[U-Boot] [PATCH] powerpc/83xx: Define USB1 and USB2 base addr for MPC834x
Define base addresse for both MPH(USB1) and DR(USB2) controllers for MPC834x socs
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- arch/powerpc/include/asm/immap_83xx.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/powerpc/include/asm/immap_83xx.h b/arch/powerpc/include/asm/immap_83xx.h index 3c86ff6..289f7ca 100644 --- a/arch/powerpc/include/asm/immap_83xx.h +++ b/arch/powerpc/include/asm/immap_83xx.h @@ -763,6 +763,7 @@ typedef struct immap { u8 res7[0xC0000]; } immap_t;
+#ifndef CONFIG_MPC834x #ifdef CONFIG_HAS_FSL_MPH_USB #define CONFIG_SYS_MPC83xx_USB1_OFFSET 0x22000 /* use the MPH controller */ #define CONFIG_SYS_MPC83xx_USB2_OFFSET 0 @@ -770,6 +771,10 @@ typedef struct immap { #define CONFIG_SYS_MPC83xx_USB1_OFFSET 0 #define CONFIG_SYS_MPC83xx_USB2_OFFSET 0x23000 /* use the DR controller */ #endif +#else +#define CONFIG_SYS_MPC83xx_USB1_OFFSET 0x22000 +#define CONFIG_SYS_MPC83xx_USB2_OFFSET 0x23000 +#endif
#elif defined(CONFIG_MPC8313) typedef struct immap {
Kim,
I can take this in if you ack it.
York
Applied to u-boot-mpc85xx/master.
York
Ramneek Mehresh
York Sun
york sun
