[PATCH] power: regulator: add dummy helper
Add dummy helper to enabling the header could be included when DM REGULATOR not enabled.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/power/regulator.h | 114 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 114 insertions(+)
diff --git a/include/power/regulator.h b/include/power/regulator.h index 74938dd61e..7f278e8c7d 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -264,6 +264,7 @@ struct dm_regulator_ops { int (*set_mode)(struct udevice *dev, int mode_id); };
+#if CONFIG_IS_ENABLED(DM_REGULATOR) /** * regulator_mode: returns a pointer to the array of regulator mode info * @@ -524,5 +525,118 @@ int regulator_get_by_platname(const char *platname, struct udevice **devp); */ int device_get_supply_regulator(struct udevice *dev, const char *supply_name, struct udevice **devp); +#else +static inline int regulator_mode(struct udevice *dev, struct dm_regulator_mode **modep) +{ + return -ENOSYS; +} + +static inline int regulator_get_value(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_set_value(struct udevice *dev, int uV) +{ + return -ENOSYS; +} + +static inline int regulator_set_suspend_value(struct udevice *dev, int uV) +{ + return -ENOSYS; +} + +static inline int regulator_get_suspend_value(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_set_value_force(struct udevice *dev, int uV) +{ + return -ENOSYS; +} + +static inline int regulator_get_current(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_set_current(struct udevice *dev, int uA) +{ + return -ENOSYS; +} + +static inline int regulator_get_enable(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_set_enable(struct udevice *dev, bool enable) +{ + return -ENOSYS; +} + +static inline int regulator_set_enable_if_allowed(struct udevice *dev, bool enable) +{ + return -ENOSYS; +} + +static inline int regulator_set_suspend_enable(struct udevice *dev, bool enable) +{ + return -ENOSYS; +} + +static inline int regulator_get_suspend_enable(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_get_mode(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_set_mode(struct udevice *dev, int mode_id) +{ + return -ENOSYS; +} + +static inline int regulators_enable_boot_on(bool verbose) +{ + return -ENOSYS; +} + +static inline int regulator_autoset(struct udevice *dev) +{ + return -ENOSYS; +} + +static inline int regulator_autoset_by_name(const char *platname, struct udevice **devp) +{ + return -ENOSYS; +} + +static inline int regulator_list_autoset(const char *list_platname[], struct udevice *list_devp[], + bool verbose) +{ + return -ENOSYS; +} + +static inline int regulator_get_by_devname(const char *devname, struct udevice **devp) +{ + return -ENOSYS; +} + +static inline int regulator_get_by_platname(const char *platname, struct udevice **devp) +{ + return -ENOSYS; +} + +static inline int device_get_supply_regulator(struct udevice *dev, const char *supply_name, + struct udevice **devp) +{ + return -ENOSYS; +} +#endif
#endif /* _INCLUDE_REGULATOR_H_ */
Peng Fan
