[U-Boot] [PATCH 1/1] usb: gadget: g_dnl: Use serial# variable to set g_dnl_serial
Since 842778a09104 commit, "fastboot devices" stopped to show correct device serial number for TI boards, showing this line instead:
???????????? fastboot
This is because serial# env variable could be set after g_dnl gadget was initialized (e.g. by using env_set() in the board file).
To fix this, before checking g_dnl_serial, let's re-check if we have valid serial# value. And if so, let's set it as g_dnl_serial value.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/usb/gadget/g_dnl.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 0491a0eea9..e4d0289757 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -226,6 +226,15 @@ static int g_dnl_bind(struct usb_composite_dev *cdev)
g_dnl_bind_fixup(&device_desc, cdev->driver->name);
+ /* First try to obtain serial number from serial# variable */ + if (strlen(g_dnl_serial) == 0) { + const char *s; + + s = env_get("serial#"); + if (s) + g_dnl_set_serialnumber((char *)s); + } + if (strlen(g_dnl_serial)) { id = usb_string_id(cdev); if (id < 0)
const char *s;
if (s)
-- 2.14.1
Similar commit: [1]. But I'm not sure that implementing g_dnl_bind_fixup() in board file is the best way to fix it.
[1] http://git.denx.de/?p=u-boot.git;a=commit;h=e91ead868b536d0a0dc49aa48f4d8c80...
const char *s;
if (s)
-- 2.14.1
I would opt for having g_dnl_bind_fixup() since it is generally used for tweaking board specific data to gadget subsystem (like vid, pid, serial number).
Can't we use U_BOOT_ENV_CALLBACK() here instead and set the serial number when the environment variable is set ?
- /* First try to obtain serial number from serial# variable */
- if (strlen(g_dnl_serial) == 0) {
const char *s;
if (s)
- if (strlen(g_dnl_serial)) { id = usb_string_id(cdev); if (id < 0)
Hmm... This might work.
However, I'm a bit concerned with having "bound" the one particular env variable ("serial#" in this case) to generic g_dnl.c code.
const char *s;
if (s)
That's a separate problem though, we already have this serial# variable in place.
Do you mean that it is the same of "fixed" variable, as "ipaddr" is for network subsytem?
Good point. I've tested this approach and it works fine. Will resend v2 shortly. Thanks for the hint!
const char *s;
if (s)
-- Best regards, Marek Vasut
On 1 September 2017 at 14:58, Sam Protsenko semen.protsenko@linaro.org wrote:
Sent v2, using U_BOOT_ENV_CALLBACK: [1]. Guys, please review.
[1] https://lists.denx.de/pipermail/u-boot/2017-September/304460.html
const char *s;
if (s)
Sam Protsenko
Łukasz Majewski
