since there is no generic U-Boot clock infrastructure. I suspect that will come with time.
My intent was to make this work with a more generic binding for now - ns16550 is a pretty standard thing and I thought I could avoid making the driver Tegra-specific. Then we could allow many SoCs to use it. Why does Tegra have its own binding in the kernel for this standard UART?
On 07/31/2014 04:10 PM, Simon Glass wrote:
Hi Stephen,
aliases {
console = &uart_d;
That's not the U-Boot approach on Tegra boards before this patch. I do not want Tegra U-Boot do adopt any more U-Boot-specific not-really-DT-but-pretending-to-be bindings.
That discussion should be had on the devicetree mailing list.
Yes.
reg-shift = <2>;
The solution here is to put the clock infra-structure in place first. One thing I've learned from the kernel DT experience is that a lot of time would have been saved by putting the correct infra-structure in place first, then using it, rather than hacking around things the wrong way, then putting the infra-structure in place, then converting to it. That's a lot more work, and rather painful. Equally, if we don't just do the infra-structure right, there's really little guarantee that we'll ever convert to the correct approach. Just look at all the DT content in use in U-Boot that don't match the real DT bindings, even after it's been around years.
The HW is not a PC-style UART where all you care about is the 16550 registers, and clocks/resets/DMA/... can be ignored or deferred to firmware to set up before DT-driven SW runs.
As an aside, /almost/ all reviewed DT bindings use DT properties of the form:
clocks = <&provider parameters>;
rather than:
clock-rate = <number>;
So, that aspect of the Tegra UART binding isn't anything remotely unusual/non-standard.
Hi Stephen,
Hi Stephen,
aliases {
console = &uart_d;
Please go ahead if you wish, but this is not a Linux issue. The aliases are used for U-Boot and have been for some time.
Yes.
reg-shift = <2>;
OK, is there a plan to put this in place? Who is working on it?
I'm not sure what you are referring to here. Are you saying that U-Boot needs to support these things? I agree it would be great to add a generic clock/reset framework and have made considerable efforts in Tegra towards this myself. But we don't have it yet.
rather than:
The great is the enemy of the good. In this case, I think I might just leave the clock as a #define.
On 08/01/2014 03:32 PM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
aliases {
console = &uart_d;
No, it's not a Linux issue, it's DT issue.
DT schemas/bindings MUST be identical between U-Boot, Linux, FreeBSD, Barebox, ... (all of which use DT). As such, all the DT bindings MUST be discussed on the devicetree mailing list.
Since you're the author of the patch, it's your responsibility to have that discussion.
reg-shift = <2>;
I don't know whether anyone is or not. However, the fact that nobody is working on a clock driver is no excuse for using the incorrect DT bindings in order to hack around its lack of existence.
Yes.
Part of the decision to use DT is to use *the* DT bindings, not something that looks like DT.
If you want to move the serial port information into DT, and part of doing so requires extracting clock-related information from DT, and that in turn requires a clock driver to do so, then yes, U-Boot needs to have that clock driver implemented before you can move the serial port information into DT.
rather than:
That probably makes sense.
To be honest, I'm not sure that using DT is going to buy U-Boot much, or even the kernel in retrospect.
Hi Stephen,
Hi Stephen,
Hi Stephen,
aliases {
console = &uart_d;
OK agreed on that then.
Are you referring to the linux,stdout-path discussion, or something more DT-generic?I suppose we could have a 'u-boot,console' for our part. But in any case you are talking about code and a convention that is already in mainline U-Boot. While I accept that we might change to something DT-generic if Linux points the way to something better, I don't want to stop using it just because Linux hasn't decided yet. The early console stuff and early debug UART stuff in Linux is not yet a shining example of perfection.
That said, it's a good time to adopt 'u-boot,console' if that's what we need?
reg-shift = <2>;
Actually the bindings are correct, you are referring to a single new addition which is the input clock speed of the UART. This information is needed in U-Boot because it does not have generic clock infrastructure (and since no one is working on clock infrastructure I guess we can ignore it for this discussion). See below.
Yes.
Again, your objection is purely about the clock-frequency property I think. The binding is otherwise correct, right?
rather than:
It's not that bad :-)
The only option I can think of given your objection to the clock-frequency property is to come up with a tegra driver which mostly uses ns16550 but provides the clock frequency from a CONFIG. I think that will work. I'll update and resend.
I'm saying that any and all additions or changes to DT schemas/bindings must be discussed on the devicetree mailing list, not made/reviewed in isolation on only the U-Boot mailing list.
I strongly believe that if U-Boot continues to use DT, the current DT usage in U-Boot needs to be actively moved in line with the bindings that the Linux kernel, Barebox, FreeBSD, ... use. I'd prefer this to happen even before U-Boot starts making additional use of DT, so the conversion doesn't get forgotten. However, I suppose it's a bit draconian to prevent further usage until the existing usage is cleaned up, except where new usage introduces additional dependencies on any current usage that's inconsistent with the standard bindings.
It's certainly a good time to start that discussion on the devicetree mailing list, and get such a new property reviewed/ack'd there.
> diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi > + uart_a: serial@70006000 { > + compatible = "nvidia,tegra20-uart"; > + reg = <0x70006000 0x40>; > + reg-shift = <2>; > + clock-frequency = <408000000>;
That property (or the definition-of/schema-for it) is part of the bindings. Unless that addition is reviewed in the appropriate place, I think it's legitimate to refer the such a change to the binding as incorrect.
