[U-Boot] Pull request: u-boot-staging
Hello Tom,
The following changes since commit 009d75ccc11d27b9a083375a88bb93cb746b4800:
Merge branch 'u-boot/master' into 'u-boot-arm/master' (2013-03-28 18:50:01 +0100)
git://git.denx.de/u-boot-staging.git agust@denx.de
Anatolij Gustschin (1): menu: export menu_default_choice() function
Pali Rohár (3): menu: Add support for user defined item choice function New command bootmenu: ANSI terminal boot menu support RX-51: Add support for bootmenu
board/ait/cam_enc_4xx/cam_enc_4xx.c | 3 +- common/Makefile | 1 + common/cmd_bootmenu.c | 517 +++++++++++++++++++++++++++++++++++ common/cmd_pxe.c | 3 +- common/menu.c | 44 +++- doc/README.bootmenu | 115 ++++++++ doc/README.menu | 9 +- include/ansi.h | 42 +++ include/configs/nokia_rx51.h | 40 +++- include/menu.h | 5 +- 10 files changed, 760 insertions(+), 19 deletions(-) create mode 100644 common/cmd_bootmenu.c create mode 100644 doc/README.bootmenu create mode 100644 include/ansi.h
Please pull. Thanks!
Anatolij
On Fri, Mar 29, 2013 at 02:26:15PM +0100, Anatolij Gustschin wrote:
Hello Tom,
Pali Roh??r (3): menu: Add support for user defined item choice function New command bootmenu: ANSI terminal boot menu support RX-51: Add support for bootmenu
Anatolij Gustschin
