[PATCH 1/2] clk: Move clk-gate2 to clock driver directory
Make clk-gate2 available for use outside of imx.
Signed-off-by: Sean Anderson seanga2@gmail.com --- drivers/clk/Makefile | 1 + drivers/clk/{imx => }/clk-gate2.c | 20 ++++---------------- drivers/clk/imx/Makefile | 2 +- drivers/clk/imx/clk.h | 5 ----- include/linux/clk-provider.h | 24 ++++++++++++++++++++---- 5 files changed, 26 insertions(+), 26 deletions(-) rename drivers/clk/{imx => }/clk-gate2.c (85%)
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 06131edb9f..fef3280f16 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_rate.o obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_factor.o obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk.o clk-divider.o clk-mux.o clk-gate.o obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-fixed-factor.o +obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-gate2.o obj-$(CONFIG_$(SPL_TPL_)CLK_COMPOSITE_CCF) += clk-composite.o
obj-y += analogbits/ diff --git a/drivers/clk/imx/clk-gate2.c b/drivers/clk/clk-gate2.c similarity index 85% rename from drivers/clk/imx/clk-gate2.c rename to drivers/clk/clk-gate2.c index 1b9db6e791..cfe21e5496 100644 --- a/drivers/clk/imx/clk-gate2.c +++ b/drivers/clk/clk-gate2.c @@ -10,8 +10,7 @@ * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. * - * Gated clock implementation - * + * Gated clock which redirects rate functions to its parent clock */
#include <common.h> @@ -21,19 +20,8 @@ #include <dm/device.h> #include <linux/clk-provider.h> #include <clk.h> -#include "clk.h" - -#define UBOOT_DM_CLK_IMX_GATE2 "imx_clk_gate2" - -struct clk_gate2 { - struct clk clk; - void __iomem *reg; - u8 bit_idx; - u8 cgr_val; - u8 flags; -};
-#define to_clk_gate2(_clk) container_of(_clk, struct clk_gate2, clk) +#define UBOOT_DM_CLK_GATE2 "clk_gate2"
static int clk_gate2_enable(struct clk *clk) { @@ -97,7 +85,7 @@ struct clk *clk_register_gate2(struct device *dev, const char *name,
clk = &gate->clk;
- ret = clk_register(clk, UBOOT_DM_CLK_IMX_GATE2, name, parent_name); + ret = clk_register(clk, UBOOT_DM_CLK_GATE2, name, parent_name); if (ret) { kfree(gate); return ERR_PTR(ret); @@ -107,7 +95,7 @@ struct clk *clk_register_gate2(struct device *dev, const char *name, }
U_BOOT_DRIVER(clk_gate2) = { - .name = UBOOT_DM_CLK_IMX_GATE2, + .name = UBOOT_DM_CLK_GATE2, .id = UCLASS_CLK, .ops = &clk_gate2_ops, .flags = DM_FLAG_PRE_RELOC, diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index 222c5a4e08..5328e9265a 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -2,7 +2,7 @@ # # SPDX-License-Identifier: GPL-2.0
-obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-gate2.o clk-pllv3.o clk-pfd.o +obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-pllv3.o clk-pfd.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMX6Q) += clk-imx6q.o obj-$(CONFIG_CLK_IMX8) += clk-imx8.o
diff --git a/drivers/clk/imx/clk.h b/drivers/clk/imx/clk.h index 07dcf94ea5..c46570e9f4 100644 --- a/drivers/clk/imx/clk.h +++ b/drivers/clk/imx/clk.h @@ -45,11 +45,6 @@ struct clk *imx_clk_pll14xx(const char *name, const char *parent_name, void __iomem *base, const struct imx_pll14xx_clk *pll_clk);
-struct clk *clk_register_gate2(struct device *dev, const char *name, - const char *parent_name, unsigned long flags, - void __iomem *reg, u8 bit_idx, u8 cgr_val, - u8 clk_gate_flags); - struct clk *imx_clk_pllv3(enum imx_pllv3_type type, const char *name, const char *parent_name, void __iomem *base, u32 div_mask); diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index 0ef6e685ad..f510291018 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -90,10 +90,6 @@ struct clk_gate { #define CLK_GATE_HIWORD_MASK BIT(1)
