[U-Boot-Users] [PATCH] - OMAP2420/H4 board update and fix.
Hello,
This patch is to a CVS pull from this morning to the pre 1.1.3. It updates the loader such that it works on all current variants of the H4 board. It also fixes the i2c compile error which was discussed earlier.
- Update support for OMAP242x (ARM11) H4 board. - clean up and add new types to H4 memory probe code. - fix to work with internal boot. - added PRCM config III operation timings. - fix marginal flash timings. - add revision ATAG usage. - enable voltage scaling at power chip. - fix compile error for i2c.
Has been tried and tested on 2420 and 2422 based boards.
Regards, Richard W.
In message 71555548814716479478431542AA5F8A0197FDBB@dlee2k04.ent.ti.com you wrote:
Added, thanks. Will go to CVS in a few hours.
Woodruff, Richard
