[U-Boot] [PATCH] driver/net/fm/memac_phy: set NEG bit for external MDIOs
NEG bit default is '1' for external MDIOs as per FMAN-v3 RM, but on some platforms, e.g. T2080QDS, this bit is '0', which leads to MDIO failure on XAUI PHY, so set this bit definitely to align with the RM.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- arch/powerpc/include/asm/fsl_memac.h | 1 + drivers/net/fm/memac_phy.c | 5 ++++- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/include/asm/fsl_memac.h b/arch/powerpc/include/asm/fsl_memac.h index 4640e33..190643e 100644 --- a/arch/powerpc/include/asm/fsl_memac.h +++ b/arch/powerpc/include/asm/fsl_memac.h @@ -243,6 +243,7 @@ struct memac_mdio_controller { #define MDIO_STAT_PRE (1 << 5) #define MDIO_STAT_ENC (1 << 6) #define MDIO_STAT_HOLD_15_CLK (7 << 2) +#define MDIO_STAT_NEG (1 << 23)
#define MDIO_CTL_DEV_ADDR(x) (x & 0x1f) #define MDIO_CTL_PORT_ADDR(x) ((x & 0x1f) << 5) diff --git a/drivers/net/fm/memac_phy.c b/drivers/net/fm/memac_phy.c index de9c0e9..f5b20d5 100644 --- a/drivers/net/fm/memac_phy.c +++ b/drivers/net/fm/memac_phy.c @@ -137,9 +137,12 @@ int fm_memac_mdio_init(bd_t *bis, struct memac_mdio_info *info) * is zero, so MDIO clock is disabled. * So, for proper functioning of MDIO, MDIO_CLK_DIV bits needs to * be properly initialized. + * NEG bit default should be '1' as per FMAN-v3 RM, but on platform + * like T2080QDS, this bit default is '0', which leads to MDIO failure + * on XAUI PHY, so set this bit definitely. */ setbits_be32(&((struct memac_mdio_controller *)info->regs)->mdio_stat, - MDIO_STAT_CLKDIV(258)); + MDIO_STAT_CLKDIV(258) | MDIO_STAT_NEG);
return mdio_register(bus); }
Applied to u-boot-mpc85xx master. Thanks.
York
Joe Hershberger
shh.xie@gmail.com
York Sun
