[U-Boot] [PATCH] am335x_evm: Drop SPI SPL support from the default build
This is only useful with the _spiboot build target anyhow, so only include it then. Drop CONFIG_SPL_OS_BOOT support then as the flash is small and didn't include a spot for the device tree already.
Signed-off-by: Tom Rini trini@ti.com --- include/configs/am335x_evm.h | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ebe2ab3..036c609 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -213,14 +213,6 @@ #define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL"
-/* SPI flash. */ -#define CONFIG_SPL_SPI_SUPPORT -#define CONFIG_SPL_SPI_FLASH_SUPPORT -#define CONFIG_SPL_SPI_LOAD -#define CONFIG_SPL_SPI_BUS 0 -#define CONFIG_SPL_SPI_CS 0 -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 - #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds"
#ifdef CONFIG_NAND @@ -362,6 +354,15 @@ * 0x442000 - 0x800000 : Userland */ #if defined(CONFIG_SPI_BOOT) +/* SPL related */ +#undef CONFIG_SPL_OS_BOOT /* Not supported by existing map */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 + #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED @@ -437,7 +438,6 @@ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ -#undef CONFIG_SPL_SPI_SUPPORT #ifdef CONFIG_NOR_BOOT #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */
Applied to u-boot-ti/master, thanks!
