[U-Boot-Users] Pull request:[ARM]
Wolfgang
Please pull from the merge branch at git://denx.de/git/u-boot-arm.git master
--- The following changes since commit 45da195cf675d0b4054aeeabf7b9c0daf798841d: Wolfgang Denk (1): Merge branch 'master' of git+ssh://10.10.0.7/home/wd/git/u-boot/master
git://www.denx.de/git/u-boot-arm.git master
Andreas Engel (1): ARM: cleanup duplicated exception handlingcode
Haavard Skinnemoen (1): Move AT91RM9200DK board support under board/atmel
Peter Pearse (6): Update board NetStar Merge branch '070524_netstar' of git://linux-arm.org/u-boot-armdev Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdev Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdev Merge branch '080202_at91rm9200dk' of git://linux-arm.org/u-boot-armdev Merge branch '080208_dupint' of git://linux-arm.org/u-boot-armdev
Stelian Pop (9): Fix arm926ejs compile when SKIP_LOWLEVEL_INIT is on Improve DataFlash CS definition. AT91CAP9 support : build integration AT91CAP9 support : include/ files AT91CAP9 support : cpu/ files AT91CAP9 support : board/ files AT91CAP9 support : MACB changes AT91CAP9 support : move board files to Atmel vendor directory. AT91CAP9 support
Timo Tuunainen (1): Support for Artila M-501 starter kit
CREDITS | 20 + MAKEALL | 2 + Makefile | 18 +- board/{at91rm9200dk => atmel/at91cap9adk}/Makefile | 8 +- board/atmel/at91cap9adk/at91cap9adk.c | 283 +++++++++++ board/atmel/at91cap9adk/config.mk | 1 + board/atmel/at91cap9adk/led.c | 80 +++ board/atmel/at91cap9adk/nand.c | 71 +++ .../{at91rm9200dk => atmel/at91cap9adk}/u-boot.lds | 10 +- board/{ => atmel}/at91rm9200dk/Makefile | 0 board/{ => atmel}/at91rm9200dk/at91rm9200dk.c | 0 board/{ => atmel}/at91rm9200dk/config.mk | 0 board/{ => atmel}/at91rm9200dk/flash.c | 0 board/{ => atmel}/at91rm9200dk/led.c | 0 board/{ => atmel}/at91rm9200dk/mux.c | 0 board/{ => atmel}/at91rm9200dk/u-boot.lds | 0 board/{at91rm9200dk => m501sk}/Makefile | 22 +- board/{at91rm9200dk => m501sk}/config.mk | 0 board/m501sk/eeprom.c | 102 ++++ board/m501sk/m501sk.c | 194 ++++++++ board/m501sk/m501sk.h | 167 +++++++ board/m501sk/memsetup.S | 200 ++++++++ board/{at91rm9200dk => m501sk}/u-boot.lds | 8 +- board/netstar/nand.c | 13 +- common/env_dataflash.c | 17 +- cpu/arm1136/interrupts.c | 134 ----- cpu/arm720t/interrupts.c | 132 +----- cpu/arm920t/interrupts.c | 135 +----- cpu/arm925t/interrupts.c | 135 ----- .../arm926ejs/at91cap9}/Makefile | 24 +- cpu/arm926ejs/at91cap9/config.mk | 2 + .../u-boot.lds => cpu/arm926ejs/at91cap9/ether.c | 46 +-- .../arm926ejs/at91cap9/lowlevel_init.S | 50 +-- cpu/arm926ejs/at91cap9/spi.c | 119 +++++ cpu/arm926ejs/at91cap9/timer.c | 149 ++++++ .../u-boot.lds => cpu/arm926ejs/at91cap9/usb.c | 57 +-- cpu/arm926ejs/interrupts.c | 136 +----- cpu/arm926ejs/start.S | 8 +- cpu/arm946es/interrupts.c | 134 ----- cpu/arm_intcm/Makefile | 2 +- cpu/ixp/interrupts.c | 132 +----- cpu/lh7a40x/interrupts.c | 135 ----- cpu/pxa/interrupts.c | 117 ----- cpu/s3c44b0/interrupts.c | 104 ---- cpu/sa1100/interrupts.c | 137 ----- drivers/mtd/dataflash.c | 36 +- drivers/net/macb.c | 8 + drivers/net/macb.h | 6 + include/asm-arm/arch-at91cap9/AT91CAP9.h | 518 ++++++++++++++++++++ .../asm-arm/arch-at91cap9/clk.h | 50 +-- include/asm-arm/arch-at91cap9/hardware.h | 38 ++ .../asm-arm/arch-at91cap9/memory-map.h | 47 +-- include/asm-arm/dma-mapping.h | 50 ++ include/configs/at91cap9adk.h | 212 ++++++++ include/configs/m501sk.h | 197 ++++++++ include/configs/netstar.h | 86 ++-- lib_arm/Makefile | 2 +- lib_arm/armlinux.c | 3 +- {cpu/arm_intcm => lib_arm}/interrupts.c | 34 +- net/eth.c | 4 + 60 files changed, 2645 insertions(+), 1750 deletions(-) copy board/{at91rm9200dk => atmel/at91cap9adk}/Makefile (87%) mode change 100755 => 100644 create mode 100644 board/atmel/at91cap9adk/at91cap9adk.c create mode 100644 board/atmel/at91cap9adk/config.mk create mode 100644 board/atmel/at91cap9adk/led.c create mode 100644 board/atmel/at91cap9adk/nand.c copy board/{at91rm9200dk => atmel/at91cap9adk}/u-boot.lds (86%) copy board/{ => atmel}/at91rm9200dk/Makefile (100%) rename board/{ => atmel}/at91rm9200dk/at91rm9200dk.c (100%) copy board/{ => atmel}/at91rm9200dk/config.mk (100%) rename board/{ => atmel}/at91rm9200dk/flash.c (100%) rename board/{ => atmel}/at91rm9200dk/led.c (100%) rename board/{ => atmel}/at91rm9200dk/mux.c (100%) copy board/{ => atmel}/at91rm9200dk/u-boot.lds (100%) copy board/{at91rm9200dk => m501sk}/Makefile (73%) mode change 100755 => 100644 rename board/{at91rm9200dk => m501sk}/config.mk (100%) create mode 100644 board/m501sk/eeprom.c create mode 100644 board/m501sk/m501sk.c create mode 100644 board/m501sk/m501sk.h create mode 100644 board/m501sk/memsetup.S copy board/{at91rm9200dk => m501sk}/u-boot.lds (90%) rename {board/at91rm9200dk => cpu/arm926ejs/at91cap9}/Makefile (69%) mode change 100755 => 100644 create mode 100644 cpu/arm926ejs/at91cap9/config.mk copy board/at91rm9200dk/u-boot.lds => cpu/arm926ejs/at91cap9/ether.c (51%) copy board/at91rm9200dk/u-boot.lds => cpu/arm926ejs/at91cap9/lowlevel_init.S (51%) create mode 100644 cpu/arm926ejs/at91cap9/spi.c create mode 100644 cpu/arm926ejs/at91cap9/timer.c copy board/at91rm9200dk/u-boot.lds => cpu/arm926ejs/at91cap9/usb.c (50%) create mode 100644 include/asm-arm/arch-at91cap9/AT91CAP9.h copy board/at91rm9200dk/u-boot.lds => include/asm-arm/arch-at91cap9/clk.h (51%) create mode 100644 include/asm-arm/arch-at91cap9/hardware.h rename board/at91rm9200dk/u-boot.lds => include/asm-arm/arch-at91cap9/memory-map.h (51%) create mode 100644 include/asm-arm/dma-mapping.h create mode 100644 include/configs/at91cap9adk.h create mode 100644 include/configs/m501sk.h rename {cpu/arm_intcm => lib_arm}/interrupts.c (77%) ---
Regards
Peter
In message 000001c86fd5$66610290$9a4d010a@Emea.Arm.com you wrote:
Wolfgang
Done, thanks lot!
Peter Pearse
