[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 3513896e57c6757c411e0633ccb5da08c36ad7d4: Robert Delien (1): Fix erroneous 32-bit access to hw_clkctrl_frac0 and hw_clkctrl_frac1 registers
git://git.denx.de/u-boot-ti.git master
Matt Porter (2): SPL: Add YMODEM over UART load support SPL: Enable YMODEM support on BeagleBone and AM335x EVM
Tom Rini (6): .gitignore: Add .su files config.mk: Make cc-option create a file under include/generated config.mk: Check for -fstack-usage support spl.c: Use __noreturn decorator README: document more SPL config options SPL: Add README.omap3
.gitignore | 1 + Makefile | 2 +- README | 69 +++++++++++++++++++++---- arch/arm/cpu/armv7/omap-common/Makefile | 3 + arch/arm/cpu/armv7/omap-common/spl.c | 10 +++- arch/arm/cpu/armv7/omap-common/spl_ymodem.c | 76 +++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 3 + common/Makefile | 3 + config.mk | 11 +++-- doc/SPL/README.omap3 | 74 ++++++++++++++++++++++++++ include/configs/am335x_evm.h | 1 + lib/Makefile | 3 + 12 files changed, 238 insertions(+), 18 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl_ymodem.c create mode 100644 doc/SPL/README.omap3
With the documentation / related changes, Wolfgang said on IRC he was OK for now with the additional SPL bits going on.
Hi Tom,
Le 06/03/2012 00:03, Tom Rini a écrit :
Hello,
All these commits are feature additions posted after the merge window, aren't they?
Amicalement,
On Tue, Mar 6, 2012 at 12:29 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Tom,
Hello,
The first part was a little late (Jan 31st) and that was held up until Wolfgang was happy with the second set.
Dear Albert ARIBAUD,
Yes, but they got added because I asked for them before I wanted to see the SPL stuff go in.
So let's pull this into the upcoming release anyway, please.
Hi Wolfgang,
Applied to u-boot-arm/master, then.
(a pull req from ARM will follow once I've checked that ARM subrepos and pending ARM repo patches are all in)
Amicalement,
Albert ARIBAUD
