[U-Boot] [PATCH] Save environment data to mmc.
This patch is to save environment data to mmc card. It uses interfaces defined in generic mmc.
Signed-off-by: Terry Lv r65388@freescale.com --- common/Makefile | 1 + common/cmd_nvedit.c | 3 +- common/env_mmc.c | 166 +++++++++++++++++++++++++++++++++++++++++++++++++ include/environment.h | 18 +++++ lib_arm/board.c | 10 ++-- lib_ppc/board.c | 12 ++-- 6 files changed, 198 insertions(+), 12 deletions(-) create mode 100644 common/env_mmc.c
diff --git a/common/Makefile b/common/Makefile index a92a75f..5f953b1 100644 --- a/common/Makefile +++ b/common/Makefile @@ -54,6 +54,7 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o COBJS-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o COBJS-$(CONFIG_ENV_IS_IN_MG_DISK) += env_mgdisk.o +COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 9f8d531..9168241 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -60,9 +60,10 @@ DECLARE_GLOBAL_DATA_PTR; !defined(CONFIG_ENV_IS_IN_NVRAM) && \ !defined(CONFIG_ENV_IS_IN_ONENAND) && \ !defined(CONFIG_ENV_IS_IN_SPI_FLASH) && \ + !defined(CONFIG_ENV_IS_IN_MMC) && \ !defined(CONFIG_ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|DATAFLASH|ONENAND|\ -SPI_FLASH|MG_DISK|NVRAM|NOWHERE} +SPI_FLASH|MG_DISK|NVRAM|MMC|NOWHERE} #endif
#define XMK_STR(x) #x diff --git a/common/env_mmc.c b/common/env_mmc.c new file mode 100644 index 0000000..5742db0 --- /dev/null +++ b/common/env_mmc.c @@ -0,0 +1,166 @@ +/* + * (C) Copyright 2008-2009 Freescale Semiconductor, Inc. + + * (C) Copyright 2000-2006 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2001 Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Andreas Heppel aheppel@sysgo.de + + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ + +#include <common.h> + +#include <command.h> +#include <environment.h> +#include <linux/stddef.h> +#include <malloc.h> +#include <mmc.h> + +#if defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_MMC) +#define CMD_SAVEENV +#elif defined(CONFIG_ENV_OFFSET_REDUND) +#error Cannot use CONFIG_ENV_OFFSET_REDUND without CONFIG_CMD_ENV & CONFIG_CMD_MMC +#endif + +#if defined(CONFIG_ENV_SIZE_REDUND) && (CONFIG_ENV_SIZE_REDUND < CONFIG_ENV_SIZE) +#error CONFIG_ENV_SIZE_REDUND should not be less then CONFIG_ENV_SIZE +#endif + +/* references to names in env_common.c */ +extern uchar default_environment[]; + +char *env_name_spec = "MMC"; + +#ifdef ENV_IS_EMBEDDED +extern uchar environment[]; +env_t *env_ptr = (env_t *)(&environment[0]); +#else /* ! ENV_IS_EMBEDDED */ +env_t *env_ptr; +#endif /* ENV_IS_EMBEDDED */ + +/* local functions */ +#if !defined(ENV_IS_EMBEDDED) +static void use_default(void); +#endif + +DECLARE_GLOBAL_DATA_PTR; + +uchar env_get_char_spec(int index) +{ + return *((uchar *)(gd->env_addr + index)); +} + +int env_init(void) +{ + /* use default */ + gd->env_addr = (ulong)&default_environment[0]; + gd->env_valid = 1; + + return 0; +} + +inline int init_mmc_for_env(struct mmc *mmc) +{ + if (!mmc) { + puts("No MMC card found\n"); + return -1; + } + + if (mmc_init(mmc)) { + puts("MMC init failed\n"); + return -1; + } + + return 0; +} + +#ifdef CMD_SAVEENV + +inline int write_env(struct mmc *mmc, unsigned long size, + unsigned long offset, const void *buffer) +{ + uint blk_start = 0, blk_cnt = 0, n = 0; + + blk_start = (offset % 512) ? ((offset / 512) + 1) : (offset / 512); + blk_cnt = (size % 512) ? ((size / 512) + 1) : (size / 512); + n = mmc->block_dev.block_write(0, blk_start , blk_cnt, (u_char *)buffer); + + return (n == blk_cnt) ? 