[U-Boot] [PATCH 01/12] clk: rmobile: Split R8A7795 and R8A7796 core clock tables
The R8A7795 and R8A7796 tables use different constants to identify clock in DT, so split the tables and use the correct constants on R8A7795. This fixes UART clock misconfiguration on R8A7795.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/clk/renesas/clk-rcar-gen3.c | 129 +++++++++++++++++++++++++++--------- 1 file changed, 96 insertions(+), 33 deletions(-)
diff --git a/drivers/clk/renesas/clk-rcar-gen3.c b/drivers/clk/renesas/clk-rcar-gen3.c index 5ea7d9a1f5..4e74856940 100644 --- a/drivers/clk/renesas/clk-rcar-gen3.c +++ b/drivers/clk/renesas/clk-rcar-gen3.c @@ -73,6 +73,8 @@ struct gen3_clk_priv { struct clk clk_extal; struct clk clk_extalr; const struct rcar_gen3_cpg_pll_config *cpg_pll_config; + const struct cpg_core_clk *core_clk; + u32 core_clk_size; const struct mssr_mod_clk *mod_clk; u32 mod_clk_size; }; @@ -181,7 +183,7 @@ enum clk_ids { MOD_CLK_BASE };
-static const struct cpg_core_clk gen3_core_clks[] = { +static const struct cpg_core_clk r8a7795_core_clks[] = { /* External Clock Inputs */ DEF_INPUT("extal", CLK_EXTAL), DEF_INPUT("extalr", CLK_EXTALR), @@ -203,38 +205,38 @@ static const struct cpg_core_clk gen3_core_clks[] = { DEF_FIXED(".sdsrc", CLK_SDSRC, CLK_PLL1_DIV2, 2, 1),
/* Core Clock Outputs */ - DEF_FIXED("ztr", R8A7796_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), - DEF_FIXED("ztrd2", R8A7796_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), - DEF_FIXED("zt", R8A7796_CLK_ZT, CLK_PLL1_DIV2, 4, 1), - DEF_FIXED("zx", R8A7796_CLK_ZX, CLK_PLL1_DIV2, 2, 1), - DEF_FIXED("s0d1", R8A7796_CLK_S0D1, CLK_S0, 1, 1), - DEF_FIXED("s0d2", R8A7796_CLK_S0D2, CLK_S0, 2, 1), - DEF_FIXED("s0d3", R8A7796_CLK_S0D3, CLK_S0, 3, 1), - DEF_FIXED("s0d4", R8A7796_CLK_S0D4, CLK_S0, 4, 1), - DEF_FIXED("s0d6", R8A7796_CLK_S0D6, CLK_S0, 6, 1), - DEF_FIXED("s0d8", R8A7796_CLK_S0D8, CLK_S0, 8, 1), - DEF_FIXED("s0d12", R8A7796_CLK_S0D12, CLK_S0, 12, 1), - DEF_FIXED("s1d1", R8A7796_CLK_S1D1, CLK_S1, 1, 1), - DEF_FIXED("s1d2", R8A7796_CLK_S1D2, CLK_S1, 2, 1), - DEF_FIXED("s1d4", R8A7796_CLK_S1D4, CLK_S1, 4, 1), - DEF_FIXED("s2d1", R8A7796_CLK_S2D1, CLK_S2, 1, 1), - DEF_FIXED("s2d2", R8A7796_CLK_S2D2, CLK_S2, 2, 1), - DEF_FIXED("s2d4", R8A7796_CLK_S2D4, CLK_S2, 4, 1), - DEF_FIXED("s3d1", R8A7796_CLK_S3D1, CLK_S3, 1, 1), - DEF_FIXED("s3d2", R8A7796_CLK_S3D2, CLK_S3, 2, 1), - DEF_FIXED("s3d4", R8A7796_CLK_S3D4, CLK_S3, 4, 1), - - DEF_GEN3_SD("sd0", R8A7796_CLK_SD0, CLK_SDSRC, 0x074), - DEF_GEN3_SD("sd1", R8A7796_CLK_SD1, CLK_SDSRC, 0x078), - DEF_GEN3_SD("sd2", R8A7796_CLK_SD2, CLK_SDSRC, 0x268), - DEF_GEN3_SD("sd3", R8A7796_CLK_SD3, CLK_SDSRC, 0x26c), - - DEF_FIXED("cl", R8A7796_CLK_CL, CLK_PLL1_DIV2, 48, 1), - DEF_FIXED("cp", R8A7796_CLK_CP, CLK_EXTAL, 2, 