[PATCH v4] fastboot: add UUU command UCmd and ACmd support
add support for the UUU commands ACmd and UCmd.
Enable them through the Kconfig option CONFIG_FASTBOOT_UUU_SUPPORT
base was commit in NXP kernel 9b149c2a2882: ("MLK-18591-3 android: Add FSL android fastboot support")
and ported it to current mainline. Tested this patch on imx6ul based board.
Signed-off-by: Heiko Schocher hs@denx.de ---
azure build was fine: https://dev.azure.com/hs0298/hs/_build/results?buildId=59&view=results
Changes in v4: - fixed missing parts from Sean Anderson patches lost while rebased to tree from lukasz
Changes in v3: - rebased to https://github.com/lmajewski/u-boot-dfu/commits/testing as Lukasz mentioned.
Changes in v2: - remove unused FSL_FASTBOOT option - add comment from Roman: do not enable this option per default add Kconfig comment that enabling this option may introduce a security issue.
doc/android/fastboot-protocol.rst | 5 +++ doc/android/fastboot.rst | 2 + drivers/fastboot/Kconfig | 9 +++++ drivers/fastboot/fb_command.c | 62 +++++++++++++++++++++++++++++++ drivers/usb/gadget/f_fastboot.c | 17 +++++++++ include/fastboot.h | 7 ++++ 6 files changed, 102 insertions(+)
diff --git a/doc/android/fastboot-protocol.rst b/doc/android/fastboot-protocol.rst index e723659e49c..e8cbd7f24ea 100644 --- a/doc/android/fastboot-protocol.rst +++ b/doc/android/fastboot-protocol.rst @@ -144,6 +144,11 @@ Command Reference
"powerdown" Power off the device.
+ "ucmd" execute any bootloader command and wait until it + finishs. + + "acmd" execute any bootloader command, do not wait. + Client Variables ----------------
diff --git a/doc/android/fastboot.rst b/doc/android/fastboot.rst index ce513a2a0f2..7611f07038e 100644 --- a/doc/android/fastboot.rst +++ b/doc/android/fastboot.rst @@ -19,6 +19,8 @@ The current implementation supports the following standard commands: - ``reboot`` - ``reboot-bootloader`` - ``set_active`` (only a stub implementation which always succeeds) +- ``ucmd`` (if enabled) +- ``acmd`` (if enabled)
The following OEM commands are supported (if enabled):
diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index a17e488714d..2d1836a80e0 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -72,6 +72,15 @@ config FASTBOOT_FLASH the downloaded image to a non-volatile storage device. Define this to enable the "fastboot flash" command.
+config FASTBOOT_UUU_SUPPORT + bool "Enable FASTBOOT i.MX UUU special command" + default n + help + The fastboot protocol includes "UCmd" and "ACmd" command. + Be aware that you provide full access to any U-Boot command, + including working with memory and may open a huge backdoor, + when enabling this option. + choice prompt "Flash provider for FASTBOOT" depends on FASTBOOT_FLASH diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index 41fc8d7904d..960e73089e0 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -49,6 +49,11 @@ static void oem_partconf(char *, char *); static void oem_bootbus(char *, char *); #endif
+#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) +static void run_ucmd(char *, char *); +static void run_acmd(char *, char *); +#endif + static const struct { const char *command; void (*dispatch)(char *cmd_parameter, char *response); @@ -117,6 +122,16 @@ static const struct { .dispatch = oem_bootbus, }, #endif +#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) + [FASTBOOT_COMMAND_UCMD] = { + .command = "UCmd", + .dispatch = run_ucmd, + }, + [FASTBOOT_COMMAND_ACMD] = { + .command = "ACmd", + .dispatch = run_acmd, + }, +#endif };
/** @@ -327,6 +342,53 @@ static void erase(char *cmd_parameter, char *response) } #endif