0 : -1; +} + +int saveenv(void) +{ + struct mmc *mmc = find_mmc_device(0); + + if (init_mmc_for_env(mmc)) + return 1; + + puts("Writing to MMC... "); + if (write_env(mmc, CONFIG_ENV_SIZE, \ + CONFIG_ENV_OFFSET, env_ptr)) { + puts("failed\n"); + return 1; + } + + puts("done\n"); + return 0; +} +#endif /* CMD_SAVEENV */ + +inline int read_env(struct mmc *mmc, unsigned long size, + unsigned long offset, const void *buffer) +{ + uint blk_start = 0, blk_cnt = 0, n = 0; + + blk_start = (offset % 512) ? ((offset / 512) + 1) : (offset / 512); + blk_cnt = (size % 512) ? ((size / 512) + 1) : (size / 512); + + n = mmc->block_dev.block_read(0, blk_start, blk_cnt, (uchar *)buffer); + + return (n == blk_cnt) ? 0 : -1; +} + +void env_relocate_spec(void) +{ +#if !defined(ENV_IS_EMBEDDED) + struct mmc *mmc = find_mmc_device(0); + + if (init_mmc_for_env(mmc)) + return; + + if (read_env(mmc, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, env_ptr)) + return use_default(); + + if (crc32(0, env_ptr->data, ENV_SIZE) != env_ptr->crc) + return use_default(); +#endif /* ! ENV_IS_EMBEDDED */ +} + +#if !defined(ENV_IS_EMBEDDED) +static void use_default() +{ + puts ("*** Warning - bad CRC or MMC, using default environment\n\n"); + set_default_env(); +} +#endif + diff --git a/include/environment.h b/include/environment.h index b9924fd..0b72e0b 100644 --- a/include/environment.h +++ b/include/environment.h @@ -94,6 +94,24 @@ # endif #endif /* CONFIG_ENV_IS_IN_MG_DISK */
+#if defined(CONFIG_ENV_IS_IN_MMC) +# ifndef CONFIG_ENV_OFFSET +# error "Need to define CONFIG_ENV_OFFSET when using CONFIG_ENV_IS_IN_MMC" +# endif +# ifndef CONFIG_ENV_ADDR +# define CONFIG_ENV_ADDR (CONFIG_ENV_OFFSET) +# endif +# ifndef CONFIG_ENV_OFFSET +# define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +# endif +# ifdef CONFIG_ENV_OFFSET_REDUND +# define CONFIG_SYS_REDUNDAND_ENVIRONMENT +# endif +# ifdef CONFIG_ENV_IS_EMBEDDED +# define ENV_IS_EMBEDDED 1 +# endif +#endif /* CONFIG_ENV_IS_IN_MMC */ + /* Embedded env is only supported for some flash types */ #ifdef CONFIG_ENV_IS_EMBEDDED # if !defined(CONFIG_ENV_IS_IN_FLASH) && \ diff --git a/lib_arm/board.c b/lib_arm/board.c index 5e3d7f6..f846d0d 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -335,6 +335,11 @@ void start_armboot (void) nand_init(); /* go init the NAND */ #endif
+#ifdef CONFIG_GENERIC_MMC + puts ("MMC: "); + mmc_initialize (gd->bd); +#endif + #if defined(CONFIG_CMD_ONENAND) onenand_init(); #endif @@ -416,11 +421,6 @@ extern void davinci_eth_set_mac_addr (const u_int8_t *addr); board_late_init (); #endif
-#ifdef CONFIG_GENERIC_MMC - puts ("MMC: "); - mmc_initialize (gd->bd); -#endif - #ifdef CONFIG_BITBANGMII bb_miiphy_init(); #endif diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 765f97a..9b3f84c 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -776,6 +776,12 @@ void board_init_r (gd_t *id, ulong dest_addr) nand_init(); /* go init the NAND */ #endif
+#ifdef CONFIG_GENERIC_MMC + WATCHDOG_RESET (); + puts ("MMC: "); + mmc_initialize (bd); +#endif + /* relocate environment function pointers etc. */ env_relocate ();
@@ -932,12 +938,6 @@ void board_init_r (gd_t *id, ulong dest_addr) scsi_init (); #endif
-#ifdef CONFIG_GENERIC_MMC - WATCHDOG_RESET (); - puts ("MMC: "); - mmc_initialize (bd); -#endif - #if defined(CONFIG_CMD_DOC) WATCHDOG_RESET (); puts ("DOC: ");
This seems not correct. If not explicitely set, we get a compiler error. Assuming you has taken this check from env_nand.c, this should be:
#if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_MMC)
Line too long.
