[PATCH 0/4] efi: Minor improvements for the EFI app
This series collects a few fixes and improvements useful when booting U-Boot as an EFI app.
Simon Glass (4): acpi: Use __packed with struct acpi_xsdt efi: Collect the ACPI tables in the app efi: Correct display of table GUIDs efi: Avoid using dm_scan_other()
cmd/efi_common.c | 4 +--- configs/efi-x86_app64_defconfig | 1 + include/acpi/acpi_table.h | 2 +- lib/efi/efi_app.c | 29 +++++++++++++++++++++++------ 4 files changed, 26 insertions(+), 10 deletions(-)
Since struct acpi_table_header is not a multiple of 64 bits, use the __packed option for struct acpi_xsdt
This ensures that the entry[] array starts on the correct boundary.
include/acpi/acpi_table.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 1f85de091d39..59ab79ed17c2 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -80,7 +80,7 @@ struct acpi_rsdt { };
/* XSDT (Extended System Description Table) */ -struct acpi_xsdt { +struct __packed acpi_xsdt { struct acpi_table_header header; u64 entry[MAX_ACPI_TABLES]; };
Typically we keep the original signed-off-by when reposting patches.
Thanks for picking this change up.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
As in your review you suggested to add a unit test I have done so in my v2:
[PATCH v2 1/2] acpi: fix struct acpi_xsdt https://patchwork.ozlabs.org/project/uboot/patch/20231112070316.17982-2-hein...
Hi Heinrich,
On Sun, 12 Nov 2023 at 09:46, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Oh yes, this is a duplicate patch to yours...I had it hanging around for a while. So we can drop it.
Locate these so that they can be displayed using the 'acpi' command.
lib/efi/efi_app.c | 24 +++++++++++++++++++++--- 1 file changed, 21 insertions(+), 3 deletions(-)
diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index 2209410f35b5..c5eb816655ea 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -12,18 +12,21 @@ #include <cpu_func.h> #include <debug_uart.h> #include <dm.h> +#include <efi.h> +#include <efi_api.h> #include <errno.h> #include <init.h> #include <malloc.h> +#include <sysreset.h> +#include <uuid.h> #include <asm/global_data.h> #include <linux/err.h> #include <linux/types.h> -#include <efi.h> -#include <efi_api.h> -#include <sysreset.h> +#include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <dm/root.h> +#include <mapmem.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -320,6 +323,19 @@ int dm_scan_other(bool pre_reloc_only) return 0; }
+static void scan_tables(struct efi_system_table *sys_table) +{ + efi_guid_t acpi = EFI_ACPI_TABLE_GUID; + uint i; + + for (i = 0; i < sys_table->nr_tables; i++) { + struct efi_configuration_table *tab = &sys_table->tables[i]; + + if (!memcmp(&tab->guid, &acpi, sizeof(efi_guid_t))) + gd_set_acpi_start(map_to_sysmem(tab->table)); + } +} + /** * efi_main() - Start an EFI image * @@ -354,6 +370,8 @@ efi_status_t EFIAPI efi_main(efi_handle_t image, return ret; }
+ scan_tables(priv->sys_table); + /* * We could store the EFI memory map here, but it changes all the time, * so this is only useful for debugging.
- efi_guid_t acpi = EFI_ACPI_TABLE_GUID;
- uint i;
- for (i = 0; i < sys_table->nr_tables; i++) {
Should we have a function efi_get_configuration_table(efi_guid_t *guid) that we can use to retrieve different configuration tables?
This would allow us to read the device-tree on non-x86 tables.
We may at some point also be interested in reading the EFI_RT_PROPERTIES_TABLE to find out which runtime services we are allowed to call.
Or would you prefer to all of this into scan_tables()?
Best regards
Heinrich
- efi_main() - Start an EFI image
- scan_tables(priv->sys_table);
- We could store the EFI memory map here, but it changes all the time,
- so this is only useful for debugging.
Hi Heinrich,
uint i;
I'm not sure...but perhaps the best approach is to use this function to find all the tables we are interested in?
BTW I started this series with a view to figuring out what is needed to make the app boot Linux, etc. It is a bit strange since the boot services need to be 'passed through' U-Boot to the underlying UEFI.
