[U-Boot-Users] IXP4xx Silicon version
Hi all
I'm not sure if anyone else has found it to be a problem but some boards we recently had built have an IXP425 on them which reports a Product Revision value 0x2 (lowest four bits of CP15, reg 0). This is only a problem because the file
cpu/ixp/npe/npe.c
uses this field in the npe_initialize function to decide how to determine how many ethernet ports there are. Unfortunately the case statement only accounts for revision values 0x0 (IX_FEATURE_CTRL_SILICON_TYPE_A0) and 0x01 (IX_FEATURE_CTRL_SILICON_TYPE_B0) so that the existing code doesn't think that these processors have any ethernet ports available. I found that by adding a 'default:' statement before line #639 remedied the problem. This file is part of u-boot, not the Intel npe library.
Since it seems that someone is immanently about to release a patch on the npe stuff anyway, would it be too much trouble to add the 'default:' statement or otherwise handle this product revision?
Thanks
Jonathan Pratt Senior Development Engineer ELPRO Technologies P/L
Hi Jonathan,
Seems that Intel has released a new revision of the CPU.
cpu/ixp/npe/npe.c
Would be interesting to know, what the differences of this new IXP425 revision are before "blindly" selecting default for Rev. A or Rev. B.
Yes, "someone" is waiting for another revised patch. I could of course add this statement, but I can't test since I don't have IXP hardware right now. Did you test this change successfully on both ethernet ports?
Best regards, Stefan
-----Original Message----- From: Stefan Roese [mailto:sr@denx.de] Sent: Thursday, 7 June 2007 3:18 PM To: u-boot-users@lists.sourceforge.net Cc: Jonathan Pratt Subject: Re: [U-Boot-Users] IXP4xx Silicon version
Hi Jonathan,
I couldn't find any reference to it in the Intel documentation (but the web site is not friendly to navigate so I didn't try all that hard).
cpu/ixp/npe/npe.c
available. I found
The 'B' option uses the reported capabilities of the device (through the ixFeatureCtrlComponentCheck function in the npe library) which reads the feature control register to get the infomration. I would have thought that (for determining whether ethernet MAC's are present) this would be a pretty safe bet.
a patch on
the 'default:'
Sorry - this hardware only utilises one of the MACs (npe B = MAC 0).
Thanks Jonathan Pratt
On Thu, Jun 07, 2007 at 08:38:16AM +1000, Jonathan Pratt wrote:
Hi all
There is a specification update from Intel, containing a proposed fixed for B1 stepping CPUs.
http://www.intel.com/design/network/products/npfamily/docs/ixp4xx.htm?prod=I...
best regards Christian
Christian Hohnstaedt
Jonathan Pratt
Stefan Roese