1), + DEF_FIXED("ztr", R8A7795_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED("ztrd2", R8A7795_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), + DEF_FIXED("zt", R8A7795_CLK_ZT, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED("zx", R8A7795_CLK_ZX, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED("s0d1", R8A7795_CLK_S0D1, CLK_S0, 1, 1), + DEF_FIXED("s0d2", R8A7795_CLK_S0D2, CLK_S0, 2, 1), + DEF_FIXED("s0d3", R8A7795_CLK_S0D3, CLK_S0, 3, 1), + DEF_FIXED("s0d4", R8A7795_CLK_S0D4, CLK_S0, 4, 1), + DEF_FIXED("s0d6", R8A7795_CLK_S0D6, CLK_S0, 6, 1), + DEF_FIXED("s0d8", R8A7795_CLK_S0D8, CLK_S0, 8, 1), + DEF_FIXED("s0d12", R8A7795_CLK_S0D12, CLK_S0, 12, 1), + DEF_FIXED("s1d1", R8A7795_CLK_S1D1, CLK_S1, 1, 1), + DEF_FIXED("s1d2", R8A7795_CLK_S1D2, CLK_S1, 2, 1), + DEF_FIXED("s1d4", R8A7795_CLK_S1D4, CLK_S1, 4, 1), + DEF_FIXED("s2d1", R8A7795_CLK_S2D1, CLK_S2, 1, 1), + DEF_FIXED("s2d2", R8A7795_CLK_S2D2, CLK_S2, 2, 1), + DEF_FIXED("s2d4", R8A7795_CLK_S2D4, CLK_S2, 4, 1), + DEF_FIXED("s3d1", R8A7795_CLK_S3D1, CLK_S3, 1, 1), + DEF_FIXED("s3d2", R8A7795_CLK_S3D2, CLK_S3, 2, 1), + DEF_FIXED("s3d4", R8A7795_CLK_S3D4, CLK_S3, 4, 1), + + DEF_GEN3_SD("sd0", R8A7795_CLK_SD0, CLK_SDSRC, 0x074), + DEF_GEN3_SD("sd1", R8A7795_CLK_SD1, CLK_SDSRC, 0x078), + DEF_GEN3_SD("sd2", R8A7795_CLK_SD2, CLK_SDSRC, 0x268), + DEF_GEN3_SD("sd3", R8A7795_CLK_SD3, CLK_SDSRC, 0x26c), + + DEF_FIXED("cl", R8A7795_CLK_CL, CLK_PLL1_DIV2, 48, 1), + DEF_FIXED("cp", R8A7795_CLK_CP, CLK_EXTAL, 2, 1),
/* NOTE: HDMI, CSI, CAN etc. clock are missing */
- DEF_BASE("r", R8A7796_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), + DEF_BASE("r", R8A7795_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), };
static const struct mssr_mod_clk r8a7795_mod_clks[] = { @@ -392,6 +394,62 @@ static const struct mssr_mod_clk r8a7795_mod_clks[] = { DEF_MOD("scu-src0", 1031, MOD_CLK_ID(1017)), };
+static const struct cpg_core_clk r8a7796_core_clks[] = { + /* External Clock Inputs */ + DEF_INPUT("extal", CLK_EXTAL), + DEF_INPUT("extalr", CLK_EXTALR), + + /* Internal Core Clocks */ + DEF_BASE(".main", CLK_MAIN, CLK_TYPE_GEN3_MAIN, CLK_EXTAL), + DEF_BASE(".pll0", CLK_PLL0, CLK_TYPE_GEN3_PLL0, CLK_MAIN), + DEF_BASE(".pll1", CLK_PLL1, CLK_TYPE_GEN3_PLL1, CLK_MAIN), + DEF_BASE(".pll2", CLK_PLL2, CLK_TYPE_GEN3_PLL2, CLK_MAIN), + DEF_BASE(".pll3", CLK_PLL3, CLK_TYPE_GEN3_PLL3, CLK_MAIN), + DEF_BASE(".pll4", CLK_PLL4, CLK_TYPE_GEN3_PLL4, CLK_MAIN), + + DEF_FIXED(".pll1_div2", CLK_PLL1_DIV2, CLK_PLL1, 2, 1), + DEF_FIXED(".pll1_div4", CLK_PLL1_DIV4, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s0", CLK_S0, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s1", CLK_S1, CLK_PLL1_DIV2, 3, 1), + DEF_FIXED(".s2", CLK_S2, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED(".s3", CLK_S3, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED(".sdsrc", CLK_SDSRC, CLK_PLL1_DIV2, 2, 1), + + /* Core Clock Outputs */ + DEF_FIXED("ztr", R8A7796_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED("ztrd2", R8A7796_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), + DEF_FIXED("zt", R8A7796_CLK_ZT, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED("zx", R8A7796_CLK_ZX, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED("s0d1", R8A7796_CLK_S0D1, CLK_S0, 1, 1), + DEF_FIXED("s0d2", R8A7796_CLK_S0D2, CLK_S0, 2, 1), + DEF_FIXED("s0d3", R8A7796_CLK_S0D3, CLK_S0, 3, 1), + DEF_FIXED("s0d4", R8A7796_CLK_S0D4, CLK_S0, 4, 1), + DEF_FIXED("s0d6", R8A7796_CLK_S0D6, CLK_S0, 6, 1), + DEF_FIXED("s0d8", R8A7796_CLK_S0D8, CLK_S0, 8, 1), + DEF_FIXED("s0d12", R8A7796_CLK_S0D12, CLK_S0, 12, 1), + DEF_FIXED("s1d1", R8A7796_CLK_S1D1, CLK_S1, 1, 1), + DEF_FIXED("s1d2", R8A7796_CLK_S1D2, CLK_S1, 2, 1), + DEF_FIXED("s1d4", R8A7796_CLK_S1D4, CLK_S1, 4, 1), + DEF_FIXED("s2d1", R8A7796_CLK_S2D1, CLK_S2, 1, 1), + DEF_FIXED("s2d2", R8A7796_CLK_S2D2, CLK_S2, 2, 1), + DEF_FIXED("s2d4", R8A7796_CLK_S2D4, CLK_S2, 4, 1), + DEF_FIXED("s3d1", R8A7796_CLK_S3D1, CLK_S3, 1, 1), + DEF_FIXED("s3d2", R8A7796_CLK_S3D2, CLK_S3, 2, 1), + DEF_FIXED("s3d4", R8A7796_CLK_S3D4, CLK_S3, 4, 1), + + DEF_GEN3_SD("sd0", R8A7796_CLK_SD0, CLK_SDSRC, 0x074), + DEF_GEN3_SD("sd1", R8A7796_CLK_SD1, CLK_SDSRC, 0x078), + DEF_GEN3_SD("sd2", R8A7796_CLK_SD2, CLK_SDSRC, 0x268), + DEF_GEN3_SD("sd3", R8A7796_CLK_SD3, CLK_SDSRC, 0x26c), + + DEF_FIXED("cl", R8A7796_CLK_CL, CLK_PLL1_DIV2, 48, 1), + DEF_FIXED("cp", R8A7796_CLK_CP, CLK_EXTAL, 2, 1), + + /* NOTE: HDMI, CSI, CAN etc. clock are missing */ + + DEF_BASE("r", R8A7796_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), +}; + static const struct mssr_mod_clk r8a7796_mod_clks[] = { DEF_MOD("scif5", 202, R8A7796_CLK_S3D4), DEF_MOD("scif4", 203, R8A7796_CLK_S3D4), @@ -648,17 +706,18 @@ static int gen3_clk_get_mod(struct clk *clk, const struct mssr_mod_clk **mssr)
static int gen3_clk_get_core(struct clk *clk, const struct cpg_core_clk **core) { + struct gen3_clk_priv *priv = dev_get_priv(clk->dev); const unsigned long clkid = clk->id & 0xffff; int i;
if (gen3_clk_is_mod(clk)) return -EINVAL;
- for (i = 0; i < ARRAY_SIZE(gen3_core_clks); i++) { - if (gen3_core_clks[i].id != clkid) + for (i = 0; i < priv->core_clk_size; i++) { + if (priv->core_clk[i].id != clkid) continue;
- *core = &gen3_core_clks[i]; + *core = &priv->core_clk[i]; return 0; }
@@ -895,6 +954,8 @@ static int gen3_clk_probe(struct udevice *dev)
switch (model) { case CLK_R8A7795: + priv->core_clk = r8a7795_core_clks; + priv->core_clk_size = ARRAY_SIZE(r8a7795_core_clks); priv->mod_clk = r8a7795_mod_clks; priv->mod_clk_size = ARRAY_SIZE(r8a7795_mod_clks); ret = fdt_node_offset_by_compatible(gd->fdt_blob, -1, @@ -903,6 +964,8 @@ static int gen3_clk_probe(struct udevice *dev) return ret; break; case CLK_R8A7796: + priv->core_clk = r8a7796_core_clks; + priv->core_clk_size = ARRAY_SIZE(r8a7796_core_clks); priv->mod_clk = r8a7796_mod_clks; priv->mod_clk_size = ARRAY_SIZE(r8a7796_mod_clks); ret = fdt_node_offset_by_compatible(gd->fdt_blob, -1,
