[U-Boot] [PATCH] mxs: timrot: Rename local macros
Local macros apply to both iMX23 and iMX28. This patch renames local macros with attribute MX28 to MXS.
Signed-off-by: Fadil Berisha f.koliqi@gmail.com Cc: Marek Vasut marex@denx.de Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mxs/timer.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/timer.c b/arch/arm/cpu/arm926ejs/mxs/timer.c index fc0a2af..61da0ca 100644 --- a/arch/arm/cpu/arm926ejs/mxs/timer.c +++ b/arch/arm/cpu/arm926ejs/mxs/timer.c @@ -46,22 +46,22 @@ DECLARE_GLOBAL_DATA_PTR; /* * This driver uses 1kHz clock source. */ -#define MX28_INCREMENTER_HZ 1000 +#define MXS_INCREMENTER_HZ 1000
static inline unsigned long tick_to_time(unsigned long tick) { - return tick / (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); + return tick / (MXS_INCREMENTER_HZ / CONFIG_SYS_HZ); }
static inline unsigned long time_to_tick(unsigned long time) { - return time * (MX28_INCREMENTER_HZ / CONFIG_SYS_HZ); + return time * (MXS_INCREMENTER_HZ / CONFIG_SYS_HZ); }
/* Calculate how many ticks happen in "us" microseconds */ static inline unsigned long us_to_tick(unsigned long us) { - return (us * MX28_INCREMENTER_HZ) / 1000000; + return (us * MXS_INCREMENTER_HZ) / 1000000; }
int timer_init(void) @@ -136,17 +136,17 @@ ulong get_timer(ulong base) }
/* We use the HW_DIGCTL_MICROSECONDS register for sub-millisecond timer. */ -#define MX28_HW_DIGCTL_MICROSECONDS 0x8001c0c0 +#define MXS_HW_DIGCTL_MICROSECONDS 0x8001c0c0
void __udelay(unsigned long usec) { uint32_t old, new, incr; uint32_t counter = 0;
- old = readl(MX28_HW_DIGCTL_MICROSECONDS); + old = readl(MXS_HW_DIGCTL_MICROSECONDS);
while (counter < usec) { - new = readl(MX28_HW_DIGCTL_MICROSECONDS); + new = readl(MXS_HW_DIGCTL_MICROSECONDS);
/* Check if the timer wrapped. */ if (new < old) { @@ -171,5 +171,5 @@ void __udelay(unsigned long usec)
ulong get_tbclk(void) { - return MX28_INCREMENTER_HZ; + return MXS_INCREMENTER_HZ; }
Acked-by: Otavio Salvador otavio@ossystems.com.br
Dear Fadil Berisha,
Acked-by: Marek Vasut marex@denx.de
NOTE: I did not receive this email, maybe your mailer is broken and doesn't handle the Cc properly?
Best regards, Marek Vasut
Fadil Berisha
Otavio Salvador
