[PATCH v2 1/4] clock_imx8mq: Delete not used init_usb_clk()
Function init_usb_clk() is not used anywhere, so it can simply be deleted. This was detected by the following sparse warning:
arch/arm/mach-imx/imx8m/clock_imx8mq.c:377:6: warning: no previous prototype for ‘init_usb_clk’ [-Wmissing-prototypes] void init_usb_clk(void) ^~~~~~~~~~~~
Signed-off-by: Pedro Jardim jardim.c.pedro@gmail.com --- Chages since v1:
- Fixed patch corruption arch/arm/mach-imx/imx8m/clock_imx8mq.c | 22 ---------------------- 1 file changed, 22 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mq.c b/arch/arm/mach-imx/imx8m/clock_imx8mq.c index 878f2be166..663fe4d3ca 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mq.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mq.c @@ -374,28 +374,6 @@ void init_wdog_clk(void) clock_enable(CCGR_WDOG3, 1); }
-void init_usb_clk(void) -{ - if (!is_usb_boot()) { - clock_enable(CCGR_USB_CTRL1, 0); - clock_enable(CCGR_USB_CTRL2, 0); - clock_enable(CCGR_USB_PHY1, 0); - clock_enable(CCGR_USB_PHY2, 0); - /* 500MHz */ - clock_set_target_val(USB_BUS_CLK_ROOT, CLK_ROOT_ON | - CLK_ROOT_SOURCE_SEL(1)); - /* 100MHz */ - clock_set_target_val(USB_CORE_REF_CLK_ROOT, CLK_ROOT_ON | - CLK_ROOT_SOURCE_SEL(1)); - /* 100MHz */ - clock_set_target_val(USB_PHY_REF_CLK_ROOT, CLK_ROOT_ON | - CLK_ROOT_SOURCE_SEL(1)); - clock_enable(CCGR_USB_CTRL1, 1); - clock_enable(CCGR_USB_CTRL2, 1); - clock_enable(CCGR_USB_PHY1, 1); - clock_enable(CCGR_USB_PHY2, 1); - } -}
void init_nand_clk(void) {
On Thu, 23 Jan 2020 10:20:14 -0300 Pedro Jardim jardim.c.pedro@gmail.com wrote:
Cc'ing Peng. Maybe this was in preparation for adding USB support ?
-- Anatolij
Hi Anatolij,
Unfortunately i.MX8M USB support has been pending for a long time.
I prefer if we could get rid of this unused code and then bring this back when USB support comes in.
Subject: Re: [PATCH v2 1/4] clock_imx8mq: Delete not used init_usb_clk()
Hi Anatolij,
Not sure whether TI guys have done the cadence USB support.
Previously Sherry did some usb work, but TI guys take over that.
After the usb IP support ready, I or someone could start support usb for i.MX8MQ.
For now, the function could be dropped.
Thanks, Peng.
Hi Anatolij,
Thanks, Peng.
I have a working port of the Linux usb phy driver for the iMX8MQ already. I think the only piece that is missing to use dwc3-generic for iMX8MQ is the common clk driver. Has anyone started work on this?
-Jon
Not that I am aware of.
Peng, do you know?
Peng, do you know?
I have not start to do that.
Jon, great to know that you did that. Look forward your patches in community.
Thanks, Peng.
Hi Anatolij,
I guess you are talking about Cadence USB3 driver. Marek already merged the support. Please find the corresponding commits below:
f69257baa8 usb: composite: add BOS descriptor support to composite framework d80effb184 usb: gadget: Add gadget_is_cdns3() macro a9ca4193bd usb: cdns3: Add TI wrapper driver for CDNS USB3 controller 927c22b0da usb: cdns3: gadget: Implement udc_set_speed() callback 7e91f6ccdc usb: Add Cadence USB3 host and gadget driver 8d94e184ff usb: udc: Introduce ->udc_set_speed() method 77dcbdf3c1 usb: gadget: Add match_ep() op to usb_gadget_ops c93e305af7 bitmaps: import for_each_set_bit() macro c37f594280 list: import list_first_entry_or_null()
Thanks and regards, Lokesh
Thanks, Peng.
Hi Anatolij,
deleted.
previous
Great.
Then I think better keep the function.
Thanks, Peng.
i.MX8MQ.
Thanks, Peng.
participants (6)
Anatolij Gustschin
Fabio Estevam
Jon Nettleton
Lokesh Vutla
Pedro Jardim
Peng Fan
