[U-Boot] Run a standalone application on a core other than 0
As the subject says, I'm trying to run the "Hello world" standalone application example on a core other than 0, on a Freescale QorIQ P4080.
I tried through the shell and programmatically by exporting cpu_release function... nothing. My first thought was that only core 0 has register r2 with the address of the "global_data" structure, so I tried to set it on the other cores, but still nothing. Help on this matter is highly appreciated.
Regards, João Fernandes
If you mean a U-Boot application, this is not supported. U-Boot doesn't run on cores other than 0, except for a small stub for the spin table code.
If you have true standalone code, you can release it on other CPUs using the "cpu <n> release" command. That code will not have access to any U-Boot functionality. Its entry state will be as described for secondary CPUs in ePAPR. It will be the same as if an OS were spinning up its secondary cores by writing directly to the spin table.
-Scott
Thank you Scott. On a somehow related question, when I use "cpu X release" to run some code on a core other than 0, the changes to memory made by cpu X are not made visible globally. I believe this is connected with WIMGE bits - as soon as disable L1 and L2 it works fine - am I correct? If so, does core 0 have 0x00000000 - 0x3FFFFFFF and 0x40000000 - 0x7FFFFFFF TLB entries marked as cache coherent, or do I also have to set them for it?
João
-Scott
You need to set the M bit in all TLB entries that reference memory that is shared. U-Boot already does this, but perhaps the code you're running on the secondary CPU does not? Is U-Boot still running on core 0 at that point?
Also be sure you're using the proper memory barriers to ensure that changes are seen in the right order.
-Scott
João Fernandes
Scott Wood
