[PATCH] doc/develop/sending_patches.rst: Clarify when to use which branch
The previous wording on the paragraph about what branch to use when submitting patches did not reflect how / when the next branch is currently used. Reword this to note that master should be used for bug and regression fixes, always, and that next should be used once it opens, with -rc2.
Reported-by: Jerome Forissier jerome.forissier@linaro.org Signed-off-by: Tom Rini trini@konsulko.com --- doc/develop/sending_patches.rst | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/doc/develop/sending_patches.rst b/doc/develop/sending_patches.rst index 3f25b1d0466f..82efb717b179 100644 --- a/doc/develop/sending_patches.rst +++ b/doc/develop/sending_patches.rst @@ -74,11 +74,13 @@ General Patch Submission Rules
* Send your patches as plain text messages: no HTML, no MIME, no links, no compression, no attachments. Just plain text. The best way the generate - patches is by using the ``git format-patch`` command. Please use the - ``master`` branch of the mainline U-Boot git repository - (``https://source.denx.de/u-boot/u-boot.git%60%60) as reference, unless (usually - late in a release cycle) there has been an announcement to use the ``next`` - branch of this repository instead. + patches is by using the ``git format-patch`` command. For a patch that is + fixing a bug or regression of some sort, please use the ``master`` branch of + the mainline U-Boot git repository + (``https://source.denx.de/u-boot/u-boot.git%60%60) as reference. For new + features, if the ``next`` branch has been opened (which happens with the + release of ``-rc2``) that branch should be used, otherwise ``master`` is + acceptable.
* Make sure that your mailer does not mangle the patch by automatic changes like wrapping of longer lines etc.
Hi Tom,
- Send your patches as plain text messages: no HTML, no MIME, no links, no compression, no attachments. Just plain text. The best way the generate
- patches is by using the ``git format-patch`` command. For a patch that is
- fixing a bug or regression of some sort, please use the ``master`` branch of
- the mainline U-Boot git repository
- (``https://source.denx.de/u-boot/u-boot.git%60%60) as reference. For new
Please also remove the tick quotes around the link, it means we cannot click on it anymore as it's basically "verbatim". Maybe in a separate patch?
Looks good to me otherwise,
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
We shouldn't have had the link to our git tree be contained within "``" as that meant that it did not work as a link, so remove those. And rather than make this a link plus text, keep this as a link within the text for overall clarity.
Suggested-by: Quentin Schulz quentin.schulz@cherry.de Signed-off-by: Tom Rini trini@konsulko.com --- doc/develop/sending_patches.rst | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/doc/develop/sending_patches.rst b/doc/develop/sending_patches.rst index 82efb717b179..990cb9912a92 100644 --- a/doc/develop/sending_patches.rst +++ b/doc/develop/sending_patches.rst @@ -76,11 +76,10 @@ General Patch Submission Rules compression, no attachments. Just plain text. The best way the generate patches is by using the ``git format-patch`` command. For a patch that is fixing a bug or regression of some sort, please use the ``master`` branch of - the mainline U-Boot git repository - (``https://source.denx.de/u-boot/u-boot.git%60%60) as reference. For new - features, if the ``next`` branch has been opened (which happens with the - release of ``-rc2``) that branch should be used, otherwise ``master`` is - acceptable. + the mainline U-Boot git repository located at + https://source.denx.de/u-boot/u-boot.git as reference. For new features, if + the ``next`` branch has been opened (which happens with the release of + ``-rc2``) that branch should be used, otherwise ``master`` is acceptable.
Hi Tom,
Thanks! Quentin
- acceptable.
- Make sure that your mailer does not mangle the patch by automatic changes
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
- acceptable.
- Make sure that your mailer does not mangle the patch by automatic changes like wrapping of longer lines etc.
Crystal clear! Thanks. FWIW and with Quentin's comment about the back ticks addressed or not:
Acked-by: Jerome Forissier jerome.forissier@linaro.org
Hello Tom,
I missed that patch in my recent documentation pull-request.
Maybe you just want to add it to master with whatever comes next.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
acceptable.
Hello Tom,
Will do, thanks.
Hello Tom,
Will do, thanks.
You got it already: commit 85deb7f69ca4467cf5cf75545b253f9414908222 Author: Tom Rini trini@konsulko.com AuthorDate: Mon Aug 26 10:39:17 2024 -0600 Commit: Heinrich Schuchardt xypron.glpk@gmx.de CommitDate: Thu Sep 12 18:13:52 2024 +0200
Hello Tom,
Ah, I think you meant to reply to: https://patchwork.ozlabs.org/project/uboot/patch/20240826170140.2791128-1-tr...
participants (5)
Jerome Forissier
Quentin Schulz
