[U-Boot] [PATCH] Kconfig: Use imply for network commands in distro default
There is no reason to unconditially select network commands as distro defaults. Systems without ethernet but with sd, sata, usb should also be able to use distro defaults. Use imply instead of select.
Kconfig | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/Kconfig b/Kconfig index 9b8a8077993a..55bb00936cf7 100644 --- a/Kconfig +++ b/Kconfig @@ -69,14 +69,14 @@ config DISTRO_DEFAULTS imply USE_BOOTCOMMAND select CMD_BOOTZ if ARM && !ARM64 select CMD_BOOTI if ARM64 - select CMD_DHCP - select CMD_PXE + imply CMD_DHCP + imply CMD_PXE select CMD_EXT2 select CMD_EXT4 select CMD_FAT select CMD_FS_GENERIC - select CMD_MII - select CMD_PING + imply CMD_MII + imply CMD_PING select CMD_PART select HUSH_PARSER help
- select CMD_DHCP
- select CMD_PXE
- imply CMD_DHCP
- imply CMD_PXE select CMD_EXT2 select CMD_EXT4 select CMD_FAT select CMD_FS_GENERIC
- select CMD_MII
- select CMD_PING
- imply CMD_MII
- imply CMD_PING select CMD_PART select HUSH_PARSER help
Should we perhaps use select CMD_DHCP if NET, etc? There's a certain level of non-opt-outedness that's supposed to be here, so long as the underlying functionality is there. And a follow-up might be that a bunch more CMDs need to be nested under / depend on NET to start with. But that's just a thought. Thanks!
- select CMD_DHCP
- select CMD_PXE
- imply CMD_DHCP
- select CMD_MII
- select CMD_PING
- imply CMD_MII
Not a problem. I will take a look at cmd_net and phylib which should depends on net and will send v2.
Thanks, Michal
Michal Simek