+#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) +/** + * run_ucmd() - Execute the UCmd command + * + * @cmd_parameter: Pointer to command parameter + * @response: Pointer to fastboot response buffer + */ +static void run_ucmd(char *cmd_parameter, char *response) +{ + if (!cmd_parameter) { + pr_err("missing slot suffix\n"); + fastboot_fail("missing command", response); + return; + } + + if (run_command(cmd_parameter, 0)) + fastboot_fail("", response); + else + fastboot_okay(NULL, response); +} + +static char g_a_cmd_buff[64]; + +void fastboot_acmd_complete(void) +{ + run_command(g_a_cmd_buff, 0); +} + +/** + * run_acmd() - Execute the ACmd command + * + * @cmd_parameter: Pointer to command parameter + * @response: Pointer to fastboot response buffer + */ +static void run_acmd(char *cmd_parameter, char *response) +{ + if (!cmd_parameter) { + pr_err("missing slot suffix\n"); + fastboot_fail("missing command", response); + return; + } + + strcpy(g_a_cmd_buff, cmd_parameter); + fastboot_okay(NULL, response); +} +#endif + /** * reboot_bootloader() - Sets reboot bootloader flag. * diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 950cc119495..8ba55aab9f8 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -494,6 +494,18 @@ static void do_bootm_on_complete(struct usb_ep *ep, struct usb_request *req) do_exit_on_complete(ep, req); }
+#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) +static void do_acmd_complete(struct usb_ep *ep, struct usb_request *req) +{ + /* When usb dequeue complete will be called + * Need status value before call run_command. + * otherwise, host can't get last message. + */ + if (req->status == 0) + fastboot_acmd_complete(); +} +#endif + static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) { char *cmdbuf = req->buf; @@ -532,6 +544,11 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) case FASTBOOT_COMMAND_REBOOT_RECOVERY: fastboot_func->in_req->complete = compl_do_reset; break; +#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) + case FASTBOOT_COMMAND_ACMD: + fastboot_func->in_req->complete = do_acmd_complete; + break; +#endif } }
diff --git a/include/fastboot.h b/include/fastboot.h index 797d7dfd529..57daaf12982 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -44,6 +44,10 @@ enum { #if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_BOOTBUS) FASTBOOT_COMMAND_OEM_BOOTBUS, #endif +#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) + FASTBOOT_COMMAND_ACMD, + FASTBOOT_COMMAND_UCMD, +#endif
FASTBOOT_COMMAND_COUNT }; @@ -169,4 +173,7 @@ void fastboot_data_download(const void *fastboot_data, */ void fastboot_data_complete(char *response);
+#if CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT) +void fastboot_acmd_complete(void); +#endif #endif /* _FASTBOOT_H_ */
Hi Heiko,
Changes in v4:
Changes in v3:
Changes in v2:
- run_command(g_a_cmd_buff, 0);
- run_acmd() - Execute the ACmd command
- @cmd_parameter: Pointer to command parameter
- @response: Pointer to fastboot response buffer
- if (!cmd_parameter) {
return;
- strcpy(g_a_cmd_buff, cmd_parameter);
to avoid overflow:
+ strncpy (g_a_cmd_buff, cmd_parameter, sizeof(g_a_cmd_buff));
or check strlen(cmd_parameter) ?
+ if (check strlen(cmd_parameter) > sizeof(g_a_cmd_buff)) {
+ pr_err("too long command\n");
+ fastboot_fail("too long command", response); + return; + }
- fastboot_okay(NULL, response);
+} +#endif
- reboot_bootloader() - Sets reboot bootloader flag.
Anyway, except this remark.
Acked-by: Patrick Delaunay patrick.delaunay@foss.st.com
Regards
Patrick
Hello Patrick,
On 08.02.21 17:56, Patrick DELAUNAY wrote:
Hi Heiko,
Changes in v4:
Changes in v3:
Changes in v2:
to avoid overflow:
- strncpy (g_a_cmd_buff, cmd_parameter, sizeof(g_a_cmd_buff));
- if (check strlen(cmd_parameter) > sizeof(g_a_cmd_buff)) {
Yes, good catch, thanks! I send a v5 with checking the length and error message
bye, Heiko
Heiko Schocher
Patrick DELAUNAY
