[U-Boot] [PATCH v3 0/3] mtd: nand: mxs: Calculate ECC strength dynamically
This patchset is based on the patch from Peng Fan: "[U-Boot,1/2] mtd:mxs:nand calculate ecc strength dynamically" https://patchwork.ozlabs.org/patch/422756/
Instead of hard-coding every possible oob size / ECC strength combination calculate the ECC strength dynamically to be aligned with the Linux Kernel MTD NAND driver. Also adds the calculation to tools/mxsboot to be aligned with the U-Boot MTD NAND driver.
Jörg Krause (2): mtd: nand: mxs: Replace magic number for bits per ECC level with macro tools: mxsboot: Calculate ECC strength dynamically
Peng Fan (1): mtd:mxs:nand calculate ecc strength dynamically
drivers/mtd/nand/mxs_nand.c | 35 +++++++++++++++-------------------- tools/mxsboot.c | 39 ++++++++++++++++++++++++--------------- 2 files changed, 39 insertions(+), 35 deletions(-)
Calculate ecc strength according oobsize, but not hardcoded which is not aligned with kernel driver
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li b37916@freescale.com Reviewed-by: Marek Vasut marex@denx.de Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- Changes for v3: - squashed "[U-Boot,v2,3/4] mtd: nand: mxs: Add comment for calculating ECC strength" https://patchwork.ozlabs.org/patch/460926/ - Coding Style cleanup Changes for v2: - None (original patch from Peng Fan) --- drivers/mtd/nand/mxs_nand.c | 30 ++++++++++++------------------ 1 file changed, 12 insertions(+), 18 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 7a064ab..a463de7 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -146,26 +146,20 @@ static uint32_t mxs_nand_aux_status_offset(void) static inline uint32_t mxs_nand_get_ecc_strength(uint32_t page_data_size, uint32_t page_oob_size) { - if (page_data_size == 2048) { - if (page_oob_size == 64) - return 8; + int ecc_strength;
- if (page_oob_size == 112) - return 14; - } - - if (page_data_size == 4096) { - if (page_oob_size == 128) - return 8; - - if (page_oob_size == 218) - return 16; - - if (page_oob_size == 224) - return 16; - } + /* + * Determine the ECC layout with the formula: + * ECC bits per chunk = (total page spare data bits) / + * (bits per ECC level) / (chunks per page) + * where: + * total page spare data bits = + * (page oob size - meta data size) * (bits per byte) + */ + ecc_strength = ((page_oob_size - MXS_NAND_METADATA_SIZE) * 8) + / (13 * mxs_nand_ecc_chunk_cnt(page_data_size));
- return 0; + return round_down(ecc_strength, 2); }
static inline uint32_t mxs_nand_get_mark_offset(uint32_t page_data_size,
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- Changes for v3: - Replace space with tab for macro definition Changes for v2: - New patch --- drivers/mtd/nand/mxs_nand.c | 7 ++++--- tools/mxsboot.c | 3 ++- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index a463de7..aa06446 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -36,7 +36,7 @@ #define MXS_NAND_CHUNK_DATA_CHUNK_SIZE_SHIFT 0 #endif #define MXS_NAND_METADATA_SIZE 10 - +#define MXS_NAND_BITS_PER_ECC_LEVEL 13 #define MXS_NAND_COMMAND_BUFFER_SIZE 32
#define MXS_NAND_BCH_TIMEOUT 10000 @@ -135,7 +135,7 @@ static uint32_t mxs_nand_ecc_chunk_cnt(uint32_t page_data_size)
static uint32_t mxs_nand_ecc_size_in_bits(uint32_t ecc_strength) { - return ecc_strength * 13; + return ecc_strength * MXS_NAND_BITS_PER_ECC_LEVEL; }
static uint32_t mxs_nand_aux_status_offset(void) @@ -157,7 +157,8 @@ static inline uint32_t mxs_nand_get_ecc_strength(uint32_t page_data_size, * (page oob size - meta data size) * (bits per byte) */ ecc_strength = ((page_oob_size - MXS_NAND_METADATA_SIZE) * 8) - / (13 * mxs_nand_ecc_chunk_cnt(page_data_size)); + / (MXS_NAND_BITS_PER_ECC_LEVEL * + mxs_nand_ecc_chunk_cnt(page_data_size));
return round_down(ecc_strength, 2); } diff --git a/tools/mxsboot.c b/tools/mxsboot.c index 6d48cfb..aaa872b 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -48,6 +48,7 @@ static uint32_t sd_sector = 2048; #define MXS_NAND_DMA_DESCRIPTOR_COUNT 4 #define MXS_NAND_CHUNK_DATA_CHUNK_SIZE 512 #define MXS_NAND_METADATA_SIZE 10 +#define MXS_NAND_BITS_PER_ECC_LEVEL 13 #define MXS_NAND_COMMAND_BUFFER_SIZE 32
struct mx28_nand_fcb { @@ -127,7 +128,7 @@ struct mx28_sd_config_block {
static inline uint32_t mx28_nand_ecc_size_in_bits(uint32_t ecc_strength) { - return ecc_strength * 13; + return ecc_strength * MXS_NAND_BITS_PER_ECC_LEVEL; }
static inline uint32_t mx28_nand_get_ecc_strength(uint32_t page_data_size,
Changes for v3:
Changes for v2:
- New patch
Best regards, Marek Vasut
Calculating the ECC strength dynamically to be aligned with the mxs NAND driver and the Linux Kernel.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- Changes for v3: - Coding Style cleanup Changes for v2: - New patch --- tools/mxsboot.c | 35 ++++++++++++++++++++++------------- 1 file changed, 22 insertions(+), 13 deletions(-)
diff --git a/tools/mxsboot.c b/tools/mxsboot.c index aaa872b..53de452 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -14,6 +14,10 @@
#include "compiler.h"
+/* Taken from <linux/kernel.h> */ +#define __round_mask(x, y) ((__typeof__(x))((y)-1)) +#define round_down(x, y) ((x) & ~__round_mask(x, y)) + /* * Default BCB layout. * @@ -126,6 +130,11 @@ struct mx28_sd_config_block { struct mx28_sd_drive_info drv_info[1]; };
+static inline uint32_t mx28_nand_ecc_chunk_cnt(uint32_t page_data_size) +{ + return page_data_size / MXS_NAND_CHUNK_DATA_CHUNK_SIZE; +} + static inline uint32_t mx28_nand_ecc_size_in_bits(uint32_t ecc_strength) { return ecc_strength * MXS_NAND_BITS_PER_ECC_LEVEL; @@ -134,21 +143,21 @@ static inline uint32_t mx28_nand_ecc_size_in_bits(uint32_t ecc_strength) static inline uint32_t mx28_nand_get_ecc_strength(uint32_t page_data_size, uint32_t page_oob_size) { - if (page_data_size == 2048) - return 8; - - if (page_data_size == 4096) { - if (page_oob_size == 128) - return 8; + int ecc_strength;
- if (page_oob_size == 218) - return 16; - - if (page_oob_size == 224) - return 16; - } + /* + * Determine the ECC layout with the formula: + * ECC bits per chunk = (total page spare data bits) / + * (bits per ECC level) / (chunks per page) + * where: + * total page spare data bits = + * (page oob size - meta data size) * (bits per byte) + */ + ecc_strength = ((page_oob_size - MXS_NAND_METADATA_SIZE) * 8) + / (MXS_NAND_BITS_PER_ECC_LEVEL * + mx28_nand_ecc_chunk_cnt(page_data_size));
static inline uint32_t mx28_nand_get_mark_offset(uint32_t page_data_size,
Jörg Krause
