[U-Boot-Users] Turning on instruction address translation on an 8349 causes processor reset
I'm working on adding support for a new 8349 board to U-Boot, and the processor resets if I turn on the IR bit in the MSR. This happens in function enable_addr_trans() in start.S.
enable_addr_trans: /* enable address translation */ mfmsr r5 ori r5, r5, (MSR_IR | MSR_DR) mtmsr r5 isync blr
with this code, when the "mtmsr" instruction is executed, the processor resets (or hangs - I can't tell). If I change the 4th line to:
ori r5, r5, MSR_DR
It works and U-Boot boots to a command prompt.
Since the BATs are configured the same for data and instruction, I presume the mapping is correct, but there's something wrong with turning on instruction address translation. Anyone have any ideas?
[snip]
ori r5, r5, MSR_DR
The MPC8349EMDS code in wolfgang's git is working well now. No hang. Please check your code carefully.
-Dave
I've tried and I can't figure out what's wrong. Right now, I have this code in mpc83xx/start.S:
/* For some reason, address translation does not work on the 8349E-mITX */ #ifndef CONFIG_MPC8349ITX /* enable address translation */ bl enable_addr_trans sync #endif
Everything else works fine (I'll be providing a patch for the 8349E-mITX in a week or so). But if I turn on either address translation (instruction or data, it doesn't matter), then the system crashes.
The crash occurs right after the 'mtmsr' instruction.
The only thing I can think of is that I'm using the wrong values for CFG_IBATxx, but I have no idea what they should be. I copied them from MPC8349EMDS.h.
Liu Dave-r63238
Timur Tabi
