[U-Boot] [PATCH v3 2/2] NET: Base support for etsec2.0
1. Modified the tsec_mdio structure to include the new regs 2. Modified the MDIO_BASE_ADDR so that it will handle both older version and new version of etsec.
Signed-off-by: Sandeep Gopalpet sandeep.kumar@freescale.com --- include/asm-ppc/immap_83xx.h | 2 +- include/asm-ppc/immap_85xx.h | 6 +++++- include/asm-ppc/immap_86xx.h | 2 +- include/configs/P1_P2_RDB.h | 5 +++++ include/tsec.h | 7 +++++++ 5 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/include/asm-ppc/immap_83xx.h b/include/asm-ppc/immap_83xx.h index 6dd477c..2e6ba2d 100644 --- a/include/asm-ppc/immap_83xx.h +++ b/include/asm-ppc/immap_83xx.h @@ -872,7 +872,7 @@ typedef struct immap { #define CONFIG_SYS_TSEC1_OFFSET 0x24000 #define TSEC_SIZE 0x01000
-#define CONFIG_SYS_MDIO1_OFFSET 0x24520 +#define CONFIG_SYS_MDIO1_OFFSET 0x24000 #define TSEC_MDIO_OFFSET 0x01000
#define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 54b43b1..2f2ebfe 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1933,9 +1933,13 @@ typedef struct ccsr_gur { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET)
/* TSEC and MDIO OFFSETS */ +#ifdef CONFIG_TSECV2 +#define CONFIG_SYS_TSEC1_OFFSET 0xB0000 +#else #define CONFIG_SYS_TSEC1_OFFSET 0x24000 +#endif
#define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) diff --git a/include/asm-ppc/immap_86xx.h b/include/asm-ppc/immap_86xx.h index be2eadd..783ea2e 100644 --- a/include/asm-ppc/immap_86xx.h +++ b/include/asm-ppc/immap_86xx.h @@ -1300,7 +1300,7 @@ extern immap_t *immr;
#define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 310242e..4d93ed8 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -84,6 +84,11 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_MP #endif
+/* TSECV2 */ +#if defined(CONFIG_P1020) +#define CONFIG_TSECV2 +#endif + /* * These can be toggled for performance analysis, otherwise use default. */ diff --git a/include/tsec.h b/include/tsec.h index d895d02..fc2f075 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -456,12 +456,19 @@ typedef struct tsec_hash_regs } tsec_hash_t;
typedef struct tsec_mdio { + uint res1[4]; + uint ieventm; + uint imaskm; + uint res2; + uint emapm; + uint res3[320]; uint miimcfg; /* MII Management: Configuration */ uint miimcom; /* MII Management: Command */ uint miimadd; /* MII Management: Address */ uint miimcon; /* MII Management: Control */ uint miimstat; /* MII Management: Status */ uint miimind; /* MII Management: Indicators */ + uint res4[690]; } tsec_mdio_t;
typedef struct tsec
Sandeep Gopalpet