extern const struct clk_ops clk_gate_ops; -struct clk *clk_register_gate(struct device *dev, const char *name, - const char *parent_name, unsigned long flags, - void __iomem *reg, u8 bit_idx, - u8 clk_gate_flags, spinlock_t *lock);
struct clk_div_table { unsigned int val; @@ -159,6 +155,16 @@ struct clk_composite {
#define to_clk_composite(_clk) container_of(_clk, struct clk_composite, clk)
+struct clk_gate2 { + struct clk clk; + void __iomem *reg; + u8 bit_idx; + u8 cgr_val; + u8 flags; +}; + +#define to_clk_gate2(_clk) container_of(_clk, struct clk_gate2, clk) + struct clk *clk_register_composite(struct device *dev, const char *name, const char * const *parent_names, int num_parents, struct clk *mux_clk, const struct clk_ops *mux_ops, @@ -184,6 +190,16 @@ struct clk *clk_register_mux(struct device *dev, const char *name, void __iomem *reg, u8 shift, u8 width, u8 clk_mux_flags);
+struct clk *clk_register_gate(struct device *dev, const char *name, + const char *parent_name, unsigned long flags, + void __iomem *reg, u8 bit_idx, + u8 clk_gate_flags, spinlock_t *lock); + +struct clk *clk_register_gate2(struct device *dev, const char *name, + const char *parent_name, unsigned long flags, + void __iomem *reg, u8 bit_idx, u8 cgr_val, + u8 clk_gate_flags); + const char *clk_hw_get_name(const struct clk *hw); ulong clk_generic_get_rate(struct clk *clk);
Hi Sean
This patch is OK.
Unfortunately, it causes buildman errors for sandbox: https://travis-ci.org/lmajewski/u-boot-dfu/jobs/641984485
The problem is with local sandbox copy of struct clk_gate2
In the clk_sandbox_ccf.c file we can re-use the 'flags' member (instead of defined for sandbox 'state') of now widely exposed struct clk_gate2 (@ clk-provider.h) and
#define SANDBOX_CCF_ENABLE (1UL << 31) #define SANDBOX_CCF_DISABLE (0UL << 31)
and remove the local sandbox copy.
How to reproduce:
make mrproper; make sandbox_defconfig; make -j4 ./u-boot -i -d arch/sandbox/dts/test.dtb => ut dm clk
(I'm going to drop this patch from PR which I'm preparing now and depending on it "clk: Add option to restrict clk-gate2 to one bit toggle").
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- Gated clock implementation
- Gated clock which redirects rate functions to its parent clock
-struct clk_gate2 {
- struct clk clk;
- u8 bit_idx;
- u8 cgr_val;
- u8 flags;
clk = &gate->clk;
parent_name);
- ret = clk_register(clk, UBOOT_DM_CLK_GATE2, name,
- .name = UBOOT_DM_CLK_GATE2, .id = UCLASS_CLK, .ops = &clk_gate2_ops, .flags = DM_FLAG_PRE_RELOC,
u8 clk_gate_flags);
flags,
+struct clk_gate2 {
- struct clk clk;
- u8 bit_idx;
- u8 cgr_val;
- u8 flags;
flags,
long flags,
cgr_val,
u8 clk_gate_flags);
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 1/26/20 3:55 PM, Lukasz Majewski wrote:
Hi Sean
This patch is OK.
How to reproduce:
That's fine. This may be a bit of duplicate effort wrt the patches I submitted regarding clk_composite. I originally used clk_gate2 in my k210 patch series, but I switched over to using clk_composite because it could function in the same manner.
Hi Sean,
Hi Sean
This patch is OK.
How to reproduce:
Thanks for the update.
Lukasz Majewski
Lukasz Majewski
Sean Anderson