We need the clock available very early, add the u-boot,dm-pre-reloc DT property on those nodes, so they come up very in the process.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/r8a7795.dtsi | 4 ++++ arch/arm/dts/r8a7796.dtsi | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/arch/arm/dts/r8a7795.dtsi b/arch/arm/dts/r8a7795.dtsi index e99d6443b3..110d0681c8 100644 --- a/arch/arm/dts/r8a7795.dtsi +++ b/arch/arm/dts/r8a7795.dtsi @@ -129,6 +129,7 @@ #clock-cells = <0>; /* This value must be overridden by the board */ clock-frequency = <0>; + u-boot,dm-pre-reloc; };
extalr_clk: extalr { @@ -136,6 +137,7 @@ #clock-cells = <0>; /* This value must be overridden by the board */ clock-frequency = <0>; + u-boot,dm-pre-reloc; };
/* @@ -189,6 +191,7 @@ #address-cells = <2>; #size-cells = <2>; ranges; + u-boot,dm-pre-reloc;
gic: interrupt-controller@f1010000 { compatible = "arm,gic-400"; @@ -380,6 +383,7 @@ #clock-cells = <2>; #power-domain-cells = <0>; #reset-cells = <1>; + u-boot,dm-pre-reloc; };
rst: reset-controller@e6160000 { diff --git a/arch/arm/dts/r8a7796.dtsi b/arch/arm/dts/r8a7796.dtsi index 2ec1ed5f49..298df5db9f 100644 --- a/arch/arm/dts/r8a7796.dtsi +++ b/arch/arm/dts/r8a7796.dtsi @@ -111,6 +111,7 @@ #clock-cells = <0>; /* This value must be overridden by the board */ clock-frequency = <0>; + u-boot,dm-pre-reloc; };
extalr_clk: extalr { @@ -118,6 +119,7 @@ #clock-cells = <0>; /* This value must be overridden by the board */ clock-frequency = <0>; + u-boot,dm-pre-reloc; };
/* External CAN clock - to be overridden by boards that provide it */ @@ -140,6 +142,7 @@ #address-cells = <2>; #size-cells = <2>; ranges; + u-boot,dm-pre-reloc;
gic: interrupt-controller@f1010000 { compatible = "arm,gic-400"; @@ -333,6 +336,7 @@ #clock-cells = <2>; #power-domain-cells = <0>; #reset-cells = <1>; + u-boot,dm-pre-reloc; };
2017-08-21 0:13 GMT+09:00 Marek Vasut marek.vasut@gmail.com:
Applied, thanks.
Best regards, Nobuhiro
u-boot,dm-pre-reloc; }; extalr_clk: extalr {
u-boot,dm-pre-reloc; }; /*
u-boot,dm-pre-reloc; gic: interrupt-controller@f1010000 { compatible = "arm,gic-400";
u-boot,dm-pre-reloc; }; rst: reset-controller@e6160000 {
u-boot,dm-pre-reloc; }; /* External CAN clock - to be overridden by boards that provide it */
-- 2.11.0
Commit da3b9e7fd6a1 (Move PHY_MICREL and PHY_MICREL_KSZ90X1 to Kconfig) broke ethernet support on R8A779x Salvator-X boards by disabling the KSZ90x1 PHY in Kconfig. Reenable it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Alexandru Gagniuc alex.g@adaptrum.com Cc: Joe Hershberger joe.hershberger@ni.com --- configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index f517e0e7ab..3d36698127 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -24,6 +24,7 @@ CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 247f8785e3..10aa0bed44 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -25,6 +25,7 @@ CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y
Applied, thanks.