I think that was the primary issue, yes. If the U-Boot usage is consistent with Documentation/devicetree/bindings/serial/ of-serial.txt and/or nvidia,tegra20-hsuart.txt (as currently hosted in the Linux kernel source tree), then it's fine.
My experience working on DT support in the kernel says otherwise, but I'm happy to disagree on that point for now:-)
I don't disagree (and at ELC I was trying to see who, if anyone, had been reaching out to the FreeBSD folks since their DT files were very far from what Linux uses afaict for am33xx), but I'm also not seeing anything from non-Linux kernel folks on the devicetrees ML, or at least my quick search failed.
Hello Tom, +Warner, +Julien Grall,
I am not actually following this topic, but FreeBSD folks do try to support unmodified dft as far as possible afaik, see e.g. [1].
Regards, Jeroen
[1] http://lists.freebsd.org/pipermail/freebsd-arm/2014-March/007634.html
Hi Stephen,
[side note: You will be aware that I have expended considerable effort getting agreement on bindings. I used to copy all DT patches to that mailing list, but I can't recall getting a reply that often. Also note that U-Boot's use of DT pre-dated the kernel with many subsystems (e.g. the request to retrofit clock bindings after the code was already written). Yes, DT bindings should be common across all platforms, but where subsystems don't exist in U-Boot I feel the approach of 'do nothing until someone writes a new subsystem' might just be a recipe for inaction/no progress. Better to iterate towards perfection than never move]
So to be clear, with the clock-frequency property moved back to being hard-coded in the CONFIG, your remaining objection is that the console alias, which is already used in U-Boot, should be agreed with the devicetree mailing list? Is that right?
On 08/04/2014 02:14 PM, Simon Glass wrote:
Hi Stephen,
Do nothing isn't the right approach.
Invent something else without co-ordinating it isn't the right approach.
Proposing the DT bindings for that subsystem (even if the kernel doesn't implement code that handles the binding yet) and getting that merged into the DT binding documentation repository (which just happens to be part of the Linux kernel tree right now) is the only approach that makes sense.
IIRC, yes.
Use driver model for serial ports (for test and comment only).
Changes in v3: - Add new patch to enable driver model for seial on tegra
Changes in v2: None
include/configs/tegra-common.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 6eb0dd9..e0779f1 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -22,6 +22,9 @@ #define CONFIG_DM #define CONFIG_CMD_DM #define CONFIG_DM_GPIO +#ifndef CONFIG_SPL_BUILD +#define CONFIG_DM_SERIAL +#endif
#define CONFIG_SYS_TIMER_RATE 1000000 #define CONFIG_SYS_TIMER_COUNTER NV_PA_TMRUS_BASE @@ -42,14 +45,17 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (4 << 20) /* 4MB */ +#define CONFIG_SYS_MALLOC_F_LEN (1 << 10)
/* * NS16550 Configuration */ -#define CONFIG_SYS_NS16550 +#ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK +#endif +#define CONFIG_SYS_NS16550
/* * Common HW configuration.
A couple of nits:
README says:
Pre-relocation malloc() is only supported on sandbox at present but is fairly easy to enable for other archs.
I assume that should be deleted now.
- NS16550 Configuration
Leaving that define in the same place would simplify the diff.
Hi Stephen,
A couple of nits:
README says:
There's another series ahead of this patch which changes this message.
OK, will do.
Since Tegra now uses driver model for serial, adjust the definition of V_NS16550_CLK so that it is clear that this is only used for SPL.
Changes in v3: - Add new patch to use V_NS16550_CLK only in SPL builds
Changes in v2: None
include/configs/tegra124-common.h | 2 ++ include/configs/tegra20-common.h | 2 ++ include/configs/tegra30-common.h | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/include/configs/tegra124-common.h b/include/configs/tegra124-common.h index 61e5026..8c5842e 100644 --- a/include/configs/tegra124-common.h +++ b/include/configs/tegra124-common.h @@ -16,7 +16,9 @@ /* * NS16550 Configuration */ +#ifdef CONFIG_SPL_BUILD #define V_NS16550_CLK 408000000 /* 408MHz (pllp_out0) */ +#endif
/* Environment information, boards can override if required */ #define CONFIG_LOADADDR 0x80408000 /* def. location for kernel */ diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index 21bf977..4f8706a 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -22,7 +22,9 @@ /* * NS16550 Configuration */ +#ifdef CONFIG_SPL_BUILD #define V_NS16550_CLK 216000000 /* 216MHz (pllp_out0) */ +#endif
/* Environment information, boards can override if required */ #define CONFIG_LOADADDR 0x00408000 /* def. location for kernel */ diff --git a/include/configs/tegra30-common.h b/include/configs/tegra30-common.h index 443c842..6d2558c 100644 --- a/include/configs/tegra30-common.h +++ b/include/configs/tegra30-common.h @@ -21,7 +21,9 @@ /* * NS16550 Configuration */ +#ifdef CONFIG_SPL_BUILD #define V_NS16550_CLK 408000000 /* 408MHz (pllp_out0) */ +#endif
May as well squash this into the previous patch.
Hi Stephen,
OK, will do. I wasn't sure what people would think of this patch so left it separate.
participants (5)
Jeroen Hofstee
Jon Loeliger
Stephen Warren
