[PATCH 1/2] board: gateworks: venice: fix gsc_get_dev
use dm_i2c_probe instead of i2c_get_chip which appears to be more reliable.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/gsc.c | 23 ++++++----------------- 1 file changed, 6 insertions(+), 17 deletions(-)
diff --git a/board/gateworks/venice/gsc.c b/board/gateworks/venice/gsc.c index ad3f8d95d9..d2490e6063 100644 --- a/board/gateworks/venice/gsc.c +++ b/board/gateworks/venice/gsc.c @@ -125,29 +125,18 @@ enum {
static struct udevice *gsc_get_dev(int busno, int slave) { - struct udevice *dev; + static const char * const i2c[] = { "i2c@30a20000", "i2c@30a30000" }; + struct udevice *dev, *bus; int ret;
-#if (IS_ENABLED(CONFIG_SPL_BUILD)) - ret = i2c_get_chip_for_busnum(busno + 1, slave, 1, &dev); - if (ret) - return NULL; -#else - struct udevice *bus; - - busno--; - - ret = uclass_get_device_by_seq(UCLASS_I2C, busno, &bus); + ret = uclass_get_device_by_name(UCLASS_I2C, i2c[busno - 1], &bus); if (ret) { - printf("i2c%d: no bus %d\n", busno + 1, ret); + printf("GSC : failed I2C%d probe: %d\n", busno, ret); return NULL; } - ret = i2c_get_chip(bus, slave, 1, &dev); - if (ret) { - printf("i2c%d@0x%02x: no chip %d\n", busno + 1, slave, ret); + ret = dm_i2c_probe(bus, slave, 0, &dev); + if (ret) return NULL; - } -#endif
return dev; }
commit 03f1f78a9b44 ("spl: fit: Prefer a malloc()'d buffer for loading images")' changed the way buffer allocation worked for SPL to a more flexible method.
For venice this caused breakage that is resolved by increasing the size of CONFIG_SYS_SPL_MALLOC_SIZE as the current FIT slighly exceeds 512KiB.
Additionally remove the unnecessary comment on CONFIG_SPL_BSS_MAX_SIZE and CONFIG_SYS_SPL_MALLOC_SIZE as the size is obvious from the define.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/imx8mm_venice.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index a406e91c84..91669255e1 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -19,9 +19,9 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_STACK 0x920000 #define CONFIG_SPL_BSS_START_ADDR 0x910000 -#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 -#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_1M
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000
Reviewed-by: Fabio Estevam festevam@gmail.com
commit 03f1f78a9b44 ("spl: fit: Prefer a malloc()'d buffer for loading images")' changed the way buffer allocation worked for SPL to a more flexible method. For venice this caused breakage that is resolved by increasing the size of CONFIG_SYS_SPL_MALLOC_SIZE as the current FIT slighly exceeds 512KiB. Additionally remove the unnecessary comment on CONFIG_SPL_BSS_MAX_SIZE and CONFIG_SYS_SPL_MALLOC_SIZE as the size is obvious from the define. Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Hi Tim,
use dm_i2c_probe instead of i2c_get_chip which appears to be more reliable. Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
sbabic@denx.de
Tim Harvey