The printf() %pU option decodes GUIDs so it is not necessary to do this first. Drop the incorrect code.
cmd/efi_common.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/cmd/efi_common.c b/cmd/efi_common.c index f4056096cd3f..1aa2351fcdfd 100644 --- a/cmd/efi_common.c +++ b/cmd/efi_common.c @@ -17,10 +17,8 @@ void efi_show_tables(struct efi_system_table *systab)
for (i = 0; i < systab->nr_tables; i++) { struct efi_configuration_table *tab = &systab->tables[i]; - char guid_str[37];
- uuid_bin_to_str(tab->guid.b, guid_str, 1); - printf("%p %pUl %s\n", tab->table, guid_str, + printf("%p %pUl %s\n", tab->table, tab->guid.b, uuid_guid_get_str(tab->guid.b) ?: "(unknown)"); } }
char guid_str[37];
Please, observe, that we have printf("%pUs", &guid) for printing the text representation of a GUID. If the text representation is unknown, it will print the numeric representation.
Best regards
Heinrich
Hi Heinrich,
char guid_str[37];
Yes, I understand but this is the output I want:
=> efi tables bfbd7690 ee4e5898-3914-4259-9d6e-dc7bd79403cf EFI_LZMA_COMPRESSED bff27c40 05ad34ba-6f02-4214-952e-4da0398e2bb9 EFI_DXE_SERVICES bfbd4010 7739f24c-93d7-11d4-9a3a-0090273fc14d EFI_HOB_LIST bff283c0 4c19049f-4137-4dd3-9c10-8b97a83ffdfa EFI_MEMORY_TYPE bff2892c 49152e77-1ada-4764-b7a2-7afefed95e8b (unknown) bfcb6210 060cc026-4c0d-4dda-8f41-595fef00a502 EFI_MEM_STATUS_CODE_REC bfc80000 eb9d2d31-2d88-11d3-9a16-0090273fc14d SMBIOS table bfe67000 eb9d2d30-2d88-11d3-9a16-0090273fc14d EFI_GUID_EFI_ACPI1 bfe67014 8868e871-e4f1-11d3-bc22-0080c73c8881 ACPI table be9b9010 dcfa911d-26eb-469f-a220-38b7dc461220 (unknown)
(so I want to show the GUID in all cases, but also indicate which ones are unknown)
This function is defined by bootstd so using it precludes using that feature. Use the board_early_init_r() feature instead.
configs/efi-x86_app64_defconfig | 1 + lib/efi/efi_app.c | 5 ++--- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/configs/efi-x86_app64_defconfig b/configs/efi-x86_app64_defconfig index d6b6c3d82995..e6a62b30dd09 100644 --- a/configs/efi-x86_app64_defconfig +++ b/configs/efi-x86_app64_defconfig @@ -17,6 +17,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="ext2load scsi 0:3 01000000 /boot/vmlinuz; zboot 01000000" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTZ=y diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index c5eb816655ea..1bced775a4d0 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -302,15 +302,14 @@ static int setup_block(void) }
/** - * dm_scan_other() - Scan for UEFI devices that should be available to U-Boot + * board_early_init_r() - Scan for UEFI devices that should be available * * This sets up block devices within U-Boot for those found in UEFI. With this, * U-Boot can access those devices * - * @pre_reloc_only: true to only bind pre-relocation devices (ignored) * Returns: 0 on success, -ve on error */ -int dm_scan_other(bool pre_reloc_only) +int board_early_init_r(void) { if (gd->flags & GD_FLG_RELOC) { int ret;
- dm_scan_other() - Scan for UEFI devices that should be available to U-Boot
- board_early_init_r() - Scan for UEFI devices that should be available
- This sets up block devices within U-Boot for those found in UEFI. With this,
- U-Boot can access those devices
- @pre_reloc_only: true to only bind pre-relocation devices (ignored)
- Returns: 0 on success, -ve on error
Should this file really be board/efi/efi-x86_app/something.c ? We don't define this function outside of the board directory today. Or should we just move the function as the rest of the code is used in other EFI applications we build (or no, the hello world one is too simple to need this) ? If all of that sounds too wrong-direction, can we use event lists or something?
Am 12. November 2023 19:03:57 MEZ schrieb Tom Rini trini@konsulko.com:
The EFI app should not be x86 specific.
Best regards
Heinrich
Yes, I suspect a follow-up would be to do whatever is needed to target a given architecture with the U-Boot as EFI application board.
Hi Tom, Heinrich,
OK will fix.
Sure, but so far we don't have an ARM version.
Best regards
Heinrich