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index f517e0e7ab..3d36698127 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -24,6 +24,7 @@ CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 247f8785e3..10aa0bed44 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -25,6 +25,7 @@ CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y -- 2.11.0
The HUSH parser was disabled somewhere along the way, reenable it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Alexandru Gagniuc alex.g@adaptrum.com Cc: Joe Hershberger joe.hershberger@ni.com --- configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7795_ulcb_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/r8a7796_ulcb_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 3d36698127..d83eaf2b67 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7795-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 8b6b03ba32..82e5942091 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -9,6 +9,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7795-h3ulcb.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 10aa0bed44..141316127a 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7796-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index bc995deea0..160bde2ef3 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7796-m3ulcb.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y
Applied, thanks.
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 3d36698127..d83eaf2b67 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7795-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 8b6b03ba32..82e5942091 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -9,6 +9,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7795-h3ulcb.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 10aa0bed44..141316127a 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7796-salvator-x.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index bc995deea0..160bde2ef3 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200 rw root=/dev/nfs nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a7796-m3ulcb.dtb" CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y -- 2.11.0
Drop the RAVB bit from the board since RAVB now probes from DT instead.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/salvator-x/salvator-x.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index 6270de4e40..ce3892da90 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -161,17 +161,6 @@ int board_init(void) return 0; }
-static struct eth_pdata salvator_x_ravb_platdata = { - .iobase = 0xE6800000, - .phy_interface = 0, - .max_speed = 1000, -}; - -U_BOOT_DEVICE(salvator_x_ravb) = { - .name = "ravb", - .platdata = &salvator_x_ravb_platdata, -}; - #ifdef CONFIG_SH_SDHI int board_mmc_init(bd_t *bis) {
Applied, thanks.
.phy_interface = 0,
.max_speed = 1000,
.name = "ravb",
#ifdef CONFIG_SH_SDHI int board_mmc_init(bd_t *bis) { -- 2.11.0
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/ulcb/ulcb.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index 4005ec8ad5..e249bd27d4 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -140,17 +140,6 @@ int board_init(void) return 0; }
Applied, thanks.
.phy_interface = 0,
.max_speed = 1000,
.name = "ravb",
Drop the Serial SH bit from the board since UART now probes from DT instead.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/salvator-x/salvator-x.c | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index ce3892da90..4ed80f5493 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -300,15 +300,3 @@ void reset_cpu(ulong addr) writel(RST_CODE, RST_CA57RESCNT); #endif } - -static const struct sh_serial_platdata serial_platdata = { - .base = SCIF2_BASE, - .type = PORT_SCIF, - .clk = CONFIG_SH_SCIF_CLK_FREQ, - .clk_mode = INT_CLK, -}; - -U_BOOT_DEVICE(salvator_x_scif2) = { - .name = "serial_sh", - .platdata = &serial_platdata, -};
Applied, thanks.
.base = SCIF2_BASE,
.type = PORT_SCIF,
2.11.0
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/ulcb/ulcb.c | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index e249bd27d4..6b080311d0 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -232,15 +232,3 @@ int dram_init_banksize(void) const struct rmobile_sysinfo sysinfo = { CONFIG_RCAR_BOARD_STRING }; - -static const struct sh_serial_platdata serial_platdata = { - .base = SCIF2_BASE, - .type = PORT_SCIF, - .clk = CONFIG_SH_SCIF_CLK_FREQ, - .clk_mode = INT_CLK, -}; - -U_BOOT_DEVICE(salvator_x_scif2) = { - .name = "serial_sh", - .platdata = &serial_platdata, -};
Applied, thanks.
.base = SCIF2_BASE,
.type = PORT_SCIF,
2.11.0
Drop the SH SDHI bit from the board since SD now probes from DT instead.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/salvator-x/salvator-x.c | 16 +--------------- 1 file changed, 1 insertion(+), 15 deletions(-)
diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index 4ed80f5493..a09cd56d66 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -164,8 +164,6 @@ int board_init(void) #ifdef CONFIG_SH_SDHI int board_mmc_init(bd_t *bis) { - int ret = -ENODEV; - /* SDHI0 */ gpio_request(GPIO_GFN_SD0_DAT0, NULL); gpio_request(GPIO_GFN_SD0_DAT1, NULL); @@ -181,11 +179,6 @@ int board_mmc_init(bd_t *bis) gpio_direction_output(GPIO_GP_5_2, 1); /* power on */ gpio_direction_output(GPIO_GP_5_1, 1); /* 1: 3.3V, 0: 1.8V */
- ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI0_BASE, 0, - SH_SDHI_QUIRK_64BIT_BUF); - if (ret) - return ret; - /* SDHI1/SDHI2 eMMC */ gpio_request(GPIO_GFN_SD1_DAT0, NULL); gpio_request(GPIO_GFN_SD1_DAT1, NULL); @@ -208,11 +201,6 @@ int board_mmc_init(bd_t *bis) gpio_direction_output(GPIO_GP_5_3, 0); /* 1: 3.3V, 0: 1.8V */ gpio_direction_output(GPIO_GP_5_9, 0); /* 1: 3.3V, 0: 1.8V */
- ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI2_BASE, 1, - SH_SDHI_QUIRK_64BIT_BUF); - if (ret) - return ret; - #if defined(CONFIG_R8A7795) /* SDHI3 */ gpio_request(GPIO_GFN_SD3_DAT0, NULL); /* GP_4_9 */ @@ -240,9 +228,7 @@ int board_mmc_init(bd_t *bis) gpio_direction_output(GPIO_GP_3_15, 1); /* power on */ gpio_direction_output(GPIO_GP_3_14, 1); /* 1: 3.3V, 0: 1.8V */
- ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI3_BASE, 2, - SH_SDHI_QUIRK_64BIT_BUF); - return ret; + return 0; } #endif
Applied, thanks.
