[U-Boot] [PATCH] ARM: UniPhier: add IDs for PH1-Pro5, ProXstream2, PH1-LD6b
This prepares for new SoCs support.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/cpu_info.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/mach-uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c index c4ba6d2..5d9ed84 100644 --- a/arch/arm/mach-uniphier/cpu_info.c +++ b/arch/arm/mach-uniphier/cpu_info.c @@ -34,6 +34,15 @@ int print_cpuinfo(void) case 0x29: puts("PH1-sLD8 (MN2WS0270)"); break; + case 0x2A: + puts("PH1-Pro5 (MN2WS0300)"); + break; + case 0x2E: + puts("ProXstream2 (MN2WS0310)"); + break; + case 0x2F: + puts("PH1-LD6b (MN2WS0320)"); + break; default: printf("Unknown Processor ID (0x%x)\n", revision); return -1;
2015-06-30 18:43 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