Ditto.
+#ifdef CMD_SAVEENV
Line too long.
- uint blk_start = 0, blk_cnt = 0, n = 0;
- blk_start = (offset % 512) ? ((offset / 512) + 1) : (offset / 512);
- blk_cnt = (size % 512) ? ((size / 512) + 1) : (size / 512);
The alignment to block size is repeated here and in the read function. Should not better to set a macro (something like BLOCK_ALIGN) providing the required alignment ?
- struct mmc *mmc = find_mmc_device(0);
Why is the MMC device hard-coded ? At least should be configurable with a CONFIG_ option. There are boards with more than one MMC controller and you constraint to use always the first one.
Already said, a macro is much more readable to perform alignment.
You missed Wolfgang's comment. I think also that there is no reason to set offset for the MMC and block numbers makes more sense.
- puts ("MMC: ");
- puts ("MMC: ");
I am quite confused. You add the initialization only for ARM and PPC. What about the other architectures ?
I tested your patch on mx51evk, environment is correctly read/written on the SD situated on the back.
Regards, Stefano
Hi Babic,
Thanks for reviewing the patch.
I will send out a new patch to fix the problems you point out.
For setting block numbers for MMC offset, I just don't want env mmc to be different. I want users to use it as similiar as other env devices.
For the initalization for ARM and PPC, It will be added for all architectures.
Thanks a lot ~~
Yours Terry
-----Original Message----- From: Stefano Babic [mailto:sbabic@denx.de] Sent: 2010年3月3日 1:03 To: Lv Terry-R65388 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] Save environment data to mmc.
+#define CMD_SAVEENV +#elif defined(CONFIG_ENV_OFFSET_REDUND) #error Cannot use +CONFIG_ENV_OFFSET_REDUND without CONFIG_CMD_ENV & CONFIG_CMD_MMC
Line too long.
+#if defined(CONFIG_ENV_SIZE_REDUND) && (CONFIG_ENV_SIZE_REDUND < +CONFIG_ENV_SIZE)
Ditto.
+#ifdef CMD_SAVEENV
Line too long.
+#if defined(CONFIG_ENV_IS_IN_MMC) +# ifndef CONFIG_ENV_OFFSET +# error "Need to define CONFIG_ENV_OFFSET when using CONFIG_ENV_IS_IN_MMC" +# endif +# ifndef CONFIG_ENV_ADDR +# define CONFIG_ENV_ADDR (CONFIG_ENV_OFFSET) +# endif +# ifndef CONFIG_ENV_OFFSET +# define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) # endif # ifdef +CONFIG_ENV_OFFSET_REDUND # define CONFIG_SYS_REDUNDAND_ENVIRONMENT # +endif # ifdef CONFIG_ENV_IS_EMBEDDED +# define ENV_IS_EMBEDDED 1 +# endif +#endif /* CONFIG_ENV_IS_IN_MMC */
- puts ("MMC: ");
- puts ("MMC: ");
Regards, Stefano
-- ===================================================================== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de =====================================================================
Hi, Terry,
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Lv Terry-R65388 Sent: 2010年3月4日 11:01 To: Stefano Babic Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] Save environment data to mmc.
Hi Babic,
Thanks a lot ‾‾
Had better not put comments on the top of the email, need follow the community style.
Yours Terry
Line too long.
Ditto.
+#ifdef CMD_SAVEENV
unsigned long
Line too long.
(offset / 512);
(offset / 512);
/* Embedded env is only supported for some flash types */ #ifdef CONFIG_ENV_IS_EMBEDDED # if !defined(CONFIG_ENV_IS_IN_FLASH) && ¥ diff --git a/lib_arm/board.c b/lib_arm/board.c index
5e3d7f6..f846d0d
100644
- puts ("MMC: ");
765f97a..9b3f84c
- puts ("MMC: ");
Regards, Stefano
Liu Hui-R64343
Lv Terry-R65388
Stefano Babic
Terry Lv