int ret = -ENODEV;
if (ret)
return ret;
if (ret)
return ret;
return ret;
} #endif
-- 2.11.0
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/ulcb/ulcb.c | 12 +----------- 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index 6b080311d0..068cbdea03 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -143,8 +143,6 @@ int board_init(void) #ifdef CONFIG_SH_SDHI int board_mmc_init(bd_t *bis) { - int ret = -ENODEV; - /* SDHI0 */ gpio_request(GPIO_GFN_SD0_DAT0, NULL); gpio_request(GPIO_GFN_SD0_DAT1, NULL); @@ -160,11 +158,6 @@ int board_mmc_init(bd_t *bis) gpio_direction_output(GPIO_GP_5_2, 1); /* power on */ gpio_direction_output(GPIO_GP_5_1, 1); /* 1: 3.3V, 0: 1.8V */
- ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI0_BASE, 0, - SH_SDHI_QUIRK_64BIT_BUF); - if (ret) - return ret; - /* SDHI1/SDHI2 eMMC */ gpio_request(GPIO_GFN_SD1_DAT0, NULL); gpio_request(GPIO_GFN_SD1_DAT1, NULL); @@ -187,10 +180,7 @@ int board_mmc_init(bd_t *bis) gpio_direction_output(GPIO_GP_5_3, 0); /* 1: 3.3V, 0: 1.8V */ gpio_direction_output(GPIO_GP_5_9, 0); /* 1: 3.3V, 0: 1.8V */
- ret = sh_sdhi_init(CONFIG_SYS_SH_SDHI2_BASE, 1, - SH_SDHI_QUIRK_64BIT_BUF); - - return ret; + return 0; } #endif
Applied, thanks.
int ret = -ENODEV;
if (ret)
return ret;
return ret;
} #endif
-- 2.11.0
Enable the MMC and USB DM on the board since it's the modern method and now supported by the drivers.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a7795_salvator-x_defconfig | 2 ++ configs/r8a7796_salvator-x_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index d83eaf2b67..d53504a5bb 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -30,6 +31,7 @@ CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 141316127a..d18bf2e965 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -31,6 +32,7 @@ CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER=""
Applied, thanks.
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index d83eaf2b67..d53504a5bb 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -30,6 +31,7 @@ CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 141316127a..d18bf2e965 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y @@ -31,6 +32,7 @@ CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" -- 2.11.0
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a7795_ulcb_defconfig | 2 ++ configs/r8a7796_ulcb_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 82e5942091..42913dffaf 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -21,11 +21,13 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index 160bde2ef3..e5f560612b 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -22,11 +22,13 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER=""
Applied, thanks.
diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 82e5942091..42913dffaf 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -21,11 +21,13 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index 160bde2ef3..e5f560612b 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -22,11 +22,13 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y +CONFIG_DM_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_SMBIOS_MANUFACTURER="" -- 2.11.0
Applied, thanks.
DEF_FIXED("cp", R8A7795_CLK_CP, CLK_EXTAL, 2, 1), /* NOTE: HDMI, CSI, CAN etc. clock are missing */
struct gen3_clk_priv *priv = dev_get_priv(clk->dev); const unsigned long clkid = clk->id & 0xffff; int i; if (gen3_clk_is_mod(clk)) return -EINVAL;
-- 2.11.0
Nobuhiro Iwamatsu
