[U-Boot] [PATCH] Allow runtime configuration of "zero-delay" check
Define the new "-2" value for bootdelay to mean autoboot with no delay and don't check for an abort key (while "0" value means do check).
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- README | 2 ++ common/main.c | 5 +++-- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/README b/README index fb9d904..da30673 100644 --- a/README +++ b/README @@ -679,6 +679,8 @@ The following options need to be configured: - Boot Delay: CONFIG_BOOTDELAY - in seconds Delay before automatically booting the default image; set to -1 to disable autoboot. + set to -2 to autoboot with no delay and not check for abort + (even when CONFIG_ZERO_BOOTDELAY_CHECK is defined).
See doc/README.autoboot for these options that work with CONFIG_BOOTDELAY. None are required. diff --git a/common/main.c b/common/main.c index 81984ac..9507cec 100644 --- a/common/main.c +++ b/common/main.c @@ -222,7 +222,8 @@ int abortboot(int bootdelay) #ifdef CONFIG_MENUPROMPT printf(CONFIG_MENUPROMPT); #else - printf("Hit any key to stop autoboot: %2d ", bootdelay); + if (bootdelay >= 0) + printf("Hit any key to stop autoboot: %2d ", bootdelay); #endif
#if defined CONFIG_ZERO_BOOTDELAY_CHECK @@ -382,7 +383,7 @@ void main_loop (void)
debug ("### main_loop: bootcmd="%s"\n", s ? s : "<UNDEFINED>");
- if (bootdelay >= 0 && s && !abortboot (bootdelay)) { + if (bootdelay != -1 && s && !abortboot(bootdelay)) { # ifdef CONFIG_AUTOBOOT_KEYED int prev = disable_ctrlc(1); /* disable Control C checking */ # endif
Joe Hershberger
