[U-Boot-Users] IDE interface on PPC has endian issue
I have a board that has a 128 MB compact flash connected to a PPC 440GP peripheral bus using True IDE mode. Up until now, I have been successfully booting using NFS, and now I am trying to get the IDE interface to work.
When I issue an IDE reset command to u-boot, the information returned is byte-swapped:
Device 0: Model: aSDnsi KDSFC-J21 8 Firm: DH X.272 Ser#: <...> Type: Removeable Hard Disk Capacity: 24576.1 MB = 24.0 GB (50331860 x 512)
Note that "aSDnsi K" is "SanDisk ". If I modify cmd_ide.c to pretend I am little endian so that the input_swap_data function is disabled (#if defined (__LITTLE_ENDIAN) version is used), I get seemingly correct results:
Device 0: Model: SanDisk SDCFJ-128 Firm: HDX 2.27 Ser#: <...> Type: Removeable Hard Disk Capacity: 122.5 MB = 0.1 GB (250880 x 512)
I am confused why I need to do this, as it seems wrong. Furthermore, although I can get the IDE information, I cannot see any partitions on the device. I created a single linux partion (type 83), but when I issue "ide part 0", I am told "IDE device 0 not available".
The CF is connected to the PPC like this:
A0,A1,A2 on the CF ==> A30, A29, A28 on 440GP D0..D15 on CF ==> D15..D0 on 440GP
I am using the following ATA configuration:
#define CFG_ATA_BASE_ADDR 0xa0300000 #define CFG_IDE_MAXDEVICE 1 #define CFG_IDE_MAXBUS 1 #define CFG_ATA_IDE0_OFFFSET 0 #define CFG_ATA_DATA_OFFSET 0 #define CFG_ATA_REG_OFFSET 1 #define CFG_ATA_ALT_OFFSET 0x00100001 #define CFG_ATA_STRIDE 2 #define ATA_RESET_TIME 5
Thanks.
Gregg
I had the same problem. It turns the idiot hardware engineer decided he would do byte swapping in hardware without telling me. To get around it, I just made the byte swapping code a noop (no byte swaping) and it worked.
Thanks.
Gregg
This SF.Net email is sponsored by the JBoss Inc. Get Certified Today Register for a JBoss Training Course. Free Certification Exam for All Training Attendees Through End of 2005. For more info visit: http://ads.osdn.com/?ad_id=7628&alloc_id=16845&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
__________________________________ Start your day with Yahoo! - Make it your home page! http://www.yahoo.com/r/hs
Frank <frannk_m1 <at> yahoo.com> writes:
Doing an endian swap every place in cmd_ide.c where it is reading the data register seems to have fixed the problem. I can now see the partitions on the disk and load a file from it. I don't understand why the endianness is different from what the u-boot code expects though, given how the data bits are connected to the peripheral bus:
CF D0..D15 => PPC D15..D0
D15 is lsb on PPC 16-bit mode bus. It is as if the u-boot code expects
CF D0..D7 => PPC D7..D0 CF D8..D15 => PPC D15..D8
Thanks,
Gregg
Frank
Gregg
