[U-Boot] [PATCH] sysreset: syscon: add support for power off
The new type sysreset 'POWER_OFF', introduced by commit 751fed426f87 ("sysreset: Add a way to find the last reset") is only supported for "syscon-poweroff" compatible.
For details see Linux binding: ./Documentation/devicetree/bindings/power/reset/syscon-poweroff.txt
This patch removes the support of POWER_OFF for "syscon-reboot" and keeps only the COLD reset (for command reset support) and it introduces the compatible "syscon-poweroff" for the POWER_OFF case.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/sysreset/sysreset_syscon.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/sysreset/sysreset_syscon.c b/drivers/sysreset/sysreset_syscon.c index 1028160..d0e586f 100644 --- a/drivers/sysreset/sysreset_syscon.c +++ b/drivers/sysreset/sysreset_syscon.c @@ -23,8 +23,9 @@ struct syscon_reboot_priv { static int syscon_reboot_request(struct udevice *dev, enum sysreset_t type) { struct syscon_reboot_priv *priv = dev_get_priv(dev); + ulong driver_data = dev_get_driver_data(dev);
- if (type == SYSRESET_POWER) + if (type != driver_data) return -EPROTONOSUPPORT;
regmap_write(priv->regmap, priv->offset, priv->mask); @@ -53,7 +54,8 @@ int syscon_reboot_probe(struct udevice *dev) }
static const struct udevice_id syscon_reboot_ids[] = { - { .compatible = "syscon-reboot" }, + { .compatible = "syscon-reboot", .data = SYSRESET_COLD }, + { .compatible = "syscon-poweroff", .data = SYSRESET_POWER_OFF }, { /* sentinel */ } };
From: Patrick DELAUNAY patrick.delaunay@st.com Sent: lundi 20 mai 2019 10:59
The new type sysreset 'POWER_OFF', introduced by commit 751fed426f87 ("sysreset: Add a way to find the last reset") is only supported for "syscon- poweroff" compatible.
Applied to u-boot-stm32/master, thanks!
Patrick
Patrick DELAUNAY
Patrick Delaunay
